[geos-commits] [SCM] GEOS branch main updated. 5dc668b7f2ca3beb9d188b9dfc6f8f3e4935894a
Mon Jun 17 19:32:33 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  5dc668b7f2ca3beb9d188b9dfc6f8f3e4935894a (commit)
      from  2aa98200475266fb63e132f806f82c00c8665c6c (commit)
revisions in full, below.
commit 5dc668b7f2ca3beb9d188b9dfc6f8f3e4935894a
Author: Dan Baston <dbaston at gmail.com>
Date:   Mon Jun 17 22:32:12 2024 -0400
    WKBReader: Support curved geometry types (#1106)
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 342d0cf6b..3661bf886 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -70,7 +70,7 @@ namespace geos { // geos
 namespace geom { // geos::geom
 /// Geometry types
-enum GeometryTypeId {
+enum GeometryTypeId : int {
     /// a point
     GEOS_POINT,
     /// a linestring
diff --git a/include/geos/geom/GeometryTypeName.h b/include/geos/geom/GeometryTypeName.h
new file mode 100644
index 000000000..9807e5a24
--- /dev/null
+++ b/include/geos/geom/GeometryTypeName.h
@@ -0,0 +1,110 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2024 ISciences, LLC
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+namespace geos {
+namespace geom {
+class Curve;
+class CurvePolygon;
+class GeometryCollection;
+class LineString;
+class LinearRing;
+class MultiCurve;
+class MultiLineString;
+class MultiPoint;
+class MultiPolygon;
+class MultiSurface;
+class Point;
+class Polygon;
+class SimpleCurve;
+class Surface;
+// These structures allow templates to have compile-time access to a type's human-readable name.
+template<typename T>
+struct GeometryTypeName {};
+template<>
+struct GeometryTypeName<geom::Curve> {
+    static constexpr const char* name = "Curve";
+template<>
+struct GeometryTypeName<geom::CurvePolygon> {
+    static constexpr const char* name = "CurvePolygon";
+template<>
+struct GeometryTypeName<geom::GeometryCollection> {
+    static constexpr const char* name = "GeometryCollection";
+template<>
+struct GeometryTypeName<geom::LineString> {
+    static constexpr const char* name = "LineString";
+template<>
+struct GeometryTypeName<geom::LinearRing> {
+    static constexpr const char* name = "LinearRing";
+template<>
+struct GeometryTypeName<geom::MultiCurve> {
+    static constexpr const char* name = "MultiCurve";
+template<>
+struct GeometryTypeName<geom::MultiLineString> {
+    static constexpr const char* name = "MultiLineString";
+template<>
+struct GeometryTypeName<geom::MultiPoint> {
+    static constexpr const char* name = "MultiPoint";
+template<>
+struct GeometryTypeName<geom::MultiPolygon> {
+    static constexpr const char* name = "MultiPolygon";
+template<>
+struct GeometryTypeName<geom::MultiSurface> {
+    static constexpr const char* name = "MultiSurface";
+template<>
+struct GeometryTypeName<geom::Point> {
+    static constexpr const char* name = "Point";
+template<>
+struct GeometryTypeName<geom::Polygon> {
+    static constexpr const char* name = "Polygon";
+template<>
+struct GeometryTypeName<geom::SimpleCurve> {
+    static constexpr const char* name = "SimpleCurve";
+template<>
+struct GeometryTypeName<geom::Surface> {
+    static constexpr const char* name = "Surface";
diff --git a/include/geos/io/WKBReader.h b/include/geos/io/WKBReader.h
index c050f26ac..008f32865 100644
--- a/include/geos/io/WKBReader.h
+++ b/include/geos/io/WKBReader.h
@@ -20,7 +20,8 @@
 #pragma once
 #include <geos/export.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryTypeName.h>
 #include <geos/io/ByteOrderDataInStream.h> // for composition
