[geos-commits] [SCM] GEOS branch 3.12 updated. 4c5eddc954a98a65119c25098f40771bb072fd05
git at osgeo.org
git at osgeo.org
Wed Feb 12 16:16:09 PST 2025
the project "GEOS".
The branch, 3.12 has been updated
via 4c5eddc954a98a65119c25098f40771bb072fd05 (commit)
from ff096655cf3c7fd5d374aa584c6c383dd2a1473a (commit)
revisions in full, below.
commit 4c5eddc954a98a65119c25098f40771bb072fd05
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Feb 12 15:58:41 2025 -0800
Remove obsolete overlay files
diff --git a/include/geos/operation/overlay/MaximalEdgeRing.h b/include/geos/operation/overlay/MaximalEdgeRing.h
deleted file mode 100644
index ad918dfce..000000000
--- a/include/geos/operation/overlay/MaximalEdgeRing.h
+++ /dev/null
@@ -1,105 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2006 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: operation/overlay/MaximalEdgeRing.java rev. 1.15 (JTS-1.10)
-#pragma once
-#include <geos/export.h>
-#include <vector>
-#include <geos/geomgraph/EdgeRing.h> // for inheritance
-// Forward declarations
-namespace geos {
-namespace geom {
-class GeometryFactory;
-namespace geomgraph {
-class DirectedEdge;
-//class EdgeRing;
-namespace operation {
-namespace overlay {
-class MinimalEdgeRing;
-namespace geos {
-namespace operation { // geos::operation
-namespace overlay { // geos::operation::overlay
-/** \brief
- * A ring of [DirectedEdges](@ref geomgraph::DirectedEdge) which may contain nodes of degree > 2.
- * A MaximalEdgeRing may represent two different spatial entities:
- * - a single polygon possibly containing inversions (if the ring is oriented CW)
- * - a single hole possibly containing exversions (if the ring is oriented CCW)
- * If the MaximalEdgeRing represents a polygon,
- * the interior of the polygon is strongly connected.
- * These are the form of rings used to define polygons under some spatial data models.
- * However, under the OGC SFS model, [MinimalEdgeRings](@ref MinimalEdgeRing) are required.
- * A MaximalEdgeRing can be converted to a list of MinimalEdgeRings using the
- * {@link #buildMinimalRings() } method.
- * @see com.vividsolutions.jts.operation.overlay.MinimalEdgeRing
-class GEOS_DLL MaximalEdgeRing: public geomgraph::EdgeRing {
-public:
- MaximalEdgeRing(geomgraph::DirectedEdge* start,
- const geom::GeometryFactory* geometryFactory);
- // throw(const TopologyException &)
- ~MaximalEdgeRing() override = default;
- geomgraph::DirectedEdge* getNext(geomgraph::DirectedEdge* de) override;
- void setEdgeRing(geomgraph::DirectedEdge* de, geomgraph::EdgeRing* er) override;
- /// \brief
- /// This function returns a newly allocated vector of
- /// pointers to newly allocated MinimalEdgeRing objects.
- /// @deprecated pass the vector yourself instead
- std::vector<MinimalEdgeRing*>* buildMinimalRings();
- /// \brief
- /// This function pushes pointers to newly allocated MinimalEdgeRing
- /// objects to the provided vector.
- void buildMinimalRings(std::vector<MinimalEdgeRing*>& minEdgeRings);
- void buildMinimalRings(std::vector<EdgeRing*>& minEdgeRings);
- /// \brief
- /// For all nodes in this EdgeRing,
- /// link the DirectedEdges at the node to form minimalEdgeRings
- void linkDirectedEdgesForMinimalEdgeRings();
-} // namespace geos::operation::overlay
diff --git a/include/geos/operation/overlay/MinimalEdgeRing.h b/include/geos/operation/overlay/MinimalEdgeRing.h
index c2df90eab..000000000
--- a/include/geos/operation/overlay/MinimalEdgeRing.h
+++ /dev/null
@@ -1,80 +0,0 @@
- * Last port: operation/overlay/MinimalEdgeRing.java rev. 1.13 (JTS-1.10)
-#pragma once
-#include <geos/geomgraph/DirectedEdge.h> // for inlines
-#include <vector>
-namespace geos {
-namespace geom {
-class EdgeRing;
-namespace geos {
-/** \brief
- * A ring of [Edges](@ref geomgraph::Edge) with the property that no node
- * has degree greater than 2.
