[geos-commits] [SCM] GEOS branch 3.14 updated. d18db3a1108a504938e7da4f7818c7195cc021c4
git at osgeo.org
git at osgeo.org
Sun Dec 7 14:08:32 PST 2025
the project "GEOS".
The branch, 3.14 has been updated
via d18db3a1108a504938e7da4f7818c7195cc021c4 (commit)
from beb52e94b100efc12a8f764d896586adc10420c8 (commit)
revisions in full, below.
commit d18db3a1108a504938e7da4f7818c7195cc021c4
Author: Mike Taves <mwtoews at gmail.com>
Date: Mon Dec 8 10:53:37 2025 +1300
Refactor FE_ macro checks for Emscripten; add CI job (#1333)
* Refactor FE_ macro checks for Emscripten; add CI job
* Re-introduce HAVE_FENV via opt-in MISSING_FENV define
* Check for cfenv C++ header instead of fenv.h C header
* Add NEWS entry
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 113f55e61..c1741a25f 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -481,6 +481,49 @@ jobs:
working-directory: ./build
run: ctest -V --output-on-failure -C ${{ matrix.build_type }}
+ emscripten:
+ name: Emscripten WASM build
+ runs-on: ubuntu-latest
+ steps:
+ - name: Install
+ run: |
+ set -e
+ sudo -E apt-get update
+ sudo -E apt-get autopurge -y needrestart
+ sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make cmake emscripten ccache
+ - uses: actions/checkout at v5
+ - name: Retrieve build cache
+ uses: actions/cache/restore at v4
+ id: restore-cache
+ with:
+ path: .ccache
+ key: emscripten-${{ github.ref_name }}-${{ github.run_id }}
+ restore-keys: emscripten
+ - name: Build
+ run: |
+ set -e
+ mkdir build
+ cd build
+ cmake --version
+ emcmake cmake \
+ -D BUILD_SHARED_LIBS=OFF \
+ -D USE_CCACHE=ON \
+ cmake --build . -j $(nproc)
+ ccache --show-stats
+ - name: Save build cache
+ uses: actions/cache/save at v4
+ with:
+ path: .ccache
+ key: ${{ steps.restore-cache.outputs.cache-primary-key }}
+# - name: Test
+# working-directory: ./build
+# run: ctest --output-on-failure
code-quality:
name: Code quality checks
diff --git a/CMakeLists.txt b/CMakeLists.txt
index a1e2f0c6e..8f63318f4 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -317,6 +317,12 @@ set(CMAKE_CXX_FLAGS_COVERAGE "-fprofile-arcs -ftest-coverage")
include(CheckLibraryExists)
check_library_exists(m pow "" HAVE_LIBM)
+# Extra include
+include(CheckIncludeFileCXX)
+check_include_file_cxx(cfenv HAVE_FENV_H)
# Target geos: C++ API library
@@ -558,10 +564,3 @@ if(PROJECT_IS_TOP_LEVEL)
unset(_is_multi_config_generator)
endif() # PROJECT_IS_TOP_LEVEL
-include(CheckIncludeFile)
-check_include_file(fenv.h HAVE_FENV_H)
-if(HAVE_FENV_H)
- target_compile_definitions(geos_cxx_flags INTERFACE HAVE_FENV)
-endif()
diff --git a/NEWS.md b/NEWS.md
index d31f941e0..cf736c28d 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -1,4 +1,10 @@
+## Changes in 3.14.2
+2025-xx-xx
+- Fixes/Improvements:
+ - Relax other floating-point exception handling with other compilers (GH-1333, Mike Taves)
## Changes in 3.14.1
2025-10-27
@@ -8,7 +14,6 @@
- GridIntersection: Fix crash for certain polygons outside grid extent (Dan Baston)
