[geos-commits] [SCM] GEOS branch 3.12 updated. 0b8114159c14df71630e74a5bb0f7661a871acdc
git at osgeo.org
git at osgeo.org
Fri Jun 14 12:19:05 PDT 2024
the project "GEOS".
The branch, 3.12 has been updated
via 0b8114159c14df71630e74a5bb0f7661a871acdc (commit)
from 23ce804783aa2ac864d08df08d329a8b082f759c (commit)
revisions in full, below.
commit 0b8114159c14df71630e74a5bb0f7661a871acdc
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Jun 14 09:58:32 2024 -0700
Fix TopologyPreservingSimplifier to remove ring endpoints safely (#1110)
diff --git a/include/geos/simplify/TaggedLineString.h b/include/geos/simplify/TaggedLineString.h
index d54663560..b23f3a400 100644
--- a/include/geos/simplify/TaggedLineString.h
+++ b/include/geos/simplify/TaggedLineString.h
@@ -105,7 +105,7 @@ public:
void addToResult(std::unique_ptr<TaggedLineSegment> seg);
- void removeRingEndpoint();
+ const TaggedLineSegment* removeRingEndpoint();
std::unique_ptr<geom::Geometry> asLineString() const;
diff --git a/src/simplify/TaggedLineString.cpp b/src/simplify/TaggedLineString.cpp
index ed5ba9ec7..e0dc40ddb 100644
--- a/src/simplify/TaggedLineString.cpp
+++ b/src/simplify/TaggedLineString.cpp
@@ -281,15 +281,16 @@ TaggedLineString::addToResult(std::unique_ptr<TaggedLineSegment> seg)
#endif
-void
+const TaggedLineSegment*
TaggedLineString::removeRingEndpoint()
auto* firstSeg = resultSegs.front();
auto* lastSeg = resultSegs.back();
firstSeg->p0 = lastSeg->p0;
- delete lastSeg;
resultSegs.pop_back();
+ delete lastSeg;
+ return firstSeg;
} // namespace geos::simplify
diff --git a/src/simplify/TaggedLineStringSimplifier.cpp b/src/simplify/TaggedLineStringSimplifier.cpp
index 3bd8e0ecf..b9d1cccc8 100644
--- a/src/simplify/TaggedLineStringSimplifier.cpp
+++ b/src/simplify/TaggedLineStringSimplifier.cpp
@@ -187,7 +187,15 @@ TaggedLineStringSimplifier::simplifyRingEndpoint(double distanceTolerance)
if (simpSeg.distance(endPt) <= distanceTolerance &&
isTopologyValid(line, firstSeg, lastSeg, simpSeg))
- line->removeRingEndpoint();
+ //-- don't know if segments are original or new, so remove from all indexes
+ inputIndex->remove(firstSeg);
+ inputIndex->remove(lastSeg);
+ outputIndex->remove(firstSeg);
+ outputIndex->remove(lastSeg);
+ const TaggedLineSegment* flatSeg = line->removeRingEndpoint();
+ //-- removed endpoint alters an existing result edge
+ outputIndex->add(flatSeg);
diff --git a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
index 0df890418..750858ebf 100644
--- a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
+++ b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
@@ -419,6 +419,16 @@ void object::test<32>()
checkTPSNoChange("LINESTRING (1 0, 2 0, 2 2, 0 2, 0 0, 1 0)", 0);
+// Test for no use-after-free triggered by ring endpoint removal handling
+// See https://github.com/libgeos/geos/issues/1107, fix https://github.com/libgeos/geos/pull/1110
+template<>
+template<>
+void object::test<33>()
+ checkTPS("POLYGON ((-222601.33094265286 6299915.50260568, -222599.13611514607 6299917.747821213, -222599.09754554977 6299925.149899498, -222599.07870256738 6299925.234615005, -222595.52372420163 6299932.934861557, -222510 6300300, -221720.85158014414 6300132.680680807, -222448.77936063593 6299647.669870703, -222618.41756525903 6299886.966175825, -222618.40178141624 6299887.020684309, -222616.09648739762 6299892.144482262, -222601.33094265286 6299915.50260568), (-222456.68914400978 6299947.489843342, -222455.07603815367 6299939.772017001, -222455.07542453965 6299939.691595431, -222456.57057590774 6299931.950053182, -222462.75368034307 6299916.87367865, -222465.9575074078 6299911.582542387, -222465.99782740293 6299911.534645676, -222483.5296791599 6299864.079888968, -222484.09789251382 6299852.105440594, -222485.11401620077 6299846.692173677, -222485.13170293145 6299846.639453617, -222487.58585740798 6299841.7086228, -222490.56062790897 6299837.359974515, -222415.1394852571 629992
6.6972160805, -222421.19226152284 6299963.389132584, -222467.0202338936 6299970.185860572, -222465.71145777934 6299968.200784476, -222465.69955208438 6299968.180154371, -222464.63560265294 6299966.053788407, -222456.68914400978 6299947.489843342))",
+ 20,
+ "POLYGON ((-222618.41756525903 6299886.966175825, -222510 6300300, -221720.85158014414 6300132.680680807, -222448.77936063593 6299647.669870703, -222618.41756525903 6299886.966175825), (-222467.0202338936 6299970.185860572, -222456.57057590774 6299931.950053182, -222490.56062790897 6299837.359974515, -222415.1394852571 6299926.6972160805, -222421.19226152284 6299963.389132584, -222467.0202338936 6299970.185860572))");
} // namespace tut
Summary of changes:
include/geos/simplify/TaggedLineString.h | 2 +-
src/simplify/TaggedLineString.cpp | 5 +++--
src/simplify/TaggedLineStringSimplifier.cpp | 10 +++++++++-
tests/unit/simplify/TopologyPreservingSimplifierTest.cpp | 10 ++++++++++
4 files changed, 23 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
