[geos-commits] [SCM] GEOS branch main updated. f175f9af82fd0c4ab2d913205ff8480b7a12a055
git at osgeo.org
git at osgeo.org
Wed Dec 10 11:15:03 PST 2025
the project "GEOS".
The branch, main has been updated
via f175f9af82fd0c4ab2d913205ff8480b7a12a055 (commit)
via bfa9cd118979a46de25a2355fd0b9973c476691a (commit)
from ad73047bf08756f0786c920358059fe3b9c5fa02 (commit)
revisions in full, below.
commit f175f9af82fd0c4ab2d913205ff8480b7a12a055
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Dec 10 11:13:59 2025 -0800
Quiet FP_DIVBYZERO exception from CGAlgorithmsDD::intersection showing in downstream libraries, closes #1235
diff --git a/include/geos/math/DD.h b/include/geos/math/DD.h
index 7be00a6f7..83b26f6a3 100644
--- a/include/geos/math/DD.h
+++ b/include/geos/math/DD.h
@@ -114,6 +114,7 @@ class GEOS_DLL DD {
int signum() const;
DD rint() const;
+ void setNaN();
public:
DD(double p_hi, double p_lo) : hi(p_hi), lo(p_lo) {};
@@ -166,6 +167,7 @@ class GEOS_DLL DD {
static DD pow(const DD &d, int exp);
static DD trunc(const DD &d);
+ bool isInf() const;
bool isNaN() const;
bool isNegative() const;
bool isPositive() const;
diff --git a/src/algorithm/CGAlgorithmsDD.cpp b/src/algorithm/CGAlgorithmsDD.cpp
index 0d61b335e..df6fd0112 100644
--- a/src/algorithm/CGAlgorithmsDD.cpp
+++ b/src/algorithm/CGAlgorithmsDD.cpp
@@ -139,19 +139,12 @@ CGAlgorithmsDD::intersection(const CoordinateXY& p1, const CoordinateXY& p2,
DD y = (qx * pw) - (px * qw);
DD w = (px * qy) - (qx * py);
+ if (w.isZero())
+ return CoordinateXY::getNull();
double xInt = (x / w).ToDouble();
double yInt = (y / w).ToDouble();
- Coordinate rv;
- if (!std::isfinite(xInt) || !std::isfinite(yInt)) {
- rv.setNull();
- return rv;
- rv.x = xInt;
- rv.y = yInt;
- return rv;
+ return {xInt, yInt};
/* public static */
diff --git a/src/math/DD.cpp b/src/math/DD.cpp
index 662f1f1d3..e158dc685 100644
--- a/src/math/DD.cpp
+++ b/src/math/DD.cpp
@@ -20,8 +20,16 @@
namespace geos {
namespace math { // geos.util
+/* private */
+void DD::setNaN()
+ hi = std::numeric_limits<double>::quiet_NaN();
+/* public */
+bool DD::isInf() const
+ return std::isinf(hi);
/* public */
bool DD::isNaN() const
@@ -351,6 +359,7 @@ DD DD::determinant(double x1, double y1, double x2, double y2)
return determinant(DD(x1), DD(y1), DD(x2), DD(y2) );
* Computes the value of this number raised to an integral power.
* Follows semantics of Java Math.pow as closely as possible.
diff --git a/tests/unit/algorithm/MinimumAreaRectangleTest.cpp b/tests/unit/algorithm/MinimumAreaRectangleTest.cpp
index a36723bb8..55cf17826 100644
--- a/tests/unit/algorithm/MinimumAreaRectangleTest.cpp
+++ b/tests/unit/algorithm/MinimumAreaRectangleTest.cpp
@@ -147,35 +147,37 @@ template<>
template<>
void object::test<10>()
- // bool error = false;
- // try {
- checkMinRectangle(
- "LINESTRING(-99.48710639268086 34.79029839231914,-99.48370699999998 34.78689899963806,-99.48152167568102 34.784713675318976)",
- "POLYGON ((-99.48710639268066 34.790298392318675, -99.48710639268066 34.790298392318675, -99.48152167568082 34.78471367531866, -99.48152167568082 34.78471367531866, -99.48710639268066 34.790298392318675))");
- // } catch (std::exception& e) {
- // error = true;
- // // errorMessage = e.what();
- // ensure("caught exception", error == true);
+ checkMinRectangle(
+ "LINESTRING(-99.48710639268086 34.79029839231914,-99.48370699999998 34.78689899963806,-99.48152167568102 34.784713675318976)",
+ "POLYGON ((-99.48710639268066 34.790298392318675, -99.48710639268066 34.790298392318675, -99.48152167568082 34.78471367531866, -99.48152167568082 34.78471367531866, -99.48710639268066 34.790298392318675))");
// testBadRectl
template<>
template<>
void object::test<11>()
- // try {
checkMinRectangle(
"POLYGON ((-5.21175 49.944633, -5.77435 50.021367, -5.7997 50.0306, -5.81815 50.0513, -5.82625 50.073567, -5.83085 50.1173, -6.2741 56.758767, -5.93245 57.909, -5.1158 58.644533, -5.07915 58.661733, -3.42575 58.686633, -3.1392 58.6685, -3.12495 58.666233, -1.88745 57.6444, 1.68845 52.715133, 1.7057 52.6829, 1.70915 52.6522, 1.7034 52.585433, 1.3867 51.214033, 1.36595 51.190267, 1.30485 51.121967, 0.96365 50.928567, 0.93025 50.912433, 0.1925 50.7436, -5.21175 49.944633))",
"POLYGON ((1.8583607388069103 50.41649058582797, -5.816631979932251 49.904263313964535, -6.395241388167441 58.57389735949991, 1.2797513305717105 59.08612463136336, 1.8583607388069103 50.41649058582797))");
- // error = true;
+// https://github.com/libgeos/geos/issues/1235
+// throwing FE_DIVBYZERO
+template<>
+template<>
+void object::test<12>()
+ "POLYGON ((-100 -100, -100 100, 100 100, 100 -100, -100 -100))",