- Fix incorrect envelope calculation for arcs (GH-1314, Dan Baston)
## Changes in 3.14.0
2025-08-21
diff --git a/tests/unit/CMakeLists.txt b/tests/unit/CMakeLists.txt
index 063c408ff..ecaa63d2f 100644
--- a/tests/unit/CMakeLists.txt
+++ b/tests/unit/CMakeLists.txt
@@ -63,6 +63,11 @@ foreach(_testfile ${_testfiles})
set_tests_properties(unit-${_cmake_testname} PROPERTIES TIMEOUT 30)
endforeach()
+if(NOT HAVE_FENV_H)
+ # Used to set HAVE_FENV in test files
+ add_compile_definitions(MISSING_FENV)
+endif()
# Run all the unit tests in one go, for faster memory checking
# under valgrind. Restrict to one configuration so it is only
# run with 'ctest -C Valgrind'
diff --git a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
index f50b58680..8e85bf0a4 100644
--- a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
@@ -16,7 +16,10 @@
#include <cmath>
#include <string>
#include <memory>
+#if !defined(MISSING_FENV)
+#define HAVE_FENV
#include <cfenv>
+#endif
namespace geos {
namespace geom {
@@ -191,13 +194,17 @@ template<>
void object::test<6>
+#ifdef HAVE_FENV
std::feclearexcept(FE_ALL_EXCEPT);
+#endif
runTest(
"LINESTRING (0 0, 100 0, 10 100, 10 100)",
"LINESTRING (0 100, 0 10, 80 10)", 0.001, 47.89);
+#ifdef FE_INVALID
ensure("FE_INVALID raised", !std::fetestexcept(FE_INVALID));
+#endif
// Crash on collection with empty components
diff --git a/tests/unit/capi/GEOSDistanceTest.cpp b/tests/unit/capi/GEOSDistanceTest.cpp
index f5f5e1471..152aade8b 100644
--- a/tests/unit/capi/GEOSDistanceTest.cpp
+++ b/tests/unit/capi/GEOSDistanceTest.cpp
@@ -9,7 +9,10 @@
#include <algorithm>
#include <cstdio>
#include <cstdlib>
+#define HAVE_FENV
#include <fenv.h>
+#endif
#include <cmath>
#include "capi_test_utils.h"
@@ -119,8 +122,10 @@ void object::test<4>
geom1_ = fromWKT("POINT (0 0)");
geom2_ = fromWKT("POINT (1 1)");
+#ifdef HAVE_FENV
// clear all floating point exceptions
feclearexcept (FE_ALL_EXCEPT);
+#endif
double d;
int status = GEOSDistance(geom1_, geom2_, &d);
@@ -128,9 +133,11 @@ void object::test<4>
ensure_equals(status, 1);
ensure_equals(d, std::sqrt(2));
+#ifdef FE_OVERFLOW
// check for floating point overflow exceptions
int raised = fetestexcept(FE_OVERFLOW);
ensure_equals(raised & FE_OVERFLOW, 0);
+#endif
// same distance between boundables should not raise floating point exception
@@ -142,8 +149,10 @@ void object::test<5>
geom1_ = fromWKT("LINESTRING (0 0, 1 1)");
geom2_ = fromWKT("LINESTRING (2 1, 1 2)");
+#ifdef HAVE_FENV
+#endif
double d;
@@ -151,9 +160,11 @@ void object::test<5>
// ensure_equals(d, std::sqrt(2));
+#ifdef FE_OVERFLOW
+#endif
template<>
diff --git a/tests/unit/capi/GEOSIntersectionTest.cpp b/tests/unit/capi/GEOSIntersectionTest.cpp
index c94b056a7..4a03845df 100644
--- a/tests/unit/capi/GEOSIntersectionTest.cpp
+++ b/tests/unit/capi/GEOSIntersectionTest.cpp
@@ -140,7 +140,9 @@ void object::test<7>
result_ = GEOSIntersection(geom1_, geom2_);
+#ifdef FE_INVALID
ensure(!std::fetestexcept(FE_INVALID));
+#endif
template<>
