[geos-commits] [SCM] GEOS branch 3.12 updated. 86039e06d249dbae6b53a9ff6480b7a36d24cc06
git at osgeo.org
git at osgeo.org
Mon Apr 21 10:37:14 PDT 2025
the project "GEOS".
The branch, 3.12 has been updated
via 86039e06d249dbae6b53a9ff6480b7a36d24cc06 (commit)
via 5f05f9bb954986e2640d141b96a064d3c109638c (commit)
from 0293c1e898082f43102ab1011d49e7ddc8f2c9ce (commit)
revisions in full, below.
commit 86039e06d249dbae6b53a9ff6480b7a36d24cc06
Author: Martin Davis <mtnclimb at gmail.com>
Date: Mon Apr 21 10:36:52 2025 -0700
Update NEWS
diff --git a/NEWS.md b/NEWS.md
index 56060dee0..17e9c0760 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -2,7 +2,7 @@
2025-xx-xx
- Fixes:
+ - Fix OverlayNG coordinate dimemsion handling for EMPTY geometries (GH-1258, Martin Davis)
## Changes in 3.12.3
commit 5f05f9bb954986e2640d141b96a064d3c109638c
Date: Mon Apr 21 10:23:46 2025 -0700
Fix OverlayNG coordinate dimemsion handling for EMPTY geometries (#1258)
diff --git a/include/geos/operation/overlayng/InputGeometry.h b/include/geos/operation/overlayng/InputGeometry.h
index 862ac9f0f..3f78107ee 100644
--- a/include/geos/operation/overlayng/InputGeometry.h
+++ b/include/geos/operation/overlayng/InputGeometry.h
@@ -59,6 +59,7 @@ public:
bool isSingle() const;
int getDimension(uint8_t index) const;
+ uint8_t getCoordinateDimension(uint8_t index) const;
const Geometry* getGeometry(uint8_t geomIndex) const;
const Envelope* getEnvelope(uint8_t geomIndex) const;
bool isEmpty(uint8_t geomIndex) const;
diff --git a/include/geos/operation/overlayng/OverlayUtil.h b/include/geos/operation/overlayng/OverlayUtil.h
index 9d30dca34..54098f1f0 100644
--- a/include/geos/operation/overlayng/OverlayUtil.h
+++ b/include/geos/operation/overlayng/OverlayUtil.h
@@ -132,13 +132,13 @@ public:
static bool isEnvDisjoint(const Geometry* a, const Geometry* b, const PrecisionModel* pm);
- * Creates an empty result geometry of the appropriate dimension,
+ * Creates an empty result geometry of the appropriate dimension and coordinate dimension,
* based on the given overlay operation and the dimensions of the inputs.
* The created geometry is an atomic geometry,
* not a collection (unless the dimension is -1,
* in which case a GEOMETRYCOLLECTION EMPTY is created.)
- static std::unique_ptr<Geometry> createEmptyResult(int dim, const GeometryFactory* geomFact);
+ static std::unique_ptr<Geometry> createEmptyResult(int dim, size_t coordDim, const GeometryFactory* geomFact);
* Computes the dimension of the result of
@@ -155,6 +155,13 @@ public:
static int resultDimension(int opCode, int dim0, int dim1);
+ * Computes the coordinate dimension of overlaying two geometries.
+ * This is the smallest of the two coordinate dimensions
+ * (to avoid having to populate Z and M with unknown values).
+ static uint8_t resultCoordinateDimension(uint8_t coordDim0, uint8_t coordDim1);
* Creates an overlay result geometry for homogeneous or mixed components.
