[geos-commits] [SCM] GEOS branch main updated. 577532dbeb6574211cca28632a2e3f188adf9696
Fri Feb 21 12:35:32 PST 2025
the project "GEOS".
The branch, main has been updated
       via  577532dbeb6574211cca28632a2e3f188adf9696 (commit)
      from  89265d66ad4c1f5cc02972415aade98bab96340e (commit)
revisions in full, below.
commit 577532dbeb6574211cca28632a2e3f188adf9696
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Feb 21 12:12:38 2025 -0800
    Use typed template to read(wkt) in tests
diff --git a/tests/unit/algorithm/AreaTest.cpp b/tests/unit/algorithm/AreaTest.cpp
index f40de5733..e46fa5dae 100644
--- a/tests/unit/algorithm/AreaTest.cpp
+++ b/tests/unit/algorithm/AreaTest.cpp
@@ -70,8 +70,7 @@ struct test_area_data {
     void
     checkAreaOfRingSigned(std::string wkt, double expectedArea)
-        std::unique_ptr<Geometry> lineGeom(reader_.read(wkt));
-        std::unique_ptr<LineString> line(dynamic_cast<LineString*>(lineGeom.release()));
+        auto line = reader_.read<LineString>(wkt);
         ensure(nullptr != line.get());
         const CoordinateSequence* ringSeq = line->getCoordinatesRO();
diff --git a/tests/unit/algorithm/CGAlgorithms/OrientationIsCCWTest.cpp b/tests/unit/algorithm/CGAlgorithms/OrientationIsCCWTest.cpp
index b56e11c16..a8054f529 100644
--- a/tests/unit/algorithm/CGAlgorithms/OrientationIsCCWTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/OrientationIsCCWTest.cpp
@@ -42,8 +42,7 @@ struct test_isccw_data {
     void
     checkCCW(bool expectedCCW, const std::string& wkt)
-        GeometryPtr geom(reader_.read(wkt));
-        geos::geom::Polygon* poly = dynamic_cast<geos::geom::Polygon*>(geom.get());
+        auto poly = reader_.read<geos::geom::Polygon>(wkt);
         ensure("WKT must be POLYGON)", poly != nullptr);
         const geos::geom::CoordinateSequence* cs = poly->getExteriorRing()->getCoordinatesRO();
         bool actualCCW = Orientation::isCCW(cs);
@@ -53,8 +52,7 @@ struct test_isccw_data {
     void
     checkCCWArea(bool expectedCCWArea, const std::string& wkt)
         bool actualCCWArea = Orientation::isCCWArea(cs);
diff --git a/tests/unit/algorithm/LengthTest.cpp b/tests/unit/algorithm/LengthTest.cpp
index e70cb87aa..598cd60de 100644
--- a/tests/unit/algorithm/LengthTest.cpp
+++ b/tests/unit/algorithm/LengthTest.cpp
@@ -48,8 +48,7 @@ struct test_length_data {
     void
     checkLengthOfLine(std::string wkt, double expectedLength)
         const CoordinateSequence* lineSeq = line->getCoordinatesRO();
         double actual = algorithm::Length::ofLine(lineSeq);
diff --git a/tests/unit/algorithm/LocatePointInRingTest.cpp b/tests/unit/algorithm/LocatePointInRingTest.cpp
index 0dfacdff2..b52768380 100644
--- a/tests/unit/algorithm/LocatePointInRingTest.cpp
+++ b/tests/unit/algorithm/LocatePointInRingTest.cpp
@@ -59,7 +59,7 @@ struct test_locatepointinring_data {
         if (checkReverse) {
-            runPtLocator(expected, pt, geom->reverse()->toString(), false);
+            runPtLocator(expected, pt, poly->reverse()->toString(), false);
diff --git a/tests/unit/algorithm/PointLocationTest.cpp b/tests/unit/algorithm/PointLocationTest.cpp
index bed1a1b0b..f580c3ee9 100644
--- a/tests/unit/algorithm/PointLocationTest.cpp
+++ b/tests/unit/algorithm/PointLocationTest.cpp
@@ -49,8 +49,7 @@ struct test_PointLocation_data {
