[geos-commits] [SCM] GEOS branch 3.13 updated. f92d697680a281f8cc26d5591b42ffa8efc7818b
    git at osgeo.org
    git at osgeo.org
    Wed Feb 12 16:15:22 PST 2025
the project "GEOS".
The branch, 3.13 has been updated
       via  f92d697680a281f8cc26d5591b42ffa8efc7818b (commit)
      from  d95a5158ff68eceb18a7327dea993e26b50aad8d (commit)
revisions in full, below.
commit f92d697680a281f8cc26d5591b42ffa8efc7818b
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Feb 12 15:58:41 2025 -0800
    Remove obsolete overlay files
diff --git a/include/geos/operation/overlay/MaximalEdgeRing.h b/include/geos/operation/overlay/MaximalEdgeRing.h
deleted file mode 100644
index ad918dfce..000000000
--- a/include/geos/operation/overlay/MaximalEdgeRing.h
+++ /dev/null
@@ -1,105 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2006 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: operation/overlay/MaximalEdgeRing.java rev. 1.15 (JTS-1.10)
-#pragma once
-#include <geos/export.h>
-#include <vector>
-#include <geos/geomgraph/EdgeRing.h> // for inheritance
-// Forward declarations
-namespace geos {
-namespace geom {
-class GeometryFactory;
-namespace geomgraph {
-class DirectedEdge;
-//class EdgeRing;
-namespace operation {
-namespace overlay {
-class MinimalEdgeRing;
-namespace geos {
-namespace operation { // geos::operation
-namespace overlay { // geos::operation::overlay
-/** \brief
- * A ring of [DirectedEdges](@ref geomgraph::DirectedEdge) which may contain nodes of degree > 2.
- * A MaximalEdgeRing may represent two different spatial entities:
- * - a single polygon possibly containing inversions (if the ring is oriented CW)
- * - a single hole possibly containing exversions (if the ring is oriented CCW)
- * If the MaximalEdgeRing represents a polygon,
- * the interior of the polygon is strongly connected.
- * These are the form of rings used to define polygons under some spatial data models.
- * However, under the OGC SFS model, [MinimalEdgeRings](@ref MinimalEdgeRing) are required.
- * A MaximalEdgeRing can be converted to a list of MinimalEdgeRings using the
- * {@link #buildMinimalRings() } method.
- * @see com.vividsolutions.jts.operation.overlay.MinimalEdgeRing
-class GEOS_DLL MaximalEdgeRing: public geomgraph::EdgeRing {
-public:
-    MaximalEdgeRing(geomgraph::DirectedEdge* start,
-                    const geom::GeometryFactory* geometryFactory);
-    // throw(const TopologyException &)
-    ~MaximalEdgeRing() override = default;
-    geomgraph::DirectedEdge* getNext(geomgraph::DirectedEdge* de) override;
-    void setEdgeRing(geomgraph::DirectedEdge* de, geomgraph::EdgeRing* er) override;
-    /// \brief
-    /// This function returns a newly allocated vector of
-    /// pointers to newly allocated MinimalEdgeRing objects.
-    /// @deprecated pass the vector yourself instead
-    std::vector<MinimalEdgeRing*>* buildMinimalRings();
-    /// \brief
-    /// This function pushes pointers to newly allocated  MinimalEdgeRing
-    /// objects to the provided vector.
-    void buildMinimalRings(std::vector<MinimalEdgeRing*>& minEdgeRings);
-    void buildMinimalRings(std::vector<EdgeRing*>& minEdgeRings);
-    /// \brief
-    /// For all nodes in this EdgeRing,
-    /// link the DirectedEdges at the node to form minimalEdgeRings
-    void linkDirectedEdgesForMinimalEdgeRings();
-} // namespace geos::operation::overlay
diff --git a/include/geos/operation/overlay/MinimalEdgeRing.h b/include/geos/operation/overlay/MinimalEdgeRing.h
index c2df90eab..000000000
--- a/include/geos/operation/overlay/MinimalEdgeRing.h
+++ /dev/null
@@ -1,80 +0,0 @@
- * Last port: operation/overlay/MinimalEdgeRing.java rev. 1.13 (JTS-1.10)
-#pragma once
-#include <geos/geomgraph/DirectedEdge.h> // for inlines
-#include <vector>
-namespace geos {
-namespace geom {
-class EdgeRing;
-namespace geos {
-/** \brief
- * A ring of [Edges](@ref geomgraph::Edge) with the property that no node
- * has degree greater than 2.