diff --git a/src/geom/HeuristicOverlay.cpp b/src/geom/HeuristicOverlay.cpp
index c164e00fb..57f6683de 100644
--- a/src/geom/HeuristicOverlay.cpp
+++ b/src/geom/HeuristicOverlay.cpp
@@ -341,8 +341,14 @@ StructuredCollection::doUnaryUnion(int resultDim) const
toVector(poly_union.get(), geoms);
if (geoms.size() == 0) {
+ uint8_t resultCoordDim2 = OverlayUtil::resultCoordinateDimension(
+ pts_less_polys_lines->getCoordinateDimension(),
+ lines_less_polys->getCoordinateDimension());
+ uint8_t resultCoordDim = OverlayUtil::resultCoordinateDimension(
+ resultCoordDim2,
+ poly_union->getCoordinateDimension());
return OverlayUtil::createEmptyResult(
- resultDim, factory);
+ resultDim, resultCoordDim, factory);
return factory->buildGeometry(geoms.begin(), geoms.end());
diff --git a/src/operation/overlayng/InputGeometry.cpp b/src/operation/overlayng/InputGeometry.cpp
index 794971887..4ddf4470f 100644
--- a/src/operation/overlayng/InputGeometry.cpp
+++ b/src/operation/overlayng/InputGeometry.cpp
@@ -41,6 +41,15 @@ InputGeometry::getDimension(uint8_t index) const
return geom[index]->getDimension();
+/*public*/
+uint8_t
+InputGeometry::getCoordinateDimension(uint8_t index) const
+ if (geom[index] == nullptr)
+ return 0;
+ return geom[index]->getCoordinateDimension();
/*public*/
const Geometry*
InputGeometry::getGeometry(uint8_t geomIndex) const
diff --git a/src/operation/overlayng/OverlayNG.cpp b/src/operation/overlayng/OverlayNG.cpp
index 02cfb9311..43f952f15 100644
--- a/src/operation/overlayng/OverlayNG.cpp
+++ b/src/operation/overlayng/OverlayNG.cpp
@@ -357,11 +357,15 @@ OverlayNG::extractResult(int p_opCode, OverlayGraph* graph)
OverlayNG::createEmptyResult()
+ uint8_t coordDim = OverlayUtil::resultCoordinateDimension(
+ inputGeom.getCoordinateDimension(0),
+ inputGeom.getCoordinateDimension(1));
OverlayUtil::resultDimension(opCode,
inputGeom.getDimension(0),
inputGeom.getDimension(1)),
- geomFact);
+ coordDim,
+ geomFact);
diff --git a/src/operation/overlayng/OverlayPoints.cpp b/src/operation/overlayng/OverlayPoints.cpp
index c1c37799c..39943febc 100644
--- a/src/operation/overlayng/OverlayPoints.cpp
+++ b/src/operation/overlayng/OverlayPoints.cpp
@@ -108,8 +108,12 @@ OverlayPoints::getResult()
break;
- if (rsltList.empty())
- return OverlayUtil::createEmptyResult(0, geometryFactory);
+ if (rsltList.empty()) {
+ geom0->getCoordinateDimension(),
+ geom1->getCoordinateDimension());
+ return OverlayUtil::createEmptyResult(0, coordDim, geometryFactory);
return geometryFactory->buildGeometry(std::move(rsltList));
diff --git a/src/operation/overlayng/OverlayUtil.cpp b/src/operation/overlayng/OverlayUtil.cpp
index 94e6387dc..0f77d1da8 100644
--- a/src/operation/overlayng/OverlayUtil.cpp
+++ b/src/operation/overlayng/OverlayUtil.cpp
@@ -173,18 +173,18 @@ OverlayUtil::isDisjoint(const Envelope* envA, const Envelope* envB, const Precis
/*public static*/
-OverlayUtil::createEmptyResult(int dim, const GeometryFactory* geomFact)
+OverlayUtil::createEmptyResult(int dim, size_t coordDim, const GeometryFactory* geomFact)
std::unique_ptr<Geometry> result(nullptr);
switch (dim) {
case 0:
- result = geomFact->createPoint();
+ result = geomFact->createPoint(coordDim);
break;
case 1:
- result = geomFact->createLineString();
+ result = geomFact->createLineString(coordDim);
break;
case 2:
- result = geomFact->createPolygon();
+ result = geomFact->createPolygon(coordDim);
break;
case -1:
result = geomFact->createGeometryCollection();
@@ -224,6 +224,22 @@ OverlayUtil::resultDimension(int opCode, int dim0, int dim1)
return resultDimension;
+/* public static */
+uint8_t
+OverlayUtil::resultCoordinateDimension(uint8_t coordDim0, uint8_t coordDim1)
+ uint8_t resultCoordDim = 4;
+ //-- handle cases where only one geometry provided
+ if (coordDim0 >= 2 && coordDim0 < resultCoordDim) {
+ resultCoordDim = coordDim0;
+ if (coordDim1 >= 2 && coordDim1 < resultCoordDim) {
+ resultCoordDim = coordDim1;
+ //-- return value must be 2, 3 or 4
+ return resultCoordDim;
/* public static */
bool
OverlayUtil::isResultAreaConsistent(
diff --git a/tests/unit/operation/overlayng/OverlayNGEmptyCoordDimTest.cpp b/tests/unit/operation/overlayng/OverlayNGEmptyCoordDimTest.cpp
new file mode 100644
index 000000000..d35cf32a5
--- /dev/null
+++ b/tests/unit/operation/overlayng/OverlayNGEmptyCoordDimTest.cpp
@@ -0,0 +1,199 @@
+// Test Suite for geos::operation::overlayng::OverlayNG coordinate dimension handling
