[geos-commits] [SCM] GEOS branch 3.10 updated. 9bce2b07eb80a8de3d2d763a91b9af40d50dc36d
git at osgeo.org
git at osgeo.org
Fri Feb 21 15:29:50 PST 2025
the project "GEOS".
The branch, 3.10 has been updated
via 9bce2b07eb80a8de3d2d763a91b9af40d50dc36d (commit)
from 24610d655ef8c3f5bb4f973f9dec097a3a583609 (commit)
revisions in full, below.
commit 9bce2b07eb80a8de3d2d763a91b9af40d50dc36d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Feb 21 15:29:01 2025 -0800
Update CI for Ubunto 20.04 deprecation
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 1e952f86e..b58f80572 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -13,6 +13,7 @@ jobs:
linux:
strategy:
+ fail-fast: false
matrix:
ci:
@@ -24,61 +25,34 @@ jobs:
cmake: 3.15.*,
os: ubuntu-latest
- # compiler: g++,
- # build_type: Release,
- # cxxstd: 11,
- # arch: 32,
- # packages: 'g++-4.8-multilib gcc-4.8-multilib g++-multilib gcc-multilib',
- # cmake: 3.13.*,
- # os: ubuntu-18.04
- compiler: clang++,
- build_type: Release,
- cxxstd: 11,
- arch: 64,
- packages: 'clang',
- cmake: 3.17.*,
- os: ubuntu-latest
- cxxstd: 11,
- arch: 64,
- cmake: 3.17.*,
- os: ubuntu-latest
- cxxstd: 11,
- arch: 64,
- packages: 'g++',
- cmake: 3.17.*,
- cmake_extra: '-DDISABLE_GEOS_INLINE=ON',
- os: ubuntu-latest
+ compiler: g++,
build_type: Debug,
cxxstd: 11,
arch: 64,
- cmake: 3.17.*,
- os: ubuntu-20.04,
+ packages: 'g++',
+ cmake: 3.15.*,
+ os: ubuntu-latest
compiler: clang++,
- cxxstd: 14,
+ cxxstd: 11,
arch: 64,
packages: 'clang',
cmake: 3.17.*,
os: ubuntu-latest
+ compiler: clang++,
+ build_type: Release,
+ cxxstd: 11,
+ arch: 64,
+ packages: 'clang',
+ cmake: 3.17.*,
+ cmake_extra: '-DDISABLE_GEOS_INLINE=ON',
+ os: ubuntu-latest
runs-on: ${{ matrix.ci.os }}
steps:
@@ -128,7 +102,7 @@ jobs:
- name: 'Upload Valgrind Log'
if: failure()
- uses: actions/upload-artifact at v2
+ uses: actions/upload-artifact at v4
with:
path: build.cmake/Testing/Temporary/MemoryChecker.**.log
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index 8bab435ba..ada465279 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -134,8 +134,7 @@ public:
* the circumcentre of an obtuse isosceles triangle lies outside the triangle.
* This method uses @ref geos::math::DD extended-precision arithmetic to provide more accurate
- * results than [circumcentre(Coordinate, Coordinate, Coordinate)]
- * (@ref geos::geom::Triangle::circumcentre(const Coordinate& p0, const Coordinate& p1, const Coordinate& p2)).
+ * results than circumcentre(Coordinate, Coordinate, Coordinate)
* @param a
* a vertex of the triangle
diff --git a/include/geos/noding/SegmentNodeList.h b/include/geos/noding/SegmentNodeList.h
index d3644ac19..800aa6529 100644
--- a/include/geos/noding/SegmentNodeList.h
+++ b/include/geos/noding/SegmentNodeList.h
@@ -157,9 +157,6 @@ public:
* Adds an intersection into the list, if it isn't already there.
* The input segmentIndex is expected to be normalized.
- * @return the SegmentIntersection found or added. It will be
- * destroyed at SegmentNodeList destruction time.
* @param intPt the intersection Coordinate, will be copied
* @param segmentIndex
diff --git a/include/geos/operation/distance/IndexedFacetDistance.h b/include/geos/operation/distance/IndexedFacetDistance.h
index bd4e23f99..db12a1331 100644
--- a/include/geos/operation/distance/IndexedFacetDistance.h
+++ b/include/geos/operation/distance/IndexedFacetDistance.h
@@ -39,7 +39,7 @@ namespace distance {
/// an repeated query situation.
