[geos-commits] [SCM] GEOS branch main updated. 96875120762bf622134adc46cec79d68edf19bfa
git at osgeo.org
git at osgeo.org
Tue Nov 19 12:51:42 PST 2024
the project "GEOS".
The branch, main has been updated
via 96875120762bf622134adc46cec79d68edf19bfa (commit)
from fc95e4b8f8490f952a3d3759684dc1c3330f5f83 (commit)
revisions in full, below.
commit 96875120762bf622134adc46cec79d68edf19bfa
Author: Mike Taves <mwtoews at gmail.com>
Date: Wed Nov 20 09:51:21 2024 +1300
Fix typos, add CI job to help catch them (#1194)
diff --git a/.codespellrc b/.codespellrc
new file mode 100644
index 000000000..3dc9e184d
--- /dev/null
+++ b/.codespellrc
@@ -0,0 +1,3 @@
+[codespell]
+skip = ./tools/astyle,./src/deps,./web/themes,./util/geosop/cxxopts.hpp
+ignore-words = ./tools/codespell.ignore
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 1900ba626..f0b0aafb2 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -524,6 +524,7 @@ jobs:
set -e
sudo -E apt-get update
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
+ python3 -m pip install --disable-pip-version-check --user codespell
- name: 'Check Out'
uses: actions/checkout at v4
@@ -531,6 +532,9 @@ jobs:
- name: 'cppcheck'
run: ./tools/cppcheck.sh
+ - name: codespell
+ run: codespell
+ # false-positives can be added to tools/codespell.ignore
cmake-subproject:
name: 'CMake Subproject'
diff --git a/NEWS.md b/NEWS.md
index 26dbae7be..56cfc634b 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -31,7 +31,7 @@
- Breaking Changes:
- Zero-length linestrings (eg LINESTRING(1 1, 1 1)) are now treated as equivalent to points (POINT(1 1)) in boolean predicates
- - CMake 3.15 or later is requried (GH-1143, Mike Taves)
+ - CMake 3.15 or later is required (GH-1143, Mike Taves)
- Fixes/Improvements:
- WKTReader: Points with all-NaN coordinates are not considered empty anymore (GH-927, Casper van der Wel)
@@ -935,7 +935,7 @@ See 3.7.0 notes
- Added Polygonizer and LineMerger classes.
- python wrapper examples
- General cleanup / warnings removal
-- cleaner win32 / older copilers builds
+- cleaner win32 / older compilers builds
- Reduced heap allocations
- debian package builder scripts
- reduction of standard C lib headers dependency
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 5ac8a5619..3d052d518 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -719,7 +719,7 @@ public:
* and dissolving the linework.
* - Unioning a set of [Polygons](@ref Polygon) will always
* return a polygonal geometry (unlike Geometry::Union(const Geometry* other) const),
- * which may return geometrys of lower dimension if a topology collapse
+ * which may return geometries of lower dimension if a topology collapse
* occurred.
* @return the union geometry
diff --git a/include/geos/geom/Surface.h b/include/geos/geom/Surface.h
index 7b1bb6ff3..d2dcb384e 100644
--- a/include/geos/geom/Surface.h
+++ b/include/geos/geom/Surface.h
@@ -100,7 +100,7 @@ protected:
int
compareToSameClass(const Geometry* g) const override;
- // Helper method allowing PolygonImpl to use GeometryFactory without cirular imports
+ // Helper method allowing PolygonImpl to use GeometryFactory without circular imports
static std::unique_ptr<Geometry> createEmptyRing(const GeometryFactory&);
virtual Curve* getExteriorRing() = 0;
diff --git a/include/geos/io/WKTWriter.h b/include/geos/io/WKTWriter.h
index 105b63739..6acaac301 100644
--- a/include/geos/io/WKTWriter.h
+++ b/include/geos/io/WKTWriter.h
@@ -107,7 +107,7 @@ public:
* Generates the WKT for a N-point <code>LineString</code>.
- * @param seq the sequence to outpout
+ * @param seq the sequence to output
* @return the WKT
diff --git a/include/geos/noding/IteratedNoder.h b/include/geos/noding/IteratedNoder.h
index 5f231fcc7..3e82c8aa1 100644
--- a/include/geos/noding/IteratedNoder.h
+++ b/include/geos/noding/IteratedNoder.h
@@ -104,7 +104,7 @@ public:
/** \brief
- * Fully nodes a list of {@link SegmentString}s, i.e. peforms noding iteratively
+ * Fully nodes a list of {@link SegmentString}s, i.e. performs noding iteratively
* until no intersections are found between segments.