 #include <iosfwd> // ostream, istream
@@ -28,8 +29,6 @@
 // #include <vector>
 #include <array>
-#define BAD_GEOM_TYPE_MSG "Bad geometry type encountered in"
 #ifdef _MSC_VER
 #pragma warning(push)
 #pragma warning(disable: 4251) // warning C4251: needs to have dll-interface to be used by clients of class
@@ -41,17 +40,24 @@ namespace geom {
 class GeometryFactory;
 class Coordinate;
+class CircularString;
+class CompoundCurve;
 class Geometry;
+enum GeometryTypeId : int;
 class Point;
 class LineString;
 class LinearRing;
 class Polygon;
+class MultiCurve;
 class MultiPoint;
 class MultiPolygon;
 class PrecisionModel;
 class CoordinateSequence;
+class SimpleCurve;
 } // namespace geom
 } // namespace geos
@@ -148,22 +154,42 @@ private:
     std::unique_ptr<geom::LinearRing> readLinearRing();
+    std::unique_ptr<geom::CircularString> readCircularString();
+    std::unique_ptr<geom::CompoundCurve> readCompoundCurve();
     std::unique_ptr<geom::Polygon> readPolygon();
+    std::unique_ptr<geom::CurvePolygon> readCurvePolygon();
     std::unique_ptr<geom::MultiPoint> readMultiPoint();
     std::unique_ptr<geom::MultiLineString> readMultiLineString();
+    std::unique_ptr<geom::MultiCurve> readMultiCurve();
     std::unique_ptr<geom::MultiPolygon> readMultiPolygon();
+    std::unique_ptr<geom::MultiSurface> readMultiSurface();
     std::unique_ptr<geom::GeometryCollection> readGeometryCollection();
     std::unique_ptr<geom::CoordinateSequence> readCoordinateSequence(unsigned int); // throws IOException
-    void minMemSize(int geomType, uint64_t size);
+    void minMemSize(geom::GeometryTypeId geomType, uint64_t size) const;
     void readCoordinate(); // throws IOException
+    template<typename T>
+    std::unique_ptr<T> readChild()
+        auto g = readGeometry();
+        if (dynamic_cast<const T*>(g.get())) {
+            return std::unique_ptr<T>(static_cast<T*>(g.release()));
+        throw io::ParseException(std::string("Expected ") + geom::GeometryTypeName<T>::name + " but got " + g->getGeometryType());
     // Declare type as noncopyable
     WKBReader(const WKBReader& other) = delete;
     WKBReader& operator=(const WKBReader& rhs) = delete;
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index 0aa9c38e9..5410ab0c7 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -20,15 +20,21 @@
 #include <geos/io/WKBConstants.h>
 #include <geos/io/ByteOrderValues.h>
 #include <geos/io/ParseException.h>
+#include <geos/geom/CircularString.h>
+#include <geos/geom/CompoundCurve.h>
+#include <geos/geom/CurvePolygon.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/geom/Coordinate.h>
 #include <geos/geom/Point.h>
 #include <geos/geom/LinearRing.h>
 #include <geos/geom/LineString.h>
 #include <geos/geom/Polygon.h>
+#include <geos/geom/MultiCurve.h>
 #include <geos/geom/MultiPoint.h>
 #include <geos/geom/MultiLineString.h>
 #include <geos/geom/MultiPolygon.h>
+#include <geos/geom/MultiSurface.h>
 #include <geos/geom/CoordinateSequence.h>
 #include <geos/geom/PrecisionModel.h>
 #include <geos/util.h>
@@ -58,6 +64,7 @@ WKBReader::WKBReader()
     : WKBReader(*(GeometryFactory::getDefaultInstance()))
 void
 WKBReader::setFixStructure(bool doFixStructure)
@@ -178,7 +185,7 @@ WKBReader::readHEX(std::istream& is)
 void
-WKBReader::minMemSize(int geomType, uint64_t size)
+WKBReader::minMemSize(geom::GeometryTypeId geomType, uint64_t size) const
     uint64_t minSize = 0;
     constexpr uint64_t minCoordSize = 2 * sizeof(double);
