[geos-commits] [SCM] GEOS branch main updated. 790f14e27d734b8ed253c1238de5f3155299afcc
Fri Jul 11 10:31:04 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  790f14e27d734b8ed253c1238de5f3155299afcc (commit)
      from  b094c692d908c41a0dd1298b44557c8de24de939 (commit)
revisions in full, below.
commit 790f14e27d734b8ed253c1238de5f3155299afcc
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Jul 11 13:30:41 2025 -0400
    Add functions to interrupt processing in a specific thread/context (#803)
    * Add functions to interrupt processing in a specific thread/context
    - Add CurrentThreadInterrupt::interrupt() (C API: GEOS_interruptThread) to
       interrupt the current thread only.
    - Add CurrentThreadInterrupt::registerCallback to register an interruption
      callback for the current thread only.
    - Add GEOSContext_setInterruptCallback_r to associate an interruption
      callback with a context handle. The callback will be registered for
      the current thread each time an _r function is called with the
      specified handle.
    * Update context-specific interruption with @macdrevx feedback
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 39671cc69..5e4a72b3c 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -333,10 +333,9 @@ typedef int (*GEOSTransformXYZCallback)(
 /* ========== Interruption ========== */
-* Callback function for use in interruption. The callback will be invoked _before_ checking for
-* interruption, so can be used to request it.
+* Callback function for use in interruption. The callback will be invoked at each
+* possible interruption point and can be used to request interruption.
 * \see GEOS_interruptRegisterCallback
 * \see GEOS_interruptRequest
@@ -345,21 +344,59 @@ typedef int (*GEOSTransformXYZCallback)(
 typedef void (GEOSInterruptCallback)(void);
-* Register a function to be called when processing is interrupted.
+* possible interruption point and can be used to request interruption by returning
+* a non-zero value.
+* \see GEOSContext_setInterruptCallback_r
+* \since 3.14
+typedef int (GEOSContextInterruptCallback)(void*);
+* Register a function to be called when a possible interruption point is reached
+* on any thread. The function may be used to request interruption.
 * \param cb Callback function to invoke
-* \return the previously configured callback
+* \return the previously registered callback, or NULL
 * \see GEOSInterruptCallback
 * \since 3.4
 extern GEOSInterruptCallback GEOS_DLL *GEOS_interruptRegisterCallback(
     GEOSInterruptCallback* cb);
-* Request safe interruption of operations
+* in code executed in the specified context. The function can interrupt the
+* thread if desired by returning True.
+* \param extHandle the context returned by \ref GEOS_init_r.
+* \param cb Callback function to invoke
+* \param userData optional data to be pe provided as argument to callback
+* \see GEOSContextInterruptCallback
+* \since 3.14
+extern GEOSContextInterruptCallback GEOS_DLL *GEOSContext_setInterruptCallback_r(
+        GEOSContextHandle_t extHandle,
+        GEOSContextInterruptCallback* cb,
+        void* userData);
+* Request safe interruption of operations. The next thread to check for an
+* interrupt will be interrupted. To request interruption of a specific thread,
+* instead call GEOS_interruptThread() from a callback executed by that thread.
 * \since 3.4
 extern void GEOS_DLL GEOS_interruptRequest(void);
+* Interrupt the current thread.
