[geos-commits] [SCM] GEOS branch main updated. 2aa98200475266fb63e132f806f82c00c8665c6c
Fri Jun 14 10:15:04 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  2aa98200475266fb63e132f806f82c00c8665c6c (commit)
      from  eea66b88041b0dd54a91bd3119e894f8b133851b (commit)
revisions in full, below.
commit 2aa98200475266fb63e132f806f82c00c8665c6c
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Jun 14 10:14:44 2024 -0700
    Add ASAN info to docs
diff --git a/web/content/project/development/tests.md b/web/content/project/development/tests.md
index a512bb462..2298639a3 100644
--- a/web/content/project/development/tests.md
+++ b/web/content/project/development/tests.md
@@ -61,9 +61,17 @@ Options:
 ### Performance Tests
-There are performance tests which are built, but not run as part of the standard test suite.
-These can be run from the command line:
+There are performance tests which are not built or run as part of the standard test suite.
+Building this is enabled by the `cmake -DBUILD_BENCHMARKS=ON` flag.
+The various tests can be run from the command line, e.g.:
 $ bin/perf_iterated_buffer
+### Memory Usage testing
+In some cases bugs are caused by improper memory access after deallocation (`heap-use-after-free`).
+This may be able to be detected and reported by using the Address Sanitizer compiler capability.
+Enable this via `cmake -DCMAKE_BUILD_TYPE=ASAN`.
diff --git a/web/content/usage/download.md b/web/content/usage/download.md
index 569a77a8f..997f132d5 100644
--- a/web/content/usage/download.md
+++ b/web/content/usage/download.md
@@ -60,7 +60,7 @@ They are specified on the `cmake` cmdline as `-DVAR=VALUE`.
 | Option               | Default    | Note  |
-| CMAKE_BUILD_TYPE     | Release    | Use `Debug` to build with debug flags and optimizations off. Use `Release` for packaging and production installs. Use `RelWithDebInfo` for optimized build with debug symbols. |
+| CMAKE_BUILD_TYPE     | Release    | Use `Debug` to build with debug flags and optimizations off. Use `Release` for packaging and production installs. Use `RelWithDebInfo` for optimized build with debug symbols. Use `ASAN` to enable memory usage checking. |
 | CMAKE_INSTALL_PREFIX | /usr/local | Set to install root. Libraries end up in `./lib` or `./lib64`, headers in `./include`, executables in `./bin` |
 | BUILD_DOCUMENTATION  | ON         | Attempt to find `doxygen` executable and build API docs |
 | BUILD_SHARED_LIBS    | ON         | Build dynamically linkable libraries |
@@ -69,6 +69,7 @@ They are specified on the `cmake` cmdline as `-DVAR=VALUE`.
 | USE_CCACHE           | OFF        | Use [`ccache`](https://ccache.dev/) to compile C/C++ objects, making subsequent builds quicker |
 ## Testing
 It is possible to run `ctest` directly. This gives access to ctest command line options (see `ctest --help` for a listing).
Summary of changes:
 web/content/project/development/tests.md | 12 ++++++++++--
 web/content/usage/download.md            |  3 ++-
 2 files changed, 12 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
