[geos-commits] [SCM] GEOS branch 3.11 updated. c1534c4c4758852b12c84072a9da7e5d7e803b9e
git at osgeo.org
git at osgeo.org
Fri Feb 21 14:51:12 PST 2025
the project "GEOS".
The branch, 3.11 has been updated
via c1534c4c4758852b12c84072a9da7e5d7e803b9e (commit)
via 76549273444a110343d9bc691eeaabbf2440b942 (commit)
from 0bb7c64df714be5772671b27726de45f2553d40f (commit)
revisions in full, below.
commit c1534c4c4758852b12c84072a9da7e5d7e803b9e
Merge: 765492734 0bb7c64df
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Feb 21 14:50:44 2025 -0800
Merge branch '3.11' of github.com:libgeos/geos into 3.11
commit 76549273444a110343d9bc691eeaabbf2440b942
Date: Fri Feb 21 14:50:20 2025 -0800
Update CI for Ubuntu 20.04 deprecation
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index a5152fbc5..06f3f7b95 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -15,63 +15,66 @@ jobs:
linux:
strategy:
+ fail-fast: false
matrix:
ci:
- compiler: g++,
- build_type: Coverage,
- cxxstd: 11,
- arch: 64,
- packages: 'g++',
- cmake: 3.15.*,
- cmake_extra: '-DBUILD_BENCHMARKS=ON',
- os: ubuntu-20.04
- # compiler: g++,
- # build_type: Release,
- # cxxstd: 11,
- # arch: 32,
- # packages: 'g++-4.8-multilib gcc-4.8-multilib g++-multilib gcc-multilib',
- # cmake: 3.13.*,
- # os: ubuntu-20.04
- compiler: clang++,
- build_type: Release,
- cxxstd: 11,
- arch: 64,
- packages: 'clang',
- cmake: 3.13.*,
- os: ubuntu-20.04
- build_type: Debug,
- cxxstd: 11,
- arch: 64,
- cmake: 3.17.*,
- os: ubuntu-20.04,
- cxxstd: 14,
- arch: 64,
- cmake: 3.17.*,
- os: ubuntu-20.04
- compiler: g++,
- cxxstd: 11,
- arch: 64,
- packages: 'g++',
- cmake: 3.22.*,
+ - compiler: g++
+ build_type: Coverage
+ cxxstd: 11
+ arch: 64
+ packages: 'g++'
+ cmake: 3.15.*
+ cmake_extra: '-DBUILD_BENCHMARKS=ON'
+ os: ubuntu-latest
+ - compiler: g++
+ build_type: Debug
+ cxxstd: 11
+ arch: 64
+ packages: 'g++'
+ cmake: 3.15.*
+ os: ubuntu-latest
+ - compiler: g++-10
+ build_type: Release
+ cxxstd: 17
+ arch: 64
+ packages: 'g++-10-multilib gcc-10-multilib'
+ cmake: 3.15.*
os: ubuntu-22.04
+ - compiler: g++-11
+ cxxstd: 17
+ arch: 64
+ packages: 'g++-11-multilib gcc-11-multilib'
+ cmake: 3.17.*
+ os: ubuntu-22.04
+ - compiler: clang++
+ cxxstd: 11
+ arch: 64
+ packages: 'clang'
+ cmake: 3.15.*
+ os: ubuntu-22.04
+ cxxstd: 14
+ arch: 64
+ packages: 'clang'
+ cmake: 3.17.*
+ os: ubuntu-22.04
+ - compiler: g++
+ cxxstd: 17
+ arch: 64
+ packages: 'g++'
+ cmake: 3.22.*
+ os: ubuntu-22.04
runs-on: ${{ matrix.ci.os }}
steps:
@@ -232,51 +235,3 @@ jobs:
cd build
ctest --output-on-failure -C Release
- # windows-msvc-17:
- # name: 'Windows (Visual Studio 2017, Release, windows-2016)'
- # runs-on: windows-2016
- # steps:
- # - name: 'Check Out'
- # uses: actions/checkout at v4
- # - name: 'Build'
- # run: |
- # mkdir build
- # cd build
- # cmake --version
- # cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_STANDARD=11 -DBUILD_SHARED_LIBS=ON ..
- # cmake --build . --config Release -j 2
- # - name: 'Test'
- # run: |
- # cd build
- # ctest --output-on-failure -C Release
- cmake-subproject:
- name: 'CMake Subproject'
- runs-on: ubuntu-20.04
- steps:
- - name: 'Install'
- run: |
- set -e
- uname -a
- sudo -E apt-get update
- sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make python3-pip g++
- python3 -m pip install --disable-pip-version-check --user cmake==3.13.*
- echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
- - name: 'Check Out'
- uses: actions/checkout at v4
- with:
- path: geos
- - name: 'CMake Superbuild'
- run: |
- set -e
- cp geos/tests/superbuild.CMakeLists.txt ./CMakeLists.txt
- cp geos/examples/capi_read.c .
- cmake --version
- cmake -S . -B build
- cmake --build build -j 2
- build/capi_read
- test ! -f build/geos/bin/test_geos_unit || { echo "Error: GEOS tests were built" 1>&2 ; exit 1; }
Summary of changes:
.github/workflows/ci.yml | 159 +++++++++++++++++------------------------------
1 file changed, 57 insertions(+), 102 deletions(-)
hooks/post-receive
More information about the geos-commits