* Maintains labelling of edges correctly through the noding.
diff --git a/include/geos/operation/overlayng/OverlayUtil.h b/include/geos/operation/overlayng/OverlayUtil.h
index bc0dbadfb..9c18e5917 100644
--- a/include/geos/operation/overlayng/OverlayUtil.h
+++ b/include/geos/operation/overlayng/OverlayUtil.h
@@ -75,7 +75,7 @@ private:
* are:
* - INTERSECTION: result envelope is the intersection of the input envelopes
- * - DIFERENCE: result envelope is the envelope of the A input geometry
+ * - DIFFERENCE: result envelope is the envelope of the A input geometry
* Otherwise, <code>null</code> is returned to indicate full extent.
diff --git a/include/geos/planargraph/DirectedEdge.h b/include/geos/planargraph/DirectedEdge.h
index 38d096830..5d1d44358 100644
--- a/include/geos/planargraph/DirectedEdge.h
+++ b/include/geos/planargraph/DirectedEdge.h
@@ -84,7 +84,7 @@ public:
* to the given parentEdges vector.
* @note Parents are pushed to the parentEdges vector, make sure
- * it is empty if index-based corrispondence is important.
+ * it is empty if index-based correspondence is important.
static void toEdges(std::vector<DirectedEdge*>& dirEdges,
std::vector<Edge*>& parentEdges);
diff --git a/include/geos/vend/json.hpp b/include/geos/vend/json.hpp
index c81c5c510..315e0a35b 100644
--- a/include/geos/vend/json.hpp
+++ b/include/geos/vend/json.hpp
@@ -5091,7 +5091,7 @@ struct wide_string_input_helper<BaseInputAdapter, 2>
-// Wraps another input apdater to convert wide character types into individual bytes.
+// Wraps another input adapter to convert wide character types into individual bytes.
template<typename BaseInputAdapter, typename WideCharType>
class wide_string_input_adapter
diff --git a/src/algorithm/InteriorPointArea.cpp b/src/algorithm/InteriorPointArea.cpp
index 55fbfe6d5..026310d20 100644
--- a/src/algorithm/InteriorPointArea.cpp
+++ b/src/algorithm/InteriorPointArea.cpp
@@ -38,7 +38,7 @@ using namespace geos::geom;
namespace geos {
namespace algorithm { // geos.algorithm
-// file statics
+// file statistics
namespace {
double
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index f454a7ac7..3e634d6e9 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -45,7 +45,7 @@ namespace algorithm { // geos.algorithm
MinimumBoundingCircle::getCircle()
- //TODO: ensure the output circle contains the extermal points.
+ //TODO: ensure the output circle contains the extremal points.
//TODO: or maybe even ensure that the returned geometry contains ALL the input points?
compute();
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index b5c77570c..9b24f7929 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -318,4 +318,4 @@ Point::getCoordinatesRO() const
} // namespace geos::geom
-} // namesapce geos
+} // namespace geos
diff --git a/src/geomgraph/Edge.cpp b/src/geomgraph/Edge.cpp
index 6212703a3..3b4ea5d51 100644
--- a/src/geomgraph/Edge.cpp
+++ b/src/geomgraph/Edge.cpp
@@ -55,7 +55,7 @@ using namespace geos::algorithm;
* Updates an IM from the label for an edge.
- * Handles edges from both L and A geometrys.
+ * Handles edges from both L and A geometries.
void
Edge::updateIM(const Label& lbl, IntersectionMatrix& im)
diff --git a/src/index/bintree/NodeBase.cpp b/src/index/bintree/NodeBase.cpp
index c35296fb9..30331aa5c 100644
--- a/src/index/bintree/NodeBase.cpp
+++ b/src/index/bintree/NodeBase.cpp
@@ -26,7 +26,7 @@ namespace index { // geos.index
namespace bintree { // geos.index.bintree
- * Returns the index of the subnode that wholely contains the given interval.
+ * Returns the index of the subnode that wholly contains the given interval.
* If none does, returns -1.
int
diff --git a/src/operation/buffer/BufferCurveSetBuilder.cpp b/src/operation/buffer/BufferCurveSetBuilder.cpp
index 41038d74e..4fc725f96 100644
--- a/src/operation/buffer/BufferCurveSetBuilder.cpp
+++ b/src/operation/buffer/BufferCurveSetBuilder.cpp
@@ -117,7 +117,7 @@ BufferCurveSetBuilder::addCurve(CoordinateSequence* coord,
// coord ownership transferred to SegmentString
SegmentString* e = new NodedSegmentString(coord, coord->hasZ(), coord->hasM(), newlabel);
- // SegmentString doesnt own the sequence, so we need to delete in
+ // SegmentString doesn't own the sequence, so we need to delete in
// the destructor
newLabels.push_back(newlabel);
curveList.push_back(e);
diff --git a/src/operation/relate/RelateComputer.cpp b/src/operation/relate/RelateComputer.cpp
index 90a18ed44..3971a7b99 100644
--- a/src/operation/relate/RelateComputer.cpp
+++ b/src/operation/relate/RelateComputer.cpp
@@ -181,7 +181,7 @@ RelateComputer::computeIM()
* Now process improper intersections
- * (eg where one or other of the geometrys has a vertex at the
+ * (eg where one or other of the geometries has a vertex at the
* intersection point)
* We need to compute the edge graph at all nodes to determine
* the IM.
