[geos-commits] [SCM] GEOS branch main updated. b0cec4048213e2723e0217c7e3551eda788e5c7e
Sun Nov 24 17:55:39 PST 2024
the project "GEOS".
The branch, main has been updated
       via  b0cec4048213e2723e0217c7e3551eda788e5c7e (commit)
      from  930487a20b6b5860eba91f9719ce0881973defc2 (commit)
revisions in full, below.
commit b0cec4048213e2723e0217c7e3551eda788e5c7e
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Sun Nov 24 17:55:11 2024 -0800
    Improve RelateNG performance for A/L cases in prepared predicates (#1201)
diff --git a/include/geos/operation/relateng/RelateGeometry.h b/include/geos/operation/relateng/RelateGeometry.h
index 09753b682..d1282d52f 100644
--- a/include/geos/operation/relateng/RelateGeometry.h
+++ b/include/geos/operation/relateng/RelateGeometry.h
@@ -179,6 +179,10 @@ public:
             case Dimension::A: return hasAreas;
         return false;
+    bool hasAreaAndLine() const {
+        return hasAreas && hasLines;
diff --git a/src/operation/relateng/TopologyComputer.cpp b/src/operation/relateng/TopologyComputer.cpp
index 0b6782e42..e911bc6f8 100644
--- a/src/operation/relateng/TopologyComputer.cpp
+++ b/src/operation/relateng/TopologyComputer.cpp
@@ -132,11 +132,16 @@ TopologyComputer::getDimension(bool isA) const
 bool
 TopologyComputer::isSelfNodingRequired() const
-    if (predicate.requireSelfNoding()) {
-        if (geomA.isSelfNodingRequired() ||
-            geomB.isSelfNodingRequired())
-        return true;
+    if (! predicate.requireSelfNoding())
+      return false;
+    if (geomA.isSelfNodingRequired())
+      return true;
+    //-- if B is a mixed GC with A and L require full noding
+    if (geomB.hasAreaAndLine())
+      return true;
     return false;
diff --git a/tests/unit/operation/relateng/RelateNGGCTest.cpp b/tests/unit/operation/relateng/RelateNGGCTest.cpp
index c8405328a..7e78401c2 100644
--- a/tests/unit/operation/relateng/RelateNGGCTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGGCTest.cpp
@@ -320,6 +320,10 @@ void object::test<23> ()
     std::string a = "POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0))";
     std::string b = "GEOMETRYCOLLECTION (POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0)), MULTIPOINT ((0 2), (0 5)))";
     checkEquals(a, b, true);
+    checkContainsWithin(a, b, true);
+    checkCoversCoveredBy(a, b, true);
+    checkContainsWithin(b, a, true);
+    checkCoversCoveredBy(b, a, true);
@@ -331,6 +335,10 @@ void object::test<24> ()
     std::string b = "GEOMETRYCOLLECTION (POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0)), LINESTRING (0 2, 0 5))";
@@ -341,7 +349,10 @@ void object::test<25> ()
     std::string b = "GEOMETRYCOLLECTION (POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)),LINESTRING(0 2, 0 5, 5 5))";
+    checkCoversCoveredBy(b, a, true);}
diff --git a/tests/xmltester/tests/general/TestRelateGC.xml b/tests/xmltester/tests/general/TestRelateGC.xml
index f67b789a0..a83444a01 100644
--- a/tests/xmltester/tests/general/TestRelateGC.xml
+++ b/tests/xmltester/tests/general/TestRelateGC.xml
@@ -574,6 +574,17 @@ GEOMETRYCOLLECTION (POLYGON ((1 9, 5 9, 6 6, 1 5, 1 9), (2 6, 4 8, 6 6, 2 6)), P
   <test><op name="overlaps"   arg1="A" arg2="B"> false </op></test>
   <test><op name="touches"    arg1="A" arg2="B"> false </op></test>
   <test><op name="within"     arg1="A" arg2="B"> true </op></test>
+  <test><op name="contains"   arg1="B" arg2="A"> true </op></test>
+  <test><op name="coveredBy"  arg1="B" arg2="A"> true </op></test>
+  <test><op name="covers"     arg1="B" arg2="A"> true </op></test>
+  <test><op name="crosses"    arg1="B" arg2="A"> false </op></test>
+  <test><op name="disjoint"   arg1="B" arg2="A"> false </op></test>
+  <test><op name="equalsTopo" arg1="B" arg2="A"> true </op></test>
+  <test><op name="intersects" arg1="B" arg2="A"> true </op></test>
+  <test><op name="overlaps"   arg1="B" arg2="A"> false </op></test>
+  <test><op name="touches"    arg1="B" arg2="A"> false </op></test>
+  <test><op name="within"     arg1="B" arg2="A"> true </op></test>
 </case>
 <case>
@@ -596,6 +607,17 @@ GEOMETRYCOLLECTION (POLYGON ((1 9, 5 9, 6 6, 1 5, 1 9), (2 6, 4 8, 6 6, 2 6)), P
 </case>
 </run>
Summary of changes:
 include/geos/operation/relateng/RelateGeometry.h |  4 ++++
 src/operation/relateng/TopologyComputer.cpp      | 15 ++++++++++-----
 tests/unit/operation/relateng/RelateNGGCTest.cpp | 13 ++++++++++++-
 tests/xmltester/tests/general/TestRelateGC.xml   | 22 ++++++++++++++++++++++
 4 files changed, 48 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
