[geos-commits] [SCM] GEOS branch main updated. fc95e4b8f8490f952a3d3759684dc1c3330f5f83
git at osgeo.org
git at osgeo.org
Mon Nov 18 14:43:02 PST 2024
the project "GEOS".
The branch, main has been updated
via fc95e4b8f8490f952a3d3759684dc1c3330f5f83 (commit)
via 32a3bf4923b6c1c8ce38f21260d6e1a02d0bbb2f (commit)
from dc4e7b2b2e6f3d61f0bd1881015a250ebd988606 (commit)
revisions in full, below.
commit fc95e4b8f8490f952a3d3759684dc1c3330f5f83
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Nov 18 12:16:49 2024 -0500
BoundaryOp: Preserve M values in (Multi)LineString inputs
Fixes https://github.com/libgeos/geos/issues/1195
diff --git a/src/operation/BoundaryOp.cpp b/src/operation/BoundaryOp.cpp
index b407a2a41..c0c452c45 100644
--- a/src/operation/BoundaryOp.cpp
+++ b/src/operation/BoundaryOp.cpp
@@ -139,7 +139,9 @@ BoundaryOp::boundaryMultiLineString(const geom::MultiLineString& mLine)
// return Point or MultiPoint
if (bdyPts->size() == 1) {
- return std::unique_ptr<Geometry>(m_geomFact.createPoint(bdyPts->getAt(0)));
+ return bdyPts->applyAt(0, [this](const auto& c) {
+ return m_geomFact.createPoint(c);
// this handles 0 points case as well
return std::unique_ptr<Geometry>(m_geomFact.createMultiPoint(*bdyPts));
@@ -148,8 +150,8 @@ BoundaryOp::boundaryMultiLineString(const geom::MultiLineString& mLine)
std::unique_ptr<CoordinateSequence>
BoundaryOp::computeBoundaryCoordinates(const geom::MultiLineString& mLine)
- auto bdyPts = detail::make_unique<CoordinateSequence>();
- std::map<Coordinate, int> endpointMap;
+ auto bdyPts = detail::make_unique<CoordinateSequence>(0, mLine.hasZ(), mLine.hasM());
+ std::map<geom::CoordinateXYZM, int> endpointMap;
for (std::size_t i = 0; i < mLine.getNumGeometries(); i++) {
const LineString* line = mLine.getGeometryN(i);
@@ -158,14 +160,20 @@ BoundaryOp::computeBoundaryCoordinates(const geom::MultiLineString& mLine)
continue;
- endpointMap[line->getCoordinateN(0)]++;
- endpointMap[line->getCoordinateN(line->getNumPoints() - 1)]++;
+ const CoordinateSequence& pts = *line->getCoordinatesRO();
+ geom::CoordinateXYZM start;
+ geom::CoordinateXYZM end;
+ pts.getAt(0, start);
+ pts.getAt(pts.size() - 1, end);
+ endpointMap[start]++;
+ endpointMap[end]++;
- for (const auto& entry: endpointMap) {
- auto valence = entry.second;
+ for (const auto& [coord, valence] : endpointMap) {
if (m_bnRule.isInBoundary(valence)) {
- bdyPts->add(entry.first);
+ bdyPts->add(coord);
diff --git a/tests/unit/capi/GEOSBoundaryTest.cpp b/tests/unit/capi/GEOSBoundaryTest.cpp
index d24bd558f..17f4af46e 100644
--- a/tests/unit/capi/GEOSBoundaryTest.cpp
+++ b/tests/unit/capi/GEOSBoundaryTest.cpp
@@ -41,5 +41,27 @@ void object::test<2>()
ensure(result_ == nullptr);
+template<>
+template<>
+void object::test<3>()
+ input_ = fromWKT("MULTILINESTRING M ((10 11 3, 20 21 4), (20 21 4, 32 21 3))");
+ result_ = GEOSBoundary(input_);
+ expected_ = fromWKT("MULTIPOINT M ((10 11 3), (32 21 3))");
+ ensure_geometry_equals_identical(result_, expected_);
+template<>
+template<>
+void object::test<4>()
+ input_ = fromWKT("POLYGON M ((0 0 0, 1 0 1, 1 1 2, 0 1 3, 0 0 4))");
+ expected_ = fromWKT("LINESTRING M (0 0 0, 1 0 1, 1 1 2, 0 1 3, 0 0 4)");
} // namespace tut
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index 803c51cf2..aef573565 100644
--- a/tests/unit/capi/capi_test_utils.h
+++ b/tests/unit/capi/capi_test_utils.h
@@ -72,7 +72,10 @@ namespace capitest {
fromWKT(const char* wkt)
GEOSGeometry* g = GEOSGeomFromWKT(wkt);
- tut::ensure(g != nullptr);
+ if (g == nullptr) {
+ std::string message = "WKT is invalid: " + std::string(wkt);
+ tut::ensure(message, g != nullptr);
return g;
commit 32a3bf4923b6c1c8ce38f21260d6e1a02d0bbb2f
Date: Mon Nov 18 08:39:42 2024 -0500
CoordinateSequence: Add applyAt method
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index b49b8693f..c135ce18d 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -679,6 +679,16 @@ public:
+ template<typename F>
+ auto applyAt(size_t i, F&& fun) const {
+ switch(getCoordinateType()) {
+ case CoordinateType::XYZ: return fun(getAt<Coordinate>(i));
+ case CoordinateType::XYM: return fun(getAt<CoordinateXYM>(i));
+ case CoordinateType::XYZM: return fun(getAt<CoordinateXYZM>(i));
+ default: return fun(getAt<CoordinateXY>(i));
void forEach(F&& fun) const {
diff --git a/src/geom/SimpleCurve.cpp b/src/geom/SimpleCurve.cpp
index 882fb9402..952d207d0 100644
--- a/src/geom/SimpleCurve.cpp
+++ b/src/geom/SimpleCurve.cpp
@@ -252,16 +252,9 @@ SimpleCurve::getPointN(std::size_t n) const
assert(getFactory());
assert(points.get());
- if (hasM() || hasZ()) {
- CoordinateXYZM c;
- points->getAt(n, c);
+ return points->applyAt(n, [this](const auto& c) {
return getFactory()->createPoint(c);
- else {
- CoordinateXY c;
- return getFactory()->createPoint(c);
std::unique_ptr<Point>
Summary of changes:
include/geos/geom/CoordinateSequence.h | 10 ++++++++++
src/geom/SimpleCurve.cpp | 11 ++---------
src/operation/BoundaryOp.cpp | 24 ++++++++++++++++--------
tests/unit/capi/GEOSBoundaryTest.cpp | 22 ++++++++++++++++++++++
tests/unit/capi/capi_test_utils.h | 5 ++++-
5 files changed, 54 insertions(+), 18 deletions(-)
hooks/post-receive
More information about the geos-commits
