[geos-commits] [SCM] GEOS branch main updated. 0fdc40af1fb125b59efc3d154c672314beff4249
Fri Feb 21 13:50:44 PST 2025
the project "GEOS".
The branch, main has been updated
       via  0fdc40af1fb125b59efc3d154c672314beff4249 (commit)
      from  577532dbeb6574211cca28632a2e3f188adf9696 (commit)
revisions in full, below.
commit 0fdc40af1fb125b59efc3d154c672314beff4249
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Feb 21 13:49:58 2025 -0800
    Update GHA runners as Ubuntu 20.04 is deprecated
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 6e5e15e39..39a94f238 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -38,63 +38,24 @@ jobs:
         - cxx_compiler: g++
           c_compiler: gcc
           build_type: Coverage
-          cxxstd: 14
+          cxxstd: 17
           arch: 64
           packages: g++
           cmake: 3.15.*
           cmake_extra: -D BUILD_BENCHMARKS=ON
           os: ubuntu-latest
-          # gcc 6 and lower are not supported
-          # in ubuntu 20.04 and higher
-        - cxx_compiler: g++-7
-          c_compiler: gcc-7
-          build_type: Release
-          cxxstd: 14
-          arch: 64
-          packages: 'g++-7-multilib gcc-7-multilib'
-          cmake: 3.17.*
-          os: ubuntu-20.04
-          c_compiler: gcc-7
-          cxxstd: 14
-          arch: 32
-          packages: 'g++-7-multilib gcc-7-multilib g++-multilib gcc-multilib'
-          cmake: 3.18.*
-          os: ubuntu-20.04
-        - cxx_compiler: g++-8
-          c_compiler: gcc-8
-          cxxstd: 14
-          arch: 64
-          packages: 'g++-8-multilib gcc-8-multilib'
-          cmake: 3.21.*
-          os: ubuntu-20.04
-        - cxx_compiler: g++-9
-          c_compiler: gcc-9
-          cxxstd: 14
-          arch: 64
-          packages: 'g++-9-multilib gcc-9-multilib'
-          cmake: 3.23.*
-          os: ubuntu-20.04
+          # gcc 9 and lower are not supported
+          # in ubuntu 22.04 and higher
         - cxx_compiler: g++-10
           c_compiler: gcc-10
           build_type: Release
-          cxxstd: 14
+          cxxstd: 17
           arch: 64
           packages: 'g++-10-multilib gcc-10-multilib'
-          cmake: 3.25.*
-          os: ubuntu-20.04
-          # gcc 10 and lower are not supported
-          # in ubuntu 22.04 and higher
+          cmake: 3.15.*
+          os: ubuntu-22.04
         - cxx_compiler: g++-11
           c_compiler: gcc-11
@@ -102,7 +63,7 @@ jobs:
           cxxstd: 17
           arch: 64
           packages: 'g++-11-multilib gcc-11-multilib'
-          cmake: 3.27.*
+          cmake: 3.17.*
           os: ubuntu-22.04
         - cxx_compiler: g++-12
@@ -111,56 +72,29 @@ jobs:
           cxxstd: 20
           arch: 64
           packages: 'g++-12-multilib gcc-12-multilib'
-          cmake: 3.29.*
+          cmake: 3.20.*
           os: ubuntu-22.04
-        # - cxx_compiler: g++-13
-        #   c_compiler: gcc-13
-        #   build_type: Release
-        #   cxxstd: 17
-        #   arch: 64
-        #   packages: 'g++-13-multilib gcc-13-multilib'
-        #   cmake: 3.22.*
-        #   os: ubuntu-22.04
+          # gcc 12 and lower are not supported
+          # in ubuntu 24.04 and higher
-          # clang 6 and lower are not supported
-        - cxx_compiler: clang++-7
-          c_compiler: clang-7
+        - cxx_compiler: g++-13
+          c_compiler: gcc-13
           build_type: Release
-          cxxstd: 14
+          cxxstd: 20
           arch: 64
-          packages: 'clang-7'
-          cmake: 3.15.*
-          os: ubuntu-20.04
+          packages: 'g++-13-multilib gcc-13-multilib'
+          cmake: 3.25.*
+          os: ubuntu-24.04
-        - cxx_compiler: clang++-8
-          c_compiler: clang-8
+        - cxx_compiler: g++-14
+          c_compiler: gcc-14
           build_type: Release
-          cxxstd: 14
+          cxxstd: 20
           arch: 64
-          packages: 'clang-8'
-          cmake: 3.17.*
-          os: ubuntu-20.04
-        - cxx_compiler: clang++-9
-          c_compiler: clang-9
-          cxxstd: 14
-          arch: 64
-          packages: 'clang-9'
-          cmake: 3.20.*
-          os: ubuntu-20.04
-        - cxx_compiler: clang++-10
-          c_compiler: clang-10
-          cxxstd: 14
-          arch: 64
-          packages: 'clang-10'
-          cmake: 3.21.*
-          os: ubuntu-20.04
+          packages: 'g++-14-multilib gcc-14-multilib'
+          cmake: 3.31.*
+          os: ubuntu-24.04
           # clang 10 and lower are not supported
@@ -171,7 +105,7 @@ jobs:
           cxxstd: 14
           arch: 64
           packages: 'clang-11'
-          cmake: 3.23.*
+          cmake: 3.15.*
           os: ubuntu-22.04
         - cxx_compiler: clang++-12
@@ -180,7 +114,7 @@ jobs:
           cxxstd: 14
           arch: 64
           packages: 'clang-12'
-          cmake: 3.25.*
+          cmake: 3.17.*
           os: ubuntu-22.04
         - cxx_compiler: clang++-13
@@ -189,7 +123,7 @@ jobs:
           cxxstd: 17
           arch: 64
           packages: 'clang-13'
-          cmake: 3.27.*
+          cmake: 3.20.*
           os: ubuntu-22.04
         - cxx_compiler: clang++-14
@@ -198,9 +132,49 @@ jobs:
           cxxstd: 20
           arch: 64
           packages: 'clang-14'
-          cmake: 3.29.*
+          cmake: 3.22.*
           os: ubuntu-22.04
+        - cxx_compiler: clang++-15
+          c_compiler: clang-15
+          build_type: ASAN
+          cxxstd: 20
+          arch: 64
+          packages: 'clang-15'
+          cmake: 3.24.*
+          os: ubuntu-22.04
+          # clang 15 and lower are not supported
+        - cxx_compiler: clang++-16
+          c_compiler: clang-16
+          build_type: ASAN
+          cxxstd: 20
+          arch: 64
+          packages: 'clang-16'
+          cmake: 3.26.*
+          os: ubuntu-24.04
+        - cxx_compiler: clang++-17
+          c_compiler: clang-17
+          build_type: ASAN
+          cxxstd: 20
+          arch: 64
+          packages: 'clang-17'
+          cmake: 3.28.*
+          os: ubuntu-24.04
+        - cxx_compiler: clang++-18
+          c_compiler: clang-18
+          build_type: ASAN
+          cxxstd: 20
+          arch: 64
+          packages: 'clang-18'
+          cmake: 3.30.*
+          os: ubuntu-24.04
     runs-on: ${{ matrix.ci.os }}
     steps:
@@ -536,7 +510,7 @@ jobs:
   cmake-subproject:
     name: 'CMake Subproject'
-    runs-on: ubuntu-20.04
+    runs-on: ubuntu-latest
     steps:
     - name: 'Install'
       run: |
Summary of changes:
 .github/workflows/ci.yml | 160 ++++++++++++++++++++---------------------------
 1 file changed, 67 insertions(+), 93 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
