[geos-commits] [SCM] GEOS branch main updated. faa29d7c0c148064c5b44342b76635502f48651b
git at osgeo.org
git at osgeo.org
Wed Jun 12 12:00:38 PDT 2024
the project "GEOS".
The branch, main has been updated
via faa29d7c0c148064c5b44342b76635502f48651b (commit)
from 667e57695ef79e93a076bbad5c54d575d9b6c35f (commit)
revisions in full, below.
commit faa29d7c0c148064c5b44342b76635502f48651b
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Jun 12 12:00:19 2024 -0700
Document BUILD_BENCHMARKS
diff --git a/web/content/usage/download.md b/web/content/usage/download.md
index fc7dbbfb0..569a77a8f 100644
--- a/web/content/usage/download.md
+++ b/web/content/usage/download.md
@@ -55,7 +55,7 @@ Options are specified via [`cmake` variables](https://cmake.org/cmake/help/lates
They are specified on the `cmake` cmdline as `-DVAR=VALUE`.
{{< hint warning >}}
-*NOTE: Running cmake with no variables does NOT clear current variable settings. They must be set explicitly on the cmdline or interactively using `ccmake ..`. To revert to the defaults, clear the build directory contents using `rm -rf *`.*
+*NOTE: Running cmake with no variables does NOT clear current variable settings. They must be set explicitly on the cmdline, or interactively using `ccmake ..`. To revert to the defaults, clear the build directory contents using `rm -rf *`.*
{{< /hint >}}
| Option | Default | Note |
@@ -63,9 +63,10 @@ They are specified on the `cmake` cmdline as `-DVAR=VALUE`.
| CMAKE_BUILD_TYPE | Release | Use `Debug` to build with debug flags and optimizations off. Use `Release` for packaging and production installs. Use `RelWithDebInfo` for optimized build with debug symbols. |
| CMAKE_INSTALL_PREFIX | /usr/local | Set to install root. Libraries end up in `./lib` or `./lib64`, headers in `./include`, executables in `./bin` |
| BUILD_DOCUMENTATION | ON | Attempt to find `doxygen` executable and build API docs |
-| BUILD_SHARED_LIBS | ON | Build dynamically linkable libraries. |
-| BUILD_TESTING | ON | Build unit tests. |
-| USE_CCACHE | OFF | Use [`ccache`](https://ccache.dev/) to compile C/C++ objects, making subsequent builds quicker. |
+| BUILD_SHARED_LIBS | ON | Build dynamically linkable libraries |
+| BUILD_TESTING | ON | Build unit tests |
+| BUILD_BENCHMARKS | OFF | Build benchmark tests |
+| USE_CCACHE | OFF | Use [`ccache`](https://ccache.dev/) to compile C/C++ objects, making subsequent builds quicker |
## Testing
Summary of changes:
web/content/usage/download.md | 9 +++++----
1 file changed, 5 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
