[geos-commits] [SCM] GEOS branch main updated. 39629616d518dfa3f5c48365b4baf7017aa1625c
Mon Jun 17 19:33:51 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  39629616d518dfa3f5c48365b4baf7017aa1625c (commit)
      from  5dc668b7f2ca3beb9d188b9dfc6f8f3e4935894a (commit)
revisions in full, below.
commit 39629616d518dfa3f5c48365b4baf7017aa1625c
Author: Dan Baston <dbaston at gmail.com>
Date:   Mon Jun 17 22:33:34 2024 -0400
    C API: Add functions to create curved types (#1108)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 12cabdfe0..0794c1801 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -1204,6 +1204,24 @@ extern "C" {
         return GEOSGeom_createPolygon_r(handle, shell, holes, nholes);
+    Geometry*
+    GEOSGeom_createCircularString(CoordinateSequence* cs)
+        return GEOSGeom_createCircularString_r(handle, cs);
+    Geometry*
+    GEOSGeom_createCompoundCurve(Geometry** curves, unsigned int ngeoms)
+        return GEOSGeom_createCompoundCurve_r(handle, curves, ngeoms);
+    Geometry*
+    GEOSGeom_createCurvePolygon(Geometry* shell, Geometry** holes, unsigned int nholes)
+        return GEOSGeom_createCurvePolygon_r(handle, shell, holes, nholes);
     Geometry*
     GEOSGeom_clone(const Geometry* g)
@@ -1728,6 +1746,24 @@ extern "C" {
         return GEOSGeom_createEmptyPolygon_r(handle);
+    geos::geom::Geometry*
+    GEOSGeom_createEmptyCircularString()
+        return GEOSGeom_createEmptyCircularString_r(handle);
+    GEOSGeom_createEmptyCompoundCurve()
+        return GEOSGeom_createEmptyCompoundCurve_r(handle);
+    GEOSGeom_createEmptyCurvePolygon()
+        return GEOSGeom_createEmptyCurvePolygon_r(handle);
     GEOSGeom_createRectangle(double xmin, double ymin, double xmax,
                             double ymax)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 5db388b24..3327da757 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -763,6 +763,36 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_clone_r(
     GEOSContextHandle_t handle,
     const GEOSGeometry* g);
+/** \see GEOSGeom_createCircularString */
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createCircularString_r(
+    GEOSContextHandle_t handle,
+    GEOSCoordSequence* s);
+/** \see GEOSGeom_createEmptyCircularString */
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCircularString_r(
+    GEOSContextHandle_t handle);
+/** \see GEOSGeom_createCompoundCurve */
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createCompoundCurve_r(
+    GEOSGeometry** curves,
+    unsigned int ncurves);
+/** \see GEOSGeom_createEmptyCompoundCurve */
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCompoundCurve_r(
+/** \see GEOSGeom_createCurvePolygon */
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createCurvePolygon_r(
+    GEOSGeometry* shell,
+    GEOSGeometry** holes,
+    unsigned int nholes);
+/** \see GEOSGeom_createEmptyCurvePolygon */
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCurvePolygon_r(
 /* ========= Memory management ========= */
 /** \see GEOSGeom_destroy */
@@ -2458,6 +2488,68 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_createPolygon(
+* Creates a CircularString geometry.
+* \param s Input coordinate sequence, ownership passes to the geometry
+* \return A newly allocated CircularString geometry. NULL on exception.
+* Caller is responsible for freeing with GEOSGeom_destroy().
+* \since 3.13
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createCircularString(GEOSCoordSequence* s);
+* Creates an empty CircularString geometry.
+* \since 3.13
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCircularString();
+* Creates a CompoundCurve geometry.
+* \param curves A list of geometries that will form the CompoundCurve
+* \param ncurves The number of geometries in the curves list
+* \return A newly allocated CompoundCurve geometry. NULL on exception.
+* \since 3.13
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createCompoundCurve(GEOSGeometry** curves,
+* Creates an empty CompoundCurve geometry.
+* \since 3.13
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCompoundCurve();
+* Creates a CurvePolygon geometry from ring geometries.