diff --git a/src/operation/relateng/RelateNG.cpp b/src/operation/relateng/RelateNG.cpp
index 9338123ff..8342fe868 100644
--- a/src/operation/relateng/RelateNG.cpp
+++ b/src/operation/relateng/RelateNG.cpp
@@ -534,7 +534,7 @@ RelateNG::computeLineEnds(
continue;
const LineString* line = static_cast<const LineString*>(elem);
- //TODO: add optimzation to skip disjoint elements once exterior point found
+ //TODO: add optimization to skip disjoint elements once exterior point found
const CoordinateXY& e0 = line->getCoordinatesRO()->getAt(0);
hasExteriorIntersection |= computeLineEnd(geom, isA, &e0, geomTarget, topoComputer);
if (topoComputer.isResultKnown()) {
diff --git a/src/operation/relateng/TopologyComputer.cpp b/src/operation/relateng/TopologyComputer.cpp
index 1c164d635..0b6782e42 100644
--- a/src/operation/relateng/TopologyComputer.cpp
+++ b/src/operation/relateng/TopologyComputer.cpp
@@ -231,7 +231,7 @@ TopologyComputer::addIntersection(NodeSection* a, NodeSection* b)
// we run this first (unlike JTS) in case the subsequent test throws
// an exception and the NodeSection pointers are not correctly
// saved in the memory managed store on the NodeSections, causing
- // a small memeory leak
+ // a small memory leak
addNodeSections(a, b);
if (! a->isSameGeometry(b)) {
diff --git a/tests/unit/capi/GEOSGeom_transformXYZTest.cpp b/tests/unit/capi/GEOSGeom_transformXYZTest.cpp
index c696b4da5..330696028 100644
--- a/tests/unit/capi/GEOSGeom_transformXYZTest.cpp
+++ b/tests/unit/capi/GEOSGeom_transformXYZTest.cpp
@@ -312,7 +312,7 @@ void object::test<14>() {
ensure_equals(toWKT(result_), "CIRCULARSTRING Z (0 0 0, 2 3 4, 4 3 0)");
-// callback should succed on 2D geometry
+// callback should succeed on 2D geometry
template <>
template <>
void object::test<15>() {
diff --git a/tests/unit/geom/util/GeometryFixerTest.cpp b/tests/unit/geom/util/GeometryFixerTest.cpp
index bc10f61d6..908552dc5 100644
--- a/tests/unit/geom/util/GeometryFixerTest.cpp
+++ b/tests/unit/geom/util/GeometryFixerTest.cpp
@@ -70,8 +70,8 @@ struct test_geometryfixer_data {
std::unique_ptr<Geometry> expected = wktreader_.read(wktExpected);
- // std::cout << "Reslt: " << wktwriter_.write(actual.get()) << std::endl;
- // std::cout << "Expct: " << wktwriter_.write(expected.get()) << std::endl;
+ // std::cout << "Result: " << wktwriter_.write(actual.get()) << std::endl;
+ // std::cout << "Expect: " << wktwriter_.write(expected.get()) << std::endl;
ensure("Result is invalid", actual->isValid());
ensure_equals_geometry(expected.get(), actual.get());
diff --git a/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml b/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
index b8a8cb474..d546a9d62 100644
--- a/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
+++ b/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
@@ -132,7 +132,7 @@
<case>
<desc>mA/L
A has 2 shells touching at one vertex and one non-vertex.
- B passes between the shells, but is wholely contained
+ B passes between the shells, but is wholly contained
</desc>
<a>
MULTIPOLYGON (((100 30, 30 110, 150 110, 100 30)),
@@ -204,7 +204,7 @@
</case>
<case>
- <desc>A/L - wholely contained
+ <desc>A/L - wholly contained
</desc>
<a> POLYGON ((10 10, 60 100, 110 10, 10 10))
</a>
diff --git a/tools/codespell.ignore b/tools/codespell.ignore
index 000000000..896a43d83
--- /dev/null
+++ b/tools/codespell.ignore
@@ -0,0 +1,17 @@
+parms
+Geometrys
+deques
+extracter
+implementors
+translater
+thirdparty
+crate
+eiter
+examplar
+nempty
+ba
+te
+seh
+bLoc
+aLo
+Wel
diff --git a/web/content/posts/2024-08-13-relateng.md b/web/content/posts/2024-08-13-relateng.md
index 77906c1ba..4cdcd8ebb 100644
--- a/web/content/posts/2024-08-13-relateng.md
+++ b/web/content/posts/2024-08-13-relateng.md
@@ -30,5 +30,5 @@ The RelateNG work has been run against the entire regression suite and returns e
* The only exception is the handling of a zero-length LineString, which is now treated as logically equivalent to a point.
