[geos-commits] [SCM] GEOS branch main updated. c02bb5b46fe48506b8edf0a794ae8c9bb3f2cea3
Tue Aug 20 10:49:30 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  c02bb5b46fe48506b8edf0a794ae8c9bb3f2cea3 (commit)
      from  8c550f74b86a400b6e9c7685a6d4339eab979294 (commit)
revisions in full, below.
commit c02bb5b46fe48506b8edf0a794ae8c9bb3f2cea3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Aug 20 10:48:39 2024 -0700
    Add RelateNGBoundarNodeRuleTest, with test 4 commented out
diff --git a/include/geos/algorithm/BoundaryNodeRule.h b/include/geos/algorithm/BoundaryNodeRule.h
index 07c38265f..19cd6e111 100644
--- a/include/geos/algorithm/BoundaryNodeRule.h
+++ b/include/geos/algorithm/BoundaryNodeRule.h
@@ -18,6 +18,8 @@
 #pragma once
+#include <string>
 #include <geos/export.h>
 // Forward declarations
@@ -55,6 +57,8 @@ public:
     virtual
     ~BoundaryNodeRule() {}
+    virtual std::string toString() const = 0;
     /** \brief
      * Tests whether a point that lies in `boundaryCount`
      * geometry component boundaries is considered to form part of
diff --git a/src/algorithm/BoundaryNodeRule.cpp b/src/algorithm/BoundaryNodeRule.cpp
index c7417b9d5..393ca5e87 100644
--- a/src/algorithm/BoundaryNodeRule.cpp
+++ b/src/algorithm/BoundaryNodeRule.cpp
@@ -48,7 +48,11 @@ public:
         // the "Mod-2 Rule"
         return boundaryCount % 2 == 1;
+    std::string
+    toString() const override {
+        return "Mod2BoundaryNodeRule";
@@ -84,7 +88,11 @@ class EndPointBoundaryNodeRule : public BoundaryNodeRule {
     isInBoundary(int boundaryCount) const override
         return boundaryCount > 0;
+    std::string
+        return "EndPointBoundaryNodeRule";
@@ -103,6 +111,10 @@ class MultiValentEndPointBoundaryNodeRule : public BoundaryNodeRule {
         return boundaryCount > 1;
+    std::string
+        return "MultiValentEndPointBoundaryNodeRule";
@@ -120,6 +132,10 @@ class MonoValentEndPointBoundaryNodeRule : public BoundaryNodeRule {
         return boundaryCount == 1;
+    std::string
+        return "MonoValentEndPointBoundaryNodeRule";
 Mod2BoundaryNodeRule mod2Rule;
diff --git a/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp b/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
new file mode 100644
index 000000000..8dc30b88c
--- /dev/null
+++ b/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
@@ -0,0 +1,186 @@
+// Test Suite for geos::operation::relateng Boundary Node Rules
+#include <tut/tut.hpp>
+#include <utility.h>
+// geos
+#include <geos/algorithm/BoundaryNodeRule.h>
+#include <geos/operation/relateng/RelateNG.h>
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/IntersectionMatrix.h>
+#include <geos/geom/Location.h>
+// std
+#include <memory>
+using namespace geos::geom;
+using namespace geos::operation::relateng;
+using geos::io::WKTReader;
+using geos::io::WKTWriter;
+namespace tut {
+// Test Group
+// Common data used by all tests
+struct test_relatengbnr_data {
+    WKTReader r;
+    WKTWriter w;
+    void runRelate(
+        const std::string& wkt1,
+        const std::string& wkt2,
+        const BoundaryNodeRule& bnRule,
+        const std::string& expectedIM)
+        std::unique_ptr<Geometry> g1 = r.read(wkt1);
+        std::unique_ptr<Geometry> g2 = r.read(wkt2);
+        auto im = RelateNG::relate(g1.get(), g2.get(), bnRule);
+        std::string imStr = im->toString();
+        //System.out.println(imStr);
+        if (imStr != expectedIM) {
+            std::cerr << std::endl << w.write(*g1) << " relate " << bnRule.toString() << " " << w.write(*g2) << " = " << imStr << std::endl;
+        ensure_equals("runRelate", imStr, expectedIM);
+typedef test_group<test_relatengbnr_data> group;
+typedef group::object object;
