[geos-commits] [SCM] GEOS branch main updated. e6e5fd799fddf29154c6e87171c8fb71713a3a58
git at osgeo.org
git at osgeo.org
Tue Jan 28 09:42:41 PST 2025
the project "GEOS".
The branch, main has been updated
via e6e5fd799fddf29154c6e87171c8fb71713a3a58 (commit)
from 9f7b1ccce2a892a59d0cdd6621710bc27ee49869 (commit)
revisions in full, below.
commit e6e5fd799fddf29154c6e87171c8fb71713a3a58
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Jan 28 09:42:14 2025 -0800
Refactor XMLTester (#1230)
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index aa01c88da..aac0efb78 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -98,45 +98,16 @@ using operation::valid::TopologyValidationError;
namespace {
+using geos::geom::Geometry;
std::unique_ptr<const PreparedGeometry>
prepare(const geom::Geometry* g)
return PreparedGeometryFactory::prepare(g);
-// Asymmetric Rounding Algorithm - equivalent to Java Math.round()
-// Copy from geos/util/math.cpp
-double
-java_math_round(double val)
- double n;
- double f = std::fabs(std::modf(val, &n));
- if(val >= 0) {
- if(f < 0.5) {
- return std::floor(val);
- else if(f > 0.5) {
- return std::ceil(val);
- else {
- return (n + 1.0);
- else {
- if(f < 0.5) {
- else {
- return n;
-} // java_math_round
#ifdef not_used
// a utility function defining a very simple method to indent a line of text
const char*
@@ -185,6 +156,21 @@ void toupper(std::string& s)
+std::string
+trimBlanks(const std::string& in)
+ std::string out;
+ std::string::size_type pos = in.find_first_not_of(" \t\n\r");
+ if(pos != std::string::npos) {
+ out = in.substr(pos);
+ pos = out.find_last_not_of(" \t\n\r");
+ out = out.substr(0, pos + 1);
+ return out;
std::string
normalize_filename(const std::string& str)
@@ -209,93 +195,6 @@ normalize_filename(const std::string& str)
return newstring;
-static int
-checkOverlaySuccess(geom::Geometry const& gRes, geom::Geometry const& gRealRes)
- double tol = operation::overlay::snap::GeometrySnapper::computeSizeBasedSnapTolerance(gRes);
- if(gRes.equals(&gRealRes)) {
- return 1;
- std::cerr << "Using an overlay tolerance of " << tol << std::endl;
- if(gRes.equalsExact(&gRealRes, tol)) {
- return 1;
- return 0;
-/* Could be an XMLTester class private but oh well.. */
-static int
-checkBufferSuccess(geom::Geometry const& gRes, geom::Geometry const& gRealRes, double dist)
- using geos::xmltester::BufferResultMatcher;
- int success = 1;
- do {
- if(gRes.getGeometryTypeId() != gRealRes.getGeometryTypeId()) {
- std::cerr << "Expected result is of type "
- << gRes.getGeometryType()
- << "; obtained result is of type "
- << gRealRes.getGeometryType()
- << std::endl;
- success = 0;
- break;
- // Is a buffer always an area ?
- if(gRes.getDimension() != 2) {
- std::cerr << "Don't know how to validate "
- << "result of buffer operation "
- << "when expected result is not an "
- << "areal type."
- << std::endl;
- if(!BufferResultMatcher::isBufferResultMatch(gRealRes, gRes, dist)) {
- std::cerr << "BufferResultMatcher FAILED" << std::endl;
- success = 0;
- break;
- while(0);
- return success;
-static int
-checkSingleSidedBufferSuccess(geom::Geometry& gRes,
- geom::Geometry& gRealRes, double dist)
- int success = 1;
- do {
- << std::endl;
- success = 0;
- break;
- geos::xmltester::SingleSidedBufferResultMatcher matcher;
- if(! matcher.isBufferResultMatch(gRealRes,
- gRes,
- dist)) {
- std::cerr << "SingleSidedBufferResultMatcher FAILED" << std::endl;
- success = 0;
- break;
- while(0);
- return success;
XMLTester::XMLTester()
gA(nullptr),
@@ -306,11 +205,11 @@ XMLTester::XMLTester()
wktwriter(nullptr),
wkbreader(nullptr),
wkbwriter(nullptr),
- test_predicates(0),
- failed(0),
- succeeded(0),
+ failedCount(0),
+ succeededCount(0),
caseCount(0),
testCount(0),
+ testLineNum(0),
testFileCount(0),
totalTestCount(0),
curr_file(nullptr),
@@ -332,77 +231,80 @@ XMLTester::setVerbosityLevel(int value)
return old_value;
+std::string
+XMLTester::testcaseRef()
+ std::stringstream ref;
+ ref << *curr_file << " (" << testLineNum << "): ";
+ ref << "case " << caseCount;
+ ref << ", test " << testCount;
+ return ref.str();
/*private*/
void
-XMLTester::printTest(bool success, const std::string& expected_result, const std::string& actual_result,
- const util::Profile& prof)
+XMLTester::printTestSQL(bool success, const std::string& expected_result, const std::string& actual_result)
+ std::cout << "INSERT INTO \"" << normalize_filename(*curr_file) << "\" VALUES ("
+ << caseCount << ", "
+ << testCount << ", "
+ //<< "'" << opSignature << "', "
+ << "'" << curr_case_desc << "', ";
+ std::string geomOut;
+ if(gA) {
+ std::cout << "'" << printGeom(gA) << "', ";
+ else {
+ std::cout << "NULL, ";
+ if(gB) {
+ std::cout << "'" << printGeom(gB) << "', ";
+ else {
+ std::cout << "'" << expected_result << "', "
+ << "'" << actual_result << "', ";
+ if(success) {
+ std::cout << "'t'";
+ else {
+ std::cout << "'f'";
+ std::cout << ");" << std::endl;
+void
+XMLTester::printTest(bool success, const std::string& op, const std::string& expected_result, const std::string& actual_result)
if(sqlOutput) {
- std::cout << "INSERT INTO \"" << normalize_filename(*curr_file) << "\" VALUES ("
- << caseCount << ", "
- << testCount << ", "
- << "'" << opSignature << "', "
- << "'" << curr_case_desc << "', ";
+ printTestSQL(success, expected_result, actual_result);
+ return;
+ //-- no output for quiet success
+ if (success && verbose == 0)
+ return;
- std::string geomOut;
+ std::cout << testcaseRef() << ": " ;
+ std::cout << op << " " << (success ? "ok." : "failed.");
+ // print geometry on failure for -v
+ // print geometry always for -v -v and above
+ if (verbose > 1 || (verbose == 1 && !success)) {
+ std::cout << "\tDescription: " << curr_case_desc << std::endl;
if(gA) {
- std::cout << "'" << printGeom(gA) << "', ";
+ std::cout << "\tGeometry A: " << printGeom(gA) << std::endl;
- else {
- std::cout << "NULL, ";
if(gB) {
- std::cout << "'" << printGeom(gB) << "', ";
- else {
- std::cout << "'" << expected_result << "', "
- << "'" << actual_result << "', ";
- if(success) {
- std::cout << "'t'";
- else {
- std::cout << "'f'";
- std::cout << ");" << std::endl;
- else {
- std::cout << *curr_file << ":";
- std::cout << " case" << caseCount << ":";
- std::cout << " test" << testCount << ": "