- * These are the form of rings required to represent polygons
- * under the OGC SFS spatial data model.
- * @see operation::overlay::MaximalEdgeRing
-class GEOS_DLL MinimalEdgeRing: public geomgraph::EdgeRing {
-public:
- MinimalEdgeRing(geomgraph::DirectedEdge* start,
- ~MinimalEdgeRing() override {};
- return de->getNextMin();
- geomgraph::EdgeRing* er) override
- de->setMinEdgeRing(er);
diff --git a/include/geos/operation/overlay/OverlayNodeFactory.h b/include/geos/operation/overlay/OverlayNodeFactory.h
index 74ba8d955..000000000
--- a/include/geos/operation/overlay/OverlayNodeFactory.h
+++ /dev/null
@@ -1,56 +0,0 @@
- * Last port: operation/overlay/OverlayNodeFactory.java rev. 1.11 (JTS-1.10)
-#pragma once
-#include <vector>
-#include <geos/geomgraph/NodeFactory.h> // for inheritance
-namespace geos {
-namespace geom {
-class Coordinate;
-class Node;
-namespace geos {
-/** \brief
- * Creates nodes for use in the geomgraph::PlanarGraph constructed during
- * overlay operations. NOTE: also used by operation::valid
-class GEOS_DLL OverlayNodeFactory: public geomgraph::NodeFactory {
-public:
- OverlayNodeFactory(): geomgraph::NodeFactory() {}
- geomgraph::Node* createNode(const geom::Coordinate& coord) const override;
- static const geomgraph::NodeFactory& instance();
diff --git a/include/geos/operation/overlay/PolygonBuilder.h b/include/geos/operation/overlay/PolygonBuilder.h
index e39e9b6c0..000000000
--- a/include/geos/operation/overlay/PolygonBuilder.h
+++ /dev/null
@@ -1,210 +0,0 @@
- * Last port: operation/overlay/PolygonBuilder.java rev. 1.20 (JTS-1.10)
-#pragma once
-#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
-#include <vector>
-#ifdef _MSC_VER
-#pragma warning(push)
-#pragma warning(disable: 4251) // warning C4251: needs to have dll-interface to be used by clients of class
-#endif
-namespace geos {
-namespace geom {
-class Geometry;
-class Coordinate;
-class EdgeRing;
-class Node;
-class PlanarGraph;
-class MaximalEdgeRing;
-namespace geos {
-/** \brief
- * Forms Polygon out of a graph of geomgraph::DirectedEdge.
- * The edges to use are marked as being in the result Area.
-class GEOS_DLL PolygonBuilder {
-public:
- PolygonBuilder(const geom::GeometryFactory* newGeometryFactory);
- ~PolygonBuilder();
- * Add a complete graph.
- * The graph is assumed to contain one or more polygons,
- * possibly with holes.
- void add(geomgraph::PlanarGraph* graph);
- * Add a set of edges and nodes, which form a graph.
- void add(const std::vector<geomgraph::DirectedEdge*>* dirEdges,
- const std::vector<geomgraph::Node*>* nodes);
- std::vector<std::unique_ptr<geom::Geometry>> getPolygons();
-private:
- const geom::GeometryFactory* geometryFactory;
- std::vector<geomgraph::EdgeRing*> shellList;
- * For all DirectedEdges in result, form them into MaximalEdgeRings
- * @param maxEdgeRings
- * Formed MaximalEdgeRings will be pushed to this vector.
- * Ownership of the elements is transferred to caller.
- void buildMaximalEdgeRings(
- const std::vector<geomgraph::DirectedEdge*>* dirEdges,
- std::vector<MaximalEdgeRing*>& maxEdgeRings);
- void buildMinimalEdgeRings(
- std::vector<MaximalEdgeRing*>& maxEdgeRings,
- std::vector<geomgraph::EdgeRing*>& newShellList,
- std::vector<geomgraph::EdgeRing*>& freeHoleList,
- std::vector<MaximalEdgeRing*>& edgeRings);
- * This method takes a list of MinimalEdgeRings derived from a
- * MaximalEdgeRing, and tests whether they form a Polygon.