+* \param shell A ring that is the exterior ring of the polygon.
+* \param holes An array of rings that are the holes.
+* \param nholes The number of rings in the holes array.
+* \return A newly allocated geometry. NULL on exception.
+* \note The holes argument is an array of GEOSGeometry* objects.
+*       The caller **retains ownership** of the containing array,
+*       but the ownership of the pointed-to objects is transferred
+*       to the returned \ref GEOSGeometry.
+* \since 3.13
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createCurvePolygon(
+* Creates an empty CurvePolygon geometry.
+* \return A newly allocated CurvePolygon geometry. NULL on exception.
+* \since 3.13
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCurvePolygon();
 * Create a geometry collection.
 * \param type The geometry type, enumerated by \ref GEOSGeomTypes
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 2c18d8489..4581860b6 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -31,9 +31,12 @@
 #include <geos/coverage/CoverageValidator.h>
 #include <geos/coverage/CoverageSimplifier.h>
 #include <geos/coverage/CoverageUnion.h>
+#include <geos/geom/CircularString.h>
+#include <geos/geom/CompoundCurve.h>
 #include <geos/geom/Coordinate.h>
 #include <geos/geom/CoordinateSequence.h>
 #include <geos/geom/Curve.h>
+#include <geos/geom/CurvePolygon.h>
 #include <geos/geom/Envelope.h>
 #include <geos/geom/Geometry.h>
 #include <geos/geom/GeometryCollection.h>
@@ -46,6 +49,7 @@
 #include <geos/geom/MultiLineString.h>
 #include <geos/geom/MultiPoint.h>
 #include <geos/geom/MultiPolygon.h>
+#include <geos/geom/MultiSurface.h>
 #include <geos/geom/Point.h>
 #include <geos/geom/Polygon.h>
 #include <geos/geom/PrecisionModel.h>
@@ -2078,6 +2082,12 @@ extern "C" {
             case GEOS_MULTIPOLYGON:
                 g = gf->createMultiPolygon(std::move(vgeoms));
                 break;
+            case GEOS_MULTICURVE:
+                g = gf->createMultiCurve(std::move(vgeoms));
+                break;
+            case GEOS_MULTISURFACE:
+                g = gf->createMultiSurface(std::move(vgeoms));
+                break;
             default:
                 handle->ERROR_MESSAGE("Unsupported type request for GEOSGeom_createCollection_r");
@@ -2991,6 +3001,113 @@ extern "C" {
+    Geometry*
+    GEOSGeom_createCircularString_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs)
+        return execute(extHandle, [&]() {
+            GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+            const GeometryFactory* gf = handle->geomFactory;
+            return gf->createCircularString(std::unique_ptr<CoordinateSequence>(cs)).release();
+    Geometry*
+    GEOSGeom_createEmptyCircularString_r(GEOSContextHandle_t extHandle)
+            return gf->createCircularString(false, false).release();
+    Geometry*
+    GEOSGeom_createCompoundCurve_r(GEOSContextHandle_t extHandle, Geometry** geoms, unsigned int ngeoms)
+        return execute(extHandle, [&]() -> Geometry* {
+            bool invalid_input = false;
+            std::vector<std::unique_ptr<SimpleCurve>> geom_vec(ngeoms);
+            for (std::size_t i = 0; i < ngeoms; i++) {
+                if (SimpleCurve* c = dynamic_cast<SimpleCurve*>(geoms[i])) {
+                    geom_vec[i].reset(c);
+                } else {
+                    delete geoms[i];
+                    invalid_input = true;
+            if (invalid_input) {
