[geos-commits] [SCM] GEOS branch main updated. f7507e9f5ab4e946d1f693d032599696c4c0be65
Sun Sep 29 18:46:40 PDT 2024
the project "GEOS".
The branch, main has been updated
       via  f7507e9f5ab4e946d1f693d032599696c4c0be65 (commit)
      from  e142764b77f4b8d0c36ec88406300c5f876743fb (commit)
revisions in full, below.
commit f7507e9f5ab4e946d1f693d032599696c4c0be65
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Sun Sep 29 18:46:17 2024 -0700
    Fix ConcaveHullOfPolygons nested shell handling (#1169)
diff --git a/include/geos/algorithm/hull/ConcaveHullOfPolygons.h b/include/geos/algorithm/hull/ConcaveHullOfPolygons.h
index 861e9a37d..1c99ab9ed 100644
--- a/include/geos/algorithm/hull/ConcaveHullOfPolygons.h
+++ b/include/geos/algorithm/hull/ConcaveHullOfPolygons.h
@@ -124,10 +124,6 @@ private:
     std::unique_ptr<Geometry> createEmptyHull();
-    static void extractShellRings(
-        const Geometry* polygons,
-        std::vector<const LinearRing*>& rings);
     void buildHullTris();
diff --git a/include/geos/algorithm/hull/OuterShellsExtracter.h b/include/geos/algorithm/hull/OuterShellsExtracter.h
new file mode 100644
index 000000000..ad0a054b0
--- /dev/null
+++ b/include/geos/algorithm/hull/OuterShellsExtracter.h
@@ -0,0 +1,75 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2024 Martin Davis
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <vector>
+namespace geos {
+namespace geom {
+class Coordinate;
+class CoordinateSequence;
+class Envelope;
+class Geometry;
+class GeometryCollection;
+class GeometryFactory;
+class LinearRing;
+class Polygon;
+using geos::geom::Geometry;
+using geos::geom::LinearRing;
+namespace geos {
+namespace algorithm { // geos::algorithm
+namespace hull {      // geos::algorithm::hull
+ * Extracts the rings of outer shells from a polygonal geometry.
+ * Outer shells are the shells of polygon elements which
+ * are not nested inside holes of other polygons.
+ * \author Martin Davis
+class OuterShellsExtracter {
+private:
+    OuterShellsExtracter(const Geometry& g);
+    void extractOuterShells(std::vector<const LinearRing*>& outerShells);
+    bool isOuter(const LinearRing& shell, std::vector<const LinearRing*>& outerShells);
+    bool covers(const LinearRing& shellA, const LinearRing& shellB);
+    bool isPointInRing(const LinearRing& shell, const LinearRing& shellRing);
+    static void extractShellRings(const Geometry& polygons, std::vector<const LinearRing*>& shells);
+    static bool envelopeAreaComparator(
+        const LinearRing* g1,
+        const LinearRing* g2);
+    const Geometry& geom;
+public:
+    static void extractShells(const Geometry* polygons, std::vector<const LinearRing*>& shells);
+} // geos::algorithm::hull
+} // geos
diff --git a/src/algorithm/hull/ConcaveHullOfPolygons.cpp b/src/algorithm/hull/ConcaveHullOfPolygons.cpp
index 6ed54fb0a..135ca5acf 100644
--- a/src/algorithm/hull/ConcaveHullOfPolygons.cpp
+++ b/src/algorithm/hull/ConcaveHullOfPolygons.cpp
@@ -13,6 +13,7 @@
 #include <geos/algorithm/hull/ConcaveHullOfPolygons.h>
+#include <geos/algorithm/hull/OuterShellsExtracter.h>
 #include <geos/geom/Coordinate.h>
 #include <geos/geom/Envelope.h>
 #include <geos/geom/Geometry.h>
@@ -182,26 +183,11 @@ ConcaveHullOfPolygons::createEmptyHull()
     return geomFactory->createPolygon();
-/* private static */
-void
-ConcaveHullOfPolygons::extractShellRings(const Geometry* polygons, std::vector<const LinearRing*>& rings)
-    rings.clear();
-    for (std::size_t i = 0; i < polygons->getNumGeometries(); i++) {
-        const Geometry* consGeom = polygons->getGeometryN(i);
-        const Polygon* consPoly = static_cast<const Polygon*>(consGeom);
-        const LinearRing* lr = consPoly->getExteriorRing();
-        rings.push_back(lr);
-    return;
 /* private */
 void
 ConcaveHullOfPolygons::buildHullTris()
-    extractShellRings(inputPolygons, polygonRings);
+    OuterShellsExtracter::extractShells(inputPolygons, polygonRings);
     std::unique_ptr<Polygon> frame = createFrame(inputPolygons->getEnvelopeInternal());
     ConstrainedDelaunayTriangulator::triangulatePolygon(frame.get(), triList);
     //System.out.println(tris);
diff --git a/src/algorithm/hull/OuterShellsExtracter.cpp b/src/algorithm/hull/OuterShellsExtracter.cpp
index 000000000..d2152fe54
--- /dev/null
+++ b/src/algorithm/hull/OuterShellsExtracter.cpp
@@ -0,0 +1,123 @@
+ * Copyright (C) 2022 Paul Ramsey <pramsey at cleverelephant.ca>
+#include <geos/algorithm/PointLocation.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/Coordinate.h>
+using geos::algorithm::PointLocation;
+using geos::geom::Polygon;