     std::unique_ptr<CoordinateSequence>
     readPts(const std::string& wkt)
-        std::unique_ptr<Geometry> geom = r_.read(wkt);
-        const LineString* line = dynamic_cast<LineString*>(geom.get());
+        auto line = r_.read<LineString>(wkt);
         if (line)
             return line->getCoordinatesRO()->clone();
         else
diff --git a/tests/unit/algorithm/PolygonNodeTopologyTest.cpp b/tests/unit/algorithm/PolygonNodeTopologyTest.cpp
index 720349164..1b6dfdef2 100644
--- a/tests/unit/algorithm/PolygonNodeTopologyTest.cpp
+++ b/tests/unit/algorithm/PolygonNodeTopologyTest.cpp
@@ -74,8 +74,7 @@ struct test_polygonnodetopology_data {
         if (line)
         else
diff --git a/tests/unit/algorithm/RectangleTest.cpp b/tests/unit/algorithm/RectangleTest.cpp
index c68810eb8..9035fb604 100644
--- a/tests/unit/algorithm/RectangleTest.cpp
+++ b/tests/unit/algorithm/RectangleTest.cpp
@@ -35,9 +35,7 @@ struct test_rectangle_data {
     void
     checkRectangle(const std::string& wkt, const std::string& wktExpected)
-        std::unique_ptr<Geometry> geom = reader_.read(wkt);
-        const LineString *line = static_cast<LineString*>(geom.get());
         const Coordinate& baseRightPt = line->getCoordinateN(0);
         const Coordinate& baseLeftPt = line->getCoordinateN(1);
diff --git a/tests/unit/algorithm/RobustLineIntersectionTest.cpp b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
index 595dbd79f..aaeea3e89 100644
--- a/tests/unit/algorithm/RobustLineIntersectionTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
@@ -116,11 +116,8 @@ struct test_robustlineintersection_data {
                       double distanceTolerance)
     //throws ParseException
-        GeomPtr g1(reader.read(wkt1));
-        GeomPtr g2(reader.read(wkt2));
-        LineString* l1ptr = dynamic_cast<LineString*>(g1.get());
-        LineString* l2ptr = dynamic_cast<LineString*>(g2.get());
+        auto l1ptr = reader.read<LineString>(wkt1);
+        auto l2ptr = reader.read<LineString>(wkt2);
         ensure(nullptr != l1ptr);
         ensure(nullptr != l2ptr);
@@ -155,11 +152,8 @@ struct test_robustlineintersection_data {
     // throws ParseException
@@ -182,11 +176,8 @@ struct test_robustlineintersection_data {
                           const std::string& wkt2)
@@ -207,11 +198,8 @@ struct test_robustlineintersection_data {
     void
     checkInputNotAltered(const std::string& wkt1, const std::string& wkt2, int scaleFactor)
diff --git a/tests/unit/coverage/TPVWSimplifierTest.cpp b/tests/unit/coverage/TPVWSimplifierTest.cpp
index de8d0beac..ce55c9965 100644
--- a/tests/unit/coverage/TPVWSimplifierTest.cpp
+++ b/tests/unit/coverage/TPVWSimplifierTest.cpp
@@ -41,9 +41,8 @@ struct test_tpvwsimplifier_data {
         double tolerance,
-        std::unique_ptr<Geometry> geom = r.read(wkt);
-        const MultiLineString* mls = static_cast<const MultiLineString*>(geom.get());
-        std::unique_ptr<Geometry> actual = TPVWSimplifier::simplify(mls, tolerance);
+        auto mls = r.read<MultiLineString>(wkt);
+        std::unique_ptr<Geometry> actual = TPVWSimplifier::simplify(mls.get(), tolerance);
         std::unique_ptr<Geometry> expected = r.read(wktExpected);
         ensure_equals_geometry(actual.get(), expected.get());
@@ -66,19 +65,18 @@ struct test_tpvwsimplifier_data {
