[geos-commits] [SCM] GEOS branch 3.10 updated. 1621a9dbb2d473d6ba0ff9132e937a9e753f41db
git at osgeo.org
git at osgeo.org
Tue Jun 17 12:01:35 PDT 2025
the project "GEOS".
The branch, 3.10 has been updated
via 1621a9dbb2d473d6ba0ff9132e937a9e753f41db (commit)
from 72188096ebc86d096197bf683d95be76a96d1475 (commit)
revisions in full, below.
commit 1621a9dbb2d473d6ba0ff9132e937a9e753f41db
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jun 17 12:01:09 2025 -0700
Remove azure pipelines CI
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml
deleted file mode 100644
index 38060975a..000000000
--- a/.azure-pipelines.yml
+++ /dev/null
@@ -1,305 +0,0 @@
-# Azure Pipelines for GEOS
-# All builds are based on the CMake configuration.
-# Author: Mateusz Loskot <mateusz at loskot dot net>
-# trigger:
-# branches:
-# include:
-# - master
-# - bugfix/*
-# - feature/*
-# - fix/*
-# - pr/*
-pr:
- branches:
- include:
- - main
-variables:
- - name: BUILD_TYPE
- value: Release
- - name: MAKEFLAGS
- value: -j2
-stages:
-- stage: Test
- jobs:
- - job: 'Linux'
- strategy:
- matrix:
- GCC 11:
- CXXSTD: 11, 20
- CXX: g++-11
- PACKAGES: g++-11
- VM_IMAGE: ubuntu-20.04
- VM_NAME: focal
- GCC 10:
- CXXSTD: 11, 17
- CXX: g++-10
- PACKAGES: g++-10
- VM_NAME: focal
- GCC 9:
- CXXSTD: 11, 14
- CXX: g++-9
- PACKAGES: g++-9
- VM_NAME: focal
- GCC 8:
- CXXSTD: 11
- CXX: g++-8
- PACKAGES: g++-8
- VM_NAME: focal
- GCC 7:
- CXXSTD: 11
- CXX: g++-7
- PACKAGES: g++-7
- VM_NAME: focal
- # GCC 6:
- # CXXSTD: 11
- # CXX: g++-6
- # PACKAGES: g++-6
- # VM_IMAGE: ubuntu-18.04
- # VM_NAME: focal
- # GCC 5:
- # CXXSTD: 11
- # CXX: g++-5
- # PACKAGES: g++-5
- # VM_NAME: focal
- # GCC 4.8:
- # CXXSTD: 11
- # CXX: g++-4.8
- # PACKAGES: g++-4.8
- # VM_NAME: focal
- Clang 12:
- CXXSTD: 11, 20
- CXX: clang++-12
- PACKAGES: clang-12
- LLVM_REPO: llvm-toolchain-focal-12
- VM_NAME: focal
- Clang 11:
- CXXSTD: 11, 17
- CXX: clang++-11
- PACKAGES: clang-11
- LLVM_REPO: llvm-toolchain-focal-11
- VM_NAME: focal
- Clang 10:
- CXXSTD: 11, 14
- CXX: clang++-10
- PACKAGES: clang-10
- LLVM_REPO: llvm-toolchain-focal-10
- VM_NAME: focal
- Clang 9:
- CXXSTD: 11
- CXX: clang++-9
- PACKAGES: clang-9
- LLVM_REPO: llvm-toolchain-focal-9
- VM_NAME: focal
- # Clang 8:
- # CXXSTD: 11
- # CXX: clang++-8
- # PACKAGES: clang-8
- # LLVM_REPO: llvm-toolchain-bionic-8
- # VM_NAME: bionic
- # Clang 7:
- # CXXSTD: 11
- # CXX: clang++-7
- # PACKAGES: clang-7
- # LLVM_REPO: llvm-toolchain-bionic-7
- # VM_NAME: bionic
- # Clang 6:
- # CXXSTD: 11
- # CXX: clang++-6.0
- # PACKAGES: clang-6.0
- # LLVM_REPO: llvm-toolchain-bionic-6.0
- # VM_NAME: bionic
- # Clang 5:
- # CXXSTD: 11
- # PACKAGES: clang-5.0
- # CXX: clang++-5.0
- # LLVM_REPO: llvm-toolchain-bionic-5.0
- # VM_NAME: bionic
- pool:
- vmImage: $(VM_IMAGE)
- steps:
- - script: |
- set -e
- uname -a
- sudo -E apt-add-repository -y "ppa:ubuntu-toolchain-r/test"
- if test -n "${LLVM_REPO}" ; then
- wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | sudo apt-key add -
- sudo -E apt-add-repository "deb http://apt.llvm.org/${VM_NAME}/ ${LLVM_REPO} main"
- fi
- sudo -E apt-get update
- sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cmake ${PACKAGES}
- displayName: 'Install'
- - script: |
- set -e
- mkdir build.cxx11
