[geos-commits] [SCM] GEOS branch 3.12 updated. 57df1921de666cd1a1d540811f321a00d0de85b9
git at osgeo.org
git at osgeo.org
Fri Mar 8 11:28:24 PST 2024
the project "GEOS".
The branch, 3.12 has been updated
via 57df1921de666cd1a1d540811f321a00d0de85b9 (commit)
from 22fe1a6cf245316c93eeec69836c3a5d378ce220 (commit)
revisions in full, below.
commit 57df1921de666cd1a1d540811f321a00d0de85b9
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Mar 8 11:28:05 2024 -0800
Add geosop minAreaRectangle op
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index ccff0bc3f..c6d988df3 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -27,6 +27,7 @@
#include <geos/algorithm/construct/LargestEmptyCircle.h>
#include <geos/algorithm/construct/MaximumInscribedCircle.h>
#include <geos/algorithm/BoundaryNodeRule.h>
+#include <geos/algorithm/MinimumAreaRectangle.h>
#include <geos/algorithm/MinimumDiameter.h>
#include <geos/algorithm/MinimumBoundingCircle.h>
#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
@@ -397,6 +398,14 @@ std::vector<GeometryOpCreator> opRegistry {
return new Result( std::move(res) );
+{"minAreaRectangle", [](std::string name) { return GeometryOp::create(name,
+ catConst,
+ "compute minimum-area rectangle enclosing geometry",
+ [](const std::unique_ptr<Geometry>& geom) {
+ std::unique_ptr<Geometry> res = geos::algorithm::MinimumAreaRectangle::getMinimumRectangle(geom.get());
+ return new Result( std::move(res) );
{"minBoundingCircle", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute minimum bounding circle of geometry",
Summary of changes:
util/geosop/GeometryOp.cpp | 9 +++++++++
1 file changed, 9 insertions(+)
hooks/post-receive
More information about the geos-commits