         double tolerance,
-        auto geom = r.read(wkt);
-        const MultiLineString* lines = static_cast<const MultiLineString*>(geom.get());
+        auto lines = r.read<MultiLineString>(wkt);
         std::vector<bool> freeRings(lines->getNumGeometries(), false);
         for (std::size_t index : freeRingIndex) {
             freeRings[index] = true;
-        std::unique_ptr<Geometry> constraintsPtr(nullptr);
+        std::unique_ptr<MultiLineString> constraints(nullptr);
         if (wktConstraints.length() > 0) {
-            constraintsPtr = r.read(wktConstraints);
+            constraints = r.read<MultiLineString>(wktConstraints);
-        const MultiLineString* constraints = static_cast<const MultiLineString*>(constraintsPtr.get());
-        std::unique_ptr<Geometry> actual = TPVWSimplifier::simplify(lines, freeRings, constraints, tolerance);
+        std::unique_ptr<Geometry> actual = TPVWSimplifier::simplify(lines.get(), freeRings, constraints.get(), tolerance);
         // std::cout << "-- actual" << std::endl;
diff --git a/tests/unit/edgegraph/EdgeGraphTest.cpp b/tests/unit/edgegraph/EdgeGraphTest.cpp
index 731dceb36..9d96139e3 100644
--- a/tests/unit/edgegraph/EdgeGraphTest.cpp
+++ b/tests/unit/edgegraph/EdgeGraphTest.cpp
@@ -21,10 +21,9 @@ struct test_edgegraph_data {
     std::unique_ptr<EdgeGraph> build(std::string wkt) {
-        auto geo = reader_.read(wkt);
-        auto geocol = dynamic_cast<const GeometryCollection *>(geo.get());
-        ensure("could not cast input geometry to collection", geocol);
-        return EdgeGraphBuilder::build(geocol);
+        auto geocol = reader_.read<GeometryCollection>(wkt);
+        ensure("could not cast input geometry to collection", geocol.get());
+        return EdgeGraphBuilder::build(geocol.get());
     void checkNodeValid(HalfEdge* e) {
diff --git a/tests/unit/geom/Geometry/isRectangleTest.cpp b/tests/unit/geom/Geometry/isRectangleTest.cpp
index c191b3f01..c2daa21b2 100644
--- a/tests/unit/geom/Geometry/isRectangleTest.cpp
+++ b/tests/unit/geom/Geometry/isRectangleTest.cpp
@@ -38,9 +38,7 @@ void object::test<1>
     const std::string wkt("POLYGON ((0 0, 0 100, 100 100, 100 0, 0 0))");
-    auto g = reader.read(wkt);
-    geos::geom::Polygon* poly = dynamic_cast<geos::geom::Polygon*>(g.get());
+    auto poly = reader.read<geos::geom::Polygon>(wkt);
     ensure("Geometry is not a Polygon: " + wkt, poly != nullptr);
     ensure(poly->isRectangle());
@@ -52,9 +50,7 @@ void object::test<2>
     const std::string wkt("POLYGON ((0 0, 0 200, 100 200, 100 0, 0 0))");
@@ -67,9 +63,7 @@ void object::test<3>
     const std::string wkt("POLYGON ((0 0, 0 100, 100 100, 100 0, 0 0), \
                               (10 10, 10 90, 90 90, 90 10, 10 10))");
     ensure(!poly->isRectangle());
@@ -81,9 +75,7 @@ void object::test<4>
     const std::string wkt("POLYGON ((0 0, 0 100, 99 100, 100 0, 0 0))");
@@ -95,9 +87,7 @@ void object::test<5>
     const std::string wkt("POLYGON ((0 0, 0 100, 100 50, 100 100, 100 0, 0 0))");
@@ -109,9 +99,7 @@ void object::test<6>
     const std::string wkt("POLYGON ((0 0, 0 100, 100 0, 0 0))");
@@ -123,9 +111,7 @@ void object::test<7>
     const std::string wkt("POLYGON ((0 0, 0 100, 100 0, 100 100, 0 0))");
diff --git a/tests/unit/geom/LineStringTest.cpp b/tests/unit/geom/LineStringTest.cpp