- * This is the case if there is a single shell
- * in the list. In this case the shell is returned.
- * The other possibility is that they are a series of connected
- * holes, in which case no shell is returned.
- * @return the shell geomgraph::EdgeRing, if there is one
- * @return NULL, if all the rings are holes
- geomgraph::EdgeRing* findShell(std::vector<MinimalEdgeRing*>* minEdgeRings);
- * This method assigns the holes for a Polygon (formed from a list of
- * MinimalEdgeRings) to its shell.
- * Determining the holes for a MinimalEdgeRing polygon serves two
- * purposes:
- * - it is faster than using a point-in-polygon check later on.
- * - it ensures correctness, since if the PIP test was used the point
- * chosen might lie on the shell, which might return an incorrect
- * result from the PIP test
- void placePolygonHoles(geomgraph::EdgeRing* shell,
- std::vector<MinimalEdgeRing*>* minEdgeRings);
- * For all rings in the input list,
- * determine whether the ring is a shell or a hole
- * and add it to the appropriate list.
- * Due to the way the DirectedEdges were linked,
- * a ring is a shell if it is oriented CW, a hole otherwise.
- void sortShellsAndHoles(std::vector<MaximalEdgeRing*>& edgeRings,
- std::vector<geomgraph::EdgeRing*>& freeHoleList);
- struct FastPIPRing {
- geomgraph::EdgeRing* edgeRing;
- algorithm::locate::IndexedPointInAreaLocator* pipLocator;
- /** \brief
- * This method determines finds a containing shell for all holes
- * which have not yet been assigned to a shell.
- * These "free" holes should all be <b>properly</b> contained in
- * their parent shells, so it is safe to use the
- * <code>findEdgeRingContaining</code> method.
- * This is the case because any holes which are NOT
- * properly contained (i.e. are connected to their
- * parent shell) would have formed part of a MaximalEdgeRing
- * and been handled in a previous step.
- * @throws TopologyException if a hole cannot be assigned to a shell
- void placeFreeHoles(std::vector<FastPIPRing>& newShellList,
- // throw(const TopologyException&)
- /** \brief
- * Find the innermost enclosing shell geomgraph::EdgeRing containing the
- * argument geomgraph::EdgeRing, if any.
- * The innermost enclosing ring is the <i>smallest</i> enclosing ring.
- * The algorithm used depends on the fact that:
- * ring A contains ring B iff envelope(ring A)
- * contains envelope(ring B)
- * This routine is only safe to use if the chosen point of the hole
- * is known to be properly contained in a shell
- * (which is guaranteed to be the case if the hole does not touch
- * its shell)
- * @return containing geomgraph::EdgeRing, if there is one
- * @return NULL if no containing geomgraph::EdgeRing is found
- geomgraph::EdgeRing* findEdgeRingContaining(geomgraph::EdgeRing* testEr,
- std::vector<FastPIPRing>& newShellList);
- std::vector<std::unique_ptr<geom::Geometry>> computePolygons(
- std::vector<geomgraph::EdgeRing*>& newShellList);
- * Checks the current set of shells (with their associated holes) to
- * see if any of them contain the point.
-#ifdef _MSC_VER
-#pragma warning(pop)
-#endif
diff --git a/src/operation/overlay/MaximalEdgeRing.cpp b/src/operation/overlay/MaximalEdgeRing.cpp
index 6221944e1..000000000
--- a/src/operation/overlay/MaximalEdgeRing.cpp
+++ /dev/null
@@ -1,136 +0,0 @@
- * Copyright (C) 2005-2006 Refractions Research Inc.
