[geos-commits] [SCM] GEOS branch main updated. 19455699c7fe48ae54d0bdb4fa914bf40b46e247
Tue May 21 11:35:27 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  19455699c7fe48ae54d0bdb4fa914bf40b46e247 (commit)
      from  5e5fc99c7a3d97b12fe76ca43b940abc79f8d389 (commit)
revisions in full, below.
commit 19455699c7fe48ae54d0bdb4fa914bf40b46e247
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue May 21 20:34:15 2024 +0200
    Format only: drop trailing spaces
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 6e71db3fd..31d1feaef 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -4151,7 +4151,7 @@ extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle(
 * The LEC is determined by the center point and a point indicating the circle radius
 * (which will lie on an obstacle).
 * \n
-* To compute an LEC which lies **wholly** within a polygonal boundary,
+* To compute an LEC which lies **wholly** within a polygonal boundary,
 * include the boundary of the polygon(s) as a linear obstacle.
 * \n
 * The implementation uses a successive-approximation technique over a grid of square cells covering the obstacles and boundary.
@@ -4366,9 +4366,9 @@ extern GEOSGeometry GEOS_DLL *GEOSPolygonize(
     unsigned int ngeoms);
-* Has the same polygonizing behavior as GEOSPolygonize(),
+* Has the same polygonizing behavior as GEOSPolygonize(),
 * but returns a result which is a valid polygonal geometry.
-* The result will not contain any edge-adjacent elements.
+* The result will not contain any edge-adjacent elements.
 * \param geoms Array of linear geometries to polygons. Caller retains ownersihp of both array container and objects.
 * \param ngeoms Size of the geoms array.
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index 310ed82e3..3ceed08d6 100644
--- a/tests/unit/capi/capi_test_utils.h
+++ b/tests/unit/capi/capi_test_utils.h
@@ -96,7 +96,7 @@ namespace capitest {
             char rslt;
             if (g1 == nullptr || g2 == nullptr) {
                 rslt = (g1 == nullptr && g2 == nullptr) ? 1 : 0;
             else {
                 GEOSNormalize(g1);
                 GEOSNormalize(g2);
@@ -112,7 +112,7 @@ namespace capitest {
             char rslt;
             else {
                 rslt = GEOSEqualsExact(g1, g2, tolerance);
@@ -126,13 +126,13 @@ namespace capitest {
             char rslt;
             else {
                 rslt = GEOSEqualsIdentical(g1, g2);
             report_not_equal("ensure_equals_identical", g1, g2, 1e-12, rslt);
             tut::ensure_equals("GEOSEqualsIdentical(g1, g2)", rslt, 1);
         void
         ensure_geometry_equals(GEOSGeometry* g1, GEOSGeometry* g2)
Summary of changes:
 capi/geos_c.h.in                  | 6 +++---
 tests/unit/capi/capi_test_utils.h | 8 ++++----
 2 files changed, 7 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