@@ -191,18 +198,24 @@ WKBReader::minMemSize(int geomType, uint64_t size)
     switch(geomType) {
         case GEOS_LINESTRING:
         case GEOS_LINEARRING:
+        case GEOS_CIRCULARSTRING:
+        case GEOS_COMPOUNDCURVE:
+        case GEOS_POINT:
             minSize = size * minCoordSize;
             break;
         case GEOS_POLYGON:
+        case GEOS_CURVEPOLYGON:
             minSize = size * minRingSize;
             break;
         case GEOS_MULTIPOINT:
             minSize = size * minPtSize;
             break;
         case GEOS_MULTILINESTRING:
+        case GEOS_MULTICURVE:
             minSize = size * minLineSize;
             break;
         case GEOS_MULTIPOLYGON:
+        case GEOS_MULTISURFACE:
             minSize = size * minPolySize;
             break;
         case GEOS_GEOMETRYCOLLECTION:
@@ -309,9 +322,18 @@ WKBReader::readGeometry()
     case WKBConstants::wkbLineString :
         result = readLineString();
         break;
+    case WKBConstants::wkbCircularString :
+        result = readCircularString();
+        break;
+    case WKBConstants::wkbCompoundCurve :
+        result = readCompoundCurve();
+        break;
     case WKBConstants::wkbPolygon :
         result = readPolygon();
         break;
+    case WKBConstants::wkbCurvePolygon :
+        result = readCurvePolygon();
+        break;
     case WKBConstants::wkbMultiPoint :
         result = readMultiPoint();
         break;
@@ -324,6 +346,12 @@ WKBReader::readGeometry()
     case WKBConstants::wkbGeometryCollection :
         result = readGeometryCollection();
         break;
+    case WKBConstants::wkbMultiCurve :
+        result = readMultiCurve();
+        break;
+    case WKBConstants::wkbMultiSurface :
+        result = readMultiSurface();
+        break;
     default:
         std::stringstream err;
         err << "Unknown WKB type " << geometryType;
@@ -376,6 +404,30 @@ WKBReader::readLinearRing()
     return factory.createLinearRing(std::move(pts));
+std::unique_ptr<CircularString>
+WKBReader::readCircularString()
+    uint32_t size = dis.readUnsigned();
+    minMemSize(GEOS_CIRCULARSTRING, size);
+    auto pts = readCoordinateSequence(size);
+    return factory.createCircularString(std::move(pts));
+std::unique_ptr<CompoundCurve>
+WKBReader::readCompoundCurve()
+    auto numCurves = dis.readUnsigned();
+    minMemSize(GEOS_COMPOUNDCURVE, numCurves);
+    std::vector<std::unique_ptr<SimpleCurve>> curves(numCurves);
+    for (std::uint32_t i = 0; i < numCurves; i++) {
+        curves[i] = readChild<SimpleCurve>();
+    return factory.createCompoundCurve(std::move(curves));
 std::unique_ptr<Polygon>
 WKBReader::readPolygon()
@@ -402,9 +454,38 @@ WKBReader::readPolygon()
         return factory.createPolygon(std::move(shell), std::move(holes));
     return factory.createPolygon(std::move(shell));
+std::unique_ptr<CurvePolygon>
+WKBReader::readCurvePolygon()
+    uint32_t numRings = dis.readUnsigned();
+    minMemSize(GEOS_POLYGON, numRings);
+#if DEBUG_WKB_READER
+    std::size_t << "WKB numRings: " << numRings << std::endl;
+#endif
+    if (numRings == 0) {
+        return factory.createCurvePolygon(hasZ, hasM);
+    auto shell = readChild<Curve>();
+    if(numRings > 1) {
+        std::vector<std::unique_ptr<Curve>> holes(numRings - 1);
+        for(uint32_t i = 0; i < numRings - 1; i++) {
+            holes[i] = readChild<Curve>();
+        return factory.createCurvePolygon(std::move(shell), std::move(holes));
+    return factory.createCurvePolygon(std::move(shell));
 std::unique_ptr<MultiPoint>
