[geos-commits] [SCM] GEOS branch main updated. 5e5fc99c7a3d97b12fe76ca43b940abc79f8d389
git at osgeo.org
git at osgeo.org
Tue May 21 11:30:15 PDT 2024
the project "GEOS".
The branch, main has been updated
via 5e5fc99c7a3d97b12fe76ca43b940abc79f8d389 (commit)
from 6043951eef998c8174e5d618bf9e0418601f1e06 (commit)
revisions in full, below.
commit 5e5fc99c7a3d97b12fe76ca43b940abc79f8d389
Author: Sandro Santilli <strk at kbt.io>
Date: Tue May 21 20:27:31 2024 +0200
Drop duplicated code in GEOSGeom_createTest and GEOSOrientationIndexTest
Closes GA-1098
diff --git a/tests/unit/capi/GEOSGeom_createTest.cpp b/tests/unit/capi/GEOSGeom_createTest.cpp
index 6910a74f7..6bfb82c69 100644
--- a/tests/unit/capi/GEOSGeom_createTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createTest.cpp
@@ -22,23 +22,9 @@ namespace tut {
struct test_capigeosgeom_create_data : public capitest::utility
GEOSGeometry* geom1_;
- GEOSContextHandle_t handle_;
- static void
- notice(const char* fmt, ...)
- std::fprintf(stdout, "NOTICE: ");
- va_list ap;
- va_start(ap, fmt);
- std::vfprintf(stdout, fmt, ap);
- va_end(ap);
- std::fprintf(stdout, "\n");
test_capigeosgeom_create_data()
- : geom1_(nullptr), handle_(initGEOS_r(notice, notice))
+ : geom1_(nullptr)
@@ -46,7 +32,6 @@ struct test_capigeosgeom_create_data : public capitest::utility
GEOSGeom_destroy(geom1_);
geom1_ = nullptr;
- finishGEOS_r(handle_);
@@ -66,12 +51,12 @@ template<>
void object::test<1>
- geom1_ = GEOSGeom_createEmptyPoint_r(handle_);
- ensure(0 != GEOSisEmpty_r(handle_, geom1_));
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_POINT);
+ geom1_ = GEOSGeom_createEmptyPoint();
+ ensure(0 != GEOSisEmpty(geom1_));
+ ensure_equals(GEOSGeomTypeId(geom1_), GEOS_POINT);
- ensure_equals(GEOSHasZ_r(handle_, geom1_), 0);
- ensure_equals(GEOSHasM_r(handle_, geom1_), 0);
+ ensure_equals(GEOSHasZ(geom1_), 0);
+ ensure_equals(GEOSHasM(geom1_), 0);
geom1_ = nullptr;
@@ -83,12 +68,12 @@ template<>
void object::test<2>
- geom1_ = GEOSGeom_createEmptyLineString_r(handle_);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_LINESTRING);
+ geom1_ = GEOSGeom_createEmptyLineString();
+ ensure_equals(GEOSGeomTypeId(geom1_), GEOS_LINESTRING);
geom1_ = nullptr;
@@ -101,12 +86,12 @@ template<>
void object::test<3>
- geom1_ = GEOSGeom_createEmptyPolygon_r(handle_);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_POLYGON);
+ geom1_ = GEOSGeom_createEmptyPolygon();
+ ensure_equals(GEOSGeomTypeId(geom1_), GEOS_POLYGON);
geom1_ = nullptr;
@@ -118,12 +103,12 @@ template<>
void object::test<4>
- geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_MULTIPOINT);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTIPOINT);
+ geom1_ = GEOSGeom_createEmptyCollection(GEOS_MULTIPOINT);
+ ensure_equals(GEOSGeomTypeId(geom1_), GEOS_MULTIPOINT);
geom1_ = nullptr;
@@ -135,12 +120,12 @@ template<>
void object::test<5>
- geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_MULTILINESTRING);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTILINESTRING);
+ geom1_ = GEOSGeom_createEmptyCollection(GEOS_MULTILINESTRING);
+ ensure_equals(GEOSGeomTypeId(geom1_), GEOS_MULTILINESTRING);
geom1_ = nullptr;
@@ -152,12 +137,12 @@ template<>
void object::test<6>
- geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_MULTIPOLYGON);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTIPOLYGON);
+ geom1_ = GEOSGeom_createEmptyCollection(GEOS_MULTIPOLYGON);
