[geos-commits] [SCM] GEOS branch main updated. 11c5e77da3147356a010c674c57478fc3c883487
    git at osgeo.org
    git at osgeo.org
    Tue Aug 20 11:04:57 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  11c5e77da3147356a010c674c57478fc3c883487 (commit)
      from  adc3348733c101416799608135da328151f7efbb (commit)
revisions in full, below.
commit 11c5e77da3147356a010c674c57478fc3c883487
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Aug 20 11:04:30 2024 -0700
    Enable failing BNR tests
diff --git a/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp b/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
index 05a173e0c..ec2e029f6 100644
--- a/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGBoundaryNodeRuleTest.cpp
@@ -55,7 +55,7 @@ struct test_relatengbnr_data {
 typedef test_group<test_relatengbnr_data> group;
 typedef group::object object;
-group test_relatengbnr_group("geos::operation::relateng::RelateNGBoundarNodeRule");
+group test_relatengbnr_group("geos::operation::relateng::RelateNGBoundaryNodeRule");
 // BoundaryNodeRule::getBoundaryRuleMod2()
 // BoundaryNodeRule::getBoundaryEndPoint()
@@ -97,29 +97,32 @@ void object::test<3> ()
     std::string a = "MULTILINESTRING ((0 0, 10 10), (10 10, 20 20))";
     std::string b = "LINESTRING (10 10, 20 0)";
-    // under Mod2, A has no boundary - A.int / B.bdy = 0
-    // runRelateTest(a, b, BoundaryNodeRule.OGC_SFS_BOUNDARY_RULE, "F01FFF102");
+    // under Mod2, A touch point is not boundary - A.int / B.bdy = 0
+    runRelate(a, b,  BoundaryNodeRule::getBoundaryOGCSFS(), "F01FF0102");
     // under EndPoint, A has a boundary node - A.bdy / B.bdy = 0
     runRelate(a, b, BoundaryNodeRule::getBoundaryEndPoint(), "FF1F00102");
-    // under MultiValent, A has a boundary node but B does not - A.bdy / B.bdy = F and A.int
-    // runRelateTest(a, b, BoundaryNodeRule.MULTIVALENT_ENDPOINT_BOUNDARY_RULE, "0F1FFF1F2");
+    // under MultiValent, A has a boundary node but B does not - A.bdy / B.bdy = F and A.bdy / B.int = 0
+    runRelate(a, b,  BoundaryNodeRule::getBoundaryMonovalentEndPoint(), "FF10FF1F2");
-// testLineRingTouchAtEndpoints
-// template<>
-// template<>
-// void object::test<4> ()
-//     std::string a = "LINESTRING (20 100, 20 220, 120 100, 20 100)";
-//     std::string b = "LINESTRING (20 20, 20 100)";
-//     // under Mod2, A has no boundary - A.int / B.bdy = 0
-//     runRelate(a, b, BoundaryNodeRule::getBoundaryOGCSFS(), "F01FFF102");
-//     // under EndPoint, A has a boundary node - A.bdy / B.bdy = 0
-//     runRelate(a, b, BoundaryNodeRule::getBoundaryEndPoint(), "FF1F0F102");
-//     // under MultiValent, A has a boundary node but B does not - A.bdy / B.bdy = F and A.int
-//     runRelate(a, b, BoundaryNodeRule::getBoundaryMonovalentEndPoint(), "FF10FF1F2");
+// testLineRingTouchAtEndpoints
+template<>
+template<>
+void object::test<4> ()
+    std::string a = "LINESTRING (20 100, 20 220, 120 100, 20 100)";
+    std::string b = "LINESTRING (20 20, 20 100)";
+    // under Mod2, A has no boundary - A.int / B.bdy = 0
+    runRelate(a, b, BoundaryNodeRule::getBoundaryOGCSFS(), "F01FFF102");
+    // under EndPoint, A has a boundary node - A.bdy / B.bdy = 0
+    runRelate(a, b, BoundaryNodeRule::getBoundaryEndPoint(), "FF1F0F102");
+    // under MultiValent, A has a boundary node but B does not - A.bdy / B.bdy = F and A.int
 // testLineRingTouchAtEndpointAndInterior
 template<>
@@ -182,14 +185,14 @@ void object::test<8> ()
 // from PostGIS ./regress/core/relate_bnr.sql
-// template<>
-// template<>
-// void object::test<9> ()
-//     std::string a = "POLYGON((0 0,140 0,140 140,0 140,0 0))";
-//     std::string b = "POLYGON((140 0,0 0,0 140,140 140,140 0))";
-//     runRelate(a, b, BoundaryNodeRule::getBoundaryMultivalentEndPoint(), "2FFF0FFF2");
+template<>
+template<>
+void object::test<9> ()
+    std::string a = "POLYGON((0 0,140 0,140 140,0 140,0 0))";
+    std::string b = "POLYGON((140 0,0 0,0 140,140 140,140 0))";
+    runRelate(a, b, BoundaryNodeRule::getBoundaryMultivalentEndPoint(), "2FFF0FFF2");
Summary of changes:
 .../relateng/RelateNGBoundaryNodeRuleTest.cpp      | 57 ++++++++++++----------
 1 file changed, 30 insertions(+), 27 deletions(-)
hooks/post-receive
More information about the geos-commits
