[geos-commits] [SCM] GEOS branch 3.12 updated. 23ce804783aa2ac864d08df08d329a8b082f759c
git at osgeo.org
git at osgeo.org
Thu Jun 6 14:01:05 PDT 2024
the project "GEOS".
The branch, 3.12 has been updated
via 23ce804783aa2ac864d08df08d329a8b082f759c (commit)
from 02584d8bebf2a889d3a0deb185fd7952f03a502d (commit)
revisions in full, below.
commit 23ce804783aa2ac864d08df08d329a8b082f759c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Jun 6 14:00:44 2024 -0700
Update actions versions for GHA node 20 update
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 485db6b5f..f1987458d 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -205,10 +205,10 @@ jobs:
echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
- name: 'Check Out'
- uses: actions/checkout at v3
+ uses: actions/checkout at v4
- name: Retrieve build cache
- uses: actions/cache/restore at v3
+ uses: actions/cache/restore at v4
with:
path: .ccache
@@ -236,7 +236,7 @@ jobs:
ccache -s
- name: Save build cache
- uses: actions/cache/save at v3
+ uses: actions/cache/save at v4
with:
path: .ccache
key: ${{ steps.restore-cache.outputs.cache-primary-key }}
@@ -286,7 +286,7 @@ jobs:
steps:
- name: 'Check Out'
- name: 'Setup'
uses: msys2/setup-msys2 at v2
@@ -296,7 +296,7 @@ jobs:
with:
path: .ccache
key: windows-mingw-${{ matrix.build_type}}-${{ github.ref_name }}-${{ github.run_id }}
@@ -315,7 +315,7 @@ jobs:
cmake --build . -j 2
with:
path: .ccache
@@ -341,14 +341,14 @@ jobs:
runs-on: ${{ matrix.ci.os }}
steps:
- name: 'Check Out'
- name: 'Setup'
run: choco install ccache
with:
path: .ccache
key: windows-msvc-${{ matrix.build_type}}-${{ github.ref_name }}-${{ github.run_id }}
@@ -363,7 +363,7 @@ jobs:
cmake --build . --config ${{ matrix.ci.build_type }} -j 2
with:
path: .ccache
@@ -406,11 +406,11 @@ jobs:
clang++ --version
- name: 'Check Out'
with:
path: .ccache
key: ${{ runner.os }}-${{ matrix.xcode }}-${{ matrix.build_type}}-${{ matrix.cxxstd }}-${{ github.ref_name }}-${{ github.run_id }}
@@ -432,7 +432,7 @@ jobs:
cmake --build . --config ${BUILD_TYPE} -j 3
with:
path: .ccache
@@ -454,7 +454,7 @@ jobs:
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
- name: 'Check Out'
- name: 'cppcheck'
run: |
@@ -475,7 +475,7 @@ jobs:
- name: 'Check Out'
with:
path: geos
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 5b4aca3e2..0505fd9e1 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -23,7 +23,7 @@ jobs:
steps:
- name: 'Check Out'
- name: Set up Docker Buildx
uses: docker/setup-buildx-action at v2
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index 377aa8d71..0cd89dd4e 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -33,7 +33,7 @@ jobs:
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
- name: 'Check Out'
- name: Get tag
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index 019c1ce24..4bcc1306c 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -27,7 +27,7 @@ jobs:
- name: 'Check Out 📗'
- name: 'Hugo Build 🛠'
# ...or replace 'master' with a full version tag, such as: v0.64.1
Summary of changes:
.github/workflows/ci.yml | 28 ++++++++++++++--------------
.github/workflows/container.yml | 2 +-
.github/workflows/release.yml | 2 +-
.github/workflows/web.yml | 2 +-
4 files changed, 17 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits
