[geos-commits] [SCM] GEOS branch main updated. 66beb4176912f3daceba65eabfc5542e6047cb60
git at osgeo.org
git at osgeo.org
Wed May 22 21:14:31 PDT 2024
the project "GEOS".
The branch, main has been updated
via 66beb4176912f3daceba65eabfc5542e6047cb60 (commit)
from a13c2aab335ac237b89e0748cf74e0c15c8498cc (commit)
revisions in full, below.
commit 66beb4176912f3daceba65eabfc5542e6047cb60
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed May 22 21:14:08 2024 -0700
Add CoveragePolygonValidator section performance optimization (#1099)
diff --git a/include/geos/coverage/CoveragePolygon.h b/include/geos/coverage/CoveragePolygon.h
new file mode 100644
index 000000000..e56668c45
--- /dev/null
+++ b/include/geos/coverage/CoveragePolygon.h
@@ -0,0 +1,57 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2024 Martin Davis <mtnclimb at gmail.com>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
+// Forward declarations
+namespace geos {
+namespace geom {
+class Coordinate;
+class Envelope;
+class Polygon;
+using geos::geom::CoordinateXY;
+using geos::geom::Envelope;
+using geos::geom::Polygon;
+using geos::algorithm::locate::IndexedPointInAreaLocator;
+namespace geos { // geos
+namespace coverage { // geos::coverage
+class GEOS_DLL CoveragePolygon {
+ // Members
+ const Polygon* m_polygon;
+ Envelope polyEnv;
+ mutable std::unique_ptr<IndexedPointInAreaLocator> m_locator;
+public:
+ CoveragePolygon(const Polygon* poly);
+ bool intersectsEnv(const Envelope& env) const;
+ bool intersectsEnv(const CoordinateXY& p) const;
+ bool contains(const CoordinateXY& p) const;
+private:
+ IndexedPointInAreaLocator& getLocator() const;
+} // namespace geos::coverage
diff --git a/include/geos/coverage/CoveragePolygonValidator.h b/include/geos/coverage/CoveragePolygonValidator.h
index c0150c895..8f635de38 100644
--- a/include/geos/coverage/CoveragePolygonValidator.h
+++ b/include/geos/coverage/CoveragePolygonValidator.h
@@ -17,6 +17,7 @@
#include <geos/noding/BasicSegmentString.h>
#include <geos/geom/LineSegment.h>
+#include <geos/coverage/CoveragePolygon.h>
#include <geos/coverage/CoverageRing.h>
#include <unordered_map>
@@ -195,11 +196,10 @@ private:
// Members
const Geometry* targetGeom;
std::vector<const Geometry*> adjGeoms;
- std::vector<const Polygon*> m_adjPolygons;
+ //std::vector<const Polygon*> m_adjPolygons;
const GeometryFactory* geomFactory;
double gapWidth = 0.0;
- std::map<std::size_t, std::unique_ptr<IndexedPointInAreaLocator>> adjPolygonLocators;
- // std::vector<std::unique_ptr<CoverageRing>> coverageRingStore;
+ std::vector<std::unique_ptr<CoveragePolygon>> m_adjCovPolygons;
std::deque<CoverageRing> coverageRingStore;
std::vector<std::unique_ptr<CoordinateSequence>> localCoordinateSequences;
std::deque<CoverageRingSegment> coverageRingSegmentStore;
@@ -273,6 +273,8 @@ public:
private:
+ static std::vector<std::unique_ptr<CoveragePolygon>>
+ toCoveragePolygons(const std::vector<const Polygon*> polygons);
static std::vector<const Polygon*> extractPolygons(std::vector<const Geometry*>& geoms);
/* private */
@@ -336,34 +338,26 @@ private:
* to an adjacent polygon.
* @param targetRings the rings with segments to test
- * @param adjPolygons the adjacent polygons
+ * @param adjCovPolygons the adjacent polygons
void markInvalidInteriorSegments(
std::vector<CoverageRing*>& targetRings,
- std::vector<const Polygon*>& adjPolygons);
+ std::vector<std::unique_ptr<CoveragePolygon>>& adjCovPolygons);
+ void markInvalidInteriorSection(
+ CoverageRing& ring,
+ std::size_t iStart,
+ std::size_t iEnd,
+ std::vector<std::unique_ptr<CoveragePolygon>>& adjCovPolygons );
+ void markInvalidInteriorSegment(
+ CoverageRing& ring, std::size_t i, CoveragePolygon* adjPoly);
void checkTargetRings(
std::vector<CoverageRing*>& adjRngs,
const Envelope& targetEnv);
- * Tests if a coordinate is in the interior of some adjacent polygon.
- * Uses the cached Point-In-Polygon indexed locators, for performance.
- * @param p the coordinate to test
- * @param adjPolygons the list of polygons
- * @return true if the point is in the interior
- bool isInteriorVertex(const Coordinate& p,
- bool polygonContainsPoint(std::size_t index,
- const Polygon* poly, const Coordinate& pt);
- IndexedPointInAreaLocator* getLocator(std::size_t index, const Polygon* poly);
std::unique_ptr<Geometry> createInvalidLines(std::vector<CoverageRing*>& rings);
std::vector<CoverageRing*> createRings(const Geometry* geom);
diff --git a/include/geos/coverage/CoverageRing.h b/include/geos/coverage/CoverageRing.h
index 45a348e9f..76bd44aaf 100644
--- a/include/geos/coverage/CoverageRing.h
+++ b/include/geos/coverage/CoverageRing.h
@@ -83,6 +83,8 @@ public:
CoverageRing(const LinearRing* ring, bool isShell);
+ geom::Envelope getEnvelope(std::size_t start, std::size_t end);
* Tests if all rings have known status (matched or invalid)
* for all segments.
diff --git a/src/coverage/CoveragePolygon.cpp b/src/coverage/CoveragePolygon.cpp
index 000000000..46ee29c7c
--- /dev/null
+++ b/src/coverage/CoveragePolygon.cpp
@@ -0,0 +1,76 @@
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/Envelope.h>
+#include <geos/geom/Location.h>
+#include <geos/geom/Polygon.h>
+using geos::geom::Location;
+namespace coverage { // geos.coverage
+/* public */
+CoveragePolygon::CoveragePolygon(const Polygon* poly)
+ : m_polygon(poly)
+ //-- cache polygon envelope for maximum performance
+ polyEnv = *(poly->getEnvelopeInternal());
+/* public */
+bool
+CoveragePolygon::intersectsEnv(const Envelope& env) const
+ return polyEnv.intersects(env);
+/* public */
+bool
+CoveragePolygon::intersectsEnv(const CoordinateXY& p) const
+ return polyEnv.intersects(p);
+/* public */
+bool
+CoveragePolygon::contains(const CoordinateXY& p) const
+ if (! intersectsEnv(p))
+ return false;
+ IndexedPointInAreaLocator& pia = getLocator();
+ return Location::INTERIOR == pia.locate(&p);
+/* private */
+IndexedPointInAreaLocator&
+CoveragePolygon::getLocator() const
+ if (m_locator == nullptr) {
+ m_locator = std::make_unique<IndexedPointInAreaLocator>(*m_polygon);
+ return *m_locator;
+} // namespace geos.coverage
diff --git a/src/coverage/CoveragePolygonValidator.cpp b/src/coverage/CoveragePolygonValidator.cpp
index a99643903..7690e2542 100644
--- a/src/coverage/CoveragePolygonValidator.cpp
+++ b/src/coverage/CoveragePolygonValidator.cpp
@@ -13,7 +13,9 @@
#include <geos/coverage/CoveragePolygonValidator.h>
#include <geos/coverage/InvalidSegmentDetector.h>
#include <geos/algorithm/Orientation.h>
@@ -31,7 +33,7 @@
using geos::algorithm::Orientation;
-using geos::geom::Coordinate;
using geos::geom::Geometry;
using geos::geom::GeometryFactory;
@@ -88,10 +90,10 @@ CoveragePolygonValidator::setGapWidth(double p_gapWidth)
CoveragePolygonValidator::validate()
- m_adjPolygons = extractPolygons(adjGeoms);
+ std::vector<const Polygon*> adjPolygons = extractPolygons(adjGeoms);
+ m_adjCovPolygons = toCoveragePolygons(adjPolygons);
std::vector<CoverageRing*> targetRings = createRings(targetGeom);
- std::vector<CoverageRing*> adjRings = createRings(m_adjPolygons);
+ std::vector<CoverageRing*> adjRings = createRings(adjPolygons);
* Mark matching segments first.
@@ -106,6 +108,15 @@ CoveragePolygonValidator::validate()
return createInvalidLines(targetRings);
+/* private static */
+std::vector<std::unique_ptr<CoveragePolygon>>
+CoveragePolygonValidator::toCoveragePolygons(const std::vector<const Polygon*> polygons) {
+ std::vector<std::unique_ptr<CoveragePolygon>> covPolys;
+ for (const Polygon* poly : polygons) {
+ covPolys.push_back( std::make_unique<CoveragePolygon>(poly) );
+ return covPolys;
/* private */
void
@@ -132,10 +143,9 @@ CoveragePolygonValidator::checkTargetRings(
* Do further checks to see if any of them are are invalid.
markInvalidInteractingSegments(targetRings, adjRings, gapWidth);
- markInvalidInteriorSegments(targetRings, m_adjPolygons);
+ markInvalidInteriorSegments(targetRings, m_adjCovPolygons);
CoveragePolygonValidator::extractPolygons(std::vector<const Geometry*>& geoms)
@@ -246,85 +256,63 @@ CoveragePolygonValidator::markInvalidInteractingSegments(
void
CoveragePolygonValidator::markInvalidInteriorSegments(
for (CoverageRing* ring : targetRings) {
- for (std::size_t i = 0; i < ring->size() - 1; i++) {
- //-- skip check for segments with known state.
- if (ring->isKnown(i))
- continue;
+ std::size_t stride = 1000; //-- RING_SECTION_STRIDE;
+ for (std::size_t i = 0; i < ring->size() - 1; i += stride) {
+ std::size_t iEnd = i + stride;
+ if (iEnd >= ring->size())
+ iEnd = ring->size() - 1;
+ markInvalidInteriorSection(*ring, i, iEnd, adjCovPolygons);
- * Check if vertex is in interior of an adjacent polygon.
- * If so, the segments on either side are in the interior.
- * Mark them invalid, unless they are already matched.
- const Coordinate& p = ring->getCoordinate(i);
- if (isInteriorVertex(p, adjPolygons)) {
- ring->markInvalid(i);
- //-- previous segment may be interior (but may also be matched)
- std::size_t iPrev = i == 0 ? ring->size()-2 : i-1;
- if (! ring->isKnown(iPrev))
- ring->markInvalid(iPrev);
+/* private */
+void
+CoveragePolygonValidator::markInvalidInteriorSection(
+ std::size_t iEnd,
+ Envelope sectionEnv = ring.getEnvelope(iStart, iEnd);
+ //TODO: is it worth indexing polygons?
+ for (auto& adjPoly : adjCovPolygons) {
+ if (adjPoly->intersectsEnv(sectionEnv)) {
+ //-- test vertices in section
+ for (std::size_t i = iStart; i < iEnd; i++) {
+ markInvalidInteriorSegment(ring, i, adjPoly.get());
/* private */
-bool
-CoveragePolygonValidator::isInteriorVertex(
- const Coordinate& p,
+void
+CoveragePolygonValidator::markInvalidInteriorSegment(
+ //-- skip check for segments with known state.
+ if (ring.isKnown(i))
+ return;
- * There should not be too many adjacent polygons,
- * and hopefully not too many segments with unknown status
- * so a linear scan should not be too inefficient
+ * Check if vertex is in interior of an adjacent polygon.
+ * If so, the segments on either side are in the interior.
+ * Mark them invalid, unless they are already matched.
- //TODO: try a spatial index?
- for (std::size_t i = 0; i < adjPolygons.size(); i++) {
- const Polygon* adjPoly = adjPolygons[i];
- if (polygonContainsPoint(i, adjPoly, p))
- return true;
- return false;
-/* private */
-bool
-CoveragePolygonValidator::polygonContainsPoint(std::size_t index,
- if (! poly->getEnvelopeInternal()->intersects(pt))
- return false;
- IndexedPointInAreaLocator* pia = getLocator(index, poly);
- return Location::INTERIOR == pia->locate(&pt);
-/* private */
-IndexedPointInAreaLocator*
-CoveragePolygonValidator::getLocator(std::size_t index, const Polygon* poly)
- auto it = adjPolygonLocators.find(index);
- // found locator already constructed
- if (it != adjPolygonLocators.end()) {
- return (it->second).get();
- // construct new locator for this polygon
- else {
- IndexedPointInAreaLocator* ipia = new IndexedPointInAreaLocator(*poly);
- adjPolygonLocators.emplace(std::piecewise_construct,
- std::forward_as_tuple(index),
- std::forward_as_tuple(ipia));
- return ipia;
+ const CoordinateXY& p = ring.getCoordinate(i);
+ if (adjPoly->contains(p)) {
+ ring.markInvalid(i);
+ //-- previous segment may be interior (but may also be matched)
+ std::size_t iPrev = i == 0 ? ring.size()-2 : i-1;
+ if (! ring.isKnown(iPrev))
+ ring.markInvalid(iPrev);
/* private */
CoveragePolygonValidator::createInvalidLines(std::vector<CoverageRing*>& rings)
diff --git a/src/coverage/CoverageRing.cpp b/src/coverage/CoverageRing.cpp
index 8f258d9d5..9a331291f 100644
--- a/src/coverage/CoverageRing.cpp
+++ b/src/coverage/CoverageRing.cpp
@@ -73,6 +73,16 @@ CoverageRing::CoverageRing(const LinearRing* ring, bool isShell)
algorithm::Orientation::isCCW(ring->getCoordinatesRO()) != isShell)
+/* public */
+geom::Envelope CoverageRing::getEnvelope(std::size_t start, std::size_t end)
+ geom::Envelope env;
+ for (std::size_t i = start; i < end; i++) {
+ env.expandToInclude(getCoordinate(i));
+ return env;
/* public */
bool
Summary of changes:
include/geos/coverage/CoveragePolygon.h | 57 +++++++++++
include/geos/coverage/CoveragePolygonValidator.h | 38 +++----
include/geos/coverage/CoverageRing.h | 2 +
src/coverage/CoveragePolygon.cpp | 76 ++++++++++++++
src/coverage/CoveragePolygonValidator.cpp | 124 ++++++++++-------------
src/coverage/CoverageRing.cpp | 10 ++
6 files changed, 217 insertions(+), 90 deletions(-)
create mode 100644 include/geos/coverage/CoveragePolygon.h
create mode 100644 src/coverage/CoveragePolygon.cpp
hooks/post-receive
More information about the geos-commits
