[geos-commits] [SCM] GEOS branch main updated. b094c692d908c41a0dd1298b44557c8de24de939
Wed Jul 9 13:38:31 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  b094c692d908c41a0dd1298b44557c8de24de939 (commit)
      from  f20da918c2b5d1edff7b2ac076332763792104ef (commit)
revisions in full, below.
commit b094c692d908c41a0dd1298b44557c8de24de939
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jul 9 13:38:11 2025 -0700
    Remove unused Unload class (#1284)
diff --git a/include/geos.h b/include/geos.h
index d5f9a8f11..31be3a966 100644
--- a/include/geos.h
+++ b/include/geos.h
@@ -33,7 +33,6 @@
 #include <geos/io/WKTReader.h>
 #include <geos/io/WKTWriter.h>
 #include <geos/io/CLocalizer.h>
-#include <geos/unload.h>
 /// Basic namespace for all GEOS functionalities.
 namespace geos {
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 36e64f042..4701c762e 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -63,7 +63,6 @@ class Point;
 class IntersectionMatrix;
 namespace io { // geos.io
-class Unload;
 } // namespace geos.io
@@ -1047,4 +1046,3 @@ struct GeomPtrPair {
 #ifdef _MSC_VER
 #pragma warning(pop)
 #endif
diff --git a/include/geos/geom/PrecisionModel.h b/include/geos/geom/PrecisionModel.h
index 2228067c5..d0d8ac648 100644
--- a/include/geos/geom/PrecisionModel.h
+++ b/include/geos/geom/PrecisionModel.h
@@ -28,7 +28,6 @@
 // Forward declarations
 namespace geos {
 namespace io {
-class Unload;
 namespace geom {
 class Coordinate;
@@ -86,7 +85,6 @@ namespace geom { // geos::geom
 class GEOS_DLL PrecisionModel {
-    friend class io::Unload;
 public:
diff --git a/include/geos/index/quadtree/Root.h b/include/geos/index/quadtree/Root.h
index c6fe85f1f..578be33c3 100644
--- a/include/geos/index/quadtree/Root.h
+++ b/include/geos/index/quadtree/Root.h
@@ -46,7 +46,6 @@ namespace quadtree { // geos::index::quadtree
  * and does not have a defined extent.
 class GEOS_DLL Root: public NodeBase {
-//friend class Unload;
 private:
@@ -84,4 +83,3 @@ protected:
 } // namespace geos::index::quadtree
 } // namespace geos
diff --git a/include/geos/unload.h b/include/geos/unload.h
deleted file mode 100644
index d60a83b5f..000000000
--- a/include/geos/unload.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
-#pragma once
-#include <geos/export.h>
-//xie add for realse static memory 2003,10,06
-namespace geos {
-namespace io {
-class GEOS_DLL Unload {
-private:
-    Unload(void) {}
-    ~Unload(void) {}
-public:
-    static void Release();
diff --git a/src/io/Unload.cpp b/src/io/Unload.cpp
index ff869e828..000000000
--- a/src/io/Unload.cpp
+++ /dev/null
@@ -1,32 +0,0 @@
- * Copyright (C) 2005-2006 Refractions Research Inc.
-#include <geos/geom/Geometry.h>
-#include <geos/geom/GeometryFactory.h>
-namespace geos {
-namespace io { // geos.io
-/*public static*/
-void
-Unload::Release()
-    //delete geom::Geometry::INTERNAL_GEOMETRY_FACTORY;
-} // namespace geos.io
-} //namespace geos
diff --git a/tests/unit/geos_unit.cpp b/tests/unit/geos_unit.cpp
index 8e008c8b2..a21402cee 100644
--- a/tests/unit/geos_unit.cpp
+++ b/tests/unit/geos_unit.cpp
@@ -10,8 +10,6 @@
 // tut
 #include <tut/tut.hpp>
 #include <tut/tut_reporter.hpp>
-// geos
 // std
 #include <cstdlib>
 #include <iomanip>
@@ -119,8 +117,5 @@ main(int argc, const char* argv[])
         return EXIT_FAILURE;
-    // XXX - mloskot - this should be removed in future!