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
-#include <geos/operation/overlay/MaximalEdgeRing.h>
-#include <geos/operation/overlay/MinimalEdgeRing.h>
-#include <geos/geomgraph/Node.h>
-#include <geos/geomgraph/EdgeEndStar.h>
-#include <geos/geomgraph/DirectedEdgeStar.h>
-#include <geos/util.h>
-#include <cassert>
-#include <vector>
-#ifndef GEOS_DEBUG
-#define GEOS_DEBUG 0
-#endif
-#if GEOS_DEBUG
-#include <iostream>
-#endif
-using namespace geos::geomgraph;
-using namespace geos::geom;
-namespace geos {
-namespace operation { // geos.operation
-namespace overlay { // geos.operation.overlay
-/*public*/
-MaximalEdgeRing::MaximalEdgeRing(DirectedEdge* start,
- const GeometryFactory* p_geometryFactory)
-// throw(const TopologyException &)
- EdgeRing(start, p_geometryFactory)
- computePoints(start);
- computeRing();
-#if GEOS_DEBUG
- std::cerr << "MaximalEdgeRing[" << this << "] ctor" << std::endl;
-#endif
-/*public*/
-DirectedEdge*
-MaximalEdgeRing::getNext(DirectedEdge* de)
- return de->getNext();
-/*public*/
-void
-MaximalEdgeRing::setEdgeRing(DirectedEdge* de, EdgeRing* er)
- de->setEdgeRing(er);
-/*public*/
-void
-MaximalEdgeRing::linkDirectedEdgesForMinimalEdgeRings()
- DirectedEdge* de = startDe;
- do {
- Node* node = de->getNode();
- EdgeEndStar* ees = node->getEdges();
- DirectedEdgeStar* des = detail::down_cast<DirectedEdgeStar*>(ees);
- des->linkMinimalDirectedEdges(this);
- de = de->getNext();
- while(de != startDe);
-/*public*/
-std::vector<MinimalEdgeRing*>*
-MaximalEdgeRing::buildMinimalRings()
- std::vector<MinimalEdgeRing*>* minEdgeRings = new std::vector<MinimalEdgeRing*>;
- buildMinimalRings(*minEdgeRings);
- return minEdgeRings;
-/*public*/
-void
-MaximalEdgeRing::buildMinimalRings(std::vector<MinimalEdgeRing*>& minEdgeRings)
- do {
- if(de->getMinEdgeRing() == nullptr) {
- MinimalEdgeRing* minEr = new MinimalEdgeRing(de, geometryFactory);
- minEdgeRings.push_back(minEr);
-/*public*/
-void
-MaximalEdgeRing::buildMinimalRings(std::vector<EdgeRing*>& minEdgeRings)
- do {
-} // namespace geos.operation.overlay
diff --git a/src/operation/overlay/MinimalEdgeRing.cpp b/src/operation/overlay/MinimalEdgeRing.cpp
index fd5cc2e72..000000000
--- a/src/operation/overlay/MinimalEdgeRing.cpp
+++ /dev/null
@@ -1,42 +0,0 @@
- * Copyright (C) 2005 Refractions Research Inc.
-namespace geos {
-MinimalEdgeRing::MinimalEdgeRing(geomgraph::DirectedEdge* start,
- const geom::GeometryFactory* p_geometryFactory)
- geomgraph::EdgeRing(start, p_geometryFactory)
- computeRing();
diff --git a/src/operation/overlay/OverlayNodeFactory.cpp b/src/operation/overlay/OverlayNodeFactory.cpp
index 095008da5..000000000
--- a/src/operation/overlay/OverlayNodeFactory.cpp
+++ /dev/null
@@ -1,46 +0,0 @@
-#include <geos/operation/overlay/OverlayNodeFactory.h>
-namespace geos {
-Node*
-OverlayNodeFactory::createNode(const geom::Coordinate& coord) const
- return new Node(coord, new DirectedEdgeStar());
-const NodeFactory&
-OverlayNodeFactory::instance()
- static OverlayNodeFactory onf;
- return onf;
diff --git a/src/operation/overlay/PolygonBuilder.cpp b/src/operation/overlay/PolygonBuilder.cpp
index e0223b432..000000000
--- a/src/operation/overlay/PolygonBuilder.cpp
+++ /dev/null
@@ -1,383 +0,0 @@
-#include <geos/operation/overlay/PolygonBuilder.h>
-#include <geos/operation/polygonize/EdgeRing.h>
-#include <geos/geomgraph/NodeMap.h>
-#include <geos/geomgraph/PlanarGraph.h>
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/LinearRing.h>
-#include <geos/geom/Polygon.h>
-#include <geos/algorithm/PointLocation.h>
-#include <geos/util/TopologyException.h>
-#include <geos/util/GEOSException.h>
-#include <vector>
-#include <cassert>
-#ifndef GEOS_DEBUG
-#endif
-#if GEOS_DEBUG
-#endif
-using namespace geos::algorithm;
-namespace geos {
-PolygonBuilder::PolygonBuilder(const GeometryFactory* newGeometryFactory)
- geometryFactory(newGeometryFactory)
-PolygonBuilder::~PolygonBuilder()
- for(std::size_t i = 0, n = shellList.size(); i < n; ++i) {
- delete shellList[i];
-/*public*/
-void
-PolygonBuilder::add(PlanarGraph* graph)
-//throw(TopologyException *)
- const std::vector<EdgeEnd*>* eeptr = graph->getEdgeEnds();
- assert(eeptr);
- const std::vector<EdgeEnd*>& ee = *eeptr;
- std::size_t eeSize = ee.size();
-#if GEOS_DEBUG
- std::cerr << __FUNCTION__ << ": PlanarGraph has " << eeSize << " EdgeEnds" << std::endl;
-#endif
- std::vector<DirectedEdge*> dirEdges(eeSize);
- for(std::size_t i = 0; i < eeSize; ++i) {
- DirectedEdge* de = detail::down_cast<DirectedEdge*>(ee[i]);
- dirEdges[i] = de;
- const auto& nodeMap = graph->getNodeMap()->nodeMap;
- std::vector<Node*> nodes;
- nodes.reserve(nodeMap.size());
- for(const auto& nodeIt: nodeMap) {
- Node* node = nodeIt.second.get();
- nodes.push_back(node);
- add(&dirEdges, &nodes); // might throw a TopologyException *
-/*public*/
-void
-PolygonBuilder::add(const std::vector<DirectedEdge*>* dirEdges,
- const std::vector<Node*>* nodes)
- PlanarGraph::linkResultDirectedEdges(nodes->begin(), nodes->end());
- std::vector<MaximalEdgeRing*> maxEdgeRings;
- buildMaximalEdgeRings(dirEdges, maxEdgeRings);
- std::vector<EdgeRing*> freeHoleList;
- std::vector<MaximalEdgeRing*> edgeRings;
- buildMinimalEdgeRings(maxEdgeRings, shellList, freeHoleList, edgeRings);
- sortShellsAndHoles(edgeRings, shellList, freeHoleList);
- std::vector<FastPIPRing> indexedshellist;
- for(auto const& shell : shellList) {
- FastPIPRing pipRing { shell, new geos::algorithm::locate::IndexedPointInAreaLocator(*shell->getLinearRing()) };
- indexedshellist.push_back(pipRing);
- placeFreeHoles(indexedshellist, freeHoleList);
- //Assert: every hole on freeHoleList has a shell assigned to it
- for(auto const& shell : indexedshellist) {
- delete shell.pipLocator;
-/*public*/
-std::vector<std::unique_ptr<Geometry>>
-PolygonBuilder::getPolygons()
- std::vector<std::unique_ptr<Geometry>> resultPolyList = computePolygons(shellList);
- return resultPolyList;
-/*private*/
-void
-PolygonBuilder::buildMaximalEdgeRings(const std::vector<DirectedEdge*>* dirEdges,
-#if GEOS_DEBUG
- std::cerr << "PolygonBuilder::buildMaximalEdgeRings got " << dirEdges->size() << " dirEdges" << std::endl;
-#endif
- std::vector<MaximalEdgeRing*>::size_type oldSize = maxEdgeRings.size();
- for(std::size_t i = 0, n = dirEdges->size(); i < n; i++) {
- DirectedEdge* de = (*dirEdges)[i];
-#if GEOS_DEBUG
- std::cerr << " dirEdge " << i << std::endl
- << de->printEdge() << std::endl
- << " inResult:" << de->isInResult() << std::endl
- << " isArea:" << de->getLabel().isArea() << std::endl;
-#endif
- if(de->isInResult() && de->getLabel().isArea()) {
- // if this edge has not yet been processed
- if(de->getEdgeRing() == nullptr) {