 WKBReader::readMultiPoint()
@@ -413,12 +494,7 @@ WKBReader::readMultiPoint()
     std::vector<std::unique_ptr<Geometry>> geoms(numGeoms);
     for(uint32_t i = 0; i < numGeoms; i++) {
-        geoms[i] = readGeometry();
-        if(!dynamic_cast<Point*>(geoms[i].get())) {
-            std::stringstream err;
-            err << BAD_GEOM_TYPE_MSG << " MultiPoint";
-            throw ParseException(err.str());
+        geoms[i] = readChild<Point>();
     return factory.createMultiPoint(std::move(geoms));
@@ -432,12 +508,7 @@ WKBReader::readMultiLineString()
-        if(!dynamic_cast<LineString*>(geoms[i].get())) {
-            err << BAD_GEOM_TYPE_MSG << " LineString";
+        geoms[i] = readChild<LineString>();
     return factory.createMultiLineString(std::move(geoms));
@@ -451,17 +522,40 @@ WKBReader::readMultiPolygon()
-        if(!dynamic_cast<Polygon*>(geoms[i].get())) {
-            err << BAD_GEOM_TYPE_MSG << " Polygon";
+        geoms[i] = readChild<Polygon>();
     return factory.createMultiPolygon(std::move(geoms));
+std::unique_ptr<MultiCurve>
+WKBReader::readMultiCurve()
+    uint32_t numGeoms = dis.readUnsigned();
+    minMemSize(GEOS_MULTICURVE, numGeoms);
+    std::vector<std::unique_ptr<Curve>> geoms(numGeoms);
+    for(uint32_t i = 0; i < numGeoms; i++) {
+        geoms[i] = readChild<Curve>();
+    return factory.createMultiCurve(std::move(geoms));
+std::unique_ptr<MultiSurface>
+WKBReader::readMultiSurface()
+    minMemSize(GEOS_MULTISURFACE, numGeoms);
+    std::vector<std::unique_ptr<Surface>> geoms(numGeoms);
+        geoms[i] = readChild<Surface>();
+    return factory.createMultiSurface(std::move(geoms));
 std::unique_ptr<GeometryCollection>
 WKBReader::readGeometryCollection()
diff --git a/tests/unit/io/WKBReaderTest.cpp b/tests/unit/io/WKBReaderTest.cpp
index 1485b6262..6628351a8 100644
--- a/tests/unit/io/WKBReaderTest.cpp
+++ b/tests/unit/io/WKBReaderTest.cpp
@@ -12,6 +12,8 @@
 #include <geos/io/WKBWriter.h>
 #include <geos/io/WKTReader.h>
@@ -741,5 +743,100 @@ void object::test<30>
+// CircularString
+template<>
+template<>
+void object::test<31>
+    // CIRCULARSTRING(1 3,2 4,3 1)
+    auto g = readHex("010800000003000000000000000000F03F0000000000000840000000000000004000000000000010400000000000000840000000000000F03F");
+    ensure_equals(g->getGeometryTypeId(), geos::geom::GEOS_CIRCULARSTRING);
+    ensure_equals(g->getNumPoints(), 3u);
+// CompoundCurve
+template<>
+template<>
+void object::test<32>
+    //  SRID=5646;COMPOUNDCURVE(CIRCULARSTRING(1 3,2 4,3 1),(3 1,0 0))
+    auto g = readHex("01090000200E16000002000000010800000003000000000000000000F03F0000000000000840000000000000004000000000000010400000000000000840000000000000F03F0102000000020000000000000000000840000000000000F03F00000000000000000000000000000000");
+    ensure_equals(g->getGeometryTypeId(), geos::geom::GEOS_COMPOUNDCURVE);
+    ensure_equals(g->getSRID(), 5646);
+    const auto* cc = static_cast<const geos::geom::CompoundCurve*>(g.get());
+    ensure_equals(cc->getNumCurves(), 2u);
+    ensure_equals(cc->getCurveN(0)->getGeometryTypeId(), geos::geom::GEOS_CIRCULARSTRING);
+    ensure_equals(cc->getCurveN(0)->getNumPoints(), 3u);
+    ensure_equals(cc->getCurveN(1)->getGeometryTypeId(), geos::geom::GEOS_LINESTRING);
+    ensure_equals(cc->getCurveN(1)->getNumPoints(), 2u);
+// CurvePolygon
+template<>
+template<>
+void object::test<33>
+    // SRID=5646;CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(0 0,2 0,2 1,2 3,4 3),(4 3,4 5,1 4,0 0)),