-The RelateNG code is new and there are no doubt lots of places in the implementation that can still be tightened up. The existing pair-wise predicates can be considered deprecated, as the new [implementation is faster](https://lin-ear-th-inking.blogspot.com/2024/05/relateng-performance.html) and just as correct. The existing prepared geometry implementation is still faster, for the cases it supports, but for all the unsupported cases RelateNG now provides faster default implentations.
+The RelateNG code is new and there are no doubt lots of places in the implementation that can still be tightened up. The existing pair-wise predicates can be considered deprecated, as the new [implementation is faster](https://lin-ear-th-inking.blogspot.com/2024/05/relateng-performance.html) and just as correct. The existing prepared geometry implementation is still faster, for the cases it supports, but for all the unsupported cases RelateNG now provides faster default implementations.
diff --git a/web/content/posts/2024-09-06-geos-3-13-released.md b/web/content/posts/2024-09-06-geos-3-13-released.md
index d628ee710..a3fc3142d 100644
--- a/web/content/posts/2024-09-06-geos-3-13-released.md
+++ b/web/content/posts/2024-09-06-geos-3-13-released.md
@@ -51,7 +51,7 @@ The full list of changes is as follows:
- **Breaking Changes:**
- - CMake 3.15 or later is requried ([GH-1143](https://github.com/libgeos/geos/issues/1143), Mike Taves)
+ - CMake 3.15 or later is required ([GH-1143](https://github.com/libgeos/geos/issues/1143), Mike Taves)
- **Fixes/Improvements:**
- Add Angle::sinCosSnap to avoid small errors, e.g. with buffer operations ([GH-978](https://github.com/libgeos/geos/issues/978), Mike Taves)
diff --git a/web/content/usage/tools.md b/web/content/usage/tools.md
index 679840a94..b29bace9e 100644
--- a/web/content/usage/tools.md
+++ b/web/content/usage/tools.md
@@ -11,7 +11,7 @@ weight: 100
`geosop` is a CLI (command-line interface) for GEOS. It can be used to:
* Run GEOS operations on one or many geometries
-* Output geometry resuls in various formats (WKT and WKB)
+* Output geometry results in various formats (WKT and WKB)
* Convert between WKT and WKB
* Time the performance of operations
* Check for memory leaks in operations
Summary of changes:
.codespellrc | 3 +++
.github/workflows/ci.yml | 4 ++++
NEWS.md | 4 ++--
include/geos/geom/Geometry.h | 2 +-
include/geos/geom/Surface.h | 2 +-
include/geos/io/WKTWriter.h | 2 +-
include/geos/noding/IteratedNoder.h | 2 +-
include/geos/operation/overlayng/OverlayUtil.h | 2 +-
include/geos/planargraph/DirectedEdge.h | 2 +-
include/geos/vend/json.hpp | 2 +-
src/algorithm/InteriorPointArea.cpp | 2 +-
src/algorithm/MinimumBoundingCircle.cpp | 2 +-
src/geom/Point.cpp | 2 +-
src/geomgraph/Edge.cpp | 2 +-
src/index/bintree/NodeBase.cpp | 2 +-
src/operation/buffer/BufferCurveSetBuilder.cpp | 2 +-
src/operation/relate/RelateComputer.cpp | 2 +-
src/operation/relateng/RelateNG.cpp | 2 +-
src/operation/relateng/TopologyComputer.cpp | 2 +-
tests/unit/capi/GEOSGeom_transformXYZTest.cpp | 2 +-
tests/unit/geom/util/GeometryFixerTest.cpp | 4 ++--
.../tests/general/TestPreparedPolygonPredicate.xml | 4 ++--
tools/codespell.ignore | 17 +++++++++++++++++
web/content/posts/2024-08-13-relateng.md | 2 +-
web/content/posts/2024-09-06-geos-3-13-released.md | 2 +-
web/content/usage/tools.md | 2 +-
26 files changed, 50 insertions(+), 26 deletions(-)
create mode 100644 .codespellrc
create mode 100644 tools/codespell.ignore
hooks/post-receive
More information about the geos-commits