- * These are the form of rings required to represent polygons
- * under the OGC SFS spatial data model.
- * @see operation::overlay::MaximalEdgeRing
-class GEOS_DLL MinimalEdgeRing: public geomgraph::EdgeRing {
-public:
-    MinimalEdgeRing(geomgraph::DirectedEdge* start,
-    ~MinimalEdgeRing() override {};
-        return de->getNextMin();
-                     geomgraph::EdgeRing* er) override
-        de->setMinEdgeRing(er);
diff --git a/include/geos/operation/overlay/OverlayNodeFactory.h b/include/geos/operation/overlay/OverlayNodeFactory.h
index 74ba8d955..000000000
--- a/include/geos/operation/overlay/OverlayNodeFactory.h
+++ /dev/null
@@ -1,56 +0,0 @@
- * Last port: operation/overlay/OverlayNodeFactory.java rev. 1.11 (JTS-1.10)
-#pragma once
-#include <vector>
-#include <geos/geomgraph/NodeFactory.h> // for inheritance
-namespace geos {
-namespace geom {
-class Coordinate;
-class Node;
-namespace geos {
-/** \brief
- * Creates nodes for use in the geomgraph::PlanarGraph constructed during
- * overlay operations. NOTE: also used by operation::valid
-class GEOS_DLL OverlayNodeFactory: public geomgraph::NodeFactory {
-public:
-    OverlayNodeFactory(): geomgraph::NodeFactory() {}
-    geomgraph::Node* createNode(const geom::Coordinate& coord) const override;
-    static const geomgraph::NodeFactory& instance();
diff --git a/include/geos/operation/overlay/PolygonBuilder.h b/include/geos/operation/overlay/PolygonBuilder.h
index e39e9b6c0..000000000
--- a/include/geos/operation/overlay/PolygonBuilder.h
+++ /dev/null
@@ -1,210 +0,0 @@
- * Last port: operation/overlay/PolygonBuilder.java rev. 1.20 (JTS-1.10)
-#pragma once
-#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
-#include <vector>
-#ifdef _MSC_VER
-#pragma warning(push)
-#pragma warning(disable: 4251) // warning C4251: needs to have dll-interface to be used by clients of class
-#endif
-namespace geos {
-namespace geom {
-class Geometry;
-class Coordinate;
-class EdgeRing;
-class Node;
-class PlanarGraph;
-class MaximalEdgeRing;
-namespace geos {
-/** \brief
- * Forms Polygon out of a graph of geomgraph::DirectedEdge.
- * The edges to use are marked as being in the result Area.
-class GEOS_DLL PolygonBuilder {
-public:
-    PolygonBuilder(const geom::GeometryFactory* newGeometryFactory);
-    ~PolygonBuilder();
-     * Add a complete graph.
-     * The graph is assumed to contain one or more polygons,
-     * possibly with holes.
-    void add(geomgraph::PlanarGraph* graph);
-     * Add a set of edges and nodes, which form a graph.
-    void add(const std::vector<geomgraph::DirectedEdge*>* dirEdges,
-             const std::vector<geomgraph::Node*>* nodes);
-    std::vector<std::unique_ptr<geom::Geometry>> getPolygons();
-private:
-    const geom::GeometryFactory* geometryFactory;
-    std::vector<geomgraph::EdgeRing*> shellList;
-     * For all DirectedEdges in result, form them into MaximalEdgeRings
-     * @param maxEdgeRings
-     *   Formed MaximalEdgeRings will be pushed to this vector.
-     *   Ownership of the elements is transferred to caller.
-    void buildMaximalEdgeRings(
-        const std::vector<geomgraph::DirectedEdge*>* dirEdges,
-        std::vector<MaximalEdgeRing*>& maxEdgeRings);
-    void buildMinimalEdgeRings(
-        std::vector<MaximalEdgeRing*>& maxEdgeRings,
-        std::vector<geomgraph::EdgeRing*>& newShellList,
-        std::vector<geomgraph::EdgeRing*>& freeHoleList,
-        std::vector<MaximalEdgeRing*>& edgeRings);
-     * This method takes a list of MinimalEdgeRings derived from a
-     * MaximalEdgeRing, and tests whether they form a Polygon.
