[geos-commits] [SCM] GEOS branch 3.12 updated. 02584d8bebf2a889d3a0deb185fd7952f03a502d
git at osgeo.org
git at osgeo.org
Thu Jun 6 12:47:56 PDT 2024
the project "GEOS".
The branch, 3.12 has been updated
via 02584d8bebf2a889d3a0deb185fd7952f03a502d (commit)
from b74fefb7be4ba6c833760106f95f0f495b832c43 (commit)
revisions in full, below.
commit 02584d8bebf2a889d3a0deb185fd7952f03a502d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Jun 6 12:30:11 2024 -0700
Stop using deprecated exec_program command in cmake, references #1102
diff --git a/cmake/cmake_uninstall.cmake.in b/cmake/cmake_uninstall.cmake.in
index 7c6342711..749221415 100644
--- a/cmake/cmake_uninstall.cmake.in
+++ b/cmake/cmake_uninstall.cmake.in
@@ -30,19 +30,23 @@ foreach(file ${files})
message(STATUS "\tTrying to execute remove command anyway.")
endif()
- exec_program("@CMAKE_COMMAND@" ARGS "-E remove \"$ENV{DESTDIR}${file}\""
+ execute_process(
+ COMMAND "@CMAKE_COMMAND@" -E remove \"$ENV{DESTDIR}${file}\"
OUTPUT_VARIABLE rm_out
- RETURN_VALUE rm_retval)
+ RESULT_VARIABLE rm_retval)
if(NOT "${rm_retval}" STREQUAL 0)
message(FATAL_ERROR "Problem when removing \"$ENV{DESTDIR}${file}\"")
endif()
endforeach()
message(STATUS "Deleting ${GEOS_INCLUDE_DIR} directory")
-exec_program("@CMAKE_COMMAND@"
- ARGS "-E remove_directory \"${GEOS_INCLUDE_DIR}\""
+execute_process(
+ COMMAND "@CMAKE_COMMAND@" -E remove_directory \"${GEOS_INCLUDE_DIR}\"
message(FATAL_ERROR "Problem when removing \"${GEOS_INCLUDE_DIR}\"")
endif()
Summary of changes:
cmake/cmake_uninstall.cmake.in | 14 +++++++++-----
1 file changed, 9 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits
