[geos-commits] [SCM] GEOS branch main updated. c66c9e8adbdfea6b7a36e14ff93fe97474fedfac
Fri May 2 12:58:40 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  c66c9e8adbdfea6b7a36e14ff93fe97474fedfac (commit)
       via  737904ec0274e64d2cd5079d0ee2988855b83a41 (commit)
       via  2d9b0f5e5e75dab3a11a94b85b0cf6d4a051faea (commit)
      from  8b04f6d04b3c63e8a8c0edb2315be9197ec45bef (commit)
revisions in full, below.
commit c66c9e8adbdfea6b7a36e14ff93fe97474fedfac
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri May 2 12:57:24 2025 -0700
    Remove unnecessary includes from tests and tut.
    From @dbaston. Closes #1141.
diff --git a/tests/unit/CMakeLists.txt b/tests/unit/CMakeLists.txt
index f7c302de6..d54d82b9c 100644
--- a/tests/unit/CMakeLists.txt
+++ b/tests/unit/CMakeLists.txt
@@ -9,6 +9,7 @@
 # by the Free Software Foundation.
 # See the COPYING file for more information.
 file(GLOB_RECURSE _sources ${CMAKE_CURRENT_LIST_DIR}/*.cpp CONFIGURE_DEPEND)
 add_executable(test_geos_unit ${_sources})
 unset(_sources)
diff --git a/tests/unit/algorithm/AngleTest.cpp b/tests/unit/algorithm/AngleTest.cpp
index cc889c5e9..4d3767182 100644
--- a/tests/unit/algorithm/AngleTest.cpp
+++ b/tests/unit/algorithm/AngleTest.cpp
@@ -7,9 +7,7 @@
 #include <geos/geom/Coordinate.h>
 #include <geos/algorithm/Angle.h>
 // std
-#include <sstream>
 #include <string>
-#include <memory>
 namespace tut {
diff --git a/tests/unit/algorithm/CGAlgorithms/OrientationIsCCWTest.cpp b/tests/unit/algorithm/CGAlgorithms/OrientationIsCCWTest.cpp
index a8054f529..ec8551eaf 100644
--- a/tests/unit/algorithm/CGAlgorithms/OrientationIsCCWTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/OrientationIsCCWTest.cpp
@@ -15,7 +15,6 @@
 // std
 #include <string>
 #include <memory>
-#include <cassert>
 #include <sstream>
 using namespace geos::algorithm;
diff --git a/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp b/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
index e75d61431..b312a01eb 100644
--- a/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
@@ -15,7 +15,6 @@
 #include <string>
 #include <memory>
 #include <cassert>
-#include <sstream>
diff --git a/tests/unit/algorithm/CentroidTest.cpp b/tests/unit/algorithm/CentroidTest.cpp
index 152d12dff..db7d65932 100644
--- a/tests/unit/algorithm/CentroidTest.cpp
+++ b/tests/unit/algorithm/CentroidTest.cpp
@@ -12,7 +12,6 @@
 #include <geos/geom/PrecisionModel.h>
 #include <geos/io/WKTReader.h>
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/ConvexHullTest.cpp b/tests/unit/algorithm/ConvexHullTest.cpp
index b265c2216..c37de5bc8 100644
--- a/tests/unit/algorithm/ConvexHullTest.cpp
+++ b/tests/unit/algorithm/ConvexHullTest.cpp
@@ -17,7 +17,6 @@
 // std
 #include <sstream>
 #include <memory>
-#include <cassert>
 namespace geos {
 namespace geom {
diff --git a/tests/unit/algorithm/InteriorPointAreaTest.cpp b/tests/unit/algorithm/InteriorPointAreaTest.cpp
index 4b30808b6..eacdba30b 100644
--- a/tests/unit/algorithm/InteriorPointAreaTest.cpp
+++ b/tests/unit/algorithm/InteriorPointAreaTest.cpp
@@ -23,7 +23,6 @@
 #include <geos/geom/Geometry.h>
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/IntersectionTest.cpp b/tests/unit/algorithm/IntersectionTest.cpp
index b2b6576e2..b3e8f0c93 100644
--- a/tests/unit/algorithm/IntersectionTest.cpp
+++ b/tests/unit/algorithm/IntersectionTest.cpp
@@ -23,8 +23,6 @@
 // std
-#include <sstream>
-#include <string>
 #include <memory>
 namespace tut {
diff --git a/tests/unit/algorithm/LengthTest.cpp b/tests/unit/algorithm/LengthTest.cpp
index 598cd60de..8eb522730 100644
--- a/tests/unit/algorithm/LengthTest.cpp
+++ b/tests/unit/algorithm/LengthTest.cpp
@@ -13,7 +13,6 @@
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/MinimumAreaRectangleTest.cpp b/tests/unit/algorithm/MinimumAreaRectangleTest.cpp
index dad960837..a36723bb8 100644
--- a/tests/unit/algorithm/MinimumAreaRectangleTest.cpp
+++ b/tests/unit/algorithm/MinimumAreaRectangleTest.cpp
@@ -8,7 +8,6 @@
 #include <utility.h>
