[geos-commits] [SCM] GEOS branch main updated. e142764b77f4b8d0c36ec88406300c5f876743fb
git at osgeo.org
git at osgeo.org
Wed Sep 25 15:41:27 PDT 2024
the project "GEOS".
The branch, main has been updated
via e142764b77f4b8d0c36ec88406300c5f876743fb (commit)
from c85a07d57505fc8ea6502756e9c4dde67e228cd3 (commit)
revisions in full, below.
commit e142764b77f4b8d0c36ec88406300c5f876743fb
Author: Howard Butler <howard at hobu.co>
Date: Wed Sep 25 17:41:07 2024 -0500
Bump minimum C++ standard to 17 (#1144)
diff --git a/CMakeLists.txt b/CMakeLists.txt
index c5548cecc..dcf03178f 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -121,7 +121,7 @@ include(CMakeDependentOption)
## CMake global variables
option(BUILD_SHARED_LIBS "Build GEOS with shared libraries" ON)
-set(CMAKE_CXX_STANDARD 14 CACHE STRING "C++ standard version to use (default is 14)")
+set(CMAKE_CXX_STANDARD 17 CACHE STRING "C++ standard version to use (minimum requirement is c++17)")
## GEOS custom variables
option(BUILD_BENCHMARKS "Build GEOS benchmarks" OFF)
@@ -203,7 +203,7 @@ set(CMAKE_CXX_EXTENSIONS OFF)
# Target geos_cxx_flags: common compilation flags
add_library(geos_cxx_flags INTERFACE)
-target_compile_features(geos_cxx_flags INTERFACE cxx_std_11)
+target_compile_features(geos_cxx_flags INTERFACE cxx_std_17)
# Add flags to prevent 'fused multiply-add' operations on targets (ARM64)
Summary of changes:
CMakeLists.txt | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
