[geos-commits] [SCM] GEOS branch main updated. a13c2aab335ac237b89e0748cf74e0c15c8498cc
git at osgeo.org
git at osgeo.org
Wed May 22 17:12:51 PDT 2024
the project "GEOS".
The branch, main has been updated
via a13c2aab335ac237b89e0748cf74e0c15c8498cc (commit)
from 19455699c7fe48ae54d0bdb4fa914bf40b46e247 (commit)
revisions in full, below.
commit a13c2aab335ac237b89e0748cf74e0c15c8498cc
Author: vadimcn <vadimcn at gmail.com>
Date: Wed May 22 17:12:28 2024 -0700
GEOSClipByRect: preserve Z coordinate (#1095)
For [multi]linestrings/linerings, Z coordinate is interpolated
from that of the nearest existing vertices.
For [multi]polygons, Z coordinate of points created on the boundary
is interpolated as above. For interior points, however, it is populated
using the ElevationModel.
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index e9ddc3142..e3f7750af 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -17,6 +17,7 @@
#include <geos/operation/intersection/RectangleIntersection.h>
#include <geos/operation/intersection/Rectangle.h>
#include <geos/operation/intersection/RectangleIntersectionBuilder.h>
+#include <geos/operation/overlayng/ElevationModel.h>
#include <geos/operation/predicate/RectangleIntersects.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/CoordinateSequence.h>
@@ -34,6 +35,7 @@
using geos::operation::intersection::Rectangle;
using geos::operation::intersection::RectangleIntersectionBuilder;
+using geos::operation::overlayng::ElevationModel;
using namespace geos::geom;
using namespace geos::algorithm;
namespace geos {
@@ -62,15 +64,18 @@ different(double x1, double y1, double x2, double y2)
inline
void
-clip_one_edge(double& x1, double& y1, double x2, double y2, double limit)
+clip_one_edge(double& x1, double& y1, double& z1, double x2, double y2, double z2, double limit)
if(x2 == limit) {
y1 = y2;
x1 = x2;
+ z1 = z2;
if(x1 != x2) {
- y1 += (y2 - y1) * (limit - x1) / (x2 - x1);
+ double fraction = (limit - x1) / (x2 - x1);
+ y1 += (y2 - y1) * fraction;
+ z1 += (z2 - z1) * fraction;
x1 = limit;
@@ -86,22 +91,22 @@ clip_one_edge(double& x1, double& y1, double x2, double y2, double limit)
void
-clip_to_edges(double& x1, double& y1,
- double x2, double y2,
+clip_to_edges(double& x1, double& y1, double& z1,
+ double x2, double y2, double z2,
const Rectangle& rect)
if(x1 < rect.xmin()) {
- clip_one_edge(x1, y1, x2, y2, rect.xmin());
+ clip_one_edge(x1, y1, z1, x2, y2, z2, rect.xmin());
else if(x1 > rect.xmax()) {
- clip_one_edge(x1, y1, x2, y2, rect.xmax());
+ clip_one_edge(x1, y1, z1, x2, y2, z2, rect.xmax());
if(y1 < rect.ymin()) {
- clip_one_edge(y1, x1, y2, x2, rect.ymin());
+ clip_one_edge(y1, x1, z1, y2, x2, z2, rect.ymin());
else if(y1 > rect.ymax()) {
- clip_one_edge(y1, x1, y2, x2, rect.ymax());
+ clip_one_edge(y1, x1, z1, y2, x2, z2, rect.ymax());
@@ -153,6 +158,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
double x0 = 0;
double y0 = 0;
+ double z0 = 0;
bool add_start = false;
// Start iterating
@@ -164,6 +170,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
double x = cs[i].x;
double y = cs[i].y;
+ double z = cs[i].z;
Rectangle::Position pos = rect.position(x, y);
if(pos == Rectangle::Outside) {
@@ -199,12 +206,14 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
// Establish new position
x = cs[i].x;
y = cs[i].y;
+ z = cs[i].z;
// Handle all possible cases
x0 = cs[i - 1].x;
y0 = cs[i - 1].y;
- clip_to_edges(x0, y0, x, y, rect);
+ z0 = cs[i - 1].z;
+ clip_to_edges(x0, y0, z0, x, y, z, rect);
if(pos == Rectangle::Inside) {
add_start = true; // x0,y0 must have clipped the rectangle
@@ -218,7 +227,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
// which will then enter the Outside section.