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/MinimumBoundingCircleTest.cpp b/tests/unit/algorithm/MinimumBoundingCircleTest.cpp
index 599c3e597..c95f0836f 100644
--- a/tests/unit/algorithm/MinimumBoundingCircleTest.cpp
+++ b/tests/unit/algorithm/MinimumBoundingCircleTest.cpp
@@ -25,7 +25,6 @@
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/MinimumDiameterTest.cpp b/tests/unit/algorithm/MinimumDiameterTest.cpp
index bf36579a3..2f1812b17 100644
--- a/tests/unit/algorithm/MinimumDiameterTest.cpp
+++ b/tests/unit/algorithm/MinimumDiameterTest.cpp
@@ -23,7 +23,6 @@
 #include <geos/io/WKTWriter.h>
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/OrientationIndexFailureTest.cpp b/tests/unit/algorithm/OrientationIndexFailureTest.cpp
index c9419332d..7bd81bbc5 100644
--- a/tests/unit/algorithm/OrientationIndexFailureTest.cpp
+++ b/tests/unit/algorithm/OrientationIndexFailureTest.cpp
@@ -7,9 +7,6 @@
 #include <geos/algorithm/Orientation.h>
 // std
-#include <sstream>
-#include <string>
-#include <memory>
 using namespace geos::geom;
diff --git a/tests/unit/algorithm/PointLocationTest.cpp b/tests/unit/algorithm/PointLocationTest.cpp
index f580c3ee9..ee053a4da 100644
--- a/tests/unit/algorithm/PointLocationTest.cpp
+++ b/tests/unit/algorithm/PointLocationTest.cpp
@@ -10,7 +10,6 @@
 #include <geos/algorithm/PointLocation.h>
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/PointLocatorTest.cpp b/tests/unit/algorithm/PointLocatorTest.cpp
index a230d9686..3cff31ac8 100644
--- a/tests/unit/algorithm/PointLocatorTest.cpp
+++ b/tests/unit/algorithm/PointLocatorTest.cpp
@@ -12,7 +12,6 @@
 #include <geos/geom/Geometry.h> // required for use in unique_ptr
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/PolygonNodeTopologyTest.cpp b/tests/unit/algorithm/PolygonNodeTopologyTest.cpp
index 1b6dfdef2..ca0270be1 100644
--- a/tests/unit/algorithm/PolygonNodeTopologyTest.cpp
+++ b/tests/unit/algorithm/PolygonNodeTopologyTest.cpp
@@ -9,7 +9,6 @@
 #include <geos/algorithm/PolygonNodeTopology.h>
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/RobustLineIntersectionTest.cpp b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
index aaeea3e89..31ec6e1ad 100644
--- a/tests/unit/algorithm/RobustLineIntersectionTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
@@ -11,7 +11,6 @@
 #include <geos/geom/LineString.h>
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/RobustLineIntersectorZTest.cpp b/tests/unit/algorithm/RobustLineIntersectorZTest.cpp
index a343102a5..d57c65b52 100644
--- a/tests/unit/algorithm/RobustLineIntersectorZTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectorZTest.cpp
@@ -10,9 +10,6 @@
 #include <geos/geom/LineSegment.h>
 // std
-#include <sstream>
-#include <string>
-#include <memory>
 #include <utility>
diff --git a/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp b/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
index 5a09e2ef8..42d86b66b 100644
--- a/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
+++ b/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
@@ -11,7 +11,6 @@
 #include <geos/constants.h>
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
index 985a1a7ae..7261e3374 100644
--- a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
+++ b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
@@ -15,7 +15,6 @@
 #include <geos/util.h>
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
index 11fb67aec..ae5c344c7 100644
--- a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
@@ -14,7 +14,6 @@
 // std
 #include <cmath>
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
index 735344cd5..f50b58680 100644
--- a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
@@ -14,7 +14,6 @@
 // std
 #include <cmath>
-#include <sstream>
 #include <string>
 #include <memory>
 #include <cfenv>
diff --git a/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp b/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp
index 83505123e..533f6c935 100644
--- a/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp
+++ b/tests/unit/algorithm/hull/ConcaveHullOfPolygonsTest.cpp