+using geos::geom::CoordinateXY;
+namespace geos {
+namespace hull {
+/* public static */
+void
+OuterShellsExtracter::extractShells(const Geometry* polygons, std::vector<const LinearRing*>& shells)
+    OuterShellsExtracter extracter(*polygons);
+    extracter.extractOuterShells(shells);
+/* private */
+OuterShellsExtracter::OuterShellsExtracter(const geom::Geometry& g)
+    : geom(g)
+/* private */
+void
+OuterShellsExtracter::extractOuterShells(std::vector<const LinearRing*>& outerShells)
+    std::vector<const LinearRing*> shells;
+    extractShellRings(geom, shells);
+    //-- sort shells in order of increasing envelope area
+    std::sort(shells.begin(), shells.end(), envelopeAreaComparator);
+    //-- Scan shells by decreasing area to ensure that shells are added before any nested shells
+    for (auto i = shells.rbegin(); i != shells.rend(); ++i) {
+      const LinearRing* shell = *i;
+      if (outerShells.size() == 0
+          || isOuter(*shell, outerShells)) {
+        outerShells.push_back(shell);
+bool
+OuterShellsExtracter::envelopeAreaComparator(
+    double area1 = g1->getEnvelopeInternal()->getArea();
+    double area2 = g2->getEnvelopeInternal()->getArea();
+    if (area1 < area2)
+        return true;
+    else
+        return false;
+/* private */
+bool
+OuterShellsExtracter::isOuter(const LinearRing& shell, std::vector<const LinearRing*>& outerShells)
+    for (const LinearRing* outShell : outerShells) {
+      if (covers(*outShell, shell)) {
+        return false;
+    return true;
+/* private */
+bool
+OuterShellsExtracter::covers(const LinearRing& shellA, const LinearRing& shellB)
+    //-- if shellB envelope is not covered then shell is not covered
+    if (! shellA.getEnvelopeInternal()->covers(shellB.getEnvelopeInternal()))
+      return false;
+    //-- if a shellB point lies inside shellA, shell is covered (since shells do not overlap)
+    if (isPointInRing(shellB, shellA))
+      return true;
+    return false;
+bool
+OuterShellsExtracter::isPointInRing(const LinearRing& shell, const LinearRing& shellRing)
+    //TODO: optimize this with cached index
+    const CoordinateXY* pt = shell.getCoordinate();
+    return PointLocation::isInRing(*pt, shellRing.getCoordinatesRO());
+void
+OuterShellsExtracter::extractShellRings(const Geometry& polygons, std::vector<const LinearRing*>& shells)
+    shells.clear();
+    for (std::size_t i = 0; i < polygons.getNumGeometries(); i++) {
+        const Geometry* consGeom = polygons.getGeometryN(i);
+        const Polygon* consPoly = static_cast<const Polygon*>(consGeom);
+        const LinearRing* lr = consPoly->getExteriorRing();
+        shells.push_back(lr);
+} // geos
\ No newline at end of file
diff --git a/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp b/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp
index 574e2da38..83505123e 100644
--- a/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp
+++ b/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp
@@ -191,5 +191,27 @@ void object::test<7>()
         "POLYGON ((6 9, 8 9, 9 5, 8 0, 6 0, 5 0, 1 0, 1 4, 1 5, 1 9, 5 9, 6 9))");
+// testPolygonHole
+template<>
+template<>
+void object::test<8>()
+    checkHullByLenRatio(
+        "MULTIPOLYGON (((1 1, 10 3, 19 1, 16 8, 19 7, 19 19, 10 20, 8 17, 1 19, 1 1), (3 4, 5 10, 3 16, 9 14, 14 15, 15 9, 13 5, 3 4)))",
+        0.9,
+        "POLYGON ((10 20, 19 19, 19 7, 19 1, 10 3, 1 1, 1 19, 10 20), (13 5, 15 9, 14 15, 9 14, 3 16, 5 10, 3 4, 13 5))" );
+// testPolygonNestedPoly
+template<>
+template<>
+void object::test<9>()
+        "MULTIPOLYGON (((1 1, 10 3, 19 1, 16 8, 19 7, 19 19, 10 20, 8 17, 1 19, 1 1), (3 4, 5 10, 3 16, 9 14, 14 15, 15 9, 13 5, 3 4)), ((6 10, 7 13, 10 12, 12 13, 13 11, 11 9, 13 8, 9 6, 6 6, 7 8, 6 10)))",
+        0.9,
+        "MULTIPOLYGON (((10 20, 19 19, 19 7, 19 1, 10 3, 1 1, 1 19, 10 20), (13 5, 15 9, 14 15, 9 14, 3 16, 5 10, 3 4, 13 5)), ((7 13, 10 12, 12 13, 13 11, 11 9, 13 8, 9 6, 6 6, 7 8, 6 10, 7 13)))" );
 } // namespace tut
Summary of changes:
 .../geos/algorithm/hull/ConcaveHullOfPolygons.h    |   4 -
 include/geos/algorithm/hull/OuterShellsExtracter.h |  75 +++++++++++++
 src/algorithm/hull/ConcaveHullOfPolygons.cpp       |  18 +--
 src/algorithm/hull/OuterShellsExtracter.cpp        | 123 +++++++++++++++++++++
 .../algorithm/hull/ConcaveHullOfPolygonsTest.cpp   |  22 ++++
 5 files changed, 222 insertions(+), 20 deletions(-)
 create mode 100644 include/geos/algorithm/hull/OuterShellsExtracter.h
 create mode 100644 src/algorithm/hull/OuterShellsExtracter.cpp
hooks/post-receive
More information about the geos-commits mailing list
