[geos-commits] [SCM] GEOS branch main updated. e0b1a0a934ec91383909d4af143141925db814be
Fri Sep 6 13:18:14 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  e0b1a0a934ec91383909d4af143141925db814be (commit)
      from  158d790fe9fa1d94a99cdf356746d46484f08946 (commit)
revisions in full, below.
commit e0b1a0a934ec91383909d4af143141925db814be
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Sep 6 13:17:54 2024 -0700
    news posting for 3.13 release
diff --git a/web/content/posts/2024-09-06-geos-3-13-released.md b/web/content/posts/2024-09-06-geos-3-13-released.md
new file mode 100644
index 000000000..d628ee710
--- /dev/null
+++ b/web/content/posts/2024-09-06-geos-3-13-released.md
@@ -0,0 +1,90 @@
+title: "Version 3.13.0"
+type: posts
+date: 2024-09-06T00:00:00
+The 3.13 release of GEOS is now available [to download]({{< ref "/usage/download" >}}).
+The headline features of this release are:
+* A new approach to boolean predicates via [RelateNG](/posts/2024-08-13-relateng/)
+  * Faster performance for many cases where a short circuit is available
+  * Avoiding the full computation of a topology graph for every call
+  * Ability to use a high speed "prepared" approach for the complete set of predicates as well as the relate matrix functions
+* Initial support for ISO SQL/MM curve types
+  * Create, read and write support for CircularString, CompoundCurve, CurvedPolygon, MultiCurve, MultiSurface
+This release includes the following new features in the C API (and of course underlying changes to the C++ code to support these features):
+  - GEOSGeom_createEmptyCircularString() creates a new empty CircularString
+  - GEOSGeom_createCircularString(coordseq) creates a CircularString with the supplied coordinates
+  - GEOSGeom_createEmptyCompoundCurve() creates a new empty CompoundCurve
+  - GEOSGeom_createCompoundCurve(curves, ncurves) creates a CompoundCurve with the supplied components (start/end coordinates must match up)
+  - GEOSGeom_createEmptyCurvePolygon() creates a new empty CurvePolygon
+  - GEOSGeom_createCurvePolygon(shell, holes, nholes) creates a CurvePolygon with the supplied rings
+  - GEOSPreparedRelate(prepgeom, geom) generates a [DE9IM](https://en.wikipedia.org/wiki/DE-9IM) intersection matrix for the geometry pair, where one input has been "prepared" for fast repeated calls
+  - GEOSPreparedRelatePattern(prepgeom, geom, pattern) tests a pair of geometry against a known DE9IM pattern to see if the relationship is consistent with the pattern
+<!--more-->
+The full list of changes is as follows:
+- **New things:**
+  - Add classes for curved geometry types ([GH-1046](https://github.com/libgeos/geos/issues/1046), Dan Baston/German QGIS users group/Canton of Basel-Landschaft/Canton of Zug)
+    - CircularString
+    - CompoundCurve
+    - CurvedPolygon
+    - MultiCurve
+    - MultiSurface
+  - Support curved geometry types in WKT/WKB readers/writers ([GH-1046](https://github.com/libgeos/geos/issues/1046), [GH-1104](https://github.com/libgeos/geos/issues/1104), [GH-1106](https://github.com/libgeos/geos/issues/1106), Dan Baston)
+  - 3D read and write support for GeoJSON ([GH-1150](https://github.com/libgeos/geos/issues/1150), Oreilles)
+  - RelateNG ([GH-1052](https://github.com/locationtech/jts/pull/1052) Martin Davis, Paul Ramsey)
+    - Rewrite of [boolean predicates and relate matrix calculations](https://lin-ear-th-inking.blogspot.com/2024/05/jts-topological-relationships-next.html)
+    - "Prepared" mode now [available for all predicates](https://lin-ear-th-inking.blogspot.com/2024/05/relateng-performance.html) and relate matrix
+    - CAPI functions GEOSPreparedRelate and GEOSPreparedRelatePattern expose new functionality
+    - CAPI implementations of GEOSPreparedTouches, etc, that were previously defaulting
+      into non-prepared implementations now default into the RelateNG prepared implementation
+    - Prepared implementations for Intersects, Covers, still use the older implementations
+- **Breaking Changes:**
+  - Zero-length linestrings (eg LINESTRING(1 1, 1 1)) are now treated as equivalent to points (POINT(1 1)) in boolean predicates
+  - CMake 3.15 or later is requried ([GH-1143](https://github.com/libgeos/geos/issues/1143), Mike Taves)
+- **Fixes/Improvements:**
+  - Add Angle::sinCosSnap to avoid small errors, e.g. with buffer operations ([GH-978](https://github.com/libgeos/geos/issues/978), Mike Taves)