/// Using this technique is usually much more performant than using the
-/// brute-force \ref geom::Geometry::distance(const Geometry* g) const when one
+/// brute-force geom::Geometry::distance(const Geometry* g) const when one
/// or both input geometries are large, or when evaluating many distance
/// computations against a single geometry.
diff --git a/include/geos/operation/overlayng/OverlayNG.h b/include/geos/operation/overlayng/OverlayNG.h
index 7fed36bba..fcad983be 100644
--- a/include/geos/operation/overlayng/OverlayNG.h
+++ b/include/geos/operation/overlayng/OverlayNG.h
@@ -271,7 +271,7 @@ public:
* the result of overlaying the geometries using
* a given overlay operation.
- * The method handles arguments of {@link Location#NONE} correctly
+ * The method handles arguments of Location#NONE correctly
static bool isResultOfOpPoint(const OverlayLabel* label, int opCode);
@@ -284,7 +284,7 @@ public:
* computed during the overlay process should be
* included in the result geometry.
- * The method handles arguments of {@link Location#NONE} correctly.
+ * The method handles arguments of Location#NONE correctly.
static bool isResultOfOp(int overlayOpCode, Location loc0, Location loc1);
diff --git a/include/geos/operation/union/UnaryUnionOp.h b/include/geos/operation/union/UnaryUnionOp.h
index eb1bfe8ee..ade73841b 100644
--- a/include/geos/operation/union/UnaryUnionOp.h
+++ b/include/geos/operation/union/UnaryUnionOp.h
@@ -72,9 +72,9 @@ namespace geounion { // geos::operation::geounion
* or portions of line segments will be reduced to a single line segment
* in the output.
* This is consistent with the semantics of the
- * [Geometry::Union(Geometry* )](@ref geom::Geometry::Union(const Geometry* other) const)
+ * Geometry::Union(Geometry* ) geom::Geometry::Union(const Geometry* other) const
* operation. If **merged** linework is required, the
- * [LineMerger](@ref operation::linemerge::LineMerger) class
+ * operation::linemerge::LineMerger class
* can be used.
* - Unioning a set of [Points](@ref geom::Point) has the effect of merging
* all identical points (producing a set with no duplicates).
diff --git a/include/geos/triangulate/polygon/PolygonEarClipper.h b/include/geos/triangulate/polygon/PolygonEarClipper.h
index 3a9089c60..a9d88512b 100644
--- a/include/geos/triangulate/polygon/PolygonEarClipper.h
+++ b/include/geos/triangulate/polygon/PolygonEarClipper.h
@@ -186,7 +186,6 @@ public:
* @param polyShell the vertices of the polygon
* @param triListResult vector to fill in with the resultant Tri s
- * @return a list of the Tris
static void triangulate(std::vector<Coordinate>& polyShell, TriList& triListResult);
diff --git a/include/geos/triangulate/polygon/VertexSequencePackedRtree.h b/include/geos/triangulate/polygon/VertexSequencePackedRtree.h
index 616b2ba72..984e586aa 100644
--- a/include/geos/triangulate/polygon/VertexSequencePackedRtree.h
+++ b/include/geos/triangulate/polygon/VertexSequencePackedRtree.h
@@ -137,7 +137,6 @@ public:
* @param queryEnv the query extent
* @param result vector to fill with results
- * @return
void query(const Envelope& queryEnv, std::vector<std::size_t>& result) const;
Summary of changes:
.github/workflows/ci.yml | 40 ++++------------------
include/geos/algorithm/CGAlgorithmsDD.h | 3 +-
include/geos/noding/SegmentNodeList.h | 3 --
.../geos/operation/distance/IndexedFacetDistance.h | 2 +-
include/geos/operation/overlayng/OverlayNG.h | 4 +--
include/geos/operation/union/UnaryUnionOp.h | 4 +--
.../geos/triangulate/polygon/PolygonEarClipper.h | 1 -
.../polygon/VertexSequencePackedRtree.h | 1 -
8 files changed, 13 insertions(+), 45 deletions(-)
hooks/post-receive
More information about the geos-commits
