[geos-commits] [SCM] GEOS branch 3.13 updated. b84d32ac39294b73d988e12f4320e0d19ff39453
    git at osgeo.org
    git at osgeo.org
    Mon Apr 21 10:29:07 PDT 2025
the project "GEOS".
The branch, 3.13 has been updated
       via  b84d32ac39294b73d988e12f4320e0d19ff39453 (commit)
       via  6f3fe122b32d76bdf445ccaeb15941225d2a34be (commit)
      from  071f7ee5c871167633a878e0ac072cbfe0509d34 (commit)
revisions in full, below.
commit b84d32ac39294b73d988e12f4320e0d19ff39453
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Apr 21 10:28:43 2025 -0700
    Update NEWS
diff --git a/NEWS.md b/NEWS.md
index 1ddc661ab..84a803e73 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -4,6 +4,7 @@
 - Fixes/Improvements:
   - Fix GeometryCollections in coverageSimplify cause segfault (GH-1250, Paul Ramsey)
+  - Fix OverlayNG coordinate dimemsion handling for EMPTY geometries (GH-1258, Martin Davis)
 ## Changes in 3.13.1
 2025-03-03
commit 6f3fe122b32d76bdf445ccaeb15941225d2a34be
Date:   Mon Apr 21 10:23:46 2025 -0700
    Fix OverlayNG coordinate dimemsion handling for EMPTY geometries (#1258)
diff --git a/include/geos/operation/overlayng/InputGeometry.h b/include/geos/operation/overlayng/InputGeometry.h
index 862ac9f0f..3f78107ee 100644
--- a/include/geos/operation/overlayng/InputGeometry.h
+++ b/include/geos/operation/overlayng/InputGeometry.h
@@ -59,6 +59,7 @@ public:
     bool isSingle() const;
     int getDimension(uint8_t index) const;
+    uint8_t getCoordinateDimension(uint8_t index) const;
     const Geometry* getGeometry(uint8_t geomIndex) const;
     const Envelope* getEnvelope(uint8_t geomIndex) const;
     bool isEmpty(uint8_t geomIndex) const;
diff --git a/include/geos/operation/overlayng/OverlayUtil.h b/include/geos/operation/overlayng/OverlayUtil.h
index a033c5a71..d885c9638 100644
--- a/include/geos/operation/overlayng/OverlayUtil.h
+++ b/include/geos/operation/overlayng/OverlayUtil.h
@@ -132,13 +132,13 @@ public:
     static bool isEnvDisjoint(const Geometry* a, const Geometry* b, const PrecisionModel* pm);
-    * Creates an empty result geometry of the appropriate dimension,
+    * Creates an empty result geometry of the appropriate dimension and coordinate dimension,
     * based on the given overlay operation and the dimensions of the inputs.
     * The created geometry is an atomic geometry,
     * not a collection (unless the dimension is -1,
     * in which case a GEOMETRYCOLLECTION EMPTY is created.)
-    static std::unique_ptr<Geometry> createEmptyResult(int dim, const GeometryFactory* geomFact);
+    static std::unique_ptr<Geometry> createEmptyResult(int dim, size_t coordDim, const GeometryFactory* geomFact);
     * Computes the dimension of the result of
@@ -155,6 +155,13 @@ public:
     static int resultDimension(int opCode, int dim0, int dim1);
+     * Computes the coordinate dimension of overlaying two geometries.
+     * This is the smallest of the two coordinate dimensions
+     * (to avoid having to populate Z and M with unknown values).
+    static uint8_t resultCoordinateDimension(uint8_t coordDim0, uint8_t coordDim1);
     * Creates an overlay result geometry for homogeneous or mixed components.