+ ensure_equals(GEOSGeomTypeId(geom1_), GEOS_MULTIPOLYGON);
geom1_ = nullptr;
@@ -169,12 +154,12 @@ template<>
void object::test<7>
- geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_GEOMETRYCOLLECTION);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_GEOMETRYCOLLECTION);
+ geom1_ = GEOSGeom_createEmptyCollection(GEOS_GEOMETRYCOLLECTION);
+ ensure_equals(GEOSGeomTypeId(geom1_), GEOS_GEOMETRYCOLLECTION);
geom1_ = nullptr;
diff --git a/tests/unit/capi/GEOSOrientationIndexTest.cpp b/tests/unit/capi/GEOSOrientationIndexTest.cpp
index 5a229391c..71e50d6f8 100644
--- a/tests/unit/capi/GEOSOrientationIndexTest.cpp
+++ b/tests/unit/capi/GEOSOrientationIndexTest.cpp
@@ -11,39 +11,15 @@
#include <cstdlib>
#include <memory>
+#include "capi_test_utils.h"
namespace tut {
// Test Group
// Common data used in test cases.
-struct test_capigeosorientationindex_data {
- static void
- va_list ap;
- va_end(ap);
- test_capigeosorientationindex_data()
- : handle_(initGEOS_r(notice, notice))
- ~test_capigeosorientationindex_data()
+struct test_capigeosorientationindex_data : public capitest::utility {};
typedef test_group<test_capigeosorientationindex_data> group;
typedef group::object object;
@@ -60,7 +36,7 @@ template<>
- int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 0, 5, 0);
+ int ret = GEOSOrientationIndex(0, 0, 10, 0, 5, 0);
ensure_equals(ret, 0);
@@ -70,7 +46,7 @@ template<>
- int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 0, 10, 0);
+ int ret = GEOSOrientationIndex(0, 0, 10, 0, 10, 0);
@@ -80,7 +56,7 @@ template<>
- int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 0, 0, 0);
+ int ret = GEOSOrientationIndex(0, 0, 10, 0, 0, 0);
@@ -90,7 +66,7 @@ template<>
- int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 0, -5, 0);
+ int ret = GEOSOrientationIndex(0, 0, 10, 0, -5, 0);
@@ -100,7 +76,7 @@ template<>
- int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 0, 20, 0);
+ int ret = GEOSOrientationIndex(0, 0, 10, 0, 20, 0);
@@ -110,7 +86,7 @@ template<>
- int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 5, 6);
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, 6);
ensure_equals(ret, 1);
@@ -120,7 +96,7 @@ template<>
- int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 5, 20);
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, 20);
@@ -130,7 +106,7 @@ template<>
void object::test<8>
- int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 5, 3);
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, 3);
ensure_equals(ret, -1);
@@ -140,7 +116,7 @@ template<>
void object::test<9>
- int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 5, -2);
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, -2);
@@ -150,7 +126,7 @@ template<>
void object::test<10>
- int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 1000000, 1000001);
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 1000000, 1000001);
@@ -160,7 +136,7 @@ template<>
void object::test<11>
- int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 1000000, 999999);
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 1000000, 999999);
Summary of changes:
tests/unit/capi/GEOSGeom_createTest.cpp | 87 ++++++++++++----------------
tests/unit/capi/GEOSOrientationIndexTest.cpp | 52 +++++------------
2 files changed, 50 insertions(+), 89 deletions(-)
hooks/post-receive
More information about the geos-commits