+    //                        CIRCULARSTRING(1.7 1,1.4 0.4,1.6 0.4,1.6 0.5,1.7 1))
+    auto g = readHex("010A0000200E1600000200000001090000000200000001080000000500000000000000000000000000000000000000000000000000004000000000000000000000000000000040000000000000F03F00000000000000400000000000000840000000000000104000000000000008400102000000040000000000000000001040000000000000084000000000000010400000000000001440000000000000F03F000000000000104000000000000000000000000000000000010800000005000000333333333333FB3F000000000000F03F666666666666F63F9A9999999999D93F9A9999999999F93F9A9999999999D93F9A9999999999F93F000000000000E03F333333333333FB3F000000000000F03F");
+    ensure_equals(g->getGeometryTypeId(), geos::geom::GEOS_CURVEPOLYGON);
+    const auto* cp = static_cast<const geos::geom::CurvePolygon*>(g.get());
+    ensure_equals(cp->getExteriorRing()->getGeometryTypeId(), geos::geom::GEOS_COMPOUNDCURVE);
+    ensure_equals(cp->getNumInteriorRing(), 1u);
+    ensure_equals(cp->getInteriorRingN(0)->getGeometryTypeId(), geos::geom::GEOS_CIRCULARSTRING);
+// MultiCurve
+template<>
+template<>
+void object::test<34>
+    // MULTICURVE((0 0,5 5),
+    //            COMPOUNDCURVE((-1 -1,0 0),CIRCULARSTRING(0 0,1 1,2 0)),
+    //            CIRCULARSTRING(4 0,4 4,8 4))
+    auto g = readHex("010B000000030000000102000000020000000000000000000000000000000000000000000000000014400000000000001440010900000002000000010200000002000000000000000000F0BF000000000000F0BF0000000000000000000000000000000001080000000300000000000000000000000000000000000000000000000000F03F000000000000F03F00000000000000400000000000000000010800000003000000000000000000104000000000000000000000000000001040000000000000104000000000000020400000000000001040");
+    ensure_equals(g->getGeometryTypeId(), geos::geom::GEOS_MULTICURVE);
+    ensure_equals(g->getNumGeometries(), 3u);
+    ensure_equals(g->getGeometryN(0)->getGeometryTypeId(), geos::geom::GEOS_LINESTRING);
+    ensure_equals(g->getGeometryN(1)->getGeometryTypeId(), geos::geom::GEOS_COMPOUNDCURVE);
+    ensure_equals(g->getGeometryN(2)->getGeometryTypeId(), geos::geom::GEOS_CIRCULARSTRING);
+// MultiSurface
+template<>
+template<>
+void object::test<35>
+    // MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(0 0,4 0,4 4,0 4,0 0),(1 1,3 3,3 1,1 1)),
+    //             ((10 10,14 12,11 10,10 10),(11 11,11.5 11,11 11.5,11 11))
+    auto g = readHex("010C00000002000000010A000000020000000108000000050000000000000000000000000000000000000000000000000010400000000000000000000000000000104000000000000010400000000000000000000000000000104000000000000000000000000000000000010200000004000000000000000000F03F000000000000F03F000000000000084000000000000008400000000000000840000000000000F03F000000000000F03F000000000000F03F01030000000200000004000000000000000000244000000000000024400000000000002C40000000000000284000000000000026400000000000002440000000000000244000000000000024400400000000000000000026400000000000002640000000000000274000000000000026400000000000002640000000000000274000000000000026400000000000002640");
+    ensure_equals(g->getGeometryTypeId(), geos::geom::GEOS_MULTISURFACE);
+    ensure_equals(g->getNumGeometries(), 2u);
+    ensure_equals(g->getGeometryN(0)->getGeometryTypeId(), geos::geom::GEOS_CURVEPOLYGON);
+    ensure_equals(g->getGeometryN(1)->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
+// Invalid CompoundCurve with Point as a member
+template<>
+template<>
+void object::test<36>
+    testParseError("01090000200E160000010000000101000000000000000000F03F000000000000F03F",