-     * This is the case if there is a single shell
-     * in the list.  In this case the shell is returned.
-     * The other possibility is that they are a series of connected
-     * holes, in which case no shell is returned.
-     * @return the shell geomgraph::EdgeRing, if there is one
-     * @return NULL, if all the rings are holes
-    geomgraph::EdgeRing* findShell(std::vector<MinimalEdgeRing*>* minEdgeRings);
-     * This method assigns the holes for a Polygon (formed from a list of
-     * MinimalEdgeRings) to its shell.
-     * Determining the holes for a MinimalEdgeRing polygon serves two
-     * purposes:
-     *  - it is faster than using a point-in-polygon check later on.
-     *  - it ensures correctness, since if the PIP test was used the point
-     *    chosen might lie on the shell, which might return an incorrect
-     *    result from the PIP test
-    void placePolygonHoles(geomgraph::EdgeRing* shell,
-                           std::vector<MinimalEdgeRing*>* minEdgeRings);
-     * For all rings in the input list,
-     * determine whether the ring is a shell or a hole
-     * and add it to the appropriate list.
-     * Due to the way the DirectedEdges were linked,
-     * a ring is a shell if it is oriented CW, a hole otherwise.
-    void sortShellsAndHoles(std::vector<MaximalEdgeRing*>& edgeRings,
-                            std::vector<geomgraph::EdgeRing*>& freeHoleList);
-    struct FastPIPRing {
-        geomgraph::EdgeRing* edgeRing;
-        algorithm::locate::IndexedPointInAreaLocator* pipLocator;
-    /** \brief
-     * This method determines finds a containing shell for all holes
-     * which have not yet been assigned to a shell.
-     * These "free" holes should all be <b>properly</b> contained in
-     * their parent shells, so it is safe to use the
-     * <code>findEdgeRingContaining</code> method.
-     * This is the case because any holes which are NOT
-     * properly contained (i.e. are connected to their
-     * parent shell) would have formed part of a MaximalEdgeRing
-     * and been handled in a previous step.
-     * @throws TopologyException if a hole cannot be assigned to a shell
-    void placeFreeHoles(std::vector<FastPIPRing>& newShellList,
-    // throw(const TopologyException&)
-    /** \brief
-     * Find the innermost enclosing shell geomgraph::EdgeRing containing the
-     * argument geomgraph::EdgeRing, if any.
-     * The innermost enclosing ring is the <i>smallest</i> enclosing ring.
-     * The algorithm used depends on the fact that:
-     * ring A contains ring B iff envelope(ring A)
-     * contains envelope(ring B)
-     * This routine is only safe to use if the chosen point of the hole
-     * is known to be properly contained in a shell
-     * (which is guaranteed to be the case if the hole does not touch
-     * its shell)
-     * @return containing geomgraph::EdgeRing, if there is one
-     * @return NULL if no containing geomgraph::EdgeRing is found
-    geomgraph::EdgeRing* findEdgeRingContaining(geomgraph::EdgeRing* testEr,
-            std::vector<FastPIPRing>& newShellList);
-    std::vector<std::unique_ptr<geom::Geometry>> computePolygons(
-        std::vector<geomgraph::EdgeRing*>& newShellList);
-     * Checks the current set of shells (with their associated holes) to
-     * see if any of them contain the point.
-#ifdef _MSC_VER
-#pragma warning(pop)
-#endif
diff --git a/src/operation/overlay/MaximalEdgeRing.cpp b/src/operation/overlay/MaximalEdgeRing.cpp
index 6221944e1..000000000
--- a/src/operation/overlay/MaximalEdgeRing.cpp
+++ /dev/null
@@ -1,136 +0,0 @@
- * Copyright (C) 2005-2006 Refractions Research Inc.