- << opSignature;
- std::cout << ": " << (success ? "ok." : "failed.");
- std::cout << " (" << std::setprecision(15) << java_math_round(prof.getTot() / 1000) << " ms)" << std::endl;
- // print geometry on failure for -v
- // print geometry no matter what for -v -v and above
- if (verbose > 1 || (verbose == 1 && !success)) {
- std::cout << "\tDescription: " << curr_case_desc << std::endl;
- if(gA) {
- std::cout << "\tGeometry A: ";
- printGeom(std::cout, gA);
- std::cout << std::endl;
- if(gB) {
- std::cout << "\tGeometry B: ";
- printGeom(std::cout, gB);
- std::cout << "\tExpected result: " << expected_result << std::endl;
- std::cout << "\tObtained result: " << actual_result << std::endl;
+ std::cout << "\tGeometry B: " << printGeom(gB) << std::endl;
+ std::cout << "\tExpected: " << expected_result << std::endl;
+ std::cout << "\tActual: " << actual_result << std::endl;
+ std::cout << std::endl;
void
@@ -447,7 +349,6 @@ XMLTester::run(const std::string& source)
parseRun(node);
void
@@ -455,14 +356,14 @@ XMLTester::resultSummary(std::ostream& os) const
os << "Files: " << testFileCount << std::endl;
os << "Tests: " << totalTestCount << std::endl;
- os << "Failed: " << failed << std::endl;
- os << "Succeeded: " << succeeded << std::endl;
+ os << "Failed: " << failedCount << std::endl;
+ os << "Succeeded: " << succeededCount << std::endl;
void
XMLTester::resetCounters()
- testFileCount = totalTestCount = failed = succeeded = 0;
+ testFileCount = totalTestCount = failedCount = succeededCount = 0;
void
@@ -584,7 +485,6 @@ XMLTester::testValid(const geom::Geometry* g, const std::string& label)
std::cerr << *curr_file << ":"
- << opSignature << ": "
<< " invalid geometry (" << label
<< "): " << err->toString() << std::endl;
@@ -643,21 +543,6 @@ XMLTester::parseGeometry(const std::string& in, const char* label)
return ret.release();
-std::string
-XMLTester::trimBlanks(const std::string& in)
- std::string out;
- std::string::size_type pos = in.find_first_not_of(" \t\n\r");
- if(pos != std::string::npos) {
- out = in.substr(pos);
- pos = out.find_last_not_of(" \t\n\r");
- out = out.substr(0, pos + 1);
- return out;
void
XMLTester::parseCase(const tinyxml2::XMLNode* node)
@@ -670,9 +555,6 @@ XMLTester::parseCase(const tinyxml2::XMLNode* node)
gA = nullptr;
gB = nullptr;
- //dump_to_stdout(node);
curr_case_desc.clear();
const tinyxml2::XMLNode* txt = node->FirstChildElement("desc");
if(txt) {
@@ -681,10 +563,6 @@ XMLTester::parseCase(const tinyxml2::XMLNode* node)
curr_case_desc = trimBlanks(txt->Value());
- //std::cerr << "Desc: " << curr_case_desc << std::endl;
try {
const tinyxml2::XMLNode* el = node->FirstChildElement("a");
geomAin = el->FirstChild()->Value();
@@ -710,7 +588,7 @@ XMLTester::parseCase(const tinyxml2::XMLNode* node)
if(thrownException != "") {
+ std::cout << " case" << caseCount << " (" << node->GetLineNum() << "): ";
std::cout << " skipped (" << thrownException << ")." << std::endl;
if (gA) delete gA;
if (gB) delete gB;
@@ -724,7 +602,7 @@ XMLTester::parseCase(const tinyxml2::XMLNode* node)
for(testnode = node->FirstChildElement("test");
testnode;
testnode = testnode->NextSiblingElement("test")) {
- parseTest(testnode);
+ runTest(testnode);
totalTestCount += testCount;
@@ -733,13 +611,6 @@ XMLTester::parseCase(const tinyxml2::XMLNode* node)
delete gB;
-/*private*/
-void
-XMLTester::printGeom(std::ostream& os, const geom::Geometry* g)
- os << printGeom(g);
std::string
XMLTester::printGeom(const geom::Geometry* g)
@@ -756,6 +627,133 @@ XMLTester::printGeom(const geom::Geometry* g)
+void
+XMLTester::runTest(const tinyxml2::XMLNode* node)
+ Test test(*this);
+ ++testCount;
+ testLineNum = node->GetLineNum();
+ bool success = test.run(node, gA, gB);
+ if(success) {
+ ++succeededCount;
+ else {
+ ++failedCount;
+void
+XMLTester::runPredicates(const geom::Geometry* p_gA, const geom::Geometry* p_gB)
+ std::cout << "\t Equals:\tAB=" << (p_gA->equals(p_gB) ? "T" : "F") << ", BA=" << (p_gB->equals(
+ p_gA) ? "T" : "F") << std::endl;
+ std::cout << "\t Disjoint:\tAB=" << (p_gA->disjoint(p_gB) ? "T" : "F") << ", BA=" << (p_gB->disjoint(
+ std::cout << "\tIntersects:\tAB=" << (p_gA->intersects(p_gB) ? "T" : "F") << ", BA=" << (p_gB->intersects(
+ std::cout << "\t Touches:\tAB=" << (p_gA->touches(p_gB) ? "T" : "F") << ", BA=" << (p_gB->touches(
+ std::cout << "\t Crosses:\tAB=" << (p_gA->crosses(p_gB) ? "T" : "F") << ", BA=" << (p_gB->crosses(
+ std::cout << "\t Within:\tAB=" << (p_gA->within(p_gB) ? "T" : "F") << ", BA=" << (p_gB->within(
+ std::cout << "\t Contains:\tAB=" << (p_gA->contains(p_gB) ? "T" : "F") << ", BA=" << (p_gB->contains(
+ std::cout << "\t Overlaps:\tAB=" << (p_gA->overlaps(p_gB) ? "T" : "F") << ", BA=" << (p_gB->overlaps(
+ std::cout << "\t Prepared Disjoint:\tAB=" << (prepare(p_gA)->disjoint(p_gB) ? "T" : "F") << ", BA=" << (prepare(
+ p_gB)->disjoint(p_gA) ? "T" : "F") << std::endl;
+ std::cout << "\tPrepared Intersects:\tAB=" << (prepare(p_gA)->intersects(p_gB) ? "T" : "F") << ", BA=" << (prepare(
+ p_gB)->intersects(p_gA) ? "T" : "F") << std::endl;
+ std::cout << "\t Prepared Touches:\tAB=" << (prepare(p_gA)->touches(p_gB) ? "T" : "F") << ", BA=" << (prepare(
+ p_gB)->touches(p_gA) ? "T" : "F") << std::endl;
+ std::cout << "\t Prepared Crosses:\tAB=" << (prepare(p_gA)->crosses(p_gB) ? "T" : "F") << ", BA=" << (prepare(
+ p_gB)->crosses(p_gA) ? "T" : "F") << std::endl;
+ std::cout << "\t Prepared Within:\tAB=" << (prepare(p_gA)->within(p_gB) ? "T" : "F") << ", BA=" << (prepare(
+ p_gB)->within(p_gA) ? "T" : "F") << std::endl;
+ std::cout << "\t Prepared Contains:\tAB=" << (prepare(p_gA)->contains(p_gB) ? "T" : "F") << ", BA=" << (prepare(
+ p_gB)->contains(p_gA) ? "T" : "F") << std::endl;
+ std::cout << "\t Prepared Overlaps:\tAB=" << (prepare(p_gA)->overlaps(p_gB) ? "T" : "F") << ", BA=" << (prepare(
+ p_gB)->overlaps(p_gA) ? "T" : "F") << std::endl;
+XMLTester::~XMLTester()
+/* static */
+bool
+Test::checkOverlaySuccess(Geometry const& gExpected, Geometry const& gActual)
+ double tol = operation::overlay::snap::GeometrySnapper::computeSizeBasedSnapTolerance(gExpected);
+ //-- BUG: this allows all empties to test equal
+ if(gExpected.equals(&gActual)) {
+ return 1;
+ //TODO: is this needed by any tests?