+group test_relatengbnr_group("geos::operation::relateng::RelateNGBoundarNodeRule");
+// BoundaryNodeRule::getBoundaryRuleMod2()
+// BoundaryNodeRule::getBoundaryEndPoint()
+// BoundaryNodeRule::getBoundaryMultivalentEndPoint()
+// BoundaryNodeRule::getBoundaryMonovalentEndPoint()
+// BoundaryNodeRule::getBoundaryOGCSFS()
+// testMultiLineStringSelfIntTouchAtEndpoint
+template<>
+template<>
+void object::test<1> ()
+    std::string a = "MULTILINESTRING ((20 20, 100 100, 100 20, 20 100), (60 60, 60 140))";
+    std::string b = "LINESTRING (60 60, 20 60)";
+    // under EndPoint, A has a boundary node - A.bdy / B.bdy = 0
+    runRelate(a, b, BoundaryNodeRule::getBoundaryEndPoint(),  "FF1F00102");
+// testLineStringSelfIntTouchAtEndpoint
+template<>
+template<>
+void object::test<2> ()
+    std::string a = "LINESTRING (20 20, 100 100, 100 20, 20 100)";
+    // results for both rules are the same
+    runRelate(a, b,  BoundaryNodeRule::getBoundaryOGCSFS(),   "F01FF0102");
+    runRelate(a, b,  BoundaryNodeRule::getBoundaryEndPoint(),  "F01FF0102");
+// testMultiLineStringTouchAtEndpoint
+template<>
+template<>
+void object::test<3> ()
+    std::string a = "MULTILINESTRING ((0 0, 10 10), (10 10, 20 20))";
+    std::string b = "LINESTRING (10 10, 20 0)";
+    // under Mod2, A has no boundary - A.int / B.bdy = 0
+    // runRelateTest(a, b,  BoundaryNodeRule.OGC_SFS_BOUNDARY_RULE,   "F01FFF102");
+    // under MultiValent, A has a boundary node but B does not - A.bdy / B.bdy = F and A.int
+    // runRelateTest(a, b,  BoundaryNodeRule.MULTIVALENT_ENDPOINT_BOUNDARY_RULE,  "0F1FFF1F2");
+// testLineRingTouchAtEndpoints
+// template<>
+// template<>
+// void object::test<4> ()
+//     std::string a = "LINESTRING (20 100, 20 220, 120 100, 20 100)";
+//     std::string b = "LINESTRING (20 20, 20 100)";
+//     // under Mod2, A has no boundary - A.int / B.bdy = 0
+//     runRelate(a, b,  BoundaryNodeRule::getBoundaryOGCSFS(),   "F01FFF102");
+//     // under EndPoint, A has a boundary node - A.bdy / B.bdy = 0
+//     runRelate(a, b,  BoundaryNodeRule::getBoundaryEndPoint(),  "FF1F0F102");
+//     // under MultiValent, A has a boundary node but B does not - A.bdy / B.bdy = F and A.int
+//     runRelate(a, b,  BoundaryNodeRule::getBoundaryMonovalentEndPoint(),  "FF10FF1F2");
+// testLineRingTouchAtEndpointAndInterior
+template<>
+template<>
+void object::test<5> ()
+    std::string a = "LINESTRING (20 100, 20 220, 120 100, 20 100)";
+    std::string b = "LINESTRING (20 20, 40 100)";
+    // this is the same result as for the above test
+    runRelate(a, b,  BoundaryNodeRule::getBoundaryOGCSFS(),   "F01FFF102");
+    // this result is different - the A node is now on the boundary, so A.bdy/B.ext = 0
+// testPolygonEmptyRing
+template<>
+template<>
+void object::test<6> ()
+    std::string a = "POLYGON EMPTY";
+    std::string b = "LINESTRING (20 100, 20 220, 120 100, 20 100)";
+    // closed line has no boundary under SFS rule
+    runRelate(a, b,  BoundaryNodeRule::getBoundaryOGCSFS(),   "FFFFFF1F2");
+    // closed line has boundary under ENDPOINT rule
+    runRelate(a, b,  BoundaryNodeRule::getBoundaryEndPoint(),  "FFFFFF102");
+// testPolygonEmptyMultiLineStringClosed
+template<>
+template<>
+void object::test<7> ()
+    std::string b = "MULTILINESTRING ((0 0, 0 1), (0 1, 1 1, 1 0, 0 0))";
+// testLineStringInteriorTouchMultivalent
+template<>
+template<>
+void object::test<8> ()
+} // namespace tut
Summary of changes:
 include/geos/algorithm/BoundaryNodeRule.h          |   4 +
 src/algorithm/BoundaryNodeRule.cpp                 |  20 ++-
 .../relateng/RelateNGBoundaryNodeRuleTest.cpp      | 186 +++++++++++++++++++++
 3 files changed, 208 insertions(+), 2 deletions(-)
 create mode 100644 tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