- cd build.cxx11
- cmake --version
- cmake -DCMAKE_CXX_STANDARD=11 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
- cmake --build . --config $BUILD_TYPE
- ctest -V --output-on-failure -C $BUILD_TYPE
- displayName: 'Build C++11'
- condition: contains(variables['CXXSTD'], '11')
- - script: |
- set -e
- mkdir build.cxx14
- cd build.cxx14
- cmake --version
- cmake -DCMAKE_CXX_STANDARD=14 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
- displayName: 'Build C++14'
- condition: contains(variables['CXXSTD'], '14')
- - script: |
- set -e
- mkdir build.cxx17
- cd build.cxx17
- cmake --version
- cmake -DCMAKE_CXX_STANDARD=17 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
- displayName: 'Build C++17'
- condition: contains(variables['CXXSTD'], '17')
- - script: |
- set -e
- mkdir build.cxx20
- cd build.cxx20
- cmake --version
- cmake -DCMAKE_CXX_STANDARD=20 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
- displayName: 'Build C++20'
- condition: contains(variables['CXXSTD'], '20')
- - job: 'Windows'
- strategy:
- matrix:
- # VS 2022 C++20:
- # TOOLSET: msvc-14.3
- # CXXSTD: 20
- # VM_IMAGE: 'windows-2022'
- VS 2019 C++20:
- TOOLSET: msvc-14.2
- CXXSTD: 20
- VM_IMAGE: 'windows-2019'
- pool:
- steps:
- - powershell: |
- Write-Host "Installing CMake 3.14.7"
- Invoke-WebRequest https://cmake.org/files/v3.14/cmake-3.14.7-win64-x64.zip -OutFile C:\cmake-3.14.7-win64-x64.zip
- Expand-Archive C:\cmake-3.14.7-win64-x64.zip -DestinationPath C:\
- Rename-Item -Path C:\cmake-3.14.7-win64-x64 -NewName C:\cmake
- Write-Host "##vso[task.prependpath]C:\cmake\bin"
- - script: |
- mkdir build.cxx%CXXSTD%
- cd build.cxx%CXXSTD%
- cmake --version
- cmake -DCMAKE_CXX_STANDARD=%CXXSTD% -DBUILD_SHARED_LIBS=ON ..
- displayName: 'CMake'
- - script: |
- cmake --build . --config %BUILD_TYPE%
- displayName: 'Build'
- - script: |
- ctest -V --output-on-failure -C %BUILD_TYPE%
- displayName: 'Test'
- - job: 'macOS'
- pool:
- vmImage: 'macOS-11'
- strategy:
- matrix:
- # https://github.com/actions/runner-images/blob/main/images/macos/macos-11-Readme.md#xcode
- Xcode 12.4:
- TOOLSET: clang
- CXXSTD: 11, 14, 20
- XCODE_APP: /Applications/Xcode_12.4.app
- Xcode 11.7:
- TOOLSET: clang
- CXXSTD: 11, 17
- XCODE_APP: /Applications/Xcode_11.7.app
- # Xcode 10.3:
- # TOOLSET: clang
- # CXXSTD: 11
- # XCODE_APP: /Applications/Xcode_10.3.app
- steps:
- - script: |
- set -e
- uname -a
- sudo xcode-select -switch ${XCODE_APP}
- which clang++
- clang++ --version
- displayName: Install
- - script: |
- set -e
- mkdir build.cxx11
- cd build.cxx11
- cmake --version
- - script: |
- set -e
- mkdir build.cxx14
- cd build.cxx14
- cmake --version
- - script: |
- set -e
- mkdir build.cxx17
- cd build.cxx17
- cmake --version
- - script: |
- set -e
- mkdir build.cxx20
- cd build.cxx20
- cmake --version
- - job: Code_quality_checks
- pool:
- vmImage: 'ubuntu-latest'
- steps:
- - script: |
- set -e
- sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
- ./tools/cppcheck.sh
- displayName: 'cppcheck'
Summary of changes:
.azure-pipelines.yml | 305 ---------------------------------------------------
1 file changed, 305 deletions(-)
delete mode 100644 .azure-pipelines.yml
hooks/post-receive
More information about the geos-commits