+// for EMPTY geometries
+#include <tut/tut.hpp>
+#include <utility.h>
+// geos
+#include <geos/operation/overlayng/OverlayNG.h>
+// std
+#include <memory>
+using namespace geos::geom;
+using namespace geos::operation::overlayng;
+using geos::io::WKTReader;
+using geos::io::WKTWriter;
+namespace tut {
+// Test Group
+// Common data used by all tests
+struct test_overlayngcemptyoorddim_data {
+ WKTReader r;
+ WKTWriter w;
+ void
+ testOverlay(const std::string& a, const std::string& b, int opCode, const std::string& expected)
+ std::unique_ptr<Geometry> geom_a = r.read(a);
+ std::unique_ptr<Geometry> geom_b = r.read(b);
+ std::unique_ptr<Geometry> geom_expected = r.read(expected);
+ std::unique_ptr<Geometry> geom_result = OverlayNG::overlay(geom_a.get(), geom_b.get(), opCode);
+ // std::string wkt_result = w.write(geom_result.get());
+ // std::cout << std::endl << wkt_result << std::endl;
+ ensure_equals_geometry(geom_expected.get(), geom_result.get());
+ ensure_equals( "Coordinate dimension: ",
+ (int) geom_result.get()->getCoordinateDimension(),
+ (int) geom_expected.get()->getCoordinateDimension()
+typedef test_group<test_overlayngcemptyoorddim_data> group;
+typedef group::object object;
+group test_overlayngcoorddim_group("geos::operation::overlayng::OverlayNGEmptyCoordDim");
+// Test Cases
+//--------- POINT / POINT
+// test ZM dim for empty POINT union
+template<>
+template<>
+void object::test<1> ()
+ testOverlay("POINT ZM EMPTY", "POINT ZM EMPTY",
+ OverlayNG::UNION, "POINT ZM EMPTY");
+// test ZM dim for empty POINT intersection
+template<>
+template<>
+void object::test<2> ()
+ OverlayNG::INTERSECTION, "POINT ZM EMPTY");
+// test mixed ZM and XY dim for empty POINT union
+template<>
+template<>
+void object::test<3> ()
+ testOverlay("POINT ZM EMPTY", "POINT EMPTY",
+ OverlayNG::UNION, "POINT EMPTY");
+// test mixed ZM and Z dim for empty POINT union
+template<>
+template<>
+void object::test<4> ()
+ testOverlay("POINT ZM EMPTY", "POINT Z EMPTY",
+ OverlayNG::UNION, "POINT Z EMPTY");
+//--------- LINESTRING / POINT
+template<>
+template<>
+void object::test<5> ()
+ testOverlay("POINT ZM EMPTY", "LINESTRING ZM EMPTY",
+ OverlayNG::UNION, "LINESTRING ZM EMPTY");
+template<>
+template<>
+void object::test<6> ()
+ testOverlay("POINT ZM EMPTY", "LINESTRING Z EMPTY",
+ OverlayNG::UNION, "LINESTRING Z EMPTY");
+template<>
+template<>
+void object::test<7> ()
+ testOverlay("POINT ZM EMPTY", "LINESTRING EMPTY",
+ OverlayNG::UNION, "LINESTRING EMPTY");
+//-- ensure coord dim is lowest of either operand
+template<>
+template<>
+void object::test<8> ()
+ testOverlay("POINT EMPTY", "LINESTRING ZM EMPTY",
+//--------- LINESTRING / LINESTRING
+// test ZM dim for empty LINESTRING union
+template<>
+template<>
+void object::test<9> ()
+ testOverlay("LINESTRING ZM EMPTY", "LINESTRING ZM EMPTY",
+// test mixed ZM and XY dim for empty LINESTRING union
+template<>
+template<>
+void object::test<10> ()
+ testOverlay("LINESTRING ZM EMPTY", "LINESTRING Z EMPTY",
+// test mixed ZM and Z dim for empty LINESTRING union
+template<>
+template<>
+void object::test<11> ()
+ testOverlay("LINESTRING ZM EMPTY", "LINESTRING EMPTY",
+//--------- GEOMETRYCOLLECTION
+//-- coord dim of GC (ZM) EMPTY is always 2
+template<>
+template<>
+void object::test<12> ()
+ testOverlay("GEOMETRYCOLLECTION ZM EMPTY",
+ "POINT ZM EMPTY",
+//-- coord dim of GC containing EMPTYs is lowest coord dim of elements
+template<>
+template<>
+void object::test<13> ()
+ testOverlay("GEOMETRYCOLLECTION (POINT ZM EMPTY)",
+ "GEOMETRYCOLLECTION (POINT ZM EMPTY, LINESTRING ZM EMPTY)",
+template<>
+template<>
+void object::test<14> ()
+ testOverlay("GEOMETRYCOLLECTION (POINT Z EMPTY)",
+template<>
+template<>
+void object::test<15> ()
+ testOverlay("GEOMETRYCOLLECTION (POINT EMPTY)",
+} // namespace tut
Summary of changes:
NEWS.md | 2 +-
include/geos/operation/overlayng/InputGeometry.h | 1 +
include/geos/operation/overlayng/OverlayUtil.h | 11 +-
src/geom/HeuristicOverlay.cpp | 8 +-
src/operation/overlayng/InputGeometry.cpp | 9 +
src/operation/overlayng/OverlayNG.cpp | 6 +-
src/operation/overlayng/OverlayPoints.cpp | 8 +-
src/operation/overlayng/OverlayUtil.cpp | 24 ++-
.../overlayng/OverlayNGEmptyCoordDimTest.cpp | 199 +++++++++++++++++++++
9 files changed, 257 insertions(+), 11 deletions(-)
create mode 100644 tests/unit/operation/overlayng/OverlayNGEmptyCoordDimTest.cpp
hooks/post-receive
More information about the geos-commits