+ std::cerr << "Using an overlay tolerance of " << tol << std::endl;
+ if(gExpected.equalsExact(&gActual, tol)) {
+ return 1;
+ return 0;
+/* static */
+bool
+Test::checkBufferSuccess(Geometry const& gExpected, Geometry const& gActual, double dist)
+ using geos::xmltester::BufferResultMatcher;
+ if(gExpected.getGeometryTypeId() != gActual.getGeometryTypeId()) {
+ std::cerr << "Expected result is of type "
+ << gExpected.getGeometryType()
+ << "; obtained result is of type "
+ << gActual.getGeometryType()
+ << std::endl;
+ return false;
+ // Is a buffer always an area ?
+ if(gExpected.getDimension() != 2) {
+ std::cerr << "Don't know how to validate "
+ << "result of buffer operation "
+ << "when expected result is not an "
+ << "areal type."
+ << std::endl;
+ if(!BufferResultMatcher::isBufferResultMatch(gActual, gExpected, dist)) {
+ std::cerr << "BufferResultMatcher FAILED" << std::endl;
+ return false;
+ return true;
+/* static */
+bool
+Test::checkSingleSidedBufferSuccess(geom::Geometry& gExpected,
+ geom::Geometry& gActual, double dist)
+ << std::endl;
+ return false;
+ geos::xmltester::SingleSidedBufferResultMatcher matcher;
+ if(! matcher.isBufferResultMatch(gActual,
+ gExpected,
+ dist)) {
+ std::cerr << "SingleSidedBufferResultMatcher FAILED" << std::endl;
+ return false;
+ return true;
* Computes the maximum area delta value
* resulting from identity equations over the overlay operations.
@@ -763,8 +761,9 @@ XMLTester::printGeom(const geom::Geometry* g)
* If the overlay operations are computed correctly
* the area delta is expected to be very small (e.g. < 1e-6).
+/* static */
double
-XMLTester::areaDelta(const geom::Geometry* a, const geom::Geometry* b, std::string& rsltMaxDiffOp, double maxDiff, std::stringstream& ss)
+Test::areaDelta(const geom::Geometry* a, const geom::Geometry* b, std::string& rsltMaxDiffOp, double maxDiff, std::stringstream& ss)
double areaA = a == nullptr ? 0 : a->getArea();
double areaB = b == nullptr ? 0 : b->getArea();
@@ -825,7 +824,6 @@ XMLTester::areaDelta(const geom::Geometry* a, const geom::Geometry* b, std::stri
// normalize the area delta value
double diffScore = maxDelta / (areaA + areaB);
if (diffScore > maxDiff) {
ss << std::endl << "A" << std::endl;
ss << *a;
@@ -843,31 +841,84 @@ XMLTester::areaDelta(const geom::Geometry* a, const geom::Geometry* b, std::stri
ss << *geomSD;
ss << std::endl;
return diffScore;
+void
+Test::checkResult( const Geometry& result )
+ checkResult( result,
+ [](Geometry& expected, Geometry& actual) -> bool {
+ //TODO: change to equalsExact, since compareTo doesn't check empty type
+ return expected.compareTo(&actual) == 0;
void
-XMLTester::parseTest(const tinyxml2::XMLNode* node)
+Test::checkResult( const Geometry& result,
+ std::function<bool(Geometry& expected, Geometry& actual)> isMatch )
- using namespace operation::overlay;
+ std::string expectedRes = opResult;
+ std::unique_ptr<Geometry> gExpectedRes(tester.parseGeometry(expectedRes, "expected"));
+ gExpectedRes->normalize();
- typedef std::unique_ptr< geom::Geometry > GeomPtr;
+ std::unique_ptr<Geometry> gActualRes(result.clone());
+ gActualRes->normalize();
- int success = 0; // no success by default
- std::string opName;
- std::string opArg1;
- std::string opArg2;
- std::string opArg3;
- std::string opArg4;
- std::string opRes;
+ isSuccess = isMatch(*gExpectedRes, *gActualRes);
- ++testCount;
+ if (testValidOutput) {
+ isSuccess &= tester.testValid(gActualRes.get(), "result");
+ actualResultStr = tester.printGeom(gActualRes.get());
+//TODO: remove this hack when tests are fixed. Only used for union, and has a bug where empties test equal
+void
+Test::checkUnionResult( const Geometry& result )
+ return checkOverlaySuccess(expected, actual);
+void
+Test::checkResult( bool result )
+ actualResultStr = result ? "true" : "false";
+ if (actualResultStr == opResult) {
+ isSuccess = true;
+void
+Test::checkResult( double result)
+ char* rest;
+ double expectedRes = std::strtod(opResult.c_str(), &rest);
+ if(rest == opResult.c_str()) {
+ throw std::runtime_error("malformed testcase: missing expected double value");
+ if (expectedRes == 0.0) {
+ if (result == 0.0) {
+ isSuccess = true;
+ else {
+ if (std::abs(expectedRes - result) / expectedRes < 1e-3) {
+ isSuccess = true;
+ std::stringstream ss;
+ ss << result;
+ actualResultStr = ss.str();
+void Test::parse(const tinyxml2::XMLNode* node) {
const tinyxml2::XMLNode* opnode = node->FirstChildElement("op");
if(! opnode) {
- throw(runtime_error("case has no op"));
+ throw(runtime_error("test has no op"));
//dump_to_stdout(opnode);
@@ -904,15 +955,13 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
const tinyxml2::XMLNode* resnode = opnode->FirstChild();
if(! resnode) {
std::stringstream p_tmp;
- p_tmp << "op of test " << testCount
- << " of case " << caseCount
- << " has no expected result child";
+ p_tmp << tester.testcaseRef() << ": op has no expected result child";
throw(runtime_error(p_tmp.str()));
- opRes = resnode->Value();
+ opResult = resnode->Value();
// trim blanks
- opRes = trimBlanks(opRes);
+ opResult = trimBlanks(opResult);
opName = trimBlanks(opName);
tolower(opName);
@@ -939,1402 +988,412 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
opSig += opArg4;
opSignature = opName + "(" + opSig + ")";
- std::string actual_result = "NONE";
- // expected_result will be modified by specific tests
- // if needed (geometry normalization, for example)
- std::string expected_result = opRes;
- util::Profile profile("op");
+bool Test::run(const tinyxml2::XMLNode* node, Geometry* geomA, Geometry* geomB)
+ parse(node);
+ Geometry* argA = geomA;
+ Geometry* argB = geomB;
+ //-- switch geom args if specified
+ if (opArg1 == "B") {
+ argA = geomB;
+ argB = geomA;
+ execute(argA, argB);
+ tester.printTest(isSuccess, opSignature, opResult, actualResultStr);
+ return isSuccess;
+void Test::execute(Geometry* geomA, Geometry* geomB)
try {
- if(opName == "relate") {
- std::unique_ptr<geom::IntersectionMatrix> im(gA->relate(gB));
- assert(im.get());
- if(im->matches(opArg3)) {
- actual_result = "true";
- else {
- actual_result = "false";
- if(actual_result == opRes) {
- success = 1;
- else if(opName == "relatestring") {
- assert(im.get());
- actual_result = im->toString();
- success = 1;
- else if(opName == "isvalid") {
- geom::Geometry* p_gT = gA;
- if((opArg1 == "B" || opArg1 == "b") && gB) {
- p_gT = gB;
- if(p_gT->isValid()) {
- else {
