[geos-commits] [SCM] GEOS branch main updated. 158d790fe9fa1d94a99cdf356746d46484f08946
git at osgeo.org
git at osgeo.org
Fri Sep 6 11:56:07 PDT 2024
the project "GEOS".
The branch, main has been updated
via 158d790fe9fa1d94a99cdf356746d46484f08946 (commit)
from e5433cd0d85437aa5700b2a5151e0367dd935c31 (commit)
revisions in full, below.
commit 158d790fe9fa1d94a99cdf356746d46484f08946
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Sep 6 11:55:47 2024 -0700
Update release directions
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index e2286c5ab..347c347f6 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -22,7 +22,7 @@
$ cmake --build . --target distcheck
4. Update the NEWS file (extract most important things from the repository log).
-Make sure to update the release date.
+ Make sure to update the release date.
5. Commit the changes in the NEWS file.
@@ -44,9 +44,16 @@ Make sure to update the release date.
8. Copy the tar.bz2 file to upload.osgeo.org:/osgeo/download/geos
-9. Create and push a release branch if this was a PATCH=0 release,
- update the versions for next release in Version.txt (both in
- main and release branch if this was a PATCH=0 release).
+9. If this a PATCH=0 release.
+ - Create a new stable branch.
+ - Update the versions for next release in Version.txt for both
+ the main and stable branch.
+ - In stable branch, bump the CAPI_INTERFACE_REVISION to 1
+ - In main branch, bump CAPI_INTERFACE_CURRENT and CAPI_INTERFACE_AGE
+ and set CAPI_INTERFACE_REVISION to 0
+ - Remove the web/ directory from the stable branch, the web site
+ is only built from the main branch.
10. Update download page of main branch: web/content/usage/download.md
@@ -54,6 +61,7 @@ Make sure to update the release date.
- Remove previous patch level release (if any)
11. If this is the latest stable tag release, update the: web/config.toml
- Change the current_release variable to this tag release
12. Close current GitHub milestone and add a new one for next release.
Summary of changes:
HOWTO_RELEASE | 16 ++++++++++++----
1 file changed, 12 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
