[geos-commits] [SCM] GEOS branch 3.11 updated. 55b8bec12195e72b477e81a494e0f6e2314b31e1
Tue Jun 17 12:01:55 PDT 2025
the project "GEOS".
The branch, 3.11 has been updated
       via  55b8bec12195e72b477e81a494e0f6e2314b31e1 (commit)
      from  5418426900b0742e890f693679207943c953ec86 (commit)
revisions in full, below.
commit 55b8bec12195e72b477e81a494e0f6e2314b31e1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jun 17 12:01:25 2025 -0700
    Remove azure pipelines CI
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml
deleted file mode 100644
index fbe6ed8f5..000000000
--- a/.azure-pipelines.yml
+++ /dev/null
@@ -1,319 +0,0 @@
-# Azure Pipelines for GEOS
-# All builds are based on the CMake configuration.
-# Author: Mateusz Loskot <mateusz at loskot dot net>
-# trigger:
-#   branches:
-#     include:
-#     - master
-#     - bugfix/*
-#     - feature/*
-#     - fix/*
-#     - pr/*
-pr:
-  branches:
-    include:
-    - main
-variables:
-  - name: BUILD_TYPE
-    value: Release
-  - name: MAKEFLAGS
-    value: -j2
-stages:
-- stage: Test
-  jobs:
-  - job: 'Linux'
-    strategy:
-      matrix:
-        GCC 12:
-          CXXSTD: 11, 20
-          CXX: g++-12
-          PACKAGES: g++-12
-          VM_IMAGE: ubuntu-22.04
-          VM_NAME: jammie
-        GCC 11:
-          CXXSTD: 11, 20
-          CXX: g++-11
-          PACKAGES: g++-11
-          VM_IMAGE: ubuntu-20.04
-          VM_NAME: focal
-        GCC 10:
-          CXXSTD: 11, 17
-          CXX: g++-10
-          PACKAGES: g++-10
-          VM_NAME: focal
-        GCC 9:
-          CXXSTD: 11, 14
-          CXX: g++-9
-          PACKAGES: g++-9
-          VM_NAME: focal
-        GCC 8:
-          CXXSTD: 11
-          CXX: g++-8
-          PACKAGES: g++-8
-          VM_NAME: focal
-        GCC 7:
-          CXXSTD: 11
-          CXX: g++-7
-          PACKAGES: g++-7
-          VM_NAME: focal
-        # GCC 6:
-        #   CXXSTD: 11
-        #   CXX: g++-6
-        #   PACKAGES: g++-6
-        #   VM_IMAGE: ubuntu-18.04
-        #   VM_NAME: focal
-        # GCC 5:
-        #   CXXSTD: 11
-        #   CXX: g++-5
-        #   PACKAGES: g++-5
-        #   VM_NAME: focal
-        # GCC 4.8:
-        #   CXXSTD: 11
-        #   CXX: g++-4.8
-        #   PACKAGES: g++-4.8
-        #   VM_NAME: focal
-        Clang 12:
-          CXXSTD: 11, 20
-          CXX: clang++-12
-          PACKAGES: clang-12
-          LLVM_REPO: llvm-toolchain-focal-12
-          VM_NAME: focal
-        Clang 11:
-          CXXSTD: 11, 17
-          CXX: clang++-11
-          PACKAGES: clang-11
-          LLVM_REPO: llvm-toolchain-focal-11
-          VM_NAME: focal
-        Clang 10:
-          CXXSTD: 11, 14
-          CXX: clang++-10
-          PACKAGES: clang-10
-          LLVM_REPO: llvm-toolchain-focal-10
-          VM_NAME: focal
-        Clang 9:
-          CXXSTD: 11
-          CXX: clang++-9
-          PACKAGES: clang-9
-          LLVM_REPO: llvm-toolchain-focal-9
-          VM_NAME: focal
-        # Clang 8:
-        #   CXXSTD: 11
-        #   CXX: clang++-8
-        #   PACKAGES: clang-8
-        #   LLVM_REPO: llvm-toolchain-bionic-8
-        #   VM_NAME: bionic
-        # Clang 7:
-        #   CXXSTD: 11
-        #   CXX: clang++-7
-        #   PACKAGES: clang-7
-        #   LLVM_REPO: llvm-toolchain-bionic-7
-        #   VM_NAME: bionic
-        # Clang 6:
-        #   CXXSTD: 11
-        #   CXX: clang++-6.0
-        #   PACKAGES: clang-6.0
-        #   LLVM_REPO: llvm-toolchain-bionic-6.0
-        #   VM_NAME: bionic
-        # Clang 5:
-        #   CXXSTD: 11
-        #   PACKAGES: clang-5.0
-        #   CXX: clang++-5.0
-        #   LLVM_REPO: llvm-toolchain-bionic-5.0
-        #   VM_NAME: bionic
-    pool:
-      vmImage: $(VM_IMAGE)
-    steps:
-    - script: |
-        set -e
-        uname -a
-        sudo -E apt-add-repository -y "ppa:ubuntu-toolchain-r/test"
-        if test -n "${LLVM_REPO}" ; then
-          wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | sudo apt-key add -
-          sudo -E apt-add-repository "deb http://apt.llvm.org/${VM_NAME}/ ${LLVM_REPO} main"
-        fi
-        sudo -E apt-get update
-        sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cmake ${PACKAGES}