- success = 1;
- else if(opName == "intersection") {
- geom::Geometry* g1 = opArg1 == "B" ? gB : gA;
- geom::Geometry* g2 = opArg2 == "B" ? gB : gA;
- GeomPtr gRes(parseGeometry(opRes, "expected"));
- gRes->normalize();
- profile.start();
- GeomPtr gRealRes(g1->intersection(g2));
- profile.stop();
- gRealRes->normalize();
- if(gRes->compareTo(gRealRes.get()) == 0) {
- success = 1;
- actual_result = printGeom(gRealRes.get());
- expected_result = printGeom(gRes.get());
- if(testValidOutput) {
- success &= int(testValid(gRealRes.get(), "result"));
- else if(opName == "intersectionng") {
- profile.start();
- GeomPtr gRealRes = OverlayNG::overlay(gA, gB, OverlayNG::INTERSECTION);
- profile.stop();
- success = 1;
- else if(opName == "unionng") {
- profile.start();
- GeomPtr gRealRes = OverlayNG::overlay(gA, gB, OverlayNG::UNION);
- profile.stop();
- success = 1;
- else if(opName == "differenceng") {
- profile.start();
- const geom::Geometry* dgA = gA;
- const geom::Geometry* dgB = gB;
- // Swap arguments if necessary
- dgA = gB;
- dgB = gA;
- GeomPtr gRealRes = OverlayNG::overlay(dgA, dgB, OverlayNG::DIFFERENCE);
- profile.stop();
- success = 1;
- else if(opName == "symdifferenceng") {
- profile.start();
- GeomPtr gRealRes = OverlayNG::overlay(gA, gB, OverlayNG::SYMDIFFERENCE);
- profile.stop();
- success = 1;
- else if(opName == "intersectionsr") {
- double precision = 1.0;
- if(opArg3 != "") {
- precision = std::atof(opArg3.c_str());
- profile.start();
- geom::PrecisionModel precMod(precision);
- GeomPtr gRealRes = OverlayNG::overlay(gA, gB, OverlayNG::INTERSECTION, &precMod);
- profile.stop();
- success = 1;
- else if(opName == "intersectionsin") {
- profile.start();
- GeomPtr gRealRes = OverlayNGRobust::Intersection(gA, gB);
- profile.stop();
- success = 1;
- else if(opName == "unionsr") {
- GeomPtr gRealRes;
- if (gB) {
- gRealRes = OverlayNG::overlay(gA, gB, OverlayNG::UNION, &precMod);
- else {
- // gRealRes = OverlayNG::geomunion(gA, &precMod);
- gRealRes = UnaryUnionNG::Union(gA, precMod);
- if(opArg2 != "") {
- precision = std::atof(opArg2.c_str());
- success = 1;
- else if(opName == "differencesr") {
- dgA = gB;
- dgB = gA;
- profile.start();
- GeomPtr gRealRes = OverlayNG::overlay(dgA, dgB, OverlayNG::DIFFERENCE, &precMod);
- profile.stop();
- success = 1;
- else if(opName == "symdifferencesr") {
- profile.start();
- GeomPtr gRealRes = OverlayNG::overlay(gA, gB, OverlayNG::SYMDIFFERENCE, &precMod);
- profile.stop();
- success = 1;
- else if(opName == "densify") {
- geom::util::Densifier den(p_gT);
- double distanceTolerance = std::atof(opArg2.c_str());
- den.setDistanceTolerance(distanceTolerance);
- GeomPtr gRealRes = den.getResultGeometry();
- success = 1;
- else if(opName == "union") {
- profile.start();
- GeomPtr gRealRes;
- if(gB) {
- gRealRes = g1->Union(g2);
- else {
- gRealRes = g1->Union();
- profile.stop();
- success = checkOverlaySuccess(*gRes, *gRealRes);
- else if(opName == "difference") {
- GeomPtr gRealRes(g1->difference(g2));
- success = 1;
- else if(opName == "symdifference") {
- GeomPtr gRealRes(g1->symDifference(g2));
- success = 1;
- else if(opName == "intersects") {
- if(usePrepared) {
- if(prepare(g1)->intersects(g2)) {
- else if(g1->intersects(g2)) {
- success = 1;
- else if(opName == "contains") {
- if(usePrepared) {
- if(prepare(g1)->contains(g2)) {
- else if(g1->contains(g2)) {
- success = 1;
- else if(opName == "overlaps") {
- if(usePrepared) {
- if(prepare(g1)->overlaps(g2)) {
- else if(g1->overlaps(g2)) {
- success = 1;
- else if(opName == "within") {
- if(usePrepared) {
- if(prepare(g1)->within(g2)) {
- else if(g1->within(g2)) {
- success = 1;
- else if(opName == "touches") {
- if(usePrepared) {
- if(prepare(g1)->touches(g2)) {
- else if(g1->touches(g2)) {
- success = 1;
- else if(opName == "crosses") {
- if(usePrepared) {
- if(prepare(g1)->crosses(g2)) {
- else if(g1->crosses(g2)) {
- success = 1;
- else if(opName == "disjoint") {
- if(usePrepared) {
- if(prepare(g1)->disjoint(g2)) {
- else if(g1->disjoint(g2)) {
- success = 1;
- else if(opName == "covers") {
- if(usePrepared) {
- if(prepare(g1)->covers(g2)) {
- else if(g1->covers(g2)) {
- success = 1;
- // equalsTopo() is synonym for equals() in JTS
- else if(opName == "equalstopo") {
- if(g1->equals(g2)) {
- success = 1;
- else if(opName == "equalsexact") {
- if(g1->equalsExact(g2)) {
- success = 1;
- // rather than implementing equalsnorm in the library,
- // we just do it in this one test case for now
- else if(opName == "equalsnorm") {
- g1->normalize();
- g2->normalize();
- success = 1;
- else if(opName == "coveredby") {
- if(usePrepared) {
- if(prepare(g1)->coveredBy(g2)) {
- else if(g1->coveredBy(g2)) {
- success = 1;
- else if(opName == "getboundary") {
- p_gT = gB;
- GeomPtr gRealRes(p_gT->getBoundary());
- success = 1;
- else if(opName == "getcentroid") {
- p_gT = gB;
- GeomPtr gRealRes(p_gT->getCentroid());
- success = 1;
- else if(opName == "issimple") {
- p_gT = gB;
- if(p_gT->isSimple()) {
- else {
- success = 1;
- else if(opName == "convexhull") {
- p_gT = gB;
- GeomPtr gRealRes(p_gT->convexHull());
- success = 1;
- else if(opName == "buffer") {
- using namespace operation::buffer;
- p_gT = gB;
- profile.start();
- GeomPtr gRealRes;
- double dist = std::atof(opArg2.c_str());
- BufferParameters params;
- params.setQuadrantSegments(std::atoi(opArg3.c_str()));
- BufferOp op(p_gT, params);
- gRealRes = op.getResultGeometry(dist);
- profile.stop();
- // Validate the buffer operation
- success = checkBufferSuccess(*gRes, *gRealRes, dist);
- else if(opName == "buffersinglesided") {
- p_gT = gB;
- profile.start();
- GeomPtr gRealRes;
- BufferParameters params ;
- params.setJoinStyle(BufferParameters::JOIN_ROUND) ;
- bool leftSide = true ;
- if(opArg4 == "right") {
- leftSide = false ;
- BufferBuilder bufBuilder(params) ;
- gRealRes = bufBuilder.bufferLineSingleSided(p_gT, dist, leftSide);
- profile.stop();
- // Validate the single sided buffer operation
- success = checkSingleSidedBufferSuccess(*gRes,
- *gRealRes, dist);
- else if(opName == "buffermitredjoin") {
- p_gT = gB;
- profile.start();
- GeomPtr gRealRes;
- params.setJoinStyle(BufferParameters::JOIN_MITRE);
- profile.stop();
- else if(opName == "getinteriorpoint") {
- p_gT = gB;
- GeomPtr gRealRes(p_gT->getInteriorPoint());
- if(gRealRes.get()) {
- else {
- gRealRes = factory->createPoint();
- success = 1;
- else if(opName == "iswithindistance") {
- double dist = std::atof(opArg3.c_str());