+* \since 3.14
+extern void GEOS_DLL GEOS_interruptThread(void);
 * Cancel a pending interruption request
 * \since 3.4
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 27ee5b812..bf6cebebc 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -242,6 +242,8 @@ typedef struct GEOSContextHandle_HS {
     void* noticeData;
     GEOSMessageHandler errorMessageOld;
     GEOSMessageHandler_r errorMessageNew;
+    GEOSContextInterruptCallback* interrupt_cb;
+    void* interrupt_cb_data;
     void* errorData;
     uint8_t WKBOutputDims;
     int WKBByteOrder;
@@ -256,6 +258,8 @@ typedef struct GEOSContextHandle_HS {
         noticeData(nullptr),
         errorMessageOld(nullptr),
         errorMessageNew(nullptr),
+        interrupt_cb(nullptr),
+        interrupt_cb_data(nullptr),
         errorData(nullptr),
         point2d(nullptr)
@@ -313,6 +317,15 @@ typedef struct GEOSContextHandle_HS {
         return f;
+    setInterruptHandler(GEOSContextInterruptCallback* cb, void* userData)
+        auto old = interrupt_cb;
+        interrupt_cb = cb;
+        interrupt_cb_data = userData;
+        return old;
     void
     NOTICE_MESSAGE(GEOS_PRINTF_FORMAT const char *fmt, ...) GEOS_PRINTF_FORMAT_ATTR(2, 3)
@@ -427,12 +440,37 @@ gstrdup(std::string const& str)
     return gstrdup_s(str.c_str(), str.size());
+struct InterruptManager {
+    InterruptManager(GEOSContextHandle_t handle) :
+        cb(handle->interrupt_cb),
+        cb_data(handle->interrupt_cb_data) {
+        if (cb) {
+            geos::util::CurrentThreadInterrupt::registerCallback(cb, cb_data);
+    ~InterruptManager() {
+        if (cb != nullptr) {
+            geos::util::CurrentThreadInterrupt::registerCallback(nullptr, nullptr);
+    GEOSContextInterruptCallback* cb;
+    void* cb_data;
+struct NotInterruptible {
+    NotInterruptible(GEOSContextHandle_t handle) {
+        (void) handle;
 } // namespace anonymous
 // Execute a lambda, using the given context handle to process errors.
 // Return errval on error.
 // Errval should be of the type returned by f, unless f returns a bool in which case we promote to char.
-template<typename F>
+template<typename InterruptManagerType=InterruptManager, typename F>
 inline auto execute(
         typename std::conditional<std::is_same<decltype(std::declval<F>()()),bool>::value,
@@ -448,6 +486,8 @@ inline auto execute(
         return errval;
+    InterruptManagerType ic(handle);
     try {
         return f();
     } catch (const std::exception& e) {
@@ -461,7 +501,7 @@ inline auto execute(
 // Return nullptr on error.
-template<typename F, typename std::enable_if<!std::is_void<decltype(std::declval<F>()())>::value, std::nullptr_t>::type = nullptr>
+template<typename InterruptManagerType=InterruptManager, typename F, typename std::enable_if<!std::is_void<decltype(std::declval<F>()())>::value, std::nullptr_t>::type = nullptr>
 inline auto execute(GEOSContextHandle_t extHandle, F&& f) -> decltype(f()) {
     if (extHandle == nullptr) {
         throw std::runtime_error("context handle is uninitialized, call initGEOS");
@@ -472,6 +512,8 @@ inline auto execute(GEOSContextHandle_t extHandle, F&& f) -> decltype(f()) {
         return nullptr;
     try {
         return f();
@@ -485,9 +527,14 @@ inline auto execute(GEOSContextHandle_t extHandle, F&& f) -> decltype(f()) {
 // No return value.
