[geos-commits] [SCM] GEOS branch main updated. f3d2096ff11494f60a07aa7d0c44a722f3709d04
git at osgeo.org
git at osgeo.org
Tue Aug 20 15:20:22 PDT 2024
the project "GEOS".
The branch, main has been updated
via f3d2096ff11494f60a07aa7d0c44a722f3709d04 (commit)
from 97a079ae411f116b946357ad5da234502417c578 (commit)
revisions in full, below.
commit f3d2096ff11494f60a07aa7d0c44a722f3709d04
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Aug 20 15:19:33 2024 -0700
Port JTS commit
https://github.com/locationtech/jts/commit/7c2627093f7d876167d651bf132a8500d428aa5f
diff --git a/include/geos/operation/relateng/RelateGeometry.h b/include/geos/operation/relateng/RelateGeometry.h
index 936c03be0..fa3fd812f 100644
--- a/include/geos/operation/relateng/RelateGeometry.h
+++ b/include/geos/operation/relateng/RelateGeometry.h
@@ -207,7 +207,7 @@ public:
* Indicates whether the geometry requires self-noding
* for correct evaluation of specific spatial predicates.
* Self-noding is required for geometries which may self-cross
- * - i.e. lines, and overlapping polygons in GeometryCollections.
+ * - i.e. lines, and overlapping elements in GeometryCollections.
* Self-noding is not required for polygonal geometries,
* since they can only touch at vertices.
* This ensures that the coordinates of nodes created by
diff --git a/include/geos/operation/relateng/TopologyComputer.h b/include/geos/operation/relateng/TopologyComputer.h
index e0a474c38..92f382c0c 100644
--- a/include/geos/operation/relateng/TopologyComputer.h
+++ b/include/geos/operation/relateng/TopologyComputer.h
@@ -155,16 +155,13 @@ public:
* Indicates whether the input geometries require self-noding
- * Self-noding is required for geometries which may self-cross
- * Self-noding is not required for polygonal geometries,
- * since they can only touch at vertices.
- * This ensures that the coordinates of nodes created by
- * crossing segments are computed explicitly.
+ * Self-noding is required for geometries which may
+ * have self-crossing linework.
+ * This causes the coordinates of nodes created by
+ * crossing segments to be computed explicitly.
* This ensures that node locations match in situations
* where a self-crossing and mutual crossing occur at the same logical location.
- * E.g. a self-crossing line tested against a single segment
- * identical to one of the crossed segments.
+ * The canonical example is a self-crossing line tested against a single segment * identical to one of the crossed segments.
* @return true if self-noding is required
diff --git a/src/operation/relateng/RelateGeometry.cpp b/src/operation/relateng/RelateGeometry.cpp
index 9c3aa3e84..d7d1b0116 100644
--- a/src/operation/relateng/RelateGeometry.cpp
+++ b/src/operation/relateng/RelateGeometry.cpp
@@ -245,7 +245,7 @@ RelateGeometry::isSelfNodingRequired() const
return false;
- //-- GC with a single polygon does not need noding
+ //-- a GC with a single polygon does not need noding
if (hasAreas && geom->getNumGeometries() == 1)
return false;
return true;
diff --git a/src/operation/relateng/TopologyComputer.cpp b/src/operation/relateng/TopologyComputer.cpp
index 006873a13..bcfdcbc62 100644
--- a/src/operation/relateng/TopologyComputer.cpp
+++ b/src/operation/relateng/TopologyComputer.cpp
@@ -132,9 +132,12 @@ TopologyComputer::getDimension(bool isA) const
bool
TopologyComputer::isSelfNodingRequired() const
- if (geomA.isSelfNodingRequired()) return true;
- if (geomB.isSelfNodingRequired()) return true;
- return predicate.requireSelfNoding();
+ if (predicate.requireSelfNoding()) {
+ if (geomA.isSelfNodingRequired() ||
+ geomB.isSelfNodingRequired())
+ return true;
+ return false;
diff --git a/tests/xmltester/tests/misc/InvalidRelates.xml b/tests/xmltester/tests/misc/InvalidRelates.xml
index 69b80bdd6..1f17bb367 100644
--- a/tests/xmltester/tests/misc/InvalidRelates.xml
+++ b/tests/xmltester/tests/misc/InvalidRelates.xml
@@ -48,12 +48,12 @@
LINESTRING(40 180, 140 180)
</a>
<b>
- MULTIPOLYGON(
- ((20 320, 180 320, 180 180, 20 180, 20 320)),
- ((60 180, 60 80, 180 80, 180 180, 60 180)))
+ GEOMETRYCOLLECTION(
+ POLYGON((20 320, 180 320, 180 180, 20 180, 20 320)),
+ POLYGON((60 180, 60 80, 180 80, 180 180, 60 180)))
</b>
<test>
- <op arg1="A" arg2="B" arg3="111F0F212" name="relate">true</op>
+ <op arg1="A" arg2="B" arg3="11F00F212" name="relate">true</op>
</test>
</case>
Summary of changes:
include/geos/operation/relateng/RelateGeometry.h | 2 +-
include/geos/operation/relateng/TopologyComputer.h | 13 +++++--------
src/operation/relateng/RelateGeometry.cpp | 2 +-
src/operation/relateng/TopologyComputer.cpp | 9 ++++++---
tests/xmltester/tests/misc/InvalidRelates.xml | 8 ++++----
5 files changed, 17 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits
