[geos-commits] [SCM] GEOS branch 3.13 updated. 677de9abfebfae181154b18de4a6cae42266ad03
Fri Feb 21 14:11:45 PST 2025
the project "GEOS".
The branch, 3.13 has been updated
       via  677de9abfebfae181154b18de4a6cae42266ad03 (commit)
       via  c026a990883e26264d37b9e36c3624f670806a15 (commit)
      from  f92d697680a281f8cc26d5591b42ffa8efc7818b (commit)
revisions in full, below.
commit 677de9abfebfae181154b18de4a6cae42266ad03
Merge: c026a9908 f92d69768
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Feb 21 14:11:21 2025 -0800
    Merge branch '3.13' of github.com:libgeos/geos into 3.13
commit c026a990883e26264d37b9e36c3624f670806a15
Date:   Fri Feb 21 14:10:40 2025 -0800
    Update CI for deprecated Ubuntu 20.04
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index d98ec451b..1cf029285 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -45,56 +45,17 @@ jobs:
           cmake_extra: -D BUILD_BENCHMARKS=ON
           os: ubuntu-latest
-          # gcc 6 and lower are not supported
-          # in ubuntu 20.04 and higher
-        - cxx_compiler: g++-7
-          c_compiler: gcc-7
-          build_type: Release
-          cxxstd: 14
-          arch: 64
-          packages: 'g++-7-multilib gcc-7-multilib'
-          cmake: 3.17.*
-          os: ubuntu-20.04
-          c_compiler: gcc-7
-          cxxstd: 14
-          arch: 32
-          packages: 'g++-7-multilib gcc-7-multilib g++-multilib gcc-multilib'
-          cmake: 3.18.*
-          os: ubuntu-20.04
-        - cxx_compiler: g++-8
-          c_compiler: gcc-8
-          cxxstd: 14
-          arch: 64
-          packages: 'g++-8-multilib gcc-8-multilib'
-          cmake: 3.21.*
-          os: ubuntu-20.04
-        - cxx_compiler: g++-9
-          c_compiler: gcc-9
-          cxxstd: 14
-          arch: 64
-          packages: 'g++-9-multilib gcc-9-multilib'
-          cmake: 3.23.*
-          os: ubuntu-20.04
+        # gcc 9 and lower are not supported
+        # in ubuntu 22.04 and higher
         - cxx_compiler: g++-10
           c_compiler: gcc-10
           build_type: Release
           cxxstd: 14
-          arch: 64
-          packages: 'g++-10-multilib gcc-10-multilib'
-          cmake: 3.25.*
-          os: ubuntu-20.04
-          # gcc 10 and lower are not supported
-          # in ubuntu 22.04 and higher
+          arch: 32
+          packages: 'g++-10-multilib gcc-10-multilib g++-multilib gcc-multilib'
+          cmake: 3.18.*
+          os: ubuntu-22.04
         - cxx_compiler: g++-11
           c_compiler: gcc-11
@@ -114,56 +75,29 @@ jobs:
           cmake: 3.29.*
           os: ubuntu-22.04
-        # - cxx_compiler: g++-13
-        #   c_compiler: gcc-13
-        #   build_type: Release
-        #   cxxstd: 17
-        #   arch: 64
-        #   packages: 'g++-13-multilib gcc-13-multilib'
-        #   cmake: 3.22.*
-        #   os: ubuntu-22.04
+        # gcc 12 and lower are not supported
+        # in ubuntu 24.04 and higher
-          # clang 6 and lower are not supported
-        - cxx_compiler: clang++-7
-          c_compiler: clang-7
+        - cxx_compiler: g++-13
+          c_compiler: gcc-13
           build_type: Release
-          cxxstd: 14
+          cxxstd: 20
           arch: 64
-          packages: 'clang-7'
-          cmake: 3.15.*
-          os: ubuntu-20.04
+          packages: 'g++-13-multilib gcc-13-multilib'
+          cmake: 3.25.*
+          os: ubuntu-24.04
-        - cxx_compiler: clang++-8
-          c_compiler: clang-8
+        - cxx_compiler: g++-14
+          c_compiler: gcc-14
           build_type: Release
-          cxxstd: 14
+          cxxstd: 20
           arch: 64
-          packages: 'clang-8'
-          cmake: 3.17.*
-          os: ubuntu-20.04
+          packages: 'g++-14-multilib gcc-14-multilib'
+          cmake: 3.31.*
+          os: ubuntu-24.04
-        - cxx_compiler: clang++-9
-          c_compiler: clang-9
-          cxxstd: 14
-          arch: 64
-          packages: 'clang-9'
-          cmake: 3.20.*
-          os: ubuntu-20.04
-        - cxx_compiler: clang++-10
-          c_compiler: clang-10
-          cxxstd: 14
-          arch: 64
-          packages: 'clang-10'
-          cmake: 3.21.*
-          os: ubuntu-20.04
-          # clang 10 and lower are not supported
+        # clang 10 and lower are not supported
         - cxx_compiler: clang++-11
           c_compiler: clang-11
@@ -542,7 +476,7 @@ jobs:
   cmake-subproject:
     name: 'CMake Subproject'
-    runs-on: ubuntu-20.04
+    runs-on: ubuntu-latest
     steps:
     - name: 'Install'
       run: |
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index 823a0dc04..e64fdf8b1 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -590,7 +590,7 @@ public:
     * Tests if the region defined by other
     * is disjoint from the region of this Envelope
-    * @param other  the Envelope being checked for disjointness
+    * @param other  the Envelope being checked for disjointedness
     * @return true if the Envelopes are disjoint
     bool disjoint(const Envelope& other) const
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index 716215b71..1fa923ccb 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -377,7 +377,7 @@ BufferBuilder::buffer(const Geometry* g, double distance)
         std::vector< std::unique_ptr<Geometry> > geoms_to_delete;
         for ( size_t i=0, n=g->getNumGeometries(); i<n; ++i )
-            // BufferBuilder class cannot be re-used, so
+            // BufferBuilder class cannot be reused, so
             // we create a new one for each subgeom
             BufferBuilder subbuilder(bufParams);
             const Geometry *subgeom = g->getGeometryN(i);
Summary of changes:
 .github/workflows/ci.yml | 112 ++++++++++-------------------------------------
 1 file changed, 23 insertions(+), 89 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