- if(gA->isWithinDistance(gB, dist)) {
- else {
- success = 1;
- else if(opName == "polygonize") {
- GeomPtr gRes(wktreader->read(opRes));
- Polygonizer plgnzr;
- plgnzr.add(gA);
- auto polys = plgnzr.getPolygons();
- GeomPtr gRealRes(factory->createGeometryCollection(std::move(polys)));
- success = 1;
- else if(opName == "linemerge") {
- p_gT = gB;
- LineMerger merger;
- merger.add(p_gT);
- auto lines = merger.getMergedLineStrings();
- GeomPtr gRealRes(factory->createGeometryCollection(std::move(lines)));
- success = 1;
- else if(opName == "overlayareatest") {
- std::string maxDiffOp;
- std::stringstream p_tmp;
- double maxDiff = 1e-6;
- double areaDiff = areaDelta(gA, gB, maxDiffOp, maxDiff, p_tmp);
- // Debug output of actual geometries returned
- if (areaDiff < maxDiff && false) {
- std::cout << p_tmp.str();
- p_tmp.str("");
- p_tmp << maxDiffOp << ": " << areaDiff;
- actual_result = p_tmp.str();
- p_tmp.str("");
- p_tmp << maxDiff;
- expected_result = p_tmp.str();
- if (areaDiff < maxDiff)
- success = 1;
- else if(opName == "unionlength") {
- char* rest;
- GeomPtr result = OverlayNGRobust::Union(gA);
- double resultLength = result->getLength();
- double expectedLength = std::strtod(opRes.c_str(), &rest);
- if(rest == opRes.c_str()) {
- throw std::runtime_error("malformed testcase: missing expected length 'unionlength' op");
- std::stringstream ss;
- ss << resultLength;
- actual_result = ss.str();
- if (std::abs(expectedLength-resultLength) / expectedLength < 1e-3) {
- success = 1;
- else if(opName == "unionarea") {
- char* rest;
- double resultArea = result->getArea();
- double expectedArea = std::strtod(opRes.c_str(), &rest);
- throw std::runtime_error("malformed testcase: missing expected area 'unionarea' op");
- ss << resultArea;
- if (std::abs(expectedArea-resultArea) / expectedArea < 1e-3) {
- success = 1;
- else if(opName == "areatest") {
- char* rest;
- double toleratedDiff = std::strtod(opRes.c_str(), &rest);
- int validOut = 1;
- throw std::runtime_error("malformed testcase: missing tolerated area difference in 'areatest' op");
- if(verbose > 1) {
- std::cerr << "Running intersection for areatest" << std::endl;
- GeomPtr gI(gA->intersection(gB));
- validOut &= int(testValid(gI.get(), "areatest intersection"));
- if(verbose > 1) {
- std::cerr << "Running difference(A,B) for areatest" << std::endl;
- GeomPtr gDab(gA->difference(gB));
- validOut &= int(testValid(gI.get(), "areatest difference(a,b)"));
- if(verbose > 1) {
- std::cerr << "Running difference(B,A) for areatest" << std::endl;
- GeomPtr gDba(gB->difference(gA));
- validOut &= int(testValid(gI.get(), "areatest difference(b,a)"));
- if(verbose > 1) {
- std::cerr << "Running symdifference for areatest" << std::endl;
- GeomPtr gSD(gA->symDifference(gB));
- validOut &= int(testValid(gI.get(), "areatest symdifference"));
- if(verbose > 1) {
- std::cerr << "Running union for areatest" << std::endl;
- GeomPtr gU(gA->Union(gB));
- double areaA = gA->getArea();
- double areaB = gB->getArea();
- double areaI = gI->getArea();
- double areaDab = gDab->getArea();
- double areaDba = gDba->getArea();
- double areaSD = gSD->getArea();
- double areaU = gU->getArea();
- double maxdiff = 0;
- std::string maxdiffop;
- // @ : symdifference
- // - : difference
- // + : union
- // ^ : intersection
- // A == ( A ^ B ) + ( A - B )
- double diff = std::fabs(areaA - areaI - areaDab);
- if(diff > maxdiff) {
- maxdiffop = "A == ( A ^ B ) + ( A - B )";
- maxdiff = diff;
- // B == ( A ^ B ) + ( B - A )
- diff = std::fabs(areaB - areaI - areaDba);
- maxdiffop = "B == ( A ^ B ) + ( B - A )";
- maxdiff = diff;
- // ( A @ B ) == ( A - B ) + ( B - A )
- diff = std::fabs(areaDab + areaDba - areaSD);
- maxdiffop = "( A @ B ) == ( A - B ) + ( B - A )";
- maxdiff = diff;
- // ( A u B ) == ( A ^ B ) + ( A @ B )
- diff = std::fabs(areaI + areaSD - areaU);
- maxdiffop = "( A u B ) == ( A ^ B ) + ( A @ B )";
- maxdiff = diff;
- if(maxdiff <= toleratedDiff) {
- success = 1 && validOut;
- p_tmp << maxdiffop << ": " << maxdiff;
- expected_result = opRes;
- else if(opName == "distance") {
- char* rest;
- double distE = std::strtod(opRes.c_str(), &rest);
- throw std::runtime_error("malformed testcase: missing expected result in 'distance' op");
- double distO = g1->distance(g2);
- ss << distO;
- // TODO: Use a tolerance ?
- success = (distO == distE) ? 1 : 0;
- else if(opName == "minclearance") {
- char* rest;
- double minclearanceE = std::strtod(opRes.c_str(), &rest);
- throw std::runtime_error("malformed testcase: missing expected result in 'minclearance' op");
- precision::MinimumClearance mc(g1);
- double minclearanceO = mc.getDistance();
- ss << minclearanceO;
- // Hack for Inf/1.7976931348623157E308 comparison
- if(minclearanceO > 1.7976931348623157E308) {
- minclearanceO = 1.7976931348623157E308;
- success = (minclearanceO == minclearanceE) ? 1 : 0;
- else if(opName == "minclearanceline") {
- double tol = 0.0000001;
- GeomPtr lineE(parseGeometry(opRes, "expected"));
- if(!lineE) {
- throw std::runtime_error("malformed testcase: missing expected result in 'minclearanceline' op");
- std::unique_ptr<geom::Geometry> lineO = mc.getLine();
- lineO.get()->normalize();
- lineE.get()->normalize();
- actual_result = printGeom(lineO.get());
- success = lineE.get()->equalsExact(lineO.get(), tol) ? 1 : 0;
- else if (opName == "buildarea")
- GeomPtr gExpected(parseGeometry(opRes, "expected"));
- gExpected->normalize();
- auto gGot = BuildArea().build(gA);
- if( gGot )
- GeomPtr gRealRes(gGot.release());
- if (gExpected->equals(gRealRes.get())) success=1;
- actual_result=printGeom(gRealRes.get());
- expected_result=printGeom(gExpected.get());
- if( actual_result == expected_result ) success=1;
- if ( testValidOutput )
- else
- success = false;
- else if (opName == "makevalid")
- auto gGot = geos::operation::valid::MakeValid().build(gA);
- if( gGot )
- else
- success = false;
- else if(opName == "simplifydp" || opName == "simplifytp")
- p_gT = gB;
- profile.start();
- GeomPtr gRealRes;
- double tolerance = std::atof(opArg2.c_str());
- if (opName == "simplifydp") {
- gRealRes = geos::simplify::DouglasPeuckerSimplifier::simplify(p_gT, tolerance);
- else {
- gRealRes = geos::simplify::TopologyPreservingSimplifier::simplify(p_gT, tolerance);
- profile.stop();
- success = gRealRes.get()->equalsExact(gRes.get(), 0.000001) ? 1 : 0;
- else {
- std::cerr << *curr_file << ":";