- MaximalEdgeRing* er;
- try {
- // MaximalEdgeRing constructor may throw
- er = new MaximalEdgeRing(de, geometryFactory);
- catch(util::GEOSException&) {
- // cleanup if that happens (see stmlf-cases-20061020.xml)
- for(std::size_t p_i = oldSize, p_n = maxEdgeRings.size(); p_i < p_n; p_i++) {
- delete maxEdgeRings[p_i];
- //cerr << "Exception! " << e.what() << std::endl;
- throw;
- maxEdgeRings.push_back(er);
- er->setInResult();
- //System.out.println("max node degree=" + er.getMaxDegree());
-#if GEOS_DEBUG
- std::cerr << " pushed " << maxEdgeRings.size() - oldSize << " maxEdgeRings" << std::endl;
-#endif
-/*private*/
-void
-PolygonBuilder::buildMinimalEdgeRings(
- std::vector<EdgeRing*>& newShellList, std::vector<EdgeRing*>& freeHoleList,
- for(std::size_t i = 0, n = maxEdgeRings.size(); i < n; ++i) {
- MaximalEdgeRing* er = maxEdgeRings[i];
-#if GEOS_DEBUG
- std::cerr << "buildMinimalEdgeRings: maxEdgeRing " << i << " has " << er->getMaxNodeDegree() << " maxNodeDegree" << std::endl;
-#endif
- if(er->getMaxNodeDegree() > 2) {
- er->linkDirectedEdgesForMinimalEdgeRings();
- std::vector<MinimalEdgeRing*> minEdgeRings;
- er->buildMinimalRings(minEdgeRings);
- // at this point we can go ahead and attempt to place
- // holes, if this EdgeRing is a polygon
- EdgeRing* shell = findShell(&minEdgeRings);
- if(shell != nullptr) {
- placePolygonHoles(shell, &minEdgeRings);
- newShellList.push_back(shell);
- else {
- freeHoleList.insert(freeHoleList.end(),
- minEdgeRings.begin(),
- minEdgeRings.end());
- delete er;
- else {
- edgeRings.push_back(er);
-/*private*/
-EdgeRing*
-PolygonBuilder::findShell(std::vector<MinimalEdgeRing*>* minEdgeRings)
- int shellCount = 0;
- EdgeRing* shell = nullptr;
-#if GEOS_DEBUG
- std::cerr << "PolygonBuilder::findShell got " << minEdgeRings->size() << " minEdgeRings" << std::endl;
-#endif
- for(std::size_t i = 0, n = minEdgeRings->size(); i < n; ++i) {
- EdgeRing* er = (*minEdgeRings)[i];
- if(! er->isHole()) {
- shell = er;
- ++shellCount;
- if(shellCount > 1) {
- throw util::TopologyException("found two shells in MinimalEdgeRing list");
- return shell;
-/*private*/
-void
-PolygonBuilder::placePolygonHoles(EdgeRing* shell,
- MinimalEdgeRing* er = (*minEdgeRings)[i];
- if(er->isHole()) {
- er->setShell(shell);
-/*private*/
-void
-PolygonBuilder::sortShellsAndHoles(std::vector<MaximalEdgeRing*>& edgeRings,
- std::vector<EdgeRing*>& newShellList, std::vector<EdgeRing*>& freeHoleList)
- for(std::size_t i = 0, n = edgeRings.size(); i < n; i++) {
- EdgeRing* er = edgeRings[i];
- //er->setInResult();
- freeHoleList.push_back(er);
- else {
- newShellList.push_back(er);
-/*private*/
-void
-PolygonBuilder::placeFreeHoles(std::vector<FastPIPRing>& newShellList,
- std::vector<EdgeRing*>& freeHoleList)
- for(std::vector<EdgeRing*>::iterator
- it = freeHoleList.begin(), itEnd = freeHoleList.end();
- it != itEnd;
- ++it) {
- EdgeRing* hole = *it;
- // only place this hole if it doesn't yet have a shell
- if(hole->getShell() == nullptr) {
- EdgeRing* shell = findEdgeRingContaining(hole, newShellList);
- if(shell == nullptr) {
-#if GEOS_DEBUG
- std::cerr << "CREATE TABLE shells (g geometry);" << std::endl;
- std::cerr << "CREATE TABLE hole (g geometry);" << std::endl;
- for(std::vector<FastPIPRing>::iterator rIt = newShellList.begin(),
- rEnd = newShellList.end(); rIt != rEnd; rIt++) {