-template<typename F, typename std::enable_if<std::is_void<decltype(std::declval<F>()())>::value, std::nullptr_t>::type = nullptr>
+template<typename InterruptManagerType=InterruptManager, typename F, typename std::enable_if<std::is_void<decltype(std::declval<F>()())>::value, std::nullptr_t>::type = nullptr>
 inline void execute(GEOSContextHandle_t extHandle, F&& f) {
     GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+    if (handle != nullptr) {
     try {
         f();
@@ -566,6 +613,17 @@ extern "C" {
         return handle->setErrorHandler(ef, userData);
+    GEOSContext_setInterruptCallback_r(GEOSContextHandle_t extHandle, GEOSContextInterruptCallback* cb, void* userData)
+        GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+        if(0 == handle->initialized) {
+            return nullptr;
+        return handle->setInterruptHandler(cb, userData);
     void
     finishGEOS_r(GEOSContextHandle_t extHandle)
@@ -939,7 +997,7 @@ extern "C" {
     int
     GEOSArea_r(GEOSContextHandle_t extHandle, const Geometry* g, double* area)
-        return execute(extHandle, 0, [&]() {
+        return execute<NotInterruptible>(extHandle, 0, [&]() {
             *area = g->getArea();
             return 1;
@@ -948,7 +1006,7 @@ extern "C" {
     int
     GEOSLength_r(GEOSContextHandle_t extHandle, const Geometry* g, double* length)
             *length = g->getLength();
             return 1;
@@ -1877,7 +1935,7 @@ extern "C" {
     int
     GEOSGetNumInteriorRings_r(GEOSContextHandle_t extHandle, const Geometry* g1)
-        return execute(extHandle, -1, [&]() {
+        return execute<NotInterruptible>(extHandle, -1, [&]() {
             const Surface* p = dynamic_cast<const Surface*>(g1);
             if(!p) {
                 throw IllegalArgumentException("Argument is not a Surface");
@@ -1891,7 +1949,7 @@ extern "C" {
     int
     GEOSGetNumGeometries_r(GEOSContextHandle_t extHandle, const Geometry* g1)
             return static_cast<int>(g1->getNumGeometries());
@@ -1904,7 +1962,7 @@ extern "C" {
     const Geometry*
     GEOSGetGeometryN_r(GEOSContextHandle_t extHandle, const Geometry* g1, int n)
-        return execute(extHandle, [&]() {
+        return execute<NotInterruptible>(extHandle, [&]() {
             if(n < 0) {
                 throw IllegalArgumentException("Index must be non-negative.");
@@ -2096,7 +2154,7 @@ extern "C" {
     const Geometry*
     GEOSGetExteriorRing_r(GEOSContextHandle_t extHandle, const Geometry* g1)
             if(!p) {
                 throw IllegalArgumentException("Invalid argument (must be a Surface)");
@@ -2112,7 +2170,7 @@ extern "C" {
     const Geometry*
     GEOSGetInteriorRingN_r(GEOSContextHandle_t extHandle, const Geometry* g1, int n)
             if(!p) {
@@ -2881,7 +2939,7 @@ extern "C" {
     GEOSCoordSeq_setOrdinate_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs,
                                unsigned int idx, unsigned int dim, double val)
             cs->setOrdinate(idx, dim, val);
             return 1;
@@ -2914,7 +2972,7 @@ extern "C" {
     int
     GEOSCoordSeq_setXY_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs, unsigned int idx, double x, double y)
             cs->setAt(CoordinateXY{x, y}, idx);
             return 1;
@@ -2923,7 +2981,7 @@ extern "C" {
     int
     GEOSCoordSeq_setXYZ_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs, unsigned int idx, double x, double y, double z)
             cs->setAt(Coordinate{x, y, z}, idx);
             return 1;
@@ -2941,7 +2999,7 @@ extern "C" {
     GEOSCoordSeq_getOrdinate_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs,
                                unsigned int idx, unsigned int dim, double* val)
             *val = cs->getOrdinate(idx, dim);
             return 1;
@@ -2974,7 +3032,7 @@ extern "C" {
     int
     GEOSCoordSeq_getXY_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int idx, double* x, double* y)
             auto& c = cs->getAt<CoordinateXY>(idx);
             *x = c.x;
             *y = c.y;
@@ -2985,7 +3043,7 @@ extern "C" {
     int
     GEOSCoordSeq_getXYZ_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int idx, double* x, double* y, double* z)
             auto& c = cs->getAt(idx);
             *x = c.x;
             *y = c.y;
@@ -2997,7 +3055,7 @@ extern "C" {
     int
     GEOSCoordSeq_getSize_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int* size)
             const std::size_t sz = cs->getSize();
             *size = static_cast<unsigned int>(sz);
             return 1;
@@ -3007,7 +3065,7 @@ extern "C" {
     int
     GEOSCoordSeq_getDimensions_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int* dims)
             const std::size_t dim = cs->getDimension();
             *dims = static_cast<unsigned int>(dim);
diff --git a/include/geos/util/Interrupt.h b/include/geos/util/Interrupt.h
index e52386d41..5c8da22d2 100644
--- a/include/geos/util/Interrupt.h
+++ b/include/geos/util/Interrupt.h
@@ -19,8 +19,6 @@
 namespace geos {
 namespace util { // geos::util
-#define GEOS_CHECK_FOR_INTERRUPTS() geos::util::Interrupt::process()
 /** \brief Used to manage interruption requests and callbacks. */
 class GEOS_DLL Interrupt {
@@ -32,7 +30,8 @@ public:
      * Request interruption of operations
      * Operations will be terminated by a GEOSInterrupt
-     * exception at first occasion.
