[geos-commits] [SCM] GEOS branch main updated. c64729cd8105a4e0973fdd024cab2b8f32ee2fee
Tue Aug 20 10:55:40 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  c64729cd8105a4e0973fdd024cab2b8f32ee2fee (commit)
      from  c02bb5b46fe48506b8edf0a794ae8c9bb3f2cea3 (commit)
revisions in full, below.
commit c64729cd8105a4e0973fdd024cab2b8f32ee2fee
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Aug 20 10:55:08 2024 -0700
    Add PostGIS test to RelateNGBoundaryNodeRuleTest.cpp as test 9
diff --git a/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp b/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
index 8dc30b88c..05a173e0c 100644
--- a/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
@@ -73,7 +73,7 @@ void object::test<1> ()
     std::string b = "LINESTRING (60 60, 20 60)";
     // under EndPoint, A has a boundary node - A.bdy / B.bdy = 0
-    runRelate(a, b, BoundaryNodeRule::getBoundaryEndPoint(),  "FF1F00102");
+    runRelate(a, b, BoundaryNodeRule::getBoundaryEndPoint(), "FF1F00102");
 // testLineStringSelfIntTouchAtEndpoint
@@ -85,8 +85,8 @@ void object::test<2> ()
     // results for both rules are the same
-    runRelate(a, b,  BoundaryNodeRule::getBoundaryOGCSFS(),   "F01FF0102");
-    runRelate(a, b,  BoundaryNodeRule::getBoundaryEndPoint(),  "F01FF0102");
+    runRelate(a, b, BoundaryNodeRule::getBoundaryOGCSFS(), "F01FF0102");
+    runRelate(a, b, BoundaryNodeRule::getBoundaryEndPoint(), "F01FF0102");
 // testMultiLineStringTouchAtEndpoint
@@ -98,11 +98,11 @@ void object::test<3> ()
     std::string b = "LINESTRING (10 10, 20 0)";
     // under Mod2, A has no boundary - A.int / B.bdy = 0
-    // runRelateTest(a, b,  BoundaryNodeRule.OGC_SFS_BOUNDARY_RULE,   "F01FFF102");
+    // runRelateTest(a, b, BoundaryNodeRule.OGC_SFS_BOUNDARY_RULE, "F01FFF102");
     // under MultiValent, A has a boundary node but B does not - A.bdy / B.bdy = F and A.int
-    // runRelateTest(a, b,  BoundaryNodeRule.MULTIVALENT_ENDPOINT_BOUNDARY_RULE,  "0F1FFF1F2");
+    // runRelateTest(a, b, BoundaryNodeRule.MULTIVALENT_ENDPOINT_BOUNDARY_RULE, "0F1FFF1F2");
 // testLineRingTouchAtEndpoints
@@ -114,11 +114,11 @@ void object::test<3> ()
 //     std::string b = "LINESTRING (20 20, 20 100)";
 //     // under Mod2, A has no boundary - A.int / B.bdy = 0
-//     runRelate(a, b,  BoundaryNodeRule::getBoundaryOGCSFS(),   "F01FFF102");
+//     runRelate(a, b, BoundaryNodeRule::getBoundaryOGCSFS(), "F01FFF102");
 //     // under EndPoint, A has a boundary node - A.bdy / B.bdy = 0
-//     runRelate(a, b,  BoundaryNodeRule::getBoundaryEndPoint(),  "FF1F0F102");
+//     runRelate(a, b, BoundaryNodeRule::getBoundaryEndPoint(), "FF1F0F102");
 //     // under MultiValent, A has a boundary node but B does not - A.bdy / B.bdy = F and A.int
-//     runRelate(a, b,  BoundaryNodeRule::getBoundaryMonovalentEndPoint(),  "FF10FF1F2");
+//     runRelate(a, b, BoundaryNodeRule::getBoundaryMonovalentEndPoint(), "FF10FF1F2");
 // testLineRingTouchAtEndpointAndInterior
@@ -130,9 +130,9 @@ void object::test<5> ()
     std::string b = "LINESTRING (20 20, 40 100)";
     // this is the same result as for the above test
-    runRelate(a, b,  BoundaryNodeRule::getBoundaryOGCSFS(),   "F01FFF102");
+    runRelate(a, b, BoundaryNodeRule::getBoundaryOGCSFS(), "F01FFF102");
     // this result is different - the A node is now on the boundary, so A.bdy/B.ext = 0
 // testPolygonEmptyRing
@@ -144,10 +144,10 @@ void object::test<6> ()
     std::string b = "LINESTRING (20 100, 20 220, 120 100, 20 100)";
     // closed line has no boundary under SFS rule
-    runRelate(a, b,  BoundaryNodeRule::getBoundaryOGCSFS(),   "FFFFFF1F2");
+    runRelate(a, b, BoundaryNodeRule::getBoundaryOGCSFS(), "FFFFFF1F2");
     // closed line has boundary under ENDPOINT rule
-    runRelate(a, b,  BoundaryNodeRule::getBoundaryEndPoint(),  "FFFFFF102");
+    runRelate(a, b, BoundaryNodeRule::getBoundaryEndPoint(), "FFFFFF102");
 // testPolygonEmptyMultiLineStringClosed
@@ -159,10 +159,10 @@ void object::test<7> ()
     std::string b = "MULTILINESTRING ((0 0, 0 1), (0 1, 1 1, 1 0, 0 0))";
 // testLineStringInteriorTouchMultivalent
@@ -174,13 +174,23 @@ void object::test<8> ()
+// from PostGIS ./regress/core/relate_bnr.sql
+// template<>
+// template<>
+// void object::test<9> ()
+//     std::string a = "POLYGON((0 0,140 0,140 140,0 140,0 0))";
+//     std::string b = "POLYGON((140 0,0 0,0 140,140 140,140 0))";
+//     runRelate(a, b, BoundaryNodeRule::getBoundaryMultivalentEndPoint(), "2FFF0FFF2");
 } // namespace tut
Summary of changes:
 .../relateng/RelateNGBoundaryNodeRuleTest.cpp      | 44 +++++++++++++---------
 1 file changed, 27 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