index 06e1dfa0c..930f8885a 100644
--- a/tests/unit/geom/LineStringTest.cpp
+++ b/tests/unit/geom/LineStringTest.cpp
@@ -596,9 +596,7 @@ template<>
 void object::test<33>
-    auto geom = reader_.read("LINESTRING M (0 1 2, 10 11 12, 20 21 22)");
-    ensure(geom != nullptr);
-    geos::geom::LineString *line = static_cast<LineString*>(geom.get());
+    auto line = reader_.read<LineString>("LINESTRING M (0 1 2, 10 11 12, 20 21 22)");
     ensure_equals(line->getCoordinateDimension(), 3);
     auto pt = line->getPointN(2);
     auto out = writer_.write(*pt);
@@ -610,9 +608,7 @@ template<>
 void object::test<34>
-    auto geom = reader_.read("LINESTRING Z (0 1 2, 10 11 12, 20 21 22)");
+    auto line = reader_.read<LineString>("LINESTRING Z (0 1 2, 10 11 12, 20 21 22)");
@@ -624,9 +620,7 @@ template<>
 void object::test<35>
-    auto geom = reader_.read("LINESTRING ZM (0 1 2 3, 10 11 12 13, 20 21 22 23)");
+    auto line = reader_.read<LineString>("LINESTRING ZM (0 1 2 3, 10 11 12 13, 20 21 22 23)");
     ensure_equals(line->getCoordinateDimension(), 4);
diff --git a/tests/unit/geom/MultiPointTest.cpp b/tests/unit/geom/MultiPointTest.cpp
index 5899f1cfe..21881b617 100644
--- a/tests/unit/geom/MultiPointTest.cpp
+++ b/tests/unit/geom/MultiPointTest.cpp
@@ -29,25 +29,20 @@ struct test_multipoint_data {
     geos::geom::GeometryFactory::Ptr factory_;
     geos::io::WKTReader reader_;
-    MultiPointAutoPtr empty_mp_;
-    MultiPointPtr mp_;
+    std::unique_ptr<geos::geom::MultiPoint> empty_mp_;
+    std::unique_ptr<geos::geom::MultiPoint> mp_;
     const std::size_t mp_size_;
     test_multipoint_data()
-        pm_(1.0), factory_(GeometryFactory::create(&pm_, 0))
+        : pm_(1.0)
+        , factory_(GeometryFactory::create(&pm_, 0))
         , reader_(factory_.get())
-        , empty_mp_(factory_->createMultiPoint()), mp_size_(5)
-        // Create non-empty MultiPoint
-        auto geo = reader_.read("MULTIPOINT((0 0), (5 5), (10 10), (15 15), (20 20))");
-        mp_ = dynamic_cast<MultiPointPtr>(geo.release());
+        , empty_mp_(factory_->createMultiPoint())
+        , mp_(reader_.read<geos::geom::MultiPoint>("MULTIPOINT((0 0), (5 5), (10 10), (15 15), (20 20))"))
+        , mp_size_(5)
-    ~test_multipoint_data()
-        factory_->destroyGeometry(mp_);
+    ~test_multipoint_data() {};
 private:
     // Declare type as noncopyable
diff --git a/tests/unit/geom/PointTest.cpp b/tests/unit/geom/PointTest.cpp
index b19de45fe..fc13bf9bc 100644
--- a/tests/unit/geom/PointTest.cpp
+++ b/tests/unit/geom/PointTest.cpp
@@ -42,22 +42,18 @@ struct test_point_data {
     geos::geom::PrecisionModel pm_;
-    PointAutoPtr empty_point_;
-    PointPtr point_;
+    std::unique_ptr<geos::geom::Point> empty_point_;
+    std::unique_ptr<geos::geom::Point> point_;
     test_point_data()
-        : pm_(1000), factory_(GeometryFactory::create(&pm_, 0))
-        , reader_(factory_.get()), empty_point_(factory_->createPoint())
-        // Create non-empty Point
-        auto geo = reader_.read("POINT(1.234 5.678)");
-        point_ = dynamic_cast<PointPtr>(geo.release());
+        : pm_(1000)
+        , reader_(factory_.get())
+        , empty_point_(factory_->createPoint())
+        , point_(reader_.read<geos::geom::Point>("POINT(1.234 5.678)"))