-      displayName: 'Install'
-    - script: |
-        set -e
-        mkdir build.cxx11
-        cd build.cxx11
-        cmake --version
-        cmake -DCMAKE_CXX_STANDARD=11 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
-        cmake --build . --config $BUILD_TYPE
-        ctest -V --output-on-failure -C $BUILD_TYPE
-      displayName: 'Build C++11'
-      condition: contains(variables['CXXSTD'], '11')
-    - script: |
-        set -e
-        mkdir build.cxx14
-        cd build.cxx14
-        cmake --version
-        cmake -DCMAKE_CXX_STANDARD=14 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
-      displayName: 'Build C++14'
-      condition: contains(variables['CXXSTD'], '14')
-    - script: |
-        set -e
-        mkdir build.cxx17
-        cd build.cxx17
-        cmake --version
-        cmake -DCMAKE_CXX_STANDARD=17 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
-      displayName: 'Build C++17'
-      condition: contains(variables['CXXSTD'], '17')
-    - script: |
-        set -e
-        mkdir build.cxx20
-        cd build.cxx20
-        cmake --version
-        cmake -DCMAKE_CXX_STANDARD=20 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
-      displayName: 'Build C++20'
-      condition: contains(variables['CXXSTD'], '20')
-  - job: 'Windows'
-    strategy:
-      matrix:
-        # VS 2022 C++20:
-        #   TOOLSET: msvc-14.3
-        #   CXXSTD: 20
-        #   VM_IMAGE: 'windows-2022'
-        VS 2019 C++20 x64:
-          TOOLSET: msvc-14.2
-          CXXSTD: 20
-          VM_IMAGE: 'windows-2019'
-          ARCH: x64
-        VS 2019 C++20 ARM64:
-          CXXSTD: 20
-          ARCH: ARM64
-    pool:
-    steps:
-    - powershell: |
-        Write-Host "Installing CMake 3.14.7"
-        Invoke-WebRequest https://cmake.org/files/v3.14/cmake-3.14.7-win64-x64.zip -OutFile C:\cmake-3.14.7-win64-x64.zip
-        Expand-Archive C:\cmake-3.14.7-win64-x64.zip -DestinationPath C:\
-        Rename-Item -Path C:\cmake-3.14.7-win64-x64 -NewName C:\cmake
-        Write-Host "##vso[task.prependpath]C:\cmake\bin"
-    - script: |
-        mkdir build.cxx%CXXSTD%.%ARCH%
-        cd build.cxx%CXXSTD%.%ARCH%
-        cmake --version
-        cmake -DCMAKE_CXX_STANDARD=%CXXSTD% -DBUILD_SHARED_LIBS=ON -A %ARCH% ..
-      displayName: 'CMake'
-    - script: |
-        cmake --build . --config %BUILD_TYPE%
-      displayName: 'Build'
-    - script: |
-        ctest -V --output-on-failure -C %BUILD_TYPE%
-      displayName: 'Test'
-      condition: and(succeeded(), eq(variables['ARCH'], 'x64'))
-  - job: 'macOS'
-    pool:
-      vmImage: 'macOS-11'
-    strategy:
-      matrix:
-        # https://github.com/actions/runner-images/blob/main/images/macos/macos-11-Readme.md#xcode
-        Xcode 12.4:
-          TOOLSET: clang
-          CXXSTD: 11, 14, 20
-          XCODE_APP: /Applications/Xcode_12.4.app
-        Xcode 11.7:
-          TOOLSET: clang
-          CXXSTD: 11, 17
-          XCODE_APP: /Applications/Xcode_11.7.app
-        # Xcode 10.3:
-        #   TOOLSET: clang
-        #   CXXSTD: 11
-        #   XCODE_APP: /Applications/Xcode_10.3.app
-    steps:
-    - script: |
-        set -e
-        uname -a
-        sudo xcode-select -switch ${XCODE_APP}
-        which clang++
-        clang++ --version
-      displayName: Install
-    - script: |
-        set -e
-        mkdir build.cxx11
-        cd build.cxx11
-        cmake --version
-    - script: |
-        set -e
-        mkdir build.cxx14
-        cd build.cxx14
-        cmake --version
-    - script: |
-        set -e
-        mkdir build.cxx17
-        cd build.cxx17
-        cmake --version
-    - script: |
-        set -e
-        mkdir build.cxx20
-        cd build.cxx20
-        cmake --version
-  - job: Code_quality_checks
-    pool:
-      vmImage: 'ubuntu-latest'
-    steps:
-    - script: |
-        set -e
-        sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
-        ./tools/cppcheck.sh
-      displayName: 'cppcheck'
Summary of changes:
 .azure-pipelines.yml | 319 ---------------------------------------------------
 1 file changed, 319 deletions(-)
 delete mode 100644 .azure-pipelines.yml
hooks/post-receive
More information about the geos-commits mailing list