+                throw IllegalArgumentException("Input is not a SimpleCurve");
+            return gf->createCompoundCurve(std::move(geom_vec)).release();
+    Geometry*
+    GEOSGeom_createEmptyCompoundCurve_r(GEOSContextHandle_t extHandle)
+            return gf->createCompoundCurve().release();
+    Geometry*
+    GEOSGeom_createCurvePolygon_r(GEOSContextHandle_t extHandle, Geometry* p_shell, Geometry** p_holes, unsigned int nholes)
+            bool good_holes = true, good_shell = true;
+            std::unique_ptr<Curve> shell;
+            std::vector<std::unique_ptr<Curve>> holes(nholes);
+            if (Curve* c = dynamic_cast<Curve*>(p_shell)) {
+                shell.reset(c);
+            } else {
+                good_shell = false;
+                delete p_shell;
+            for (std::size_t i = 0; i < nholes; i++) {
+                if (Curve* c = dynamic_cast<Curve*>(p_holes[i])) {
+                    holes[i].reset(c);
+                } else {
+                    delete p_holes[i];
+            if (good_shell && good_holes) {
+                return gf->createCurvePolygon(std::move(shell), std::move(holes)).release();
+            } else if (!good_shell) {
+                throw IllegalArgumentException("Shell is not a Curve");
+            } else {
+                throw IllegalArgumentException("Hole is not a Curve");
+    Geometry*
+    GEOSGeom_createEmptyCurvePolygon_r(GEOSContextHandle_t extHandle)
+            return gf->createCurvePolygon(false, false).release();
     Geometry*
     GEOSGeom_clone_r(GEOSContextHandle_t extHandle, const Geometry* g)
diff --git a/tests/unit/capi/GEOSGeom_createCircularStringTest.cpp b/tests/unit/capi/GEOSGeom_createCircularStringTest.cpp
new file mode 100644
index 000000000..c4b29f901
--- /dev/null
+++ b/tests/unit/capi/GEOSGeom_createCircularStringTest.cpp
@@ -0,0 +1,44 @@
+#include <tut/tut.hpp>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+struct test_geosgeom_createcircularstring_data : public capitest::utility {};
+typedef test_group<test_geosgeom_createcircularstring_data> group;
+typedef group::object object;
+group test_geosgeom_createcircularstring("capi::GEOSGeom_createCircularString");
+template<>
+template<>
+void object::test<1>
+    GEOSCoordSequence* seq = GEOSCoordSeq_create(3, 2);
+    GEOSCoordSeq_setXY(seq, 0, 1, 2);
+    GEOSCoordSeq_setXY(seq, 1, 4, 5);
+    GEOSCoordSeq_setXY(seq, 2, 9, -2);
+    result_ = GEOSGeom_createCircularString(seq);
+    expected_ = fromWKT("CIRCULARSTRING (1 2, 4 5, 9 -2)");
+    ensure_geometry_equals_identical(result_, expected_);
+template<>
+template<>
+void object::test<2>
+    result_ = GEOSGeom_createEmptyCircularString();
+    ensure(GEOSisEmpty(result_));
+    ensure(!GEOSHasZ(result_));
+    ensure(!GEOSHasM(result_));
+} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
index c0ac20ce7..93474d8cb 100644
--- a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
@@ -172,5 +172,38 @@ void object::test<7>
+// Create MultiCurve
+template<>
+template<>
+void object::test<8>
+    GEOSGeometry* geoms[2];
+    geoms[0] = fromWKT("CIRCULARSTRING (0 0, 1 1, 2 0)");
+    geoms[1] = fromWKT("LINESTRING (2 0, 3 3)");
+    result_ = GEOSGeom_createCollection(GEOS_MULTICURVE, geoms, 2);
+    expected_ = fromWKT("MULTICURVE (CIRCULARSTRING (0 0, 1 1, 2 0), (2 0, 3 3))");
+// Create MultiSurface
+template<>
+template<>
+void object::test<9>
+    geoms[0] = fromWKT("POLYGON ((0 0, 1 0, 1 1, 0 0))");