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
-#include <geos/operation/overlay/MaximalEdgeRing.h>
-#include <geos/operation/overlay/MinimalEdgeRing.h>
-#include <geos/geomgraph/Node.h>
-#include <geos/geomgraph/EdgeEndStar.h>
-#include <geos/geomgraph/DirectedEdgeStar.h>
-#include <geos/util.h>
-#include <cassert>
-#include <vector>
-#ifndef GEOS_DEBUG
-#define GEOS_DEBUG 0
-#endif
-#if GEOS_DEBUG
-#include <iostream>
-#endif
-using namespace geos::geomgraph;
-using namespace geos::geom;
-namespace geos {
-namespace operation { // geos.operation
-namespace overlay { // geos.operation.overlay
-/*public*/
-MaximalEdgeRing::MaximalEdgeRing(DirectedEdge* start,
-                                 const GeometryFactory* p_geometryFactory)
-// throw(const TopologyException &)
-    EdgeRing(start, p_geometryFactory)
-    computePoints(start);
-    computeRing();
-#if GEOS_DEBUG
-    std::cerr << "MaximalEdgeRing[" << this << "] ctor" << std::endl;
-#endif
-/*public*/
-DirectedEdge*
-MaximalEdgeRing::getNext(DirectedEdge* de)
-    return de->getNext();
-/*public*/
-void
-MaximalEdgeRing::setEdgeRing(DirectedEdge* de, EdgeRing* er)
-    de->setEdgeRing(er);
-/*public*/
-void
-MaximalEdgeRing::linkDirectedEdgesForMinimalEdgeRings()
-    DirectedEdge* de = startDe;
-    do {
-        Node* node = de->getNode();
-        EdgeEndStar* ees = node->getEdges();
-        DirectedEdgeStar* des = detail::down_cast<DirectedEdgeStar*>(ees);
-        des->linkMinimalDirectedEdges(this);
-        de = de->getNext();
-    while(de != startDe);
-/*public*/
-std::vector<MinimalEdgeRing*>*
-MaximalEdgeRing::buildMinimalRings()
-    std::vector<MinimalEdgeRing*>* minEdgeRings = new std::vector<MinimalEdgeRing*>;
-    buildMinimalRings(*minEdgeRings);
-    return minEdgeRings;
-/*public*/
-void
-MaximalEdgeRing::buildMinimalRings(std::vector<MinimalEdgeRing*>& minEdgeRings)
-    do {
-        if(de->getMinEdgeRing() == nullptr) {
-            MinimalEdgeRing* minEr = new MinimalEdgeRing(de, geometryFactory);
-            minEdgeRings.push_back(minEr);
-/*public*/
-void
-MaximalEdgeRing::buildMinimalRings(std::vector<EdgeRing*>& minEdgeRings)
-    do {
-} // namespace geos.operation.overlay
diff --git a/src/operation/overlay/MinimalEdgeRing.cpp b/src/operation/overlay/MinimalEdgeRing.cpp
index fd5cc2e72..000000000
--- a/src/operation/overlay/MinimalEdgeRing.cpp
+++ /dev/null
@@ -1,42 +0,0 @@
- * Copyright (C) 2005 Refractions Research Inc.
-namespace geos {
-MinimalEdgeRing::MinimalEdgeRing(geomgraph::DirectedEdge* start,
-                                 const geom::GeometryFactory* p_geometryFactory)
-    geomgraph::EdgeRing(start, p_geometryFactory)
-    computeRing();
diff --git a/src/operation/overlay/OverlayNodeFactory.cpp b/src/operation/overlay/OverlayNodeFactory.cpp
index 095008da5..000000000
--- a/src/operation/overlay/OverlayNodeFactory.cpp
+++ /dev/null
@@ -1,46 +0,0 @@
-#include <geos/operation/overlay/OverlayNodeFactory.h>
-namespace geos {
-Node*
-OverlayNodeFactory::createNode(const geom::Coordinate& coord) const
-    return new Node(coord, new DirectedEdgeStar());
-const NodeFactory&
-OverlayNodeFactory::instance()
-    static OverlayNodeFactory onf;
-    return onf;
diff --git a/src/operation/overlay/PolygonBuilder.cpp b/src/operation/overlay/PolygonBuilder.cpp
index e0223b432..000000000
--- a/src/operation/overlay/PolygonBuilder.cpp
+++ /dev/null
@@ -1,383 +0,0 @@
-#include <geos/operation/overlay/PolygonBuilder.h>
-#include <geos/operation/polygonize/EdgeRing.h>
-#include <geos/geomgraph/NodeMap.h>
-#include <geos/geomgraph/PlanarGraph.h>
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/LinearRing.h>
-#include <geos/geom/Polygon.h>
-#include <geos/algorithm/PointLocation.h>
-#include <geos/util/TopologyException.h>