- std::cerr << " case" << caseCount << ":";
- std::cerr << " test" << testCount << ": "
- << opName << "(" << opSig << ")";
- std::cerr << ": skipped (unrecognized)." << std::endl;
- return;
+ executeOp(geomA, geomB);
catch(const std::exception& e) {
- if (expected_result == "exception") {
- success = true;
- actual_result = "exception";
+ if (opResult == "exception") {
+ isSuccess = true;
+ actualResultStr = "exception";
else {
- std::cerr << "EXCEPTION on case " << caseCount
- << " test " << testCount << ": " << e.what()
+ std::cerr << "EXCEPTION in " << tester.testcaseRef() << ": " << e.what()
<< std::endl;
- actual_result = e.what();
+ actualResultStr = e.what();
catch(...) {
- std::cerr << "Unknown EXCEPTION on case "
- << caseCount
+ std::cerr << "Unknown EXCEPTION in "
+ << tester.testcaseRef()
<< std::endl;
- actual_result = "Unknown exception thrown";
+ actualResultStr = "Unknown exception thrown";
- if(success) {
- ++succeeded;
+void Test::executeOp(Geometry* gA, Geometry* gB)
+ if(opName == "relate") {
+ std::unique_ptr<geom::IntersectionMatrix> im(gA->relate(gB));
+ checkResult( im->matches(opArg3) );
+ else if(opName == "isvalid") {
+ checkResult( gA->isValid() );
+ else if(opName == "intersection" || opName == "intersectionng"
+ //TODO: remove this opname by fixing test
+ || opName == "intersectionsin") {
+ checkResult( *(gA->intersection(gB)) );
+ //-- in current GEOS all overlay is OverlayNG
+ else if(opName == "union"|| opName == "unionng") {
+ if (gB) {
+ checkUnionResult( *gA->Union(gB) );
+ else {
+ checkUnionResult( *gA->Union() );
+ else if(opName == "difference" || opName == "differenceng") {
+ checkResult( *gA->difference(gB) );
+ else if(opName == "symdifference" || opName == "symdifferenceng") {
+ checkResult( *gA->symDifference(gB) );
+ else if(opName == "intersectionsr") {
+ double precision = 1.0;
+ if(opArg3 != "") {
+ precision = std::atof(opArg3.c_str());
+ geom::PrecisionModel precMod(precision);
+ std::unique_ptr<Geometry> res = OverlayNG::overlay(gA, gB, OverlayNG::INTERSECTION, &precMod);
+ checkResult( *res );
+ else if(opName == "unionsr") {
+ std::unique_ptr<Geometry> res;
+ if (gB) {
+ res = OverlayNG::overlay(gA, gB, OverlayNG::UNION, &precMod);
+ else {
+ if(opArg2 != "") {
+ precision = std::atof(opArg2.c_str());
+ // gRealRes = OverlayNG::geomunion(gA, &precMod);
+ res = UnaryUnionNG::Union(gA, precMod);
+ else if(opName == "differencesr") {
+ std::unique_ptr<Geometry> res = OverlayNG::overlay(gA, gB, OverlayNG::DIFFERENCE, &precMod);
+ else if(opName == "symdifferencesr") {
+ std::unique_ptr<Geometry> res = OverlayNG::overlay(gA, gB, OverlayNG::SYMDIFFERENCE, &precMod);
+ else if(opName == "densify") {
+ double distanceTolerance = std::atof(opArg2.c_str());
+ geom::util::Densifier den(gA);
+ den.setDistanceTolerance(distanceTolerance);
+ checkResult( *den.getResultGeometry() );
+ else if(opName == "intersects") {
+ bool res = tester.isPrepared() ? prepare(gA)->intersects(gB) : gA->intersects(gB);
+ checkResult( res );
+ else if(opName == "contains") {
+ bool res = tester.isPrepared() ? prepare(gA)->contains(gB) : gA->contains(gB);
+ else if(opName == "overlaps") {
+ bool res = tester.isPrepared() ? prepare(gA)->overlaps(gB) : gA->overlaps(gB);
+ else if(opName == "within") {
+ bool res = tester.isPrepared() ? prepare(gA)->within(gB) : gA->within(gB);
+ else if(opName == "touches") {
+ bool res = tester.isPrepared() ? prepare(gA)->touches(gB) : gA->touches(gB);
+ else if(opName == "crosses") {
+ bool res = tester.isPrepared() ? prepare(gA)->crosses(gB) : gA->crosses(gB);
+ else if(opName == "disjoint") {
+ bool res = tester.isPrepared() ? prepare(gA)->disjoint(gB) : gA->disjoint(gB);
+ else if(opName == "covers") {
+ bool res = tester.isPrepared() ? prepare(gA)->covers(gB) : gA->covers(gB);
+ else if(opName == "coveredby") {
+ bool res = tester.isPrepared() ? prepare(gA)->coveredBy(gB) : gA->coveredBy(gB);
+ else if(opName == "equalstopo") {
+ // equalsTopo() is synonym for equals() in JTS
+ checkResult( gA->equals(gB));
+ else if(opName == "equalsexact") {
+ checkResult( gA->equalsExact(gB));
+ else if(opName == "equalsnorm") {
+ // rather than implementing equalsnorm in the library,
+ // we just do it in this one test case for now
+ // NOTE: mutates A and B !!!!
+ gA->normalize();
+ gB->normalize();
+ else if(opName == "getboundary") {
+ checkResult( *gA->getBoundary() );
+ else if(opName == "getcentroid") {
+ checkResult( *gA->getCentroid() );
+ else if(opName == "issimple") {
+ checkResult( gA->isSimple() );
+ else if(opName == "convexhull") {
+ checkResult( *gA->convexHull() );
+ else if(opName == "buffer") {
+ double dist = std::atof(opArg2.c_str());
+ operation::buffer::BufferParameters params;
+ params.setQuadrantSegments(std::atoi(opArg3.c_str()));
+ operation::buffer::BufferOp op(gA, params);
+ std::unique_ptr<Geometry> result = op.getResultGeometry(dist);
+ checkResult( *result,
+ [dist](Geometry& expected, Geometry& actual) -> bool {
+ return checkBufferSuccess(expected, actual, dist);
+ else if(opName == "buffermitredjoin") {
+ params.setJoinStyle(operation::buffer::BufferParameters::JOIN_MITRE);
+ else if(opName == "buffersinglesided") {
+ params.setJoinStyle(operation::buffer::BufferParameters::JOIN_ROUND);
+ bool leftSide = true ;
+ if(opArg4 == "right") {
+ leftSide = false ;
+ operation::buffer::BufferBuilder bufBuilder(params) ;
+ std::unique_ptr<Geometry> result = bufBuilder.bufferLineSingleSided(gA, dist, leftSide);
+ return checkSingleSidedBufferSuccess(expected, actual, dist);
+ else if(opName == "getinteriorpoint") {
+ //-- may return null
+ std::unique_ptr<Geometry> res(gA->getInteriorPoint());
+ if (! res.get()) {
+ res = tester.getFactory()->createPoint();
+ else if(opName == "iswithindistance") {
+ double dist = std::atof(opArg3.c_str());
+ checkResult( gA->isWithinDistance(gB, dist) );
+ else if(opName == "polygonize") {
+ Polygonizer plgnzr;
+ plgnzr.add(gA);
+ auto polys = plgnzr.getPolygons();
+ std::unique_ptr<Geometry> res(tester.getFactory()->createGeometryCollection(std::move(polys)));
+ else if(opName == "linemerge") {
+ LineMerger merger;
+ merger.add(gA);
+ auto lines = merger.getMergedLineStrings();
+ std::unique_ptr<Geometry> res(tester.getFactory()->createGeometryCollection(std::move(lines)));
+ else if(opName == "overlayareatest") {
+ std::string maxDiffOp;
+ std::stringstream p_tmp;
+ double maxDiff = 1e-6;