-    geos::io::Unload::Release();
     return (visi.all_ok() ? EXIT_SUCCESS : EXIT_FAILURE);
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index aac0efb78..c3b33b939 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -57,7 +57,6 @@
 #include <geos/operation/polygonize/Polygonizer.h>
 #include <geos/operation/linemerge/LineMerger.h>
 #include <geos/profiler.h>
 #include <geos/operation/valid/IsValidOp.h>
 #include "XMLTester.h"
 #include "BufferResultMatcher.h"
@@ -151,7 +150,7 @@ tolower(std::string& str)
 void toupper(std::string& s)
-    std::transform(s.begin(), s.end(), s.begin(),
+    std::transform(s.begin(), s.end(), s.begin(),
         [](char c){ return (char)std::toupper(c); }
@@ -231,7 +230,7 @@ XMLTester::setVerbosityLevel(int value)
     return old_value;
-std::string
+std::string
 XMLTester::testcaseRef()
     std::stringstream ref;
@@ -630,7 +629,7 @@ XMLTester::printGeom(const geom::Geometry* g)
 void
 XMLTester::runTest(const tinyxml2::XMLNode* node)
-    Test test(*this);
+    Test test(*this);
     ++testCount;
     testLineNum = node->GetLineNum();
@@ -845,9 +844,9 @@ Test::areaDelta(const geom::Geometry* a, const geom::Geometry* b, std::string& r
 void
-Test::checkResult( const Geometry& result )
+Test::checkResult( const Geometry& result )
-    checkResult( result,
+    checkResult( result,
     [](Geometry& expected, Geometry& actual) -> bool {
         //TODO: change to equalsExact, since compareTo doesn't check empty type
         return expected.compareTo(&actual) == 0;
@@ -855,8 +854,8 @@ Test::checkResult( const Geometry& result )
 void
-Test::checkResult( const Geometry& result,
-    std::function<bool(Geometry& expected, Geometry& actual)> isMatch )
+Test::checkResult( const Geometry& result,
+    std::function<bool(Geometry& expected, Geometry& actual)> isMatch )
     std::string expectedRes = opResult;
     std::unique_ptr<Geometry> gExpectedRes(tester.parseGeometry(expectedRes, "expected"));
@@ -875,16 +874,16 @@ Test::checkResult( const Geometry& result,
 //TODO: remove this hack when tests are fixed.  Only used for union, and has a bug where empties test equal
 void
-Test::checkUnionResult( const Geometry& result )
+Test::checkUnionResult( const Geometry& result )
             return checkOverlaySuccess(expected, actual);
 void
-Test::checkResult( bool result )
+Test::checkResult( bool result )
     actualResultStr = result ? "true" : "false";
     if (actualResultStr == opResult) {
@@ -893,7 +892,7 @@ Test::checkResult( bool result )
 void
-Test::checkResult( double result)
+Test::checkResult( double result)
     char* rest;
     double expectedRes = std::strtod(opResult.c_str(), &rest);
@@ -1031,7 +1030,7 @@ void Test::execute(Geometry* geomA, Geometry* geomB)
 void Test::executeOp(Geometry* gA, Geometry* gB)
     if(opName == "relate") {
         std::unique_ptr<geom::IntersectionMatrix> im(gA->relate(gB));
         checkResult( im->matches(opArg3) );
@@ -1184,7 +1183,7 @@ void Test::executeOp(Geometry* gA, Geometry* gB)
         operation::buffer::BufferOp op(gA, params);
         std::unique_ptr<Geometry> result = op.getResultGeometry(dist);
-        checkResult( *result,
+        checkResult( *result,
             [dist](Geometry& expected, Geometry& actual) -> bool {
                 return checkBufferSuccess(expected, actual, dist);
@@ -1200,7 +1199,7 @@ void Test::executeOp(Geometry* gA, Geometry* gB)
@@ -1219,7 +1218,7 @@ void Test::executeOp(Geometry* gA, Geometry* gB)
         operation::buffer::BufferBuilder bufBuilder(params) ;
         std::unique_ptr<Geometry> result = bufBuilder.bufferLineSingleSided(gA, dist, leftSide);
                 return checkSingleSidedBufferSuccess(expected, actual, dist);
@@ -1255,7 +1254,7 @@ void Test::executeOp(Geometry* gA, Geometry* gB)
         std::stringstream p_tmp;
         double maxDiff = 1e-6;
         double areaDiff = areaDelta(gA, gB, maxDiffOp, maxDiff, p_tmp);
         // Debug output of actual geometries returned
         if (areaDiff < maxDiff && false) {
             std::cout << p_tmp.str();
@@ -1479,8 +1478,6 @@ main(int argC, char* argV[])
             tester.resultSummary(std::cerr);
-        io::Unload::Release();
         return tester.getFailuresCount();
 #if defined(_MSC_VER) && defined(GEOS_TEST_USE_STACKWALKER)
@@ -1488,4 +1485,3 @@ main(int argC, char* argV[])
     DeInitAllocCheck();
 #endif
Summary of changes:
 include/geos.h                     |  1 -
 include/geos/geom/Geometry.h       |  2 --
 include/geos/geom/PrecisionModel.h |  2 --
 include/geos/index/quadtree/Root.h |  2 --
 include/geos/unload.h              | 33 ---------------------------------
 src/io/Unload.cpp                  | 32 --------------------------------
 tests/unit/geos_unit.cpp           |  5 -----
 tests/xmltester/XMLTester.cpp      | 36 ++++++++++++++++--------------------
 8 files changed, 16 insertions(+), 97 deletions(-)
 delete mode 100644 include/geos/unload.h
 delete mode 100644 src/io/Unload.cpp
hooks/post-receive
More information about the geos-commits mailing list
