[geos-commits] [SCM] GEOS branch main updated. 9f7b1ccce2a892a59d0cdd6621710bc27ee49869
Thu Jan 23 09:35:02 PST 2025
the project "GEOS".
The branch, main has been updated
       via  9f7b1ccce2a892a59d0cdd6621710bc27ee49869 (commit)
      from  4310f3bf820d7ea57633f88c14e3453bd0936b40 (commit)
revisions in full, below.
commit 9f7b1ccce2a892a59d0cdd6621710bc27ee49869
Author: Daniel Baston <dbaston at gmail.com>
Date:   Thu Jan 23 12:34:38 2025 -0500
    CI: Restore codecov upload (#1231)
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index f0b0aafb2..2ddfda4e9 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -219,7 +219,7 @@ jobs:
         uname -a
         sudo -E apt-get update
         sudo -E apt-get autopurge -y needrestart
-        sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen python3-pip ccache valgrind ${{ matrix.ci.packages }}
+        sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen lcov python3-pip ccache valgrind ${{ matrix.ci.packages }}
         python3 -m pip install --disable-pip-version-check --user cmake==${{ matrix.ci.cmake }}
         echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
@@ -284,12 +284,19 @@ jobs:
         path: build/Testing/Temporary/MemoryChecker.**.log
         retention-days: 1
-    - name: Upload Coverage to Codecov
+    - name: Generate coverage report
       if: matrix.ci.build_type == 'Coverage'
       run: |
-        curl -o codecov.sh https://codecov.io/bash
-        bash codecov.sh
-      shell: bash
+        cd build
+        lcov --ignore-errors=gcov,negative --capture --directory CMakeFiles --output-file coverage.info
+    - name: Upload Coverage to Codecov
+      if: ${{ matrix.ci.build_type == 'Coverage' && !cancelled() }}
+      uses: codecov/codecov-action at v5
+      with:
+        fail_ci_if_error: false
+        files: build/coverage.info
+        token: ${{ secrets.CODECOV_TOKEN }}
   windows-mingw:
     name: 'Windows (mingw-w64, x86_64, windows-2019)'
Summary of changes:
 .github/workflows/ci.yml | 17 ++++++++++++-----
 1 file changed, 12 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