diff --git a/tests/unit/capi/GEOSProjectTest.cpp b/tests/unit/capi/GEOSProjectTest.cpp
index af8640f8b..d2556a897 100644
--- a/tests/unit/capi/GEOSProjectTest.cpp
+++ b/tests/unit/capi/GEOSProjectTest.cpp
@@ -100,14 +100,22 @@ void object::test<5>
geom1_ = GEOSGeomFromWKT("LINESTRING (0 0, 1 1, 1 1, 2 2)");
geom2_ = GEOSGeomFromWKT("POINT (0 1)");
+#ifdef HAVE_FENV
+#endif
double dist = GEOSProject(geom1_, geom2_);
+#ifdef FE_INVALID
+#endif
ensure_equals("GEOSProject", dist, 0.7071, 0.0001);
+#ifdef HAVE_FENV
+#endif
double dist_norm = GEOSProjectNormalized(geom1_, geom2_);
+#ifdef FE_INVALID
+#endif
ensure_equals("GEOSProjectNormalized", dist_norm, 0.25);
diff --git a/tests/unit/capi/GEOSVoronoiDiagramTest.cpp b/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
index 7c5b05bcd..d79181351 100644
--- a/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
+++ b/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
@@ -5,7 +5,10 @@
// geos
#include <geos_c.h>
// std
+#define HAVE_FENV
#include <cfenv>
+#endif
@@ -57,7 +60,9 @@ template<>
void object::test<1>
+#ifdef HAVE_FENV
+#endif
geom1_ = GEOSGeomFromWKT("POINT(10 20)");
@@ -69,7 +74,9 @@ void object::test<1>
geom2_ = GEOSVoronoiDiagram(geom1_, nullptr, 0, 1);
ensure_geometry_equals(geom2_, "MULTILINESTRING EMPTY");
+#ifdef FE_INVALID
+#endif
//More points:
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index 67818d6a1..0b8d03284 100644
--- a/tests/unit/capi/capi_test_utils.h
+++ b/tests/unit/capi/capi_test_utils.h
@@ -7,7 +7,10 @@
#include <cstdarg>
#include <cstdio>
+#define HAVE_FENV
#include <cfenv>
+#endif
namespace capitest {
@@ -29,7 +32,9 @@ namespace capitest {
wktw_ = GEOSWKTWriter_create();
GEOSWKTWriter_setRoundingPrecision(wktw_, 10);
+#ifdef HAVE_FENV
+#endif
~utility()
diff --git a/tests/unit/geom/EnvelopeTest.cpp b/tests/unit/geom/EnvelopeTest.cpp
index b1250a63e..5974f84e0 100644
--- a/tests/unit/geom/EnvelopeTest.cpp
+++ b/tests/unit/geom/EnvelopeTest.cpp
@@ -8,7 +8,10 @@
#include <geos/geom/Coordinate.h>
#include <array>
+#define HAVE_FENV
#include <cfenv>
+#endif
#include <unordered_set>
namespace tut {
@@ -23,7 +26,9 @@ using geos::geom::Envelope;
struct test_envelope_data {
test_envelope_data()
+#ifdef HAVE_FENV
+#endif
static std::size_t
@@ -91,11 +96,21 @@ struct test_envelope_data {
static void
ensure_no_fp_except()
+#ifdef FE_DIVBYZERO
ensure("FE_DIVBYZERO raised", !std::fetestexcept(FE_DIVBYZERO));
+#endif
+//#ifdef FE_INEXACT
//ensure("FE_INEXACT raised", !std::fetestexcept(FE_INEXACT));
+//#endif
+#ifdef FE_INVALID
+#endif
+#ifdef FE_OVERFLOW
ensure("FE_OVERFLOW raised", !std::fetestexcept(FE_OVERFLOW));
+#endif
+#ifdef FE_UNDERFLOW
ensure("FE_UNDERFLOW raised", !std::fetestexcept(FE_UNDERFLOW));
+#endif
diff --git a/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp b/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
index 27279708e..66865b349 100644
--- a/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
