[geos-commits] [SCM] GEOS branch main updated. 97a079ae411f116b946357ad5da234502417c578
    git at osgeo.org
    git at osgeo.org
    Tue Aug 20 15:08:51 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  97a079ae411f116b946357ad5da234502417c578 (commit)
       via  792084ee015c7e19671ccdc941e17f9fd4fee419 (commit)
      from  ee1cce91c9e7500af1a5eb8a56e66e6b9dd6db32 (commit)
revisions in full, below.
commit 97a079ae411f116b946357ad5da234502417c578
Merge: 792084ee0 ee1cce91c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Aug 20 15:08:11 2024 -0700
    Merge branch 'main' of github.com:libgeos/geos
commit 792084ee015c7e19671ccdc941e17f9fd4fee419
Date:   Tue Aug 20 15:07:05 2024 -0700
    Port JTS commit
    https://github.com/locationtech/jts/commit/28aa77d57957bb5cef311c0066a20bc3a1210312
    Fix GeometryCollection equals equivalent primitive with some shared boundaries.
    Closes GH-1148
diff --git a/include/geos/operation/relateng/RelateGeometry.h b/include/geos/operation/relateng/RelateGeometry.h
index e96a3b878..936c03be0 100644
--- a/include/geos/operation/relateng/RelateGeometry.h
+++ b/include/geos/operation/relateng/RelateGeometry.h
@@ -203,7 +203,23 @@ public:
     int locateWithDim(const CoordinateXY* pt);
-    bool isPointsOrPolygons() const;
+     * Indicates whether the geometry requires self-noding
+     * for correct evaluation of specific spatial predicates.
+     * Self-noding is required for geometries which may self-cross
+     * - i.e. lines, and overlapping polygons in GeometryCollections.
+     * Self-noding is not required for polygonal geometries,
+     * since they can only touch at vertices.
+     * This ensures that the coordinates of nodes created by
+     * crossing segments are computed explicitly.
+     * This ensures that node locations match in situations
+     * where a self-crossing and mutual crossing occur at the same logical location.
+     * E.g. a self-crossing line tested against a single segment
+     * identical to one of the crossed segments.
+     * @return true if self-noding is required for this geometry
+    bool isSelfNodingRequired() const;
      * Tests whether the geometry has polygonal topology.
diff --git a/include/geos/operation/relateng/TopologyComputer.h b/include/geos/operation/relateng/TopologyComputer.h
index 00b204693..e0a474c38 100644
--- a/include/geos/operation/relateng/TopologyComputer.h
+++ b/include/geos/operation/relateng/TopologyComputer.h
@@ -157,8 +157,9 @@ public:
-     * Self-noding is not required for polygonal geometries.
-     * This ensures that the locations of nodes created by
diff --git a/src/operation/relateng/RelateGeometry.cpp b/src/operation/relateng/RelateGeometry.cpp
index 8a9620053..9c3aa3e84 100644
--- a/src/operation/relateng/RelateGeometry.cpp
+++ b/src/operation/relateng/RelateGeometry.cpp
@@ -235,13 +235,20 @@ RelateGeometry::locateWithDim(const CoordinateXY* pt)
 /* public */
 bool
-RelateGeometry::isPointsOrPolygons() const
+RelateGeometry::isSelfNodingRequired() const
     GeometryTypeId typeId = geom->getGeometryTypeId();
-    return typeId == GEOS_POINT
+    if (typeId == GEOS_POINT
         || typeId == GEOS_MULTIPOINT
         || typeId == GEOS_POLYGON
-        || typeId == GEOS_MULTIPOLYGON;
+        || typeId == GEOS_MULTIPOLYGON)
+         return false;
+    //-- GC with a single polygon does not need noding
+    if (hasAreas && geom->getNumGeometries() == 1)
+        return false;
+    return true;
diff --git a/src/operation/relateng/TopologyComputer.cpp b/src/operation/relateng/TopologyComputer.cpp
index 6d6d11b16..006873a13 100644
--- a/src/operation/relateng/TopologyComputer.cpp
+++ b/src/operation/relateng/TopologyComputer.cpp
@@ -132,9 +132,8 @@ TopologyComputer::getDimension(bool isA) const
 bool
 TopologyComputer::isSelfNodingRequired() const
-    //TODO: change to testing for lines or GC with > 1 polygon
-    if (geomA.isPointsOrPolygons()) return false;
-    if (geomB.isPointsOrPolygons()) return false;
+    if (geomA.isSelfNodingRequired()) return true;
+    if (geomB.isSelfNodingRequired()) return true;
     return predicate.requireSelfNoding();
diff --git a/tests/unit/operation/relateng/RelateNGGCTest.cpp b/tests/unit/operation/relateng/RelateNGGCTest.cpp
index 5ca0bf8ff..f9b972096 100644
--- a/tests/unit/operation/relateng/RelateNGGCTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGGCTest.cpp
@@ -311,5 +311,27 @@ void object::test<22> ()
+// testPolygonContainingPointsInBoundary
+// https://github.com/libgeos/geos/issues/1148
+template<>
+template<>
+void object::test<23> ()
+    std::string a = "POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0))";
+    std::string b = "GEOMETRYCOLLECTION (POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0)), MULTIPOINT ((0 2), (0 5)))";
+    checkEquals(a, b, true);
+// testPolygonContainingLineInBoundary
+template<>
+template<>
+void object::test<24> ()
+    std::string b = "GEOMETRYCOLLECTION (POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0)), LINESTRING (0 2, 0 5))";
 } // namespace tut
Summary of changes:
 include/geos/operation/relateng/RelateGeometry.h   | 18 +++++++++++++++++-
 include/geos/operation/relateng/TopologyComputer.h |  5 +++--
 src/operation/relateng/RelateGeometry.cpp          | 13 ++++++++++---
 src/operation/relateng/TopologyComputer.cpp        |  5 ++---
 tests/unit/operation/relateng/RelateNGGCTest.cpp   | 22 ++++++++++++++++++++++
 5 files changed, 54 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