- std::unique_ptr<Geometry> geom = (*rIt).edgeRing->toPolygon(geometryFactory);
- std::cerr << "INSERT INTO shells VALUES ('"
- << *geom
- << "');" << std::endl;
- std::unique_ptr<Geometry> geom = hole->toPolygon(geometryFactory);
- std::cerr << "INSERT INTO hole VALUES ('"
- << *geom
-#endif
- //assert(shell!=NULL); // unable to assign hole to a shell
- throw util::TopologyException("unable to assign hole to a shell");
- hole->setShell(shell);
-/*private*/
-EdgeRing*
-PolygonBuilder::findEdgeRingContaining(EdgeRing* testEr,
- LinearRing* testRing = testEr->getLinearRing();
- const Envelope* testEnv = testRing->getEnvelopeInternal();
- EdgeRing* minShell = nullptr;
- const Envelope* minShellEnv = nullptr;
- for(auto const& tryShell : newShellList) {
- LinearRing* tryShellRing = tryShell.edgeRing->getLinearRing();
- const Envelope* tryShellEnv = tryShellRing->getEnvelopeInternal();
- // the hole envelope cannot equal the shell envelope
- // (also guards against testing rings against themselves)
- if(tryShellEnv->equals(testEnv)) {
- continue;
- // hole must be contained in shell
- if(!tryShellEnv->contains(testEnv)) {
- continue;
- const CoordinateSequence* tsrcs = tryShellRing->getCoordinatesRO();
- const Coordinate& testPt = operation::polygonize::EdgeRing::ptNotInList(testRing->getCoordinatesRO(), tsrcs);
- bool isContained = false;
- if(tryShell.pipLocator->locate(&testPt) != Location::EXTERIOR) {
- isContained = true;
- // check if this new containing ring is smaller than
- // the current minimum ring
- if(isContained) {
- if(minShell == nullptr
- || minShellEnv->contains(tryShellEnv)) {
- minShell = tryShell.edgeRing;
- minShellEnv = minShell->getLinearRing()->getEnvelopeInternal();
- return minShell;
-/*private*/
-PolygonBuilder::computePolygons(std::vector<EdgeRing*>& newShellList)
-#if GEOS_DEBUG
- std::cerr << "PolygonBuilder::computePolygons: got " << newShellList.size() << " shells" << std::endl;
-#endif
- std::vector<std::unique_ptr<Geometry>> resultPolyList;
- // add Polygons for all shells
- for(std::size_t i = 0, n = newShellList.size(); i < n; i++) {
- EdgeRing* er = newShellList[i];
- auto poly = er->toPolygon(geometryFactory);
- resultPolyList.push_back(std::move(poly));
Summary of changes:
include/geos/operation/overlay/MaximalEdgeRing.h | 105 ------
include/geos/operation/overlay/MinimalEdgeRing.h | 80 -----
.../geos/operation/overlay/OverlayNodeFactory.h | 56 ---
include/geos/operation/overlay/PolygonBuilder.h | 210 -----------
src/operation/overlay/MaximalEdgeRing.cpp | 136 --------
src/operation/overlay/MinimalEdgeRing.cpp | 42 ---
src/operation/overlay/OverlayNodeFactory.cpp | 46 ---
src/operation/overlay/PolygonBuilder.cpp | 383 ---------------------
8 files changed, 1058 deletions(-)
delete mode 100644 include/geos/operation/overlay/MaximalEdgeRing.h
delete mode 100644 include/geos/operation/overlay/MinimalEdgeRing.h
delete mode 100644 include/geos/operation/overlay/OverlayNodeFactory.h
delete mode 100644 include/geos/operation/overlay/PolygonBuilder.h
delete mode 100644 src/operation/overlay/MaximalEdgeRing.cpp
delete mode 100644 src/operation/overlay/MinimalEdgeRing.cpp
delete mode 100644 src/operation/overlay/OverlayNodeFactory.cpp
delete mode 100644 src/operation/overlay/PolygonBuilder.cpp
hooks/post-receive
More information about the geos-commits