+                   "ParseException: Expected SimpleCurve but got Point");
 } // namespace tut
diff --git a/tests/unit/io/WKTReaderTest.cpp b/tests/unit/io/WKTReaderTest.cpp
index 8873141f9..59e5f1b25 100644
--- a/tests/unit/io/WKTReaderTest.cpp
+++ b/tests/unit/io/WKTReaderTest.cpp
@@ -473,96 +473,4 @@ void object::test<24>
     ensure_equals(geom->getNumGeometries(), 3u);
-// Read a CircularString
-template<>
-template<>
-void object::test<25>
-    auto geom = wktreader.read("CIRCULARSTRING (0 0, 1 1, 2 0)");
-    ensure_equals(geom->getGeometryTypeId(), geos::geom::GEOS_CIRCULARSTRING);
-    ensure_equals(geom->getNumPoints(), 3u);
-// Read a CompoundCurve
-template<>
-template<>
-void object::test<26>
-    auto geom = wktreader.read("COMPOUNDCURVE (CIRCULARSTRING (0 0, 1 1, 1 0), (1 0, 0 1))");
-    ensure_equals(geom->getGeometryTypeId(), geos::geom::GEOS_COMPOUNDCURVE);
-    ensure_equals(geom->getNumPoints(), 5u);
-    // explicit form
-    auto geom2 = wktreader.read("COMPOUNDCURVE (CIRCULARSTRING (0 0, 1 1, 1 0), LINESTRING (1 0, 0 1))");
-    ensure(geom->equalsIdentical(geom2.get()));
-// Read a CurvePolygon whose components are simple curves
-template<>
-template<>
-void object::test<27>
-    auto geom = wktreader.read("CURVEPOLYGON( CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0), (1 1, 3 3, 3 1, 1 1) )");
-    ensure_equals(geom->getGeometryTypeId(), geos::geom::GEOS_CURVEPOLYGON);
-// Read a CurvePolygon whose components include compound curves
-template<>
-template<>
-void object::test<28>
-    auto geom = wktreader.read("CURVEPOLYGON( COMPOUNDCURVE( CIRCULARSTRING(0 0,2 0, 2 1, 2 3, 4 3), (4 3, 4 5, 1 4, 0 0)), CIRCULARSTRING(1.7 1, 1.4 0.4, 1.6 0.4, 1.6 0.5, 1.7 1) )");
-// Read a MultiCurve
-template<>
-template<>
-void object::test<29>
-    auto geom = wktreader.read("MULTICURVE( (0 0, 5 5), CIRCULARSTRING(4 0, 4 4, 8 4))");
-    ensure_equals(geom->getGeometryTypeId(), geos::geom::GEOS_MULTICURVE);
-    // explicit form
-    auto geom2 = wktreader.read("MULTICURVE( LINESTRING(0 0, 5 5), CIRCULARSTRING(4 0, 4 4, 8 4))");
-// Read a MultiCurve whose elements contain CompoundCurves
-template<>
-template<>
-void object::test<30>
-    auto geom = wktreader.read("MULTICURVE( (0 0, 5 5), COMPOUNDCURVE( (0 0, 1 1), CIRCULARSTRING (0 0, 1 1, 2 0)), CIRCULARSTRING(4 0, 4 4, 8 4))");
-// Read a MultiSurface
-template<>
-template<>
-void object::test<31>
-    auto geom = wktreader.read("MULTISURFACE( CURVEPOLYGON( CIRCULARSTRING( 0 0, 4 0, 4 4, 0 4, 0 0), (1 1, 3 3, 3 1, 1 1)), ((10 10, 14 12, 11 10, 10 10), (11 11, 11.5 11, 11 11.5, 11 11)))");
-    ensure_equals(geom->getGeometryTypeId(), geos::geom::GEOS_MULTISURFACE);
-    // explicit form
-    auto geom2 = wktreader.read("MULTISURFACE( CURVEPOLYGON( CIRCULARSTRING( 0 0, 4 0, 4 4, 0 4, 0 0), (1 1, 3 3, 3 1, 1 1)), POLYGON ((10 10, 14 12, 11 10, 10 10), (11 11, 11.5 11, 11 11.5, 11 11)))");
 } // namespace tut
Summary of changes:
 include/geos/geom/Geometry.h         |   2 +-
 include/geos/geom/GeometryTypeName.h | 110 +++++++++++++++++++++++++++++
 include/geos/io/WKBReader.h          |  34 +++++++--
 src/io/WKBReader.cpp                 | 132 ++++++++++++++++++++++++++++++-----
 tests/unit/io/WKBReaderTest.cpp      |  97 +++++++++++++++++++++++++
 tests/unit/io/WKTReaderTest.cpp      |  92 ------------------------
 6 files changed, 351 insertions(+), 116 deletions(-)
 create mode 100644 include/geos/geom/GeometryTypeName.h
hooks/post-receive
More information about the geos-commits mailing list