+    geoms[1] = fromWKT("CURVEPOLYGON (CIRCULARSTRING (10 10, 20 10, 15 15, 10 10))");
+    result_ = GEOSGeom_createCollection(GEOS_MULTISURFACE, geoms, 2);
+    expected_ = fromWKT("MULTISURFACE (((0 0, 1 0, 1 1, 0 0)), CURVEPOLYGON (CIRCULARSTRING (10 10, 20 10, 15 15, 10 10)))");
 } // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_createCompoundCurveTest.cpp b/tests/unit/capi/GEOSGeom_createCompoundCurveTest.cpp
index 000000000..ee3536f32
--- /dev/null
+++ b/tests/unit/capi/GEOSGeom_createCompoundCurveTest.cpp
@@ -0,0 +1,57 @@
+namespace tut {
+// Test Group
+struct test_geosgeom_createcompoundcurve_data : public capitest::utility {};
+typedef test_group<test_geosgeom_createcompoundcurve_data> group;
+group test_geosgeom_createcompoundcurve("capi::GEOSGeom_createCompoundCurve");
+template<>
+template<>
+    GEOSGeometry* c1 = fromWKT("LINESTRING (0 0, 1 1)");
+    GEOSGeometry* c2 = fromWKT("CIRCULARSTRING (1 1, 2 0, 3 1)");
+    GEOSGeometry* curves[] = {c1, c2};
+    result_ = GEOSGeom_createCompoundCurve(curves, 2);
+    expected_ = fromWKT("COMPOUNDCURVE((0 0, 1 1), CIRCULARSTRING (1 1, 2 0, 3 1))");
+// Make sure we take ownership of inputs even in case of failure
+template<>
+template<>
+    GEOSGeometry* c2 = fromWKT("POINT (13 2)");
+    ensure(result_ == nullptr);
+template<>
+template<>
+void object::test<3>
+    result_ = GEOSGeom_createEmptyCompoundCurve();
+} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_createCurvePolygonTest.cpp b/tests/unit/capi/GEOSGeom_createCurvePolygonTest.cpp
index 000000000..5b9a8ff5a
--- /dev/null
+++ b/tests/unit/capi/GEOSGeom_createCurvePolygonTest.cpp
@@ -0,0 +1,58 @@
+namespace tut {
+// Test Group
+struct test_geosgeom_createcurvepolygon_data : public capitest::utility {};
+typedef test_group<test_geosgeom_createcurvepolygon_data> group;
+group test_geosgeom_createcurvepolygon("capi::GEOSGeom_createCurvePolygon");
+template<>
+template<>
+    GEOSGeometry* shell = fromWKT("CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0)");
+    GEOSGeometry* hole = fromWKT("LINESTRING (1 1, 3 3, 3 1, 1 1)");
+    GEOSGeometry* holes[] = {hole};
+    result_ = GEOSGeom_createCurvePolygon(shell, holes, 1);
+    expected_ = fromWKT("CURVEPOLYGON( CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0), (1 1, 3 3, 3 1, 1 1) )");
+// Ownership transferred on error
+template<>
+template<>
+    GEOSGeometry* hole1 = fromWKT("POINT (3 3)");
+    GEOSGeometry* hole2 = fromWKT("LINESTRING (1 1, 3 3, 3 1, 1 1)");
+    GEOSGeometry* holes[] = {hole1, hole2};
+    result_ = GEOSGeom_createCurvePolygon(shell, holes, 2);
+template<>
+template<>
+    result_ = GEOSGeom_createEmptyCurvePolygon();
+} // namespace tut
Summary of changes:
 capi/geos_c.cpp                                    |  36 +++++++
 capi/geos_c.h.in                                   |  92 ++++++++++++++++
 capi/geos_ts_c.cpp                                 | 117 +++++++++++++++++++++
 .../capi/GEOSGeom_createCircularStringTest.cpp     |  44 ++++++++
 tests/unit/capi/GEOSGeom_createCollectionTest.cpp  |  33 ++++++
 .../unit/capi/GEOSGeom_createCompoundCurveTest.cpp |  57 ++++++++++
 .../unit/capi/GEOSGeom_createCurvePolygonTest.cpp  |  58 ++++++++++
 7 files changed, 437 insertions(+)
 create mode 100644 tests/unit/capi/GEOSGeom_createCircularStringTest.cpp
 create mode 100644 tests/unit/capi/GEOSGeom_createCompoundCurveTest.cpp
 create mode 100644 tests/unit/capi/GEOSGeom_createCurvePolygonTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