+ double areaDiff = areaDelta(gA, gB, maxDiffOp, maxDiff, p_tmp);
+ // Debug output of actual geometries returned
+ if (areaDiff < maxDiff && false) {
+ std::cout << p_tmp.str();
+ checkResult(areaDiff < maxDiff);
+ else if(opName == "unionlength") {
+ checkResult( OverlayNGRobust::Union(gA)->getLength() );
+ else if(opName == "unionarea") {
+ checkResult( OverlayNGRobust::Union(gA)->getArea() );
+ else if(opName == "areatest") {
+ char* rest;
+ double toleratedDiff = std::strtod(opResult.c_str(), &rest);
+ bool validOut = true;
+ throw std::runtime_error("malformed testcase: missing tolerated area difference in 'areatest' op");
+ std::unique_ptr<Geometry> gI(gA->intersection(gB));
+ if(testValidOutput) {
+ validOut &= tester.testValid(gI.get(), "areatest intersection");
+ std::unique_ptr<Geometry> gDab(gA->difference(gB));
+ validOut &= tester.testValid(gI.get(), "areatest difference(a,b)");
+ std::unique_ptr<Geometry> gDba(gB->difference(gA));
+ validOut &= tester.testValid(gI.get(), "areatest difference(b,a)");
+ std::unique_ptr<Geometry> gSD(gA->symDifference(gB));
+ validOut &= tester.testValid(gI.get(), "areatest symdifference");
+ std::unique_ptr<Geometry> gU(gA->Union(gB));
+ double areaA = gA->getArea();
+ double areaB = gB->getArea();
+ double areaI = gI->getArea();
+ double areaDab = gDab->getArea();
+ double areaDba = gDba->getArea();
+ double areaSD = gSD->getArea();
+ double areaU = gU->getArea();
+ double maxdiff = 0;
+ std::string maxdiffop;
+ // @ : symdifference
+ // - : difference
+ // + : union
+ // ^ : intersection
+ // A == ( A ^ B ) + ( A - B )
+ double diff = std::fabs(areaA - areaI - areaDab);
+ if(diff > maxdiff) {
+ maxdiffop = "A == ( A ^ B ) + ( A - B )";
+ maxdiff = diff;
+ // B == ( A ^ B ) + ( B - A )
+ diff = std::fabs(areaB - areaI - areaDba);
+ maxdiffop = "B == ( A ^ B ) + ( B - A )";
+ maxdiff = diff;
+ // ( A @ B ) == ( A - B ) + ( B - A )
+ diff = std::fabs(areaDab + areaDba - areaSD);
+ maxdiffop = "( A @ B ) == ( A - B ) + ( B - A )";
+ maxdiff = diff;
+ // ( A u B ) == ( A ^ B ) + ( A @ B )
+ diff = std::fabs(areaI + areaSD - areaU);
+ maxdiffop = "( A u B ) == ( A ^ B ) + ( A @ B )";
+ maxdiff = diff;
+ if(maxdiff <= toleratedDiff) {
+ isSuccess = validOut;
+ p_tmp << maxdiffop << ": " << maxdiff;
+ actualResultStr = p_tmp.str();
+ else if(opName == "distance") {
+ checkResult( gA->distance(gB) );
+ else if(opName == "minclearance") {
+ precision::MinimumClearance mc(gA);
+ double minclearanceO = mc.getDistance();
+ // Hack for Inf/1.7976931348623157E308 comparison
+ if(minclearanceO > 1.7976931348623157E308) {
+ minclearanceO = 1.7976931348623157E308;
+ checkResult( minclearanceO );
+ else if(opName == "minclearanceline") {
+ //TODO: could use a checkResult with a tolerance?
+ checkResult( *mc.getLine() );
+ else if (opName == "buildarea")
+ checkResult( *BuildArea().build(gA) );
+ else if (opName == "makevalid")
+ checkResult( *geos::operation::valid::MakeValid().build(gA) );
+ else if(opName == "simplifydp")
+ double tolerance = std::atof(opArg2.c_str());
+ checkResult( *geos::simplify::DouglasPeuckerSimplifier::simplify(gA, tolerance) );
+ else if(opName == "simplifytp")
+ checkResult( *geos::simplify::TopologyPreservingSimplifier::simplify(gA, tolerance) );
else {
- ++failed;
+ //TODO: error out here?
+ std::cerr << tester.testcaseRef() << " - " << opName;
+ std::cerr << ": skipped (unrecognized)." << std::endl;
- if((!success && verbose) || verbose > 0) {
- printTest(!!success, expected_result, actual_result, profile);
- if(test_predicates && gB && gA) {
- runPredicates(gA, gB);
-void
-XMLTester::runPredicates(const geom::Geometry* p_gA, const geom::Geometry* p_gB)
- std::cout << "\t Equals:\tAB=" << (p_gA->equals(p_gB) ? "T" : "F") << ", BA=" << (p_gB->equals(
- p_gA) ? "T" : "F") << std::endl;
- std::cout << "\t Disjoint:\tAB=" << (p_gA->disjoint(p_gB) ? "T" : "F") << ", BA=" << (p_gB->disjoint(
- std::cout << "\tIntersects:\tAB=" << (p_gA->intersects(p_gB) ? "T" : "F") << ", BA=" << (p_gB->intersects(
- std::cout << "\t Touches:\tAB=" << (p_gA->touches(p_gB) ? "T" : "F") << ", BA=" << (p_gB->touches(
- std::cout << "\t Crosses:\tAB=" << (p_gA->crosses(p_gB) ? "T" : "F") << ", BA=" << (p_gB->crosses(
- std::cout << "\t Within:\tAB=" << (p_gA->within(p_gB) ? "T" : "F") << ", BA=" << (p_gB->within(
- std::cout << "\t Contains:\tAB=" << (p_gA->contains(p_gB) ? "T" : "F") << ", BA=" << (p_gB->contains(
- std::cout << "\t Overlaps:\tAB=" << (p_gA->overlaps(p_gB) ? "T" : "F") << ", BA=" << (p_gB->overlaps(
- std::cout << "\t Prepared Disjoint:\tAB=" << (prepare(p_gA)->disjoint(p_gB) ? "T" : "F") << ", BA=" << (prepare(
- p_gB)->disjoint(p_gA) ? "T" : "F") << std::endl;
- std::cout << "\tPrepared Intersects:\tAB=" << (prepare(p_gA)->intersects(p_gB) ? "T" : "F") << ", BA=" << (prepare(
- p_gB)->intersects(p_gA) ? "T" : "F") << std::endl;
- std::cout << "\t Prepared Touches:\tAB=" << (prepare(p_gA)->touches(p_gB) ? "T" : "F") << ", BA=" << (prepare(
- p_gB)->touches(p_gA) ? "T" : "F") << std::endl;
- std::cout << "\t Prepared Crosses:\tAB=" << (prepare(p_gA)->crosses(p_gB) ? "T" : "F") << ", BA=" << (prepare(
- p_gB)->crosses(p_gA) ? "T" : "F") << std::endl;
- std::cout << "\t Prepared Within:\tAB=" << (prepare(p_gA)->within(p_gB) ? "T" : "F") << ", BA=" << (prepare(
- p_gB)->within(p_gA) ? "T" : "F") << std::endl;
- std::cout << "\t Prepared Contains:\tAB=" << (prepare(p_gA)->contains(p_gB) ? "T" : "F") << ", BA=" << (prepare(
- p_gB)->contains(p_gA) ? "T" : "F") << std::endl;
- std::cout << "\t Prepared Overlaps:\tAB=" << (prepare(p_gA)->overlaps(p_gB) ? "T" : "F") << ", BA=" << (prepare(
- p_gB)->overlaps(p_gA) ? "T" : "F") << std::endl;
-XMLTester::~XMLTester()
static void
usage(char* me, int exitcode, std::ostream& os)
@@ -2385,7 +1444,7 @@ main(int argC, char* argV[])
continue;
if(! std::strcmp(argV[i], "--test-valid-output")) {
- tester.testOutputValidity(true);
+ tester.setTestOutputValidity(true);
continue;
if(! std::strcmp(argV[i], "--sql-output")) {
@@ -2399,7 +1458,7 @@ main(int argC, char* argV[])
continue;
if(! std::strcmp(argV[i], "--test-valid-input")) {
- tester.testInputValidity(true);
+ tester.setTestInputValidity(true);
continue;
@@ -2428,39 +1487,5 @@ main(int argC, char* argV[])
DeInitAllocCheck();
#endif
- * $Log: XMLTester.cpp,v $
- * Revision 1.38 2006/07/13 03:59:10 csavage
- * Changes to compile on VC++ - fully qualified polygon name. Should also work on MingW, will test next.