+     * exception at first occasion, by the first thread
+     * to check for an interrupt request.
     static void request();
@@ -43,14 +42,14 @@ public:
     static bool check();
     /** \brief
-     * Register a callback that will be invoked
+     * Register a callback that will be invoked by all threads
      * before checking for interruption requests.
      * NOTE that interruption request checking may happen
-     * frequently so any callback would better be quick.
+     * frequently so the callback should execute quickly.
      * The callback can be used to call Interrupt::request()
+     * or Interrupt::requestForCurrentThread().
     static Callback* registerCallback(Callback* cb);
@@ -65,7 +64,26 @@ public:
+class GEOS_DLL CurrentThreadInterrupt {
+public:
+    typedef int (ThreadCallback)(void*);
+    /** \brief
+     * Register a callback that will be invoked by the current thread
+     * to check if it should be interrupted. If the callback returns
+     * True, the thread will be interrupted. The previously registered
+     * callback, if any, will be returned.
+    static ThreadCallback* registerCallback(ThreadCallback* cb, void* data);
+    static void process();
+    static void interrupt();
 } // namespace geos::util
 } // namespace geos
+inline void GEOS_CHECK_FOR_INTERRUPTS() { geos::util::Interrupt::process(); geos::util::CurrentThreadInterrupt::process(); }
diff --git a/src/util/Interrupt.cpp b/src/util/Interrupt.cpp
index 0bc988221..a56fd8229 100644
--- a/src/util/Interrupt.cpp
+++ b/src/util/Interrupt.cpp
@@ -16,10 +16,15 @@
 #include <geos/util/GEOSException.h> // for inheritance
 namespace {
-/* Could these be portably stored in thread-specific space ? */
+// Callback and request status for interruption of any single thread
+geos::util::Interrupt::Callback* callback = nullptr;
 bool requested = false;
-geos::util::Interrupt::Callback* callback = nullptr;
+// Callback for interruption of the current thread
+thread_local geos::util::CurrentThreadInterrupt::ThreadCallback* callback_thread = nullptr;
+thread_local void* callback_thread_data = nullptr;
 namespace geos {
@@ -63,8 +68,7 @@ Interrupt::process()
     if(callback) {
         (*callback)();
-    if(requested) {
-        requested = false;
+    if(check()) {
         interrupt();
@@ -77,6 +81,25 @@ Interrupt::interrupt()
     throw InterruptedException();
+CurrentThreadInterrupt::ThreadCallback*
+CurrentThreadInterrupt::registerCallback(ThreadCallback *cb, void *data) {
+    auto* prev = callback_thread;
+    callback_thread = cb;
+    callback_thread_data = data;
+    return prev;
+void
+CurrentThreadInterrupt::process() {
+    if (callback_thread && (*callback_thread)(callback_thread_data)) {
+        interrupt();
+void
+CurrentThreadInterrupt::interrupt() {
+    throw InterruptedException();
 } // namespace geos
diff --git a/tests/unit/CMakeLists.txt b/tests/unit/CMakeLists.txt
index d54d82b9c..b28795cbc 100644
--- a/tests/unit/CMakeLists.txt
+++ b/tests/unit/CMakeLists.txt
@@ -31,6 +31,7 @@ foreach(_testfile ${_testfiles})
       string(CONCAT _testname "geos::" ${_testname})
     endif()
     add_test(NAME unit-${_cmake_testname} COMMAND test_geos_unit ${_testname})
+    set_tests_properties(unit-${_cmake_testname} PROPERTIES TIMEOUT 30)
 endforeach()
 # Run all the unit tests in one go, for faster memory checking
diff --git a/tests/unit/capi/GEOSInterruptTest.cpp b/tests/unit/capi/GEOSInterruptTest.cpp
index 0843d1bea..facb017cc 100644
--- a/tests/unit/capi/GEOSInterruptTest.cpp
+++ b/tests/unit/capi/GEOSInterruptTest.cpp
@@ -1,9 +1,11 @@
-// Test Suite for C-API custom allocators
+// Test Suite for C-API interrupt functions
 #include <tut/tut.hpp>
 // geos
 #include <geos_c.h>
+#include <geos/util/Interrupt.h>
+// std
+#include <thread>
 #include "capi_test_utils.h"
@@ -15,6 +17,7 @@ namespace tut {
 // Common data used in test cases.