+  - WKTReader: Points with all-NaN coordinates are not considered empty anymore ([GH-927](https://github.com/libgeos/geos/issues/927), Casper van der Wel)
+  - WKTWriter: Points with all-NaN coordinates are written as such ([GH-927](https://github.com/libgeos/geos/issues/927), Casper van der Wel)
+  - ConvexHull: Performance improvement for larger geometries ([JTS-985](https://github.com/locationtech/jts/issues/985), Martin Davis)
+  - Distance: Improve performance, especially for point-point distance ([GH-1067](https://github.com/libgeos/geos/issues/1067), Dan Baston)
+  - Intersection: change to using DoubleDouble computation to improve robustness ([GH-937](https://github.com/libgeos/geos/issues/937), Martin Davis)
+  - Fix LargestEmptyCircle to respect polygonal obstacles ([GH-939](https://github.com/libgeos/geos/issues/939), Martin Davis)
+  - Fix WKTWriter to emit EMPTY elements in multi-geometries ([GH-952](https://github.com/libgeos/geos/issues/952), Mike Taves)
+  - Fix IncrementalDelaunayTriangulator to ensure triangulation boundary is convex ([GH-953](https://github.com/libgeos/geos/issues/953), Martin Davis)
+  - Fix PreparedLineStringDistance for lines within envelope and polygons ([GH-959](https://github.com/libgeos/geos/issues/959), Martin Davis)
+  - Improve scale handling for PrecisionModel ([GH-956](https://github.com/libgeos/geos/issues/956), Martin Davis)
+  - Fix error in CoordinateSequence::add when disallowing repeated points ([GH-963](https://github.com/libgeos/geos/issues/963), Dan Baston)
+  - Fix WKTWriter::writeTrimmedNumber for big and small values ([GH-973](https://github.com/libgeos/geos/issues/973), Mike Taves)
+  - Fix InteriorPointPoint to handle empty elements ([GH-977](https://github.com/libgeos/geos/issues/977), Martin Davis)
+  - Fix TopologyPreservingSimplifier endpoint handling to avoid self-intersections ([GH-986](https://github.com/libgeos/geos/issues/986), Martin Davis)
+  - Fix spatial predicates for MultiPoint with EMPTY ([GH-989](https://github.com/libgeos/geos/issues/989), Martin Davis)
+  - Fix DiscreteHausdorffDistance for LinearRing ([GH-1000](https://github.com/libgeos/geos/issues/1000), Martin Davis)
+  - Fix IsSimpleOp for MultiPoint with empty element ([GH-1005](https://github.com/libgeos/geos/issues/1005), Martin Davis)
+  - Fix PreparedPolygonContains for GC with MultiPoint ([GH-1008](https://github.com/libgeos/geos/issues/1008), Martin Davis)
+  - Fix reading WKT with EMPTY token with white space ([GH-1025](https://github.com/libgeos/geos/issues/1025), Mike Taves)
+  - Fix buffer Inverted Ring Removal check ([GH-1056](https://github.com/libgeos/geos/issues/1056), Martin Davis)
+  - Add PointLocation.isOnSegment and remove LineIntersector point methods ([GH-1083](https://github.com/libgeos/geos/issues/1083), Martin Davis)
+  - Densify: Interpolate Z coordinates ([GH-1094](https://github.com/libgeos/geos/issues/1094))
+  - GEOSLineSubstring: Fix crash on NaN length fractions ([GH-1088](https://github.com/libgeos/geos/issues/1088), Dan Baston)
+  - MinimumClearance: Fix crash on NaN inputs ([GH-1082](https://github.com/libgeos/geos/issues/1082), Dan Baston)
+  - Centroid: Fix crash on polygons with empty holes ([GH-1075](https://github.com/libgeos/geos/issues/1075), Dan Baston)
+  - GEOSRelatePatternMatch: Fix crash on invalid DE-9IM pattern ([GH-1089](https://github.com/libgeos/geos/issues/1089), Dan Baston)
+  - CoveragePolygonValidator: add section performance optimization ([GH-1099](https://github.com/libgeos/geos/issues/1099), Martin Davis)
+  - TopologyPreservingSimplifier: fix to remove ring endpoints safely ([GH-1110](https://github.com/libgeos/geos/issues/1110), Martin Davis)
+  - TopologyPreservingSimplifier: fix stack overflow on degenerate inputs ([GH-1113](https://github.com/libgeos/geos/issues/1113), Dan Baston)
+  - DouglasPeuckerSimplifier: fix stack overflow on NaN tolerance ([GH-1114](https://github.com/libgeos/geos/issues/1114), Dan Baston)
+  - GEOSConcaveHullOfPolygons: Avoid crash on zero-area input ([GH-1076](https://github.com/libgeos/geos/issues/1076), Dan Baston)
Summary of changes:
 web/content/posts/2024-09-06-geos-3-13-released.md | 90 ++++++++++++++++++++++
 1 file changed, 90 insertions(+)
 create mode 100644 web/content/posts/2024-09-06-geos-3-13-released.md
hooks/post-receive
More information about the geos-commits mailing list