- * Revision 1.37 2006/06/19 20:48:35 strk
- * parseCase(): make sure to exit the <case> tag before returning
- * Revision 1.36 2006/06/14 19:19:10 strk
- * Added support for "AreaTest" operations.
- * Revision 1.35 2006/06/12 10:39:29 strk
- * don't print test file precision model if verbosity level < 2.
- * Revision 1.34 2006/06/05 15:36:34 strk
- * Given OverlayOp funx code enum a name and renamed values to have a lowercase prefix. Drop all of noding headers from installed header set.
- * Revision 1.33 2006/05/19 16:38:22 strk
- * * tests/xmltester/XMLTester.cpp: report
- * error on load of requested tests.
- * Revision 1.32 2006/04/14 14:57:15 strk
- * XMLTester binary ops invoked using the new HeuristicOverlay template function.
- * Revision 1.31 2006/04/07 13:26:38 strk
- * Use of unique_ptr<> to prevent confusing leaks in tester
- * Revision 1.30 2006/03/22 16:01:33 strk
- * indexBintree.h header split, classes renamed to match JTS
- * Revision 1.29 2006/03/17 14:56:39 strk
- * Fixed filename normalizer for sql output
diff --git a/tests/xmltester/XMLTester.h b/tests/xmltester/XMLTester.h
index c37c0760a..4a10b9fb1 100644
--- a/tests/xmltester/XMLTester.h
+++ b/tests/xmltester/XMLTester.h
@@ -20,36 +20,22 @@
#include <tinyxml2.h>
using namespace geos;
class XMLTester {
private:
- enum {
- SHOW_RUN_INFO = 1,
- SHOW_CASE,
- SHOW_TEST,
- SHOW_RESULT,
- SHOW_GEOMS,
- SHOW_GEOMS_FULL,
- PRED
void parsePrecisionModel(const tinyxml2::XMLElement* el);
void parseRun(const tinyxml2::XMLNode* node);
void parseCase(const tinyxml2::XMLNode* node);
- void parseTest(const tinyxml2::XMLNode* node);
void runPredicates(const geom::Geometry* a, const geom::Geometry* b);
- geom::Geometry* parseGeometry(const std::string& in, const char* label = "parsed");
- static std::string trimBlanks(const std::string& in);
- void printGeom(std::ostream& os, const geom::Geometry* g);
- double areaDelta(const geom::Geometry* a, const geom::Geometry* b, std::string& rsltMaxDiffOp, double maxDiff, std::stringstream& ss);
- std::string printGeom(const geom::Geometry* g);
- void printTest(bool success, const std::string& expected_result, const std::string& actual_result,
- const util::Profile&);
+ void runTest(const tinyxml2::XMLNode* node);
- geom::Geometry* gA;
- geom::Geometry* gB;
+ Geometry* gA;
+ Geometry* gB;
bool usePrepared;
std::unique_ptr<geom::PrecisionModel> pm;
@@ -61,14 +47,12 @@ private:
tinyxml2::XMLDocument xml;
int verbose;
- int test_predicates;
- int failed;
- int succeeded;
+ int failedCount;
+ int succeededCount;
int caseCount;
int testCount;
- std::string opSignature;
+ int testLineNum;
int testFileCount;
int totalTestCount;
@@ -80,7 +64,6 @@ private:
bool sqlOutput;
bool HEXWKB_output;
- bool testValid(const geom::Geometry* g, const std::string& label);
public:
XMLTester();
@@ -89,6 +72,13 @@ public:
void resultSummary(std::ostream& os) const;
void resetCounters();
+ Geometry* parseGeometry(const std::string& in, const char* label = "parsed");
+ std::string printGeom(const geom::Geometry* g);
+ void printTest(bool success, const std::string& op, const std::string& expected_result, const std::string& actual_result);
+ void printTestSQL(bool success, const std::string& expected_result, const std::string& actual_result);
+ bool testValid(const geom::Geometry* g, const std::string& label);
+ std::string testcaseRef();
* Values:
* 0: Show case description, run tests, show result
@@ -99,32 +89,81 @@ public:
int setVerbosityLevel(int val);
- int
- getFailuresCount()
- return failed;
- void
- testOutputValidity(bool val)
+ void setTestOutputValidity(bool val)
testValidOutput = val;
- void
- testInputValidity(bool val)
+ void setTestInputValidity(bool val)
testValidInput = val;
- void
- setSQLOutput(bool val)
+ void setSQLOutput(bool val)
sqlOutput = val;
- void
- setHEXWKBOutput(bool val)
+ void setHEXWKBOutput(bool val)
HEXWKB_output = val;
+ int isVerbose() { return verbose; }
+ bool isTestValidOutput() { return testValidOutput; }
+ bool isPrepared() { return usePrepared; }
+ geom::GeometryFactory* getFactory() { return factory.get(); }
+ int getFailuresCount() { return failedCount; }
+ Executes a single test in a XML test file.
+class Test {
+private:
+ XMLTester& tester;
+ std::string opName;
+ std::string opArg1;
+ std::string opArg2;
+ std::string opArg3;
+ std::string opArg4;
+ std::string opResult;
+ std::string opSignature;
+ //TODO: make these functions on XMLTester?
+ bool testValidOutput;
+ bool isSuccess;
+ std::string actualResultStr;
+ void parse(const tinyxml2::XMLNode* node);
+ void execute(Geometry* geomA, Geometry* geomB);
+ void executeOp(Geometry* geomA, Geometry* geomB);
+ void checkResult( const Geometry& result );
+ void checkResult( const Geometry& result,
+ std::function<bool( Geometry& expected,
+ Geometry& actual )> isMatch );
+ void checkUnionResult( const Geometry& result );
+ void checkResult( double result );
+ void checkResult( bool result );
+ static bool checkBufferSuccess(Geometry const& gExpected, Geometry const& gActual, double dist);
+ static bool checkSingleSidedBufferSuccess(Geometry& gExpected, Geometry& gActual, double dist);
+ static bool checkOverlaySuccess(Geometry const& gExpected, Geometry const& gActual);
+ static double areaDelta(const geom::Geometry* a, const geom::Geometry* b, std::string& rsltMaxDiffOp, double maxDiff, std::stringstream& ss);
+public:
+ Test(XMLTester& xmlTester)
+ : tester(xmlTester),
+ isSuccess(false),
+ actualResultStr("NONE")
+ testValidOutput = tester.isTestValidOutput();
+ bool run(const tinyxml2::XMLNode* node, Geometry* geomA, Geometry* geomB);
Summary of changes:
tests/xmltester/XMLTester.cpp | 2265 ++++++++++++-----------------------------
tests/xmltester/XMLTester.h | 117 ++-
2 files changed, 723 insertions(+), 1659 deletions(-)
hooks/post-receive
More information about the geos-commits