diff --git a/src/geom/HeuristicOverlay.cpp b/src/geom/HeuristicOverlay.cpp
index c164e00fb..57f6683de 100644
--- a/src/geom/HeuristicOverlay.cpp
+++ b/src/geom/HeuristicOverlay.cpp
@@ -341,8 +341,14 @@ StructuredCollection::doUnaryUnion(int resultDim) const
     toVector(poly_union.get(), geoms);
     if (geoms.size() == 0) {
+        uint8_t resultCoordDim2 = OverlayUtil::resultCoordinateDimension(
+            pts_less_polys_lines->getCoordinateDimension(),
+            lines_less_polys->getCoordinateDimension());
+        uint8_t resultCoordDim = OverlayUtil::resultCoordinateDimension(
+            resultCoordDim2,
+            poly_union->getCoordinateDimension());
         return OverlayUtil::createEmptyResult(
-            resultDim, factory);
+            resultDim, resultCoordDim, factory);
     return factory->buildGeometry(geoms.begin(), geoms.end());
diff --git a/src/operation/overlayng/InputGeometry.cpp b/src/operation/overlayng/InputGeometry.cpp
index 794971887..4ddf4470f 100644
--- a/src/operation/overlayng/InputGeometry.cpp
+++ b/src/operation/overlayng/InputGeometry.cpp
@@ -41,6 +41,15 @@ InputGeometry::getDimension(uint8_t index) const
     return geom[index]->getDimension();
+/*public*/
+uint8_t
+InputGeometry::getCoordinateDimension(uint8_t index) const
+    if (geom[index] == nullptr)
+        return 0;
+    return geom[index]->getCoordinateDimension();
 /*public*/
 const Geometry*
 InputGeometry::getGeometry(uint8_t geomIndex) const
diff --git a/src/operation/overlayng/OverlayNG.cpp b/src/operation/overlayng/OverlayNG.cpp
index 02cfb9311..43f952f15 100644
--- a/src/operation/overlayng/OverlayNG.cpp
+++ b/src/operation/overlayng/OverlayNG.cpp
@@ -357,11 +357,15 @@ OverlayNG::extractResult(int p_opCode, OverlayGraph* graph)
 OverlayNG::createEmptyResult()
+    uint8_t coordDim = OverlayUtil::resultCoordinateDimension(
+                            inputGeom.getCoordinateDimension(0),
+                            inputGeom.getCoordinateDimension(1));
                 OverlayUtil::resultDimension(opCode,
                     inputGeom.getDimension(0),
                     inputGeom.getDimension(1)),
-                geomFact);
+                    coordDim,
+                    geomFact);
diff --git a/src/operation/overlayng/OverlayPoints.cpp b/src/operation/overlayng/OverlayPoints.cpp
index 6afe7a211..79018f8ac 100644
--- a/src/operation/overlayng/OverlayPoints.cpp
+++ b/src/operation/overlayng/OverlayPoints.cpp
@@ -108,8 +108,12 @@ OverlayPoints::getResult()
             break;
-    if (rsltList.empty())
-        return OverlayUtil::createEmptyResult(0, geometryFactory);
+    if (rsltList.empty()) {
+                                            geom0->getCoordinateDimension(),
+                                            geom1->getCoordinateDimension());
+        return OverlayUtil::createEmptyResult(0, coordDim, geometryFactory);
     return geometryFactory->buildGeometry(std::move(rsltList));
diff --git a/src/operation/overlayng/OverlayUtil.cpp b/src/operation/overlayng/OverlayUtil.cpp
index 94e6387dc..0f77d1da8 100644
--- a/src/operation/overlayng/OverlayUtil.cpp
+++ b/src/operation/overlayng/OverlayUtil.cpp
@@ -173,18 +173,18 @@ OverlayUtil::isDisjoint(const Envelope* envA, const Envelope* envB, const Precis
 /*public static*/
-OverlayUtil::createEmptyResult(int dim, const GeometryFactory* geomFact)
+OverlayUtil::createEmptyResult(int dim, size_t coordDim, const GeometryFactory* geomFact)
     std::unique_ptr<Geometry> result(nullptr);
     switch (dim) {
     case 0:
-        result = geomFact->createPoint();
+        result = geomFact->createPoint(coordDim);
         break;
     case 1:
-        result = geomFact->createLineString();
+        result = geomFact->createLineString(coordDim);
         break;
     case 2:
-        result = geomFact->createPolygon();
+        result = geomFact->createPolygon(coordDim);
         break;
     case -1:
         result = geomFact->createGeometryCollection();
@@ -224,6 +224,22 @@ OverlayUtil::resultDimension(int opCode, int dim0, int dim1)
     return resultDimension;
+/* public static */
+uint8_t
+OverlayUtil::resultCoordinateDimension(uint8_t coordDim0, uint8_t coordDim1)
+    uint8_t resultCoordDim = 4;
+    //-- handle cases where only one geometry provided
+    if (coordDim0 >= 2 && coordDim0 < resultCoordDim) {
+        resultCoordDim = coordDim0;
+    if (coordDim1 >= 2 && coordDim1 < resultCoordDim) {
+        resultCoordDim = coordDim1;
+    //-- return value must be 2, 3 or 4
+    return resultCoordDim;
 /* public static */
 bool
 OverlayUtil::isResultAreaConsistent(
diff --git a/tests/unit/operation/overlayng/OverlayNGEmptyCoordDimTest.cpp b/tests/unit/operation/overlayng/OverlayNGEmptyCoordDimTest.cpp
new file mode 100644
index 000000000..d35cf32a5
--- /dev/null
+++ b/tests/unit/operation/overlayng/OverlayNGEmptyCoordDimTest.cpp
@@ -0,0 +1,199 @@