 struct test_capiinterrupt_data : public capitest::utility {
     static int numcalls;
+    static int maxcalls;
     static GEOSInterruptCallback* nextcb;
     static void
@@ -32,9 +35,16 @@ struct test_capiinterrupt_data : public capitest::utility {
+    static int
+    interruptAfterMaxCalls(void* data)
+        return ++*static_cast<int*>(data) >= maxcalls;
 int test_capiinterrupt_data::numcalls = 0;
+int test_capiinterrupt_data::maxcalls = 0;
 GEOSInterruptCallback* test_capiinterrupt_data::nextcb = nullptr;
 typedef test_group<test_capiinterrupt_data> group;
@@ -66,7 +76,7 @@ void object::test<1>
     GEOSGeometry* geom2 = GEOSBuffer(geom1, 1, 8);
-    ensure("GEOSBufferWithStyle failed", nullptr != geom2);
+    ensure("GEOSBuffer failed", nullptr != geom2);
     ensure("interrupt callback never called", numcalls > 0);
@@ -79,7 +89,7 @@ void object::test<1>
     finishGEOS();
-/// Test interrupt callback being called XXX
+/// Test interrupt callback being called
 template<>
 template<>
 void object::test<2>
@@ -197,5 +207,55 @@ void object::test<5>
+// Test callback is thread-local
+template<>
+template<>
+void object::test<6>
+    using geos::util::CurrentThreadInterrupt;
+    maxcalls = 3;
+    int calls_1 = 0;
+    int calls_2 = 0;
+    GEOSContextHandle_t h1 = initGEOS_r(notice, notice);
+    GEOSContextHandle_t h2 = initGEOS_r(notice, notice);
+    GEOSContext_setInterruptCallback_r(h1, interruptAfterMaxCalls, &calls_1);
+    GEOSContext_setInterruptCallback_r(h2, interruptAfterMaxCalls, &calls_2);
+    // get previously registered callback and verify there was none
+    // (the context registered its callback only when invoking a function)
+    ensure(CurrentThreadInterrupt::registerCallback(nullptr, nullptr) == nullptr);
+    auto buffer = [](GEOSContextHandle_t handle) {
+        GEOSWKTReader* reader = GEOSWKTReader_create_r(handle);
+        GEOSGeometry* geom1 = GEOSWKTReader_read_r(handle, reader, "LINESTRING (0 0, 1 0)");
+        GEOSGeometry* geom2 = GEOSBuffer_r(handle, geom1, 1, 8);
+        GEOSGeom_destroy_r(handle, geom2);
+        GEOSGeom_destroy_r(handle, geom1);
+        GEOSWKTReader_destroy_r(handle, reader);
+    std::thread t1(buffer, h1);
+    std::thread t2(buffer, h2);
+    t1.join();
+    t2.join();
+    ensure_equals(calls_1, maxcalls);
+    ensure_equals(calls_2, maxcalls);
+    // (context unregistered its callback after completing GEOSBuffer)
+    finishGEOS_r(h1);
+    finishGEOS_r(h2);
 } // namespace tut
diff --git a/tests/unit/util/InterruptTest.cpp b/tests/unit/util/InterruptTest.cpp
new file mode 100644
index 000000000..caeb96581
--- /dev/null
+++ b/tests/unit/util/InterruptTest.cpp
@@ -0,0 +1,150 @@
+// tut
+#include <tut/tut.hpp>
+// geos
+// std
+#include <chrono>
+#include <functional>
+#include <thread>
+using geos::util::Interrupt;
+using geos::util::CurrentThreadInterrupt;
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_interrupt_data {
+    static void workForever() {
+        try {
+            //std::cerr << "Started " << std::this_thread::get_id() << "." << std::endl;
+            while (true) {
+                std::this_thread::sleep_for(std::chrono::milliseconds(10));