// Clip the other end too
- clip_to_edges(x, y, x0, y0, rect);
+ clip_to_edges(x, y, z, x0, y0, z0, rect);
Rectangle::Position prev_pos = rect.position(x0, y0);
@@ -229,8 +238,8 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
!Rectangle::onSameEdge(prev_pos, pos) // discard if travels along edge
auto coords = detail::make_unique<geom::CoordinateSequence>(2u);
- coords->setAt(Coordinate(x0, y0), 0);
- coords->setAt(Coordinate(x, y), 1);
+ coords->setAt(Coordinate(x0, y0, z0), 0);
+ coords->setAt(Coordinate(x, y, z), 1);
auto line = _gf->createLineString(std::move(coords));
parts.add(line.release());
@@ -267,6 +276,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
while(!go_outside && ++i < n) {
x = cs[i].x;
y = cs[i].y;
+ z = cs[i].z;
Rectangle::Position prev_pos = pos;
@@ -278,7 +288,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
go_outside = true;
// Clip the outside point to edges
- clip_to_edges(x, y, cs[i - 1].x, cs[i - 1].y, rect);
+ clip_to_edges(x, y, z, cs[i - 1].x, cs[i - 1].y, cs[i - 1].z, rect);
// Does the line exit through the inside of the box?
@@ -291,7 +301,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
if(start_index < i - 1 || add_start || through_box) {
auto coords = detail::make_unique<CoordinateSequence>();
if(add_start) {
- coords->add(Coordinate(x0, y0));
+ coords->add(Coordinate(x0, y0, z0));
add_start = false;
//line->addSubLineString(&g, start_index, i-1);
@@ -299,7 +309,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
cs.begin() + static_cast<long>(i));
if(through_box) {
- coords->add(Coordinate(x, y));
+ coords->add(Coordinate(x, y, z));
@@ -316,7 +326,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
//geom::LineString * line = new geom::LineString();
if(add_start) {
//line->addPoint(x0,y0);
add_start = false;
@@ -349,7 +359,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
if(add_start) {
add_start = false;
@@ -521,7 +531,6 @@ RectangleIntersection::clip_polygon_to_polygons(const geom::Polygon* g,
parts.reconnectPolygons(rect);
parts.release(toParts);
@@ -682,7 +691,14 @@ std::unique_ptr<geom::Geometry>
RectangleIntersection::clip(const geom::Geometry& g, const Rectangle& rect)
RectangleIntersection ri(g, rect);
- return ri.clip();
+ std::unique_ptr<geom::Geometry> result = ri.clip();
+ if (g.hasZ()) {
+ std::unique_ptr<ElevationModel> elevModel = ElevationModel::create(g);
+ elevModel->populateZ(*result);
+ return result;
diff --git a/tests/unit/capi/GEOSClipByRectTest.cpp b/tests/unit/capi/GEOSClipByRectTest.cpp
index 13fde6f73..be47a4c0f 100644
--- a/tests/unit/capi/GEOSClipByRectTest.cpp
+++ b/tests/unit/capi/GEOSClipByRectTest.cpp
@@ -42,6 +42,27 @@ struct test_capigeosclipbyrect_data : public capitest::utility {
ensure(equal);