-#include <geos/util/GEOSException.h>
-#include <vector>
-#include <cassert>
-#ifndef GEOS_DEBUG
-#endif
-#if GEOS_DEBUG
-#endif
-using namespace geos::algorithm;
-namespace geos {
-PolygonBuilder::PolygonBuilder(const GeometryFactory* newGeometryFactory)
-    geometryFactory(newGeometryFactory)
-PolygonBuilder::~PolygonBuilder()
-    for(std::size_t i = 0, n = shellList.size(); i < n; ++i) {
-        delete shellList[i];
-/*public*/
-void
-PolygonBuilder::add(PlanarGraph* graph)
-//throw(TopologyException *)
-    const std::vector<EdgeEnd*>* eeptr = graph->getEdgeEnds();
-    assert(eeptr);
-    const std::vector<EdgeEnd*>& ee = *eeptr;
-    std::size_t eeSize = ee.size();
-#if GEOS_DEBUG
-    std::cerr << __FUNCTION__ << ": PlanarGraph has " << eeSize << " EdgeEnds" << std::endl;
-#endif
-    std::vector<DirectedEdge*> dirEdges(eeSize);
-    for(std::size_t i = 0; i < eeSize; ++i) {
-        DirectedEdge* de = detail::down_cast<DirectedEdge*>(ee[i]);
-        dirEdges[i] = de;
-    const auto& nodeMap = graph->getNodeMap()->nodeMap;
-    std::vector<Node*> nodes;
-    nodes.reserve(nodeMap.size());
-    for(const auto& nodeIt: nodeMap) {
-        Node* node = nodeIt.second.get();
-        nodes.push_back(node);
-    add(&dirEdges, &nodes); // might throw a TopologyException *
-/*public*/
-void
-PolygonBuilder::add(const std::vector<DirectedEdge*>* dirEdges,
-                    const std::vector<Node*>* nodes)
-    PlanarGraph::linkResultDirectedEdges(nodes->begin(), nodes->end());
-    std::vector<MaximalEdgeRing*> maxEdgeRings;
-    buildMaximalEdgeRings(dirEdges, maxEdgeRings);
-    std::vector<EdgeRing*> freeHoleList;
-    std::vector<MaximalEdgeRing*> edgeRings;
-    buildMinimalEdgeRings(maxEdgeRings, shellList, freeHoleList, edgeRings);
-    sortShellsAndHoles(edgeRings, shellList, freeHoleList);
-    std::vector<FastPIPRing> indexedshellist;
-    for(auto const& shell : shellList) {
-        FastPIPRing pipRing { shell, new geos::algorithm::locate::IndexedPointInAreaLocator(*shell->getLinearRing()) };
-        indexedshellist.push_back(pipRing);
-    placeFreeHoles(indexedshellist, freeHoleList);
-    //Assert: every hole on freeHoleList has a shell assigned to it
-    for(auto const& shell : indexedshellist) {
-        delete shell.pipLocator;
-/*public*/
-std::vector<std::unique_ptr<Geometry>>
-PolygonBuilder::getPolygons()
-    std::vector<std::unique_ptr<Geometry>> resultPolyList = computePolygons(shellList);
-    return resultPolyList;
-/*private*/
-void
-PolygonBuilder::buildMaximalEdgeRings(const std::vector<DirectedEdge*>* dirEdges,
-#if GEOS_DEBUG
-    std::cerr << "PolygonBuilder::buildMaximalEdgeRings got " << dirEdges->size() << " dirEdges" << std::endl;
-#endif
-    std::vector<MaximalEdgeRing*>::size_type oldSize = maxEdgeRings.size();
-    for(std::size_t i = 0, n = dirEdges->size(); i < n; i++) {
-        DirectedEdge* de = (*dirEdges)[i];
-#if GEOS_DEBUG
-        std::cerr << "  dirEdge " << i << std::endl
-             << de->printEdge() << std::endl
-             << " inResult:" << de->isInResult() << std::endl
-             << " isArea:" << de->getLabel().isArea() << std::endl;
-#endif
-        if(de->isInResult() && de->getLabel().isArea()) {
-            // if this edge has not yet been processed
-            if(de->getEdgeRing() == nullptr) {
-                MaximalEdgeRing* er;
-                try {
-                    // MaximalEdgeRing constructor may throw
-                    er = new MaximalEdgeRing(de, geometryFactory);
-                catch(util::GEOSException&) {
-                    // cleanup if that happens (see stmlf-cases-20061020.xml)
-                    for(std::size_t p_i = oldSize, p_n = maxEdgeRings.size(); p_i < p_n; p_i++) {
-                        delete maxEdgeRings[p_i];