+++ b/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
@@ -9,7 +9,10 @@
#include <geos/util.h>
// std
+#define HAVE_FENV
#include <cfenv>
+#endif
#include <memory>
using namespace geos::geom;
@@ -33,9 +36,13 @@ struct test_coverageunionng_data {
std::unique_ptr<Geometry> geom = r.read(wkt);
std::unique_ptr<Geometry> expected = r.read(wktExpected);
+#ifdef HAVE_FENV
+#endif
std::unique_ptr<Geometry> result = CoverageUnion::geomunion(geom.get());
+#ifdef FE_INVALID
+#endif
try {
ensure_equals_geometry_xyzm(result.get(), expected.get());
diff --git a/util/geosop/CMakeLists.txt b/util/geosop/CMakeLists.txt
index 165727460..2351fc6ff 100644
--- a/util/geosop/CMakeLists.txt
+++ b/util/geosop/CMakeLists.txt
@@ -16,6 +16,10 @@ add_executable(geosop
target_link_libraries(geosop PRIVATE geos geos_c)
+ target_compile_definitions(geosop PRIVATE MISSING_FENV)
+endif()
install(TARGETS geosop
DESTINATION ${CMAKE_INSTALL_BINDIR}
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 05307cf30..bee8b75a9 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -26,7 +26,8 @@
#include <geos/io/WKBStreamReader.h>
#include <geos/io/WKBWriter.h>
-#if defined(HAVE_FENV)
+#define HAVE_FENV
#include <cfenv>
#endif
#include <fstream>
@@ -396,30 +397,44 @@ void GeosOp::run(OpArguments& opArgs) {
try {
+#ifdef HAVE_FENV
std::feclearexcept(FE_ALL_EXCEPT); // clear floating-point status flags
-#endif
execute(op, opArgs);
+#ifdef FE_INEXACT
// Catch everything except for FE_INEXACT, which is usually harmless
const int fpexp = std::fetestexcept(FE_ALL_EXCEPT ^ FE_INEXACT);
+#else
+ const int fpexp = std::fetestexcept(FE_ALL_EXCEPT);
+#endif
if (args.isVerbose && (fpexp != 0)) {
std::cerr << "Operation raised floating-point environment flag(s):";
if (fpexp & FE_DIVBYZERO)
std::cerr << " FE_DIVBYZERO";
+#endif
+#ifdef FE_INEXACT
if (fpexp & FE_INEXACT)
std::cerr << " FE_INEXACT";
+#endif
+#ifdef FE_INVALID
if (fpexp & FE_INVALID)
std::cerr << " FE_INVALID";
+#endif
+#ifdef FE_OVERFLOW
if (fpexp & FE_OVERFLOW)
std::cerr << " FE_OVERFLOW";
+#endif
if (fpexp & FE_UNDERFLOW)
std::cerr << " FE_UNDERFLOW";
+#endif
std::cerr << std::endl;
-#endif
+#else // MISSING_FENV
+ execute(op, opArgs);
+#endif // HAVE_FENV
catch (std::exception &e) {
std::cerr << "Run-time exception: " << e.what() << std::endl;
Summary of changes:
.github/workflows/ci.yml | 43 ++++++++++++++++++++++
CMakeLists.txt | 13 +++----
NEWS.md | 7 +++-
tests/unit/CMakeLists.txt | 5 +++
.../distance/DiscreteHausdorffDistanceTest.cpp | 7 ++++
tests/unit/capi/GEOSDistanceTest.cpp | 11 ++++++
tests/unit/capi/GEOSIntersectionTest.cpp | 2 +
tests/unit/capi/GEOSProjectTest.cpp | 8 ++++
tests/unit/capi/GEOSVoronoiDiagramTest.cpp | 7 ++++
tests/unit/capi/capi_test_utils.h | 5 +++
tests/unit/geom/EnvelopeTest.cpp | 15 ++++++++
.../operation/overlayng/CoverageUnionNGTest.cpp | 7 ++++
util/geosop/CMakeLists.txt | 4 ++
util/geosop/GeosOp.cpp | 25 ++++++++++---
14 files changed, 146 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits
