[geos-commits] [SCM] GEOS branch main updated. adc3348733c101416799608135da328151f7efbb
git at osgeo.org
git at osgeo.org
Tue Aug 20 10:57:15 PDT 2024
the project "GEOS".
The branch, main has been updated
via adc3348733c101416799608135da328151f7efbb (commit)
from c64729cd8105a4e0973fdd024cab2b8f32ee2fee (commit)
revisions in full, below.
commit adc3348733c101416799608135da328151f7efbb
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Aug 20 10:56:49 2024 -0700
Remove dupe tests from RelateNGTest that are now in RelateNGBoundarNodeRuleTest
diff --git a/tests/unit/operation/relateng/RelateNGTest.cpp b/tests/unit/operation/relateng/RelateNGTest.cpp
index 98ed898bd..7e54c71c9 100644
--- a/tests/unit/operation/relateng/RelateNGTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGTest.cpp
@@ -875,16 +875,5 @@ void object::test<62> ()
checkRelate(a, b, "212101212");
-// Boundary node
-// template<>
-// template<>
-// void object::test<63> ()
-// std::string a = "POLYGON((0 0,140 0,140 140,0 140,0 0))";
-// std::string b = "POLYGON((140 0,0 0,0 140,140 140,140 0))";
-// checkRelateRule(a, b, "2FFF0FFF2", geos::algorithm::BoundaryNodeRule::getBoundaryMultivalentEndPoint());
} // namespace tut
diff --git a/tests/unit/operation/relateng/RelateNGTest.h b/tests/unit/operation/relateng/RelateNGTest.h
index 8231f886b..a1f4f7d07 100644
--- a/tests/unit/operation/relateng/RelateNGTest.h
+++ b/tests/unit/operation/relateng/RelateNGTest.h
@@ -95,13 +95,13 @@ struct test_relateng_support {
checkPredicate(*RelatePredicate::equalsTopo(), wktb, wkta, expectedValue);
- void checkRelateRule(const std::string& wkta, const std::string& wktb, const std::string expectedValue, const BoundaryNodeRule& bnRule)
+ void checkRelate(const std::string& wkta, const std::string& wktb, const std::string expectedValue)
std::unique_ptr<Geometry> a = r.read(wkta);
std::unique_ptr<Geometry> b = r.read(wktb);
RelateMatrixPredicate pred;
// TopologyPredicate predTrace = trace(pred);
- RelateNG::relate(a.get(), b.get(), pred, bnRule);
+ RelateNG::relate(a.get(), b.get(), pred);
std::string actualVal = pred.getIM()->toString();
if (actualVal != expectedValue) {
std::cerr << std::endl << w.write(*a) << " relate " << w.write(*b) << " = " << actualVal << std::endl;
@@ -110,11 +110,6 @@ struct test_relateng_support {
checkPrepared(a.get(), b.get());
- void checkRelate(const std::string& wkta, const std::string& wktb, const std::string expectedValue)
- checkRelateRule(wkta, wktb, expectedValue, BoundaryNodeRule::getBoundaryRuleMod2());
void checkRelateMatches(const std::string& wkta, const std::string& wktb, const std::string pattern, bool expectedValue)
auto pred = RelatePredicate::matches(pattern);
Summary of changes:
tests/unit/operation/relateng/RelateNGTest.cpp | 11 -----------
tests/unit/operation/relateng/RelateNGTest.h | 9 ++-------
2 files changed, 2 insertions(+), 18 deletions(-)
hooks/post-receive
More information about the geos-commits