+ void
+ checkClipByRectIdentical(
+ const char* wktInput,
+ double xmin, double ymin,
+ double xmax, double ymax,
+ const char* wktExpected)
+ input_ = fromWKT(wktInput);
+ result_ = GEOSClipByRect(input_, xmin, ymin, xmax, ymax);
+ expected_ = fromWKT(wktExpected);
+ bool equal = GEOSEqualsIdentical(result_, expected_) == 1;
+ if (!equal) {
+ wkt_ = GEOSWKTWriter_write(wktw_, expected_);
+ std::printf("EXP: %s\n", wkt_);
+ GEOSFree(wkt_);
+ wkt_ = GEOSWKTWriter_write(wktw_, result_);
+ std::printf("OBT: %s\n", wkt_);
+ ensure(equal);
typedef test_group<test_capigeosclipbyrect_data> group;
@@ -70,7 +91,7 @@ template<>
template<>
void object::test<2>()
- checkClipByRect(
"POINT(15 15)",
10, 10, 20, 20,
"POINT(15 15)"
@@ -106,7 +127,7 @@ template<>
template<>
void object::test<5>()
- checkClipByRect(
"LINESTRING(15 15, 16 15)",
10, 10, 20, 20,
@@ -130,7 +151,7 @@ template<>
template<>
void object::test<7>()
- checkClipByRect(
"LINESTRING(10 5, 25 20)",
10, 10, 20, 20,
"LINESTRING (15 10, 20 15)"
@@ -191,7 +212,7 @@ template<>
void object::test<12>()
const char* wkt = "POLYGON((1 1, 1 30, 30 30, 30 1, 1 1),(10 10, 20 10, 20 20, 10 20, 10 10))";
- checkClipByRect(
wkt,
0, 0, 40, 40,
wkt);
@@ -202,7 +223,7 @@ template<>
template<>
void object::test<13>()
- checkClipByRect(
"POLYGON((0 0, 0 30, 30 30, 30 0, 0 0),(10 10, 20 10, 20 20, 10 20, 10 10))",
5, 5, 15, 15,
"POLYGON ((5 5, 5 15, 10 15, 10 10, 15 10, 15 5, 5 5))"
@@ -282,6 +303,66 @@ void object::test<17>()
ensure(result_ == nullptr);
+/// Point Z inside
+template<>
+template<>
+void object::test<18>()
+ "POINT Z (15 15 100)",
+ 10, 10, 20, 20,
+/// Line Z inside
+template<>
+template<>
+void object::test<19>()
+ "LINESTRING Z (15 15 0, 16 15 100)",
+ 10, 10, 20, 20,
+/// Line Z splitting rectangle
+template<>
+template<>
+void object::test<20>()
+ "LINESTRING Z (0 15 0, 100 15 100)",
+ 10, 10, 20, 20,
+ "LINESTRING Z (10 15 10, 20 15 20)"
+/// Polygon Z overlapping rectangle
+template<>
+template<>
+void object::test<21>()
+ "POLYGON Z ((0 0 100, 0 30 100, 30 30 100, 30 0 100, 0 0 100),(10 10 100, 20 10 100, 20 20 100, 10 20 100, 10 10 100))",
+ 5, 5, 15, 15,
+ "POLYGON Z ((5 5 100, 5 15 100, 10 15 100, 10 10 100, 15 10 100, 15 5 100, 5 5 100))"
+/// Polygon Z enclosing rectangle
+template<>
+template<>
+void object::test<22>()
+ "POLYGON Z ((0 0 100, 0 30 100, 30 30 100, 30 0 100, 0 0 100))",
+ 5, 5, 15, 15,
+ "POLYGON Z ((5 5 100, 5 15 100, 15 15 100, 15 5 100, 5 5 100))"
} // namespace tut
Summary of changes:
.../intersection/RectangleIntersection.cpp | 54 ++++++++-----
tests/unit/capi/GEOSClipByRectTest.cpp | 91 ++++++++++++++++++++--
2 files changed, 121 insertions(+), 24 deletions(-)
hooks/post-receive
More information about the geos-commits
