[geos-commits] [SCM] GEOS branch main updated. 667e57695ef79e93a076bbad5c54d575d9b6c35f
git at osgeo.org
git at osgeo.org
Wed Jun 12 11:52:20 PDT 2024
the project "GEOS".
The branch, main has been updated
via 667e57695ef79e93a076bbad5c54d575d9b6c35f (commit)
from 10475608bfd41a0dd2258bd0eff8a90070f9982f (commit)
revisions in full, below.
commit 667e57695ef79e93a076bbad5c54d575d9b6c35f
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Jun 12 11:52:00 2024 -0700
Add perf_geostpsimplifystable test app
diff --git a/benchmarks/capi/CMakeLists.txt b/benchmarks/capi/CMakeLists.txt
index c539eaf7c..17457b848 100644
--- a/benchmarks/capi/CMakeLists.txt
+++ b/benchmarks/capi/CMakeLists.txt
@@ -20,6 +20,9 @@ target_link_libraries(perf_memleak_mp_prep PRIVATE geos_c)
add_executable(perf_geospreparedcontains GEOSPreparedContainsPerfTest.cpp)
target_link_libraries(perf_geospreparedcontains PRIVATE geos geos_c)
+add_executable(perf_geostpsimplifystable GEOSTopologyPreserveSimplifyStableTest.cpp)
+target_link_libraries(perf_geostpsimplifystable PRIVATE geos geos_c)
add_executable(perf_intersection IntersectionPerfTest.cpp)
target_link_libraries(perf_intersection PRIVATE geos geos_c)
diff --git a/benchmarks/capi/GEOSTopologyPreserveSimplifyStableTest.cpp b/benchmarks/capi/GEOSTopologyPreserveSimplifyStableTest.cpp
new file mode 100644
index 000000000..a73906989
--- /dev/null
+++ b/benchmarks/capi/GEOSTopologyPreserveSimplifyStableTest.cpp
@@ -0,0 +1,97 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2024 Martin Davis
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Tests the stability of topology-preserving simplification
+ * (using GEOSTopologyPreserveSimplify).
+ * The expectation is that repeated calls to GEOSTopologyPreserveSimplify(geom, tol)
+ * produce identical results.
+ * See https://github.com/libgeos/geos/issues/1107
+#include <geos_c.h>
+#include <fstream>
+#include <iostream>
+#include <sstream>
+#include <deque>
+GEOSGeometry* readGeom(std::string& fname) {
+ std::ifstream f(fname);
+ std::string line;
+ if (! std::getline(f, line)) {
+ return nullptr;
+ auto geom = GEOSGeomFromWKT(line.c_str());
+ f.close();
+ return geom;
+ //---------- Run test ---------------
+void run(std::string& fname, int nRuns, double tolerance)
+ initGEOS(nullptr, nullptr);
+ GEOSGeometry* geom = readGeom(fname);
+ int nErrors = 0;
+ for (int i = 0; i < nRuns; i++) {
+ GEOSGeometry* simp1 = GEOSTopologyPreserveSimplify(geom, tolerance);
+ GEOSGeometry* simp2 = GEOSTopologyPreserveSimplify(geom, tolerance);
+ bool isEqualExact = 1 == GEOSEqualsExact(simp1, simp2, 0.0);
+ GEOSGeometry* diff = GEOSSymDifference(simp1, simp2);
+ bool isDiffEmpty = 1 == GEOSisEmpty(diff);
+ //std::cout << "Run " << i << std::endl;
+ if (! isEqualExact || ! isDiffEmpty) {
+ nErrors++;
+ std::cout << "simplified results are not identical" << std::endl;
+ std::cout << diff << std::endl;
+ GEOSGeom_destroy(simp1);
+ GEOSGeom_destroy(simp2);
+ GEOSGeom_destroy(diff);
+ std::cout << "Number of tests with non-identical results: " << nErrors << std::endl;
+ if (nErrors > 0) {
+ std::cout << "ERRORS FOUND " << std::endl;
+ GEOSGeom_destroy(geom);
+int main(int argc, char** argv) {
+ if (argc != 4) {
+ std::cout << "Reads a geometry from a WKT file" << std::endl;
+ std::cout << "and executes GEOSTopologyPreserveSimplify(geom, TOL) N times," << std::endl;
+ std::cout << "checking that the results are identical" << std::endl;
+ std::cout << std::endl;
+ std::cout << "Usage: perf_geostpsimplifystable wktfile TOL N" << std::endl;
+ return 0;
+ std::string fname{argv[1]};
+ std::cout << "Reading geometry from " << fname << std::endl;
+ double tolerance = atof(argv[2]);
+ std::cout << "Tolerance: " << tolerance << std::endl;
+ int nRuns = std::atoi(argv[3]);
+ std::cout << "Performing " << nRuns << " tests." << std::endl;
+ run(fname, nRuns, tolerance);
Summary of changes:
benchmarks/capi/CMakeLists.txt | 3 +
.../GEOSTopologyPreserveSimplifyStableTest.cpp | 97 ++++++++++++++++++++++
2 files changed, 100 insertions(+)
create mode 100644 benchmarks/capi/GEOSTopologyPreserveSimplifyStableTest.cpp
hooks/post-receive
More information about the geos-commits