-                    //cerr << "Exception! " << e.what() << std::endl;
-                    throw;
-                maxEdgeRings.push_back(er);
-                er->setInResult();
-                //System.out.println("max node degree=" + er.getMaxDegree());
-#if GEOS_DEBUG
-    std::cerr << "  pushed " << maxEdgeRings.size() - oldSize << " maxEdgeRings" << std::endl;
-#endif
-/*private*/
-void
-PolygonBuilder::buildMinimalEdgeRings(
-    std::vector<EdgeRing*>& newShellList, std::vector<EdgeRing*>& freeHoleList,
-    for(std::size_t i = 0, n = maxEdgeRings.size(); i < n; ++i) {
-        MaximalEdgeRing* er = maxEdgeRings[i];
-#if GEOS_DEBUG
-        std::cerr << "buildMinimalEdgeRings: maxEdgeRing " << i << " has " << er->getMaxNodeDegree() << " maxNodeDegree" << std::endl;
-#endif
-        if(er->getMaxNodeDegree() > 2) {
-            er->linkDirectedEdgesForMinimalEdgeRings();
-            std::vector<MinimalEdgeRing*> minEdgeRings;
-            er->buildMinimalRings(minEdgeRings);
-            // at this point we can go ahead and attempt to place
-            // holes, if this EdgeRing is a polygon
-            EdgeRing* shell = findShell(&minEdgeRings);
-            if(shell != nullptr) {
-                placePolygonHoles(shell, &minEdgeRings);
-                newShellList.push_back(shell);
-            else {
-                freeHoleList.insert(freeHoleList.end(),
-                                    minEdgeRings.begin(),
-                                    minEdgeRings.end());
-            delete er;
-        else {
-            edgeRings.push_back(er);
-/*private*/
-EdgeRing*
-PolygonBuilder::findShell(std::vector<MinimalEdgeRing*>* minEdgeRings)
-    int shellCount = 0;
-    EdgeRing* shell = nullptr;
-#if GEOS_DEBUG
-    std::cerr << "PolygonBuilder::findShell got " << minEdgeRings->size() << " minEdgeRings" << std::endl;
-#endif
-    for(std::size_t i = 0, n = minEdgeRings->size(); i < n; ++i) {
-        EdgeRing* er = (*minEdgeRings)[i];
-        if(! er->isHole()) {
-            shell = er;
-            ++shellCount;
-    if(shellCount > 1) {
-        throw util::TopologyException("found two shells in MinimalEdgeRing list");
-    return shell;
-/*private*/
-void
-PolygonBuilder::placePolygonHoles(EdgeRing* shell,
-        MinimalEdgeRing* er = (*minEdgeRings)[i];
-        if(er->isHole()) {
-            er->setShell(shell);
-/*private*/
-void
-PolygonBuilder::sortShellsAndHoles(std::vector<MaximalEdgeRing*>& edgeRings,
-                                   std::vector<EdgeRing*>& newShellList, std::vector<EdgeRing*>& freeHoleList)
-    for(std::size_t i = 0, n = edgeRings.size(); i < n; i++) {
-        EdgeRing* er = edgeRings[i];
-        //er->setInResult();
-            freeHoleList.push_back(er);
-        else {
-            newShellList.push_back(er);
-/*private*/
-void
-PolygonBuilder::placeFreeHoles(std::vector<FastPIPRing>& newShellList,
-                               std::vector<EdgeRing*>& freeHoleList)
-    for(std::vector<EdgeRing*>::iterator
-            it = freeHoleList.begin(), itEnd = freeHoleList.end();
-            it != itEnd;
-            ++it) {
-        EdgeRing* hole = *it;
-        // only place this hole if it doesn't yet have a shell
-        if(hole->getShell() == nullptr) {
-            EdgeRing* shell = findEdgeRingContaining(hole, newShellList);
-            if(shell == nullptr) {
-#if GEOS_DEBUG
-                std::cerr << "CREATE TABLE shells (g geometry);" << std::endl;
-                std::cerr << "CREATE TABLE hole (g geometry);" << std::endl;
-                for(std::vector<FastPIPRing>::iterator rIt = newShellList.begin(),
-                        rEnd = newShellList.end(); rIt != rEnd; rIt++) {
-                    std::unique_ptr<Geometry> geom = (*rIt).edgeRing->toPolygon(geometryFactory);
