[geos-commits] [SCM] GEOS branch 3.9 updated. 835d1360220955ca0928f9d8ff9472bbede4ae27
Mon Jun 17 11:50:36 PDT 2024
the project "GEOS".
The branch, 3.9 has been updated
       via  835d1360220955ca0928f9d8ff9472bbede4ae27 (commit)
       via  64c96ba2265f9707eed692cc3caa4d41d885d4e8 (commit)
       via  7590379676d1b2a99fce225416d3df2f1c66a87c (commit)
      from  3effbfd32bf304c0276bed1691137d2c48ed907b (commit)
revisions in full, below.
commit 835d1360220955ca0928f9d8ff9472bbede4ae27
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Jun 17 14:47:32 2024 -0400
    NEWS updates
diff --git a/NEWS b/NEWS
index 195b7fa50..889f00328 100644
--- a/NEWS
+++ b/NEWS
@@ -3,7 +3,8 @@ xxxx-xx-xx
 - Bug fixes / improvements:
   - Intersection: change to using DoubleDouble computation to improve robustness (GH-937, Martin Davis)
+  - Centroid: Fix crash on polygons with empty holes (GH-1075, Dan Baston)
+  - GEOSRelatePatternMatch: Fix crash on invalid DE-9IM pattern (GH-1089, Dan Baston)
 ## Changes in 3.9.5
 2023-11-12
commit 64c96ba2265f9707eed692cc3caa4d41d885d4e8
Date:   Tue Apr 30 18:37:19 2024 -0400
    IntersectionMatrix: Ignore patterns longer than 9 characters
    Fixes https://github.com/libgeos/geos/issues/1084
diff --git a/src/geom/IntersectionMatrix.cpp b/src/geom/IntersectionMatrix.cpp
index a8c7a4b39..b055742a3 100644
--- a/src/geom/IntersectionMatrix.cpp
+++ b/src/geom/IntersectionMatrix.cpp
@@ -146,7 +146,7 @@ IntersectionMatrix::set(Location row, Location col, int dimensionValue)
 void
 IntersectionMatrix::set(const string& dimensionSymbols)
-    auto limit = dimensionSymbols.length();
+    auto limit = std::min(dimensionSymbols.length(), static_cast<std::size_t>(9));
     for(size_t i = 0; i < limit; i++) {
         auto row = i / firstDim;
diff --git a/tests/unit/capi/GEOSRelatePatternMatchTest.cpp b/tests/unit/capi/GEOSRelatePatternMatchTest.cpp
index 90549d47d..c4509119e 100644
--- a/tests/unit/capi/GEOSRelatePatternMatchTest.cpp
+++ b/tests/unit/capi/GEOSRelatePatternMatchTest.cpp
@@ -8,6 +8,7 @@
 #include <cstdarg>
 #include <cstdio>
 #include <cstdlib>
+#include <cstring>
 namespace tut {
@@ -101,5 +102,18 @@ void object::test<5>
     ensure_equals(ret, char(0));
+// invalid DE-9IM argument
+// https://github.com/libgeos/geos/issues/1084
+template<>
+template<>
+void object::test<6>
+    const char* mat = "0000000000";
+    ensure_equals(strlen(mat), 10u); // not a valid DE-9IM!