-    ~test_point_data()
-        factory_->destroyGeometry(point_);
+    ~test_point_data() {};
 typedef test_group<test_point_data, MAX_TESTS> group;
diff --git a/tests/unit/operation/overlayng/OverlayGraphTest.cpp b/tests/unit/operation/overlayng/OverlayGraphTest.cpp
index 46db88b5a..e179702fe 100644
--- a/tests/unit/operation/overlayng/OverlayGraphTest.cpp
+++ b/tests/unit/operation/overlayng/OverlayGraphTest.cpp
@@ -46,10 +46,9 @@ struct test_overlaygraph_data {
     void
-    addEdge(OverlayGraph* graph, const char* wktLine)
+    addEdge(OverlayGraph* graph, const std::string& wktLine)
-        std::unique_ptr<Geometry> geom = r.read(std::string(wktLine));
-        LineString* line = dynamic_cast<LineString*>(geom.get());
+        auto line = r.read<LineString>(wktLine);
         std::unique_ptr<CoordinateSequence> cs = line->getCoordinates();
         EdgeSourceInfo esi(0);
diff --git a/tests/unit/triangulate/polygon/PolygonHoleJoinerTest.cpp b/tests/unit/triangulate/polygon/PolygonHoleJoinerTest.cpp
index 3a61c1782..afe0f6fa3 100644
--- a/tests/unit/triangulate/polygon/PolygonHoleJoinerTest.cpp
+++ b/tests/unit/triangulate/polygon/PolygonHoleJoinerTest.cpp
@@ -32,13 +32,12 @@ struct test_polygonholejoiner_data {
     // test_polygonholejoiner_data() {}
     void checkJoin(const std::string& wkt, const std::string& wktExpected) {
-        Polygon* polyPtr = dynamic_cast<Polygon*>(geom.get());
-        ensure(polyPtr);
-        std::unique_ptr<Polygon> actual = PolygonHoleJoiner::joinAsPolygon(polyPtr);
-        std::unique_ptr<Geometry> expected = r.read(wktExpected);
-        Geometry* actualPtr = dynamic_cast<Geometry*>(actual.get());
-        ensure(actualPtr);
+        auto poly = r.read<Polygon>(wkt);
+        std::unique_ptr<Polygon> actual = PolygonHoleJoiner::joinAsPolygon(poly.get());
+        auto actualPtr = dynamic_cast<const Geometry*>(actual.get());
+        std::unique_ptr<Geometry> expected = r.read<Geometry>(wktExpected);
         // std::cout << std::endl << "geom" << std::endl << *geom << std::endl;
         // std::cout << std::endl << "actual" << std::endl << *actual << std::endl;
Summary of changes:
 tests/unit/algorithm/AreaTest.cpp                  |  3 +--
 .../CGAlgorithms/OrientationIsCCWTest.cpp          |  6 ++---
 tests/unit/algorithm/LengthTest.cpp                |  3 +--
 tests/unit/algorithm/LocatePointInRingTest.cpp     |  2 +-
 tests/unit/algorithm/PointLocationTest.cpp         |  3 +--
 tests/unit/algorithm/PolygonNodeTopologyTest.cpp   |  3 +--
 tests/unit/algorithm/RectangleTest.cpp             |  4 +---
 .../unit/algorithm/RobustLineIntersectionTest.cpp  | 28 +++++++---------------
 tests/unit/coverage/TPVWSimplifierTest.cpp         | 16 ++++++-------
 tests/unit/edgegraph/EdgeGraphTest.cpp             |  7 +++---
 tests/unit/geom/Geometry/isRectangleTest.cpp       | 28 ++++++----------------
 tests/unit/geom/LineStringTest.cpp                 | 12 +++-------
 tests/unit/geom/MultiPointTest.cpp                 | 23 +++++++-----------
 tests/unit/geom/PointTest.cpp                      | 24 ++++++++-----------
 .../unit/operation/overlayng/OverlayGraphTest.cpp  |  5 ++--
 .../triangulate/polygon/PolygonHoleJoinerTest.cpp  | 13 +++++-----
 16 files changed, 63 insertions(+), 117 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