+// Test Suite for geos::operation::overlayng::OverlayNG coordinate dimension handling
+// for EMPTY geometries
+#include <tut/tut.hpp>
+#include <utility.h>
+// geos
+#include <geos/operation/overlayng/OverlayNG.h>
+// std
+#include <memory>
+using namespace geos::geom;
+using namespace geos::operation::overlayng;
+using geos::io::WKTReader;
+using geos::io::WKTWriter;
+namespace tut {
+// Test Group
+// Common data used by all tests
+struct test_overlayngcemptyoorddim_data {
+    WKTReader r;
+    WKTWriter w;
+    void
+    testOverlay(const std::string& a, const std::string& b, int opCode, const std::string& expected)
+        std::unique_ptr<Geometry> geom_a = r.read(a);
+        std::unique_ptr<Geometry> geom_b = r.read(b);
+        std::unique_ptr<Geometry> geom_expected = r.read(expected);
+        std::unique_ptr<Geometry> geom_result = OverlayNG::overlay(geom_a.get(), geom_b.get(), opCode);
+        // std::string wkt_result = w.write(geom_result.get());
+        // std::cout << std::endl << wkt_result << std::endl;
+        ensure_equals_geometry(geom_expected.get(), geom_result.get());
+        ensure_equals(  "Coordinate dimension: ",
+                        (int) geom_result.get()->getCoordinateDimension(),
+                        (int) geom_expected.get()->getCoordinateDimension()
+typedef test_group<test_overlayngcemptyoorddim_data> group;
+typedef group::object object;
+group test_overlayngcoorddim_group("geos::operation::overlayng::OverlayNGEmptyCoordDim");
+// Test Cases
+//--------- POINT / POINT
+// test ZM dim for empty POINT union
+template<>
+template<>
+void object::test<1> ()
+    testOverlay("POINT ZM EMPTY", "POINT ZM EMPTY",
+                OverlayNG::UNION, "POINT ZM EMPTY");
+// test ZM dim for empty POINT intersection
+template<>
+template<>
+void object::test<2> ()
+        OverlayNG::INTERSECTION, "POINT ZM EMPTY");
+// test mixed ZM and XY dim for empty POINT union
+template<>
+template<>
+void object::test<3> ()
+    testOverlay("POINT ZM EMPTY", "POINT EMPTY",
+        OverlayNG::UNION, "POINT EMPTY");
+// test mixed ZM and Z dim for empty POINT union
+template<>
+template<>
+void object::test<4> ()
+    testOverlay("POINT ZM EMPTY", "POINT Z EMPTY",
+        OverlayNG::UNION, "POINT Z EMPTY");
+//--------- LINESTRING / POINT
+template<>
+template<>
+void object::test<5> ()
+    testOverlay("POINT ZM EMPTY", "LINESTRING ZM EMPTY",
+        OverlayNG::UNION, "LINESTRING ZM EMPTY");
+template<>
+template<>
+void object::test<6> ()
+    testOverlay("POINT ZM EMPTY", "LINESTRING Z EMPTY",
+        OverlayNG::UNION, "LINESTRING Z EMPTY");
+template<>
+template<>
+void object::test<7> ()
+    testOverlay("POINT ZM EMPTY", "LINESTRING EMPTY",
+        OverlayNG::UNION, "LINESTRING EMPTY");
+//-- ensure coord dim is lowest of either operand
+template<>
+template<>
+void object::test<8> ()
+    testOverlay("POINT EMPTY", "LINESTRING ZM EMPTY",
+//--------- LINESTRING / LINESTRING
+// test ZM dim for empty LINESTRING union
+template<>
+template<>
+void object::test<9> ()
+    testOverlay("LINESTRING ZM EMPTY", "LINESTRING ZM EMPTY",
+// test mixed ZM and XY dim for empty LINESTRING union
+template<>
+template<>
+void object::test<10> ()
+    testOverlay("LINESTRING ZM EMPTY", "LINESTRING Z EMPTY",
+// test mixed ZM and Z dim for empty LINESTRING union
+template<>
+template<>
+void object::test<11> ()
+    testOverlay("LINESTRING ZM EMPTY", "LINESTRING EMPTY",
+//--------- GEOMETRYCOLLECTION
+//-- coord dim of GC (ZM) EMPTY is always 2
+template<>
+template<>
+void object::test<12> ()
+    testOverlay("GEOMETRYCOLLECTION ZM EMPTY",
+                "POINT ZM EMPTY",
+//-- coord dim of GC containing EMPTYs is lowest coord dim of elements
+template<>
+template<>
+void object::test<13> ()
+    testOverlay("GEOMETRYCOLLECTION (POINT ZM EMPTY)",
+        "GEOMETRYCOLLECTION (POINT ZM EMPTY, LINESTRING ZM EMPTY)",
+template<>
+template<>
+void object::test<14> ()
+    testOverlay("GEOMETRYCOLLECTION (POINT Z EMPTY)",
+template<>
+template<>
+void object::test<15> ()
+    testOverlay("GEOMETRYCOLLECTION (POINT EMPTY)",
+} // namespace tut
Summary of changes:
 NEWS.md                                            |   1 +
 include/geos/operation/overlayng/InputGeometry.h   |   1 +
 include/geos/operation/overlayng/OverlayUtil.h     |  11 +-
 src/geom/HeuristicOverlay.cpp                      |   8 +-
 src/operation/overlayng/InputGeometry.cpp          |   9 +
 src/operation/overlayng/OverlayNG.cpp              |   6 +-
 src/operation/overlayng/OverlayPoints.cpp          |   8 +-
 src/operation/overlayng/OverlayUtil.cpp            |  24 ++-
 .../overlayng/OverlayNGEmptyCoordDimTest.cpp       | 199 +++++++++++++++++++++
 9 files changed, 257 insertions(+), 10 deletions(-)
 create mode 100644 tests/unit/operation/overlayng/OverlayNGEmptyCoordDimTest.cpp
hooks/post-receive
More information about the geos-commits
