[geos-commits] [SCM] GEOS branch main updated. 930487a20b6b5860eba91f9719ce0881973defc2
git at osgeo.org
git at osgeo.org
Sat Nov 23 13:29:34 PST 2024
the project "GEOS".
The branch, main has been updated
via 930487a20b6b5860eba91f9719ce0881973defc2 (commit)
from 1ab10dd64bcb0032adbd76b91fa699bacba8d4e2 (commit)
revisions in full, below.
commit 930487a20b6b5860eba91f9719ce0881973defc2
Author: Martin Davis <mtnclimb at gmail.com>
Date: Sat Nov 23 13:29:08 2024 -0800
Add options to TopologyPredicatePerfTest
diff --git a/benchmarks/geom/TopologyPredicatePerfTest.cpp b/benchmarks/geom/TopologyPredicatePerfTest.cpp
index e21ffce77..c3ea05bae 100644
--- a/benchmarks/geom/TopologyPredicatePerfTest.cpp
+++ b/benchmarks/geom/TopologyPredicatePerfTest.cpp
@@ -4,7 +4,12 @@
* Tests a target geometry against grids of points, lines and polygons covering the target.
* Target is either a geometry from a WKT file or a set of generated sine stars increasing in size.
- * Usage: perf_topo_predicate [WKT file] [ intersects | contains | covers | touches ] [num target geoms]
+ * Usage: perf_topo_predicate [-v] [WKT file] [ pred ] [num target geoms]
+ * where pred ::= intersects | contains | covers | touches | relate:PPPPPPPPP
+ * with PPPPPPPPP being a DE-9IM pattern
+ * (e.g. T******** (INTERIOR_INTERSECTS) or T**FF*FF* (CONTAINS_PROPERLY)
+ * - -v enables verbose mode. The test geometries are printed
#include <geos/geom/util/SineStarFactory.h>
@@ -31,14 +36,17 @@ std::size_t MAX_ITER = 1;
std::size_t NUM_GEOM = 1000;
std::size_t NUM_PTS = 100;
-#define INTERSECTS 0
-#define CONTAINS 1
-#define COVERS 2
-#define TOUCHES 3
+#define PRED_INTERSECTS 0
+#define PRED_CONTAINS 1
+#define PRED_COVERS 2
+#define PRED_TOUCHES 3
+#define PRED_RELATE 4
+bool isVerbose = false;
std::string inputFilename{""};
std::string predicateName{"intersects"};
-int predicateOp = INTERSECTS;
+std::string relatePattern{"********"};
+int predicateOp = PRED_INTERSECTS;
std::size_t numTestGeometries = NUM_GEOM;
int testRelateOpIntersects(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
@@ -77,6 +85,15 @@ int testRelateOpTouches(const Geometry& g, const std::vector<std::unique_ptr<Geo
return count;
+int testRelateOpRelate(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
+ int count = 0;
+ for (const auto& geom : geoms) {
+ auto im = RelateOp::relate(&g, geom.get());
+ count += im->matches(relatePattern.c_str());
+ return count;
int testGeometryIntersects(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
int count = 0;
@@ -109,6 +126,14 @@ int testGeometryTouches(const Geometry& g, const std::vector<std::unique_ptr<Geo
return count;
+int testGeometryRelate(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
+ int count = 0;
+ count += g.relate(geom.get(), relatePattern.c_str());
+ return count;
int testPrepGeomIntersects(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
int count = 0;
auto prep = prep::PreparedGeometryFactory::prepare(&g);
@@ -172,6 +197,15 @@ int testRelateNGPreparedTouches(const Geometry& g, const std::vector<std::unique
return count;
+int testRelateNGPreparedRelate(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms) {
+ int count = 0;
+ auto prep = geos::operation::relateng::RelateNG::prepare(&g);
+ for (const auto& line : geoms) {
+ count += prep->evaluate(line.get(), *geos::operation::relateng::RelatePredicate::matches(relatePattern.c_str()));
+ return count;
template<typename F>
double test(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geoms, const std::string& method, F&& fun, double baseTime)
@@ -187,12 +221,12 @@ double test(const Geometry& g, const std::vector<std::unique_ptr<Geometry>>& geo
double tot = sw.getTot();
double timesFaster = baseTime == 0 ? 1 : baseTime / tot;
std::cout << std::fixed << std::setprecision(0);
- std::cout << g.getNumPoints() << ","
- << MAX_ITER * geoms.size() << ","
- << count << "," << geoms[0]->getGeometryType() << ","
- << geoms[0]->getNumPoints() << ","
- << method << " - " << predicateName << ","
- << tot << ",";
+ std::cout << g.getNumPoints() << ", "
+ << MAX_ITER * geoms.size() << ", "
+ << count << ", " << geoms[0]->getGeometryType() << ", "
+ << geoms[0]->getNumPoints() << ", "
+ << method << " - " << predicateName << ", "
+ << tot << ", ";
std::cout << std::fixed << std::setprecision(1);
std::cout << timesFaster
<< std::endl;
@@ -215,7 +249,27 @@ loadWKT(std::string& fname) {
return geom;
+void dump(std::vector<std::unique_ptr<Geometry>>& geoms)
+ std::cout << geom->toString() << std::endl;