+    GEOSRelatePatternMatch(mat,  "111111111");
 } // namespace tut
commit 7590379676d1b2a99fce225416d3df2f1c66a87c
Date:   Fri Apr 19 19:49:55 2024 -0400
    Centroid: Avoid crash with empty hole
    Resolves https://github.com/libgeos/geos/issues/1073
diff --git a/src/algorithm/Centroid.cpp b/src/algorithm/Centroid.cpp
index 8f6568201..16fbbe7d5 100644
--- a/src/algorithm/Centroid.cpp
+++ b/src/algorithm/Centroid.cpp
@@ -124,6 +124,10 @@ Centroid::addShell(const CoordinateSequence& pts)
 void
 Centroid::addHole(const CoordinateSequence& pts)
+    if (pts.isEmpty()) {
+        return;
     bool isPositiveArea = Orientation::isCCW(&pts);
     for(size_t i = 0, e = pts.size() - 1; i < e; ++i) {
         addTriangle(*areaBasePt, pts[i], pts[i + 1], isPositiveArea);
diff --git a/tests/unit/algorithm/CentroidTest.cpp b/tests/unit/algorithm/CentroidTest.cpp
new file mode 100644
index 000000000..be3dcc05e
--- /dev/null
+++ b/tests/unit/algorithm/CentroidTest.cpp
@@ -0,0 +1,133 @@
+// Test Suite for geos::algorithm::Centroid
+#include <tut/tut.hpp>
+// geos
+#include <geos/algorithm/Centroid.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateArraySequence.h>
+#include <geos/geom/Dimension.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/io/WKTReader.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+using namespace geos;
+using namespace geos::geom;
+namespace tut {
+// Test Group
+// dummy data, not used
+struct test_centroid_data {
+    std::unique_ptr<Geometry> geom_;
+    PrecisionModel pm_;
+    GeometryFactory::Ptr factory_;
+    io::WKTReader reader_;
+    test_centroid_data():
+        geom_(nullptr),
+        pm_(1),
+        factory_(GeometryFactory::create(&pm_, 0)),
+        reader_(factory_.get())
+        assert(nullptr == geom_);
+    ~test_centroid_data()
+    void
+    checkCentroid(std::string inputWkt, bool expectResult, double expectedX, double expectedY)
+        std::unique_ptr<Geometry> inputGeom(reader_.read(inputWkt));
+        Coordinate resultCoord;
+        bool gotResult = algorithm::Centroid::getCentroid(*inputGeom, resultCoord);
+        ensure_equals(gotResult, expectResult);
+        if (expectResult) {
+            ensure_equals(expectedX, resultCoord.x);
+            ensure_equals(expectedY, resultCoord.y);
+    void
+    checkCentroid(std::string inputWkt, double expectedX, double expectedY)
+        checkCentroid(inputWkt, true, expectedX, expectedY);
+    void
+    checkCentroidFails(std::string inputWkt)
+        checkCentroid(inputWkt, false, 0, 0);
+typedef test_group<test_centroid_data> group;
+typedef group::object object;
+group test_centroid_group("geos::algorithm::Centroid");
+// Test Cases
+template<>
+template<>
+void object::test<1>() {
+    checkCentroid(
+        "LINESTRING (0 0, 200 200)",
+        100.0, 100.0);
+template<>
+template<>
+void object::test<2>() {
+    checkCentroid(
+        "POLYGON ((0 0, 100 0, 100 100, 0 100, 0 0))",
+        50.0, 50.0);
+template<>
+template<>
+void object::test<3>() {
+    checkCentroid(
+        "GEOMETRYCOLLECTION(POLYGON ((0 0, 100 0, 100 100, 0 100, 0 0)))",
+        50.0, 50.0);
+template<>
+template<>
+void object::test<4>() {
+    checkCentroid(
+        "GEOMETRYCOLLECTION(POLYGON ((0 0, 100 0, 100 100, 0 100, 0 0)), POINT EMPTY)",
+        50.0, 50.0);
+template<>
+template<>
+void object::test<5>() {
+        "POLYGON EMPTY");
+template<>
+template<>
+void object::test<6>() {
+    checkCentroid("POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0), EMPTY)", 0.5, 0.5);
+} // namespace tut
Summary of changes:
 NEWS                                           |   3 +-
 src/algorithm/Centroid.cpp                     |   4 +
 src/geom/IntersectionMatrix.cpp                |   2 +-
 tests/unit/algorithm/CentroidTest.cpp          | 133 +++++++++++++++++++++++++
 tests/unit/capi/GEOSRelatePatternMatchTest.cpp |  14 +++
 5 files changed, 154 insertions(+), 2 deletions(-)
 create mode 100644 tests/unit/algorithm/CentroidTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