+                GEOS_CHECK_FOR_INTERRUPTS();
+        } catch (const std::exception&) {
+            //std::cerr << "Interrupted " << std::this_thread::get_id() << "." << std::endl;
+    static void interruptNow() {
+        Interrupt::request();
+    static std::map<std::thread::id, bool>* toInterrupt;
+    static void interruptIfRequested() {
+        if (toInterrupt == nullptr) {
+            return;
+        auto it = toInterrupt->find(std::this_thread::get_id());
+        if (it != toInterrupt->end() && it->second) {
+            it->second = false;
+            CurrentThreadInterrupt::interrupt();
+    static bool interruptCurrentThreadIfRequested() {
+            return false;
+            return true;
+        return false;
+std::map<std::thread::id, bool>* test_interrupt_data::toInterrupt = nullptr;
+typedef test_group<test_interrupt_data> group;
+typedef group::object object;
+group test_interrupt_group("geos::util::Interrupt");
+// Test Cases
+// Interrupt worker thread via global request from main thead
+template<>
+template<>
+void object::test<1>
+    std::thread t(workForever);
+    t.join();
+// Interrupt worker thread via thread-specific request from worker thread using a callback
+template<>
+template<>
+void object::test<2>
+    Interrupt::registerCallback(interruptIfRequested);
+    std::thread t1(workForever);
+    std::thread t2(workForever);
+    // Create map and add entries before exposing it to the interrupt
+    // callback that will be accessed from multiple threads. It's OK
+    // for multiple threads to modify entries in the map but not for
+    // multiple threads to create entries.
+    std::map<std::thread::id, bool> shouldInterrupt;
+    shouldInterrupt[t1.get_id()] = false;
+    shouldInterrupt[t2.get_id()] = false;
+    toInterrupt = &shouldInterrupt;
+    shouldInterrupt[t2.get_id()] = true;
+    t2.join();
+    shouldInterrupt[t1.get_id()] = true;
+    t1.join();
+// Register separate callbacks for each thread. Each callback will
+// request interruption of itself only.
+template<>
+template<>
+void object::test<3>
+    bool interrupt1 = false;
+    int numCalls2 = 0;
+    auto cb1 = ([](void* data) -> int {
+        return *static_cast<bool*>(data);
+    auto cb2 = ([](void* data) -> int {
+        return ++*static_cast<int*>(data) > 5;
+    std::thread t1([&cb1, &interrupt1]() {
+        CurrentThreadInterrupt::registerCallback(cb1, &interrupt1);
+    std::thread t2([&cb2, &numCalls2]() {
+        CurrentThreadInterrupt::registerCallback(cb2, &numCalls2);
+    t2.join();
+    interrupt1 = true;
+    t1.join();
+} // namespace tut
Summary of changes:
 capi/geos_c.h.in                      |  49 +++++++++--
 capi/geos_ts_c.cpp                    |  94 +++++++++++++++++----
 include/geos/util/Interrupt.h         |  30 +++++--
 src/util/Interrupt.cpp                |  31 ++++++-
 tests/unit/CMakeLists.txt             |   1 +
 tests/unit/capi/GEOSInterruptTest.cpp |  68 ++++++++++++++-
 tests/unit/util/InterruptTest.cpp     | 150 ++++++++++++++++++++++++++++++++++
 7 files changed, 385 insertions(+), 38 deletions(-)
 create mode 100644 tests/unit/util/InterruptTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