+double computeSize(Geometry& target, size_t numGeoms)
+ const Envelope* env = target.getEnvelopeInternal();
+ double w = env->getWidth();
+ double h = env->getHeight();
+ double d = std::min(w, h);
+ double size = d / std::sqrt(numGeoms);
+ return size;
void testTarget(int dim, Geometry& target) {
+ double size = computeSize(target, numTestGeometries);
std::vector<std::unique_ptr<Geometry>> geoms;
switch (dim) {
case 0:
@@ -224,43 +278,52 @@ void testTarget(int dim, Geometry& target) {
break;
case 1:
geoms = geos::benchmark::createLines(*target.getEnvelopeInternal(),
- numTestGeometries, 1.0, NUM_PTS);
+ numTestGeometries, size, NUM_PTS);
break;
case 2:
geoms = geos::benchmark::createPolygons(*target.getEnvelopeInternal(),
break;
+ if (isVerbose) dump(geoms);
double baseTime;
switch (predicateOp) {
- case INTERSECTS:
+ case PRED_INTERSECTS:
baseTime = test(target, geoms, "RelateOp", testRelateOpIntersects, 0);
test(target, geoms, "Geometry", testGeometryIntersects, baseTime);
test(target, geoms, "PreparedGeom", testPrepGeomIntersects, baseTime);
test(target, geoms, "RelateNGPrepared", testRelateNGPreparedIntersects, baseTime);
break;
- case CONTAINS:
+ case PRED_CONTAINS:
test(target, geoms, "PreparedGeom", testPrepGeomContains, baseTime);
test(target, geoms, "RelateNGPrepared", testRelateNGPreparedContains, baseTime);
break;
- case COVERS:
+ case PRED_COVERS:
baseTime = test(target, geoms, "RelateOp", testRelateOpCovers, 0);
test(target, geoms, "Geometry", testGeometryCovers, baseTime);
test(target, geoms, "PreparedGeom", testPrepGeomCovers, baseTime);
test(target, geoms, "RelateNGPrepared", testRelateNGPreparedCovers, baseTime);
break;
- case TOUCHES:
+ case PRED_TOUCHES:
baseTime = test(target, geoms, "RelateOp", testRelateOpTouches, 0);
test(target, geoms, "Geometry", testGeometryTouches, baseTime);
test(target, geoms, "RelateNGPrepared", testRelateNGPreparedTouches, baseTime);
break;
+ case PRED_RELATE:
+ baseTime = test(target, geoms, "RelateOp", testRelateOpRelate, 0);
+ test(target, geoms, "Geometry", testGeometryRelate, baseTime);
+ test(target, geoms, "RelateNGPrepared", testRelateNGPreparedRelate, baseTime);
+ break;
void testStar(int dim, std::size_t npts) {
std::unique_ptr<Geometry> star = geos::benchmark::createSineStar({0, 0}, 100, npts);
+ if (isVerbose) {
+ std::cout << star->toString() << std::endl << std::endl;
testTarget(dim, *star);
@@ -276,45 +339,67 @@ void testStarAll(int dim)
testStar(dim, 16000);
-void parseArgs(int argc, char** argv) {
- int iPred = -1;
- int iFile = -1;
- //-- parse filename, predicate, num geoms, if present
- for (int i = 1; i < argc; i++) {
- std::string arg = argv[i];
- if (arg.find(".") != std::string::npos)
- iFile = i;
- else {
- bool isInt = (arg.find_first_not_of( "0123456789" ) == std::string::npos);
- if (isInt) {
- numTestGeometries = (size_t) std::stoi(arg);
- else {
- iPred = i;
+void parsePredicate(std::string& predArg)
+ predicateName = predArg;
+ if (predicateName.substr(0, 6) == "relate") {
+ if (predicateName.length() != 16) {
+ std::cerr << "Invalid relate pattern: " << predicateName << std::endl;
+ exit(1);
- if (iPred > 0) {
- predicateName = argv[iPred];
- if (iFile > 0) {
- inputFilename = argv[iFile];
+ relatePattern = predicateName.substr(7, 9);
//-- interpret args
- predicateOp = INTERSECTS;
+ predicateOp = PRED_INTERSECTS;
if (predicateName == "contains") {
- predicateOp = CONTAINS;
+ predicateOp = PRED_CONTAINS;
else if (predicateName == "covers") {
- predicateOp = COVERS;
+ predicateOp = PRED_COVERS;
else if (predicateName == "touches") {
- predicateOp = TOUCHES;
+ predicateOp = PRED_TOUCHES;
+ else if (predicateName.substr(0, 6) == "relate") {
+ predicateOp = PRED_RELATE;
+void parseArgs(int argc, char** argv) {
+ int iArg = 1;
+ //-- parse verbose flag, if present
+ if (iArg >= argc) return;
+ std::string arg = argv[iArg];
+ if (arg == "-v") {
+ isVerbose = true;
+ iArg++;
+ //-- parse filename, if present
+ arg = argv[iArg];
+ if (arg.find(".") != std::string::npos) {
+ inputFilename = arg;
+ iArg++;
+ //-- parse predicate, if present
+ arg = argv[iArg];
+ bool isInt = (arg.find_first_not_of( "0123456789" ) == std::string::npos);
+ if (! isInt) {
+ parsePredicate(arg);
+ iArg++;
+ arg = argv[iArg];
+ numTestGeometries = (size_t) std::stoi(arg);
int main(int argc, char** argv) {
Summary of changes:
benchmarks/geom/TopologyPredicatePerfTest.cpp | 175 +++++++++++++++++++-------
1 file changed, 130 insertions(+), 45 deletions(-)
hooks/post-receive
More information about the geos-commits