+ "POLYGON ((-100 -100, -100 100, 100 100, 100 -100, -100 -100))");
} // namespace tut
diff --git a/tests/unit/geos_unit.cpp b/tests/unit/geos_unit.cpp
index 9526b009e..cbd1a86cc 100644
--- a/tests/unit/geos_unit.cpp
+++ b/tests/unit/geos_unit.cpp
@@ -50,7 +50,7 @@ usage()
<< " " << module << " geos::geom::Envelope\n"
<< " " << module << " geos::geom::Envelope 2\n"
<< endl
- << "GEOS homepage: http://geos.osgeo.org" << endl;
+ << "GEOS homepage: https://libgeos.org" << endl;
int
commit bfa9cd118979a46de25a2355fd0b9973c476691a
Date: Wed Dec 10 10:49:16 2025 -0800
Use nameless catch for exceptions that do not use exception var
diff --git a/src/linearref/LinearGeometryBuilder.cpp b/src/linearref/LinearGeometryBuilder.cpp
index 445f2d70d..947747ba8 100644
--- a/src/linearref/LinearGeometryBuilder.cpp
+++ b/src/linearref/LinearGeometryBuilder.cpp
@@ -117,10 +117,9 @@ LinearGeometryBuilder::endLine()
try {
line = geomFact->createLineString(std::move(coordList));
- catch(util::IllegalArgumentException & ex) {
+ catch(util::IllegalArgumentException &) {
// exception is due to too few points in line.
// only propagate if not ignoring short lines
- ::geos::ignore_unused_variable_warning(ex);
if(! ignoreInvalidLines) {
throw;
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 82cd91bcc..35a93b0e9 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -204,8 +204,7 @@ ClassicUnionStrategy::Union(const geom::Geometry* g0, const geom::Geometry* g1)
try {
return operation::overlayng::OverlayNGRobust::Overlay(g0, g1, operation::overlayng::OverlayNG::UNION);
- catch (const util::TopologyException &ex) {
+ catch (const util::TopologyException &) {
// union-by-buffer only works for polygons
if (g0->getDimension() != 2 || g1->getDimension() != 2)
throw;
diff --git a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
index e7e917509..f17568ef7 100644
--- a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
+++ b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
@@ -202,16 +202,15 @@ void object::test<8> ()
try {
MaximumInscribedCircle mic(g1.get(), 1);
mic.getCenter();
- } catch (const util::GEOSException & e) {
- ::geos::ignore_unused_variable_warning(e);
+ } catch (const util::GEOSException &) {
auto g2 = reader_.read("POLYGON ((0 0, 1 0, 2 NaN, 0 0))");
try {
mic.getCenter();
+ catch (const util::GEOSException &) {
diff --git a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
index 86472ac06..b98c8f8d5 100644
--- a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
@@ -76,27 +76,24 @@ void object::test<1> ()
try {
checkDensifiedFrechet("LINESTRING (0 0, 2 1)", "LINESTRING EMPTY", 0.0, 0);
- catch(const geos::util::IllegalArgumentException& e) {
+ catch(const geos::util::IllegalArgumentException &) {
// We do expect an exception
// too big densify factor
try {
checkDensifiedFrechet("LINESTRING (0 0, 2 1)", "LINESTRING EMPTY", 1 + 1e-10, 0);
// too small positive densify factor
try {
checkDensifiedFrechet("LINESTRING (0 0, 2 1)", "LINESTRING EMPTY", 1e-30, 0);
diff --git a/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp b/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
index 66865b349..01095d0f5 100644
--- a/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
+++ b/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
@@ -46,8 +46,7 @@ struct test_coverageunionng_data {
try {
ensure_equals_geometry_xyzm(result.get(), expected.get());
- } catch (const std::exception& e) {
+ } catch (const std::exception &) {
std::string wkt_result = w.write(result.get());
std::cerr << std::endl << wkt_result << std::endl;
throw;
diff --git a/tests/unit/triangulate/VoronoiTest.cpp b/tests/unit/triangulate/VoronoiTest.cpp
index dd9066a95..e1ffaf6ee 100644
--- a/tests/unit/triangulate/VoronoiTest.cpp
+++ b/tests/unit/triangulate/VoronoiTest.cpp
@@ -323,8 +323,7 @@ void object::test<14>
try {
runVoronoi(wkt, "", 0, false, true);
fail();
- } catch (const geos::util::GEOSException & e) {
+ } catch (const geos::util::GEOSException &) {
Summary of changes:
include/geos/math/DD.h | 2 ++
src/algorithm/CGAlgorithmsDD.cpp | 15 +++------
src/linearref/LinearGeometryBuilder.cpp | 3 +-
src/math/DD.cpp | 13 ++++++--
src/operation/union/CascadedPolygonUnion.cpp | 3 +-
tests/unit/algorithm/MinimumAreaRectangleTest.cpp | 36 ++++++++++++----------
.../construct/MaximumInscribedCircleTest.cpp | 7 ++---
.../distance/DiscreteFrechetDistanceTest.cpp | 9 ++----
tests/unit/geos_unit.cpp | 2 +-
.../operation/overlayng/CoverageUnionNGTest.cpp | 3 +-
tests/unit/triangulate/VoronoiTest.cpp | 3 +-
11 files changed, 47 insertions(+), 49 deletions(-)
hooks/post-receive
More information about the geos-commits
