[geos-commits] [SCM] GEOS branch main updated. d0d3d5a0bf9c5a3f3bcb4da64ae53fef0f7d64e2
git at osgeo.org
git at osgeo.org
Thu Jun 6 13:59:18 PDT 2024
the project "GEOS".
The branch, main has been updated
via d0d3d5a0bf9c5a3f3bcb4da64ae53fef0f7d64e2 (commit)
from 960c39f4504c7e8ee4d40b073e2c66fc779a2f6d (commit)
revisions in full, below.
commit d0d3d5a0bf9c5a3f3bcb4da64ae53fef0f7d64e2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Jun 6 13:58:33 2024 -0700
Bump up actions versions as GHA bumps node version to 20
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 4680e3b99..50ca80369 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -222,10 +222,10 @@ jobs:
echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
- name: 'Check Out'
- uses: actions/checkout at v3
+ uses: actions/checkout at v4
- name: Retrieve build cache
- uses: actions/cache/restore at v3
+ uses: actions/cache/restore at v4
with:
path: .ccache
@@ -253,7 +253,7 @@ jobs:
ccache -s
- name: Save build cache
- uses: actions/cache/save at v3
+ uses: actions/cache/save at v4
with:
path: .ccache
key: ${{ steps.restore-cache.outputs.cache-primary-key }}
@@ -303,7 +303,7 @@ jobs:
steps:
- name: 'Check Out'
- name: 'Setup'
uses: msys2/setup-msys2 at v2
@@ -313,7 +313,7 @@ jobs:
with:
path: .ccache
key: windows-mingw-${{ matrix.build_type}}-${{ github.ref_name }}-${{ github.run_id }}
@@ -332,7 +332,7 @@ jobs:
cmake --build . -j 4
with:
path: .ccache
@@ -358,14 +358,14 @@ jobs:
runs-on: ${{ matrix.ci.os }}
steps:
- name: 'Check Out'
- name: 'Setup'
run: choco install ccache
with:
path: .ccache
key: windows-msvc-${{ matrix.build_type}}-${{ github.ref_name }}-${{ github.run_id }}
@@ -427,11 +427,11 @@ jobs:
clang++ --version
- name: 'Check Out'
with:
path: .ccache
key: ${{ runner.os }}-${{ matrix.xcode }}-${{ matrix.build_type}}-${{ matrix.cxxstd }}-${{ github.ref_name }}-${{ github.run_id }}
@@ -453,7 +453,7 @@ jobs:
cmake --build . --config ${BUILD_TYPE} -j 4
with:
path: .ccache
@@ -475,7 +475,7 @@ jobs:
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
- name: 'Check Out'
- name: 'cppcheck'
run: |
@@ -496,7 +496,7 @@ jobs:
- name: 'Check Out'
with:
path: geos
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 5b4aca3e2..0505fd9e1 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -23,7 +23,7 @@ jobs:
steps:
- name: 'Check Out'
- name: Set up Docker Buildx
uses: docker/setup-buildx-action at v2
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index 377aa8d71..0cd89dd4e 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -33,7 +33,7 @@ jobs:
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
- name: 'Check Out'
- name: Get tag
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index 019c1ce24..4bcc1306c 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -27,7 +27,7 @@ jobs:
- name: 'Check Out 📗'
- name: 'Hugo Build 🛠'
# ...or replace 'master' with a full version tag, such as: v0.64.1
Summary of changes:
.github/workflows/ci.yml | 26 +++++++++++++-------------
.github/workflows/container.yml | 2 +-
.github/workflows/release.yml | 2 +-
.github/workflows/web.yml | 2 +-
4 files changed, 16 insertions(+), 16 deletions(-)
hooks/post-receive
More information about the geos-commits
