[geos-commits] [SCM] GEOS branch main updated. 08a24d9b763dbcde847c338539e4c96d24e84b98
git at osgeo.org
git at osgeo.org
Fri Mar 8 11:23:42 PST 2024
the project "GEOS".
The branch, main has been updated
via 08a24d9b763dbcde847c338539e4c96d24e84b98 (commit)
from bdceea69174e80cf2cc2959d6da8d9dd0e766e3e (commit)
revisions in full, below.
commit 08a24d9b763dbcde847c338539e4c96d24e84b98
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Mar 8 11:23:04 2024 -0800
Add geosop minAreaRectangle op
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index 35b70b5a6..f5fa28b91 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -27,6 +27,7 @@
#include <geos/algorithm/construct/LargestEmptyCircle.h>
#include <geos/algorithm/construct/MaximumInscribedCircle.h>
#include <geos/algorithm/BoundaryNodeRule.h>
+#include <geos/algorithm/MinimumAreaRectangle.h>
#include <geos/algorithm/MinimumDiameter.h>
#include <geos/algorithm/MinimumBoundingCircle.h>
#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
@@ -404,6 +405,14 @@ std::vector<GeometryOpCreator> opRegistry {
return new Result( std::move(res) );
+{"minAreaRectangle", [](std::string name) { return GeometryOp::create(name,
+ catConst,
+ "compute minimum-area rectangle enclosing geometry",
+ [](const std::unique_ptr<Geometry>& geom) {
+ std::unique_ptr<Geometry> res = geos::algorithm::MinimumAreaRectangle::getMinimumRectangle(geom.get());
+ return new Result( std::move(res) );
{"minBoundingCircle", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute minimum bounding circle of geometry",
Summary of changes:
util/geosop/GeometryOp.cpp | 9 +++++++++
1 file changed, 9 insertions(+)
hooks/post-receive
More information about the geos-commits