-                    std::cerr << "INSERT INTO shells VALUES ('"
-                              << *geom
-                              << "');" << std::endl;
-                std::unique_ptr<Geometry> geom = hole->toPolygon(geometryFactory);
-                std::cerr << "INSERT INTO hole VALUES ('"
-                          << *geom
-#endif
-                //assert(shell!=NULL); // unable to assign hole to a shell
-                throw util::TopologyException("unable to assign hole to a shell");
-            hole->setShell(shell);
-/*private*/
-EdgeRing*
-PolygonBuilder::findEdgeRingContaining(EdgeRing* testEr,
-    LinearRing* testRing = testEr->getLinearRing();
-    const Envelope* testEnv = testRing->getEnvelopeInternal();
-    EdgeRing* minShell = nullptr;
-    const Envelope* minShellEnv = nullptr;
-    for(auto const& tryShell : newShellList) {
-        LinearRing* tryShellRing = tryShell.edgeRing->getLinearRing();
-        const Envelope* tryShellEnv = tryShellRing->getEnvelopeInternal();
-        // the hole envelope cannot equal the shell envelope
-        // (also guards against testing rings against themselves)
-        if(tryShellEnv->equals(testEnv)) {
-            continue;
-        // hole must be contained in shell
-        if(!tryShellEnv->contains(testEnv)) {
-            continue;
-        const CoordinateSequence* tsrcs = tryShellRing->getCoordinatesRO();
-        const Coordinate& testPt = operation::polygonize::EdgeRing::ptNotInList(testRing->getCoordinatesRO(), tsrcs);
-        bool isContained = false;
-        if(tryShell.pipLocator->locate(&testPt) != Location::EXTERIOR) {
-            isContained = true;
-        // check if this new containing ring is smaller than
-        // the current minimum ring
-        if(isContained) {
-            if(minShell == nullptr
-                    || minShellEnv->contains(tryShellEnv)) {
-                minShell = tryShell.edgeRing;
-                minShellEnv = minShell->getLinearRing()->getEnvelopeInternal();
-    return minShell;
-/*private*/
-PolygonBuilder::computePolygons(std::vector<EdgeRing*>& newShellList)
-#if GEOS_DEBUG
-    std::cerr << "PolygonBuilder::computePolygons: got " << newShellList.size() << " shells" << std::endl;
-#endif
-    std::vector<std::unique_ptr<Geometry>> resultPolyList;
-    // add Polygons for all shells
-    for(std::size_t i = 0, n = newShellList.size(); i < n; i++) {
-        EdgeRing* er = newShellList[i];
-        auto poly = er->toPolygon(geometryFactory);
-        resultPolyList.push_back(std::move(poly));
Summary of changes:
 include/geos/operation/overlay/MaximalEdgeRing.h   | 105 ------
 include/geos/operation/overlay/MinimalEdgeRing.h   |  80 -----
 .../geos/operation/overlay/OverlayNodeFactory.h    |  56 ---
 include/geos/operation/overlay/PolygonBuilder.h    | 210 -----------
 src/operation/overlay/MaximalEdgeRing.cpp          | 136 --------
 src/operation/overlay/MinimalEdgeRing.cpp          |  42 ---
 src/operation/overlay/OverlayNodeFactory.cpp       |  46 ---
 src/operation/overlay/PolygonBuilder.cpp           | 383 ---------------------
 8 files changed, 1058 deletions(-)
 delete mode 100644 include/geos/operation/overlay/MaximalEdgeRing.h
 delete mode 100644 include/geos/operation/overlay/MinimalEdgeRing.h
 delete mode 100644 include/geos/operation/overlay/OverlayNodeFactory.h
 delete mode 100644 include/geos/operation/overlay/PolygonBuilder.h
 delete mode 100644 src/operation/overlay/MaximalEdgeRing.cpp
 delete mode 100644 src/operation/overlay/MinimalEdgeRing.cpp
 delete mode 100644 src/operation/overlay/OverlayNodeFactory.cpp
 delete mode 100644 src/operation/overlay/PolygonBuilder.cpp
hooks/post-receive
More information about the geos-commits