@@ -10,7 +10,6 @@
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/hull/ConcaveHullTest.cpp b/tests/unit/algorithm/hull/ConcaveHullTest.cpp
index 3d47bbc93..c68961e72 100644
--- a/tests/unit/algorithm/hull/ConcaveHullTest.cpp
+++ b/tests/unit/algorithm/hull/ConcaveHullTest.cpp
@@ -10,7 +10,6 @@
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/algorithm/locate/IndexedPointInAreaLocatorTest.cpp b/tests/unit/algorithm/locate/IndexedPointInAreaLocatorTest.cpp
index db9cadc56..1258d6506 100644
--- a/tests/unit/algorithm/locate/IndexedPointInAreaLocatorTest.cpp
+++ b/tests/unit/algorithm/locate/IndexedPointInAreaLocatorTest.cpp
@@ -5,8 +5,6 @@
 #include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
 // std
-#include <sstream>
-#include <string>
 #include <memory>
 using geos::geom::CoordinateXY;
diff --git a/tests/unit/capi/GEOSBufferTest.cpp b/tests/unit/capi/GEOSBufferTest.cpp
index badf30684..538dfbf75 100644
--- a/tests/unit/capi/GEOSBufferTest.cpp
+++ b/tests/unit/capi/GEOSBufferTest.cpp
@@ -5,10 +5,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
 #include "capi_test_utils.h"
diff --git a/tests/unit/capi/GEOSBuildAreaTest.cpp b/tests/unit/capi/GEOSBuildAreaTest.cpp
index 012de41e4..503003dd6 100644
--- a/tests/unit/capi/GEOSBuildAreaTest.cpp
+++ b/tests/unit/capi/GEOSBuildAreaTest.cpp
@@ -4,10 +4,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cmath>
diff --git a/tests/unit/capi/GEOSCAPIDefinesTest.cpp b/tests/unit/capi/GEOSCAPIDefinesTest.cpp
index 5d5347128..b86c8fe1c 100644
--- a/tests/unit/capi/GEOSCAPIDefinesTest.cpp
+++ b/tests/unit/capi/GEOSCAPIDefinesTest.cpp
@@ -5,10 +5,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
 #define QUOTE(x) #x
 #define EXPAND_AND_QUOTE(y) QUOTE(y)
diff --git a/tests/unit/capi/GEOSClipByRectTest.cpp b/tests/unit/capi/GEOSClipByRectTest.cpp
index be47a4c0f..9ff33d336 100644
--- a/tests/unit/capi/GEOSClipByRectTest.cpp
+++ b/tests/unit/capi/GEOSClipByRectTest.cpp
@@ -5,10 +5,8 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
 #include <cstdio>
 #include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp b/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp
index 2cd039fb5..751e4cdc4 100644
--- a/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp
+++ b/tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp
@@ -5,9 +5,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSConcaveHullTest.cpp b/tests/unit/capi/GEOSConcaveHullTest.cpp
index 243161d31..5411db1d0 100644
--- a/tests/unit/capi/GEOSConcaveHullTest.cpp
+++ b/tests/unit/capi/GEOSConcaveHullTest.cpp
@@ -5,9 +5,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp b/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
index 2022b7f90..cee6d9019 100644
--- a/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
+++ b/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
@@ -5,10 +5,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSContainsTest.cpp b/tests/unit/capi/GEOSContainsTest.cpp
index 2e570424d..3d377e829 100644
--- a/tests/unit/capi/GEOSContainsTest.cpp
+++ b/tests/unit/capi/GEOSContainsTest.cpp
@@ -8,9 +8,6 @@
 #include <geos/geom/GeometryFactory.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSConvexHullTest.cpp b/tests/unit/capi/GEOSConvexHullTest.cpp
index e7c20ac0b..adb679cca 100644
--- a/tests/unit/capi/GEOSConvexHullTest.cpp
+++ b/tests/unit/capi/GEOSConvexHullTest.cpp
@@ -5,9 +5,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSCoordSeqTest.cpp b/tests/unit/capi/GEOSCoordSeqTest.cpp
index 176b3d523..ffa7912b0 100644
--- a/tests/unit/capi/GEOSCoordSeqTest.cpp
+++ b/tests/unit/capi/GEOSCoordSeqTest.cpp
@@ -5,10 +5,9 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
+#include <algorithm>
 #include <cstdio>
 #include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSCoverageIsValidTest.cpp b/tests/unit/capi/GEOSCoverageIsValidTest.cpp
index 93868959d..8f1e02889 100644
--- a/tests/unit/capi/GEOSCoverageIsValidTest.cpp
+++ b/tests/unit/capi/GEOSCoverageIsValidTest.cpp
@@ -4,11 +4,6 @@
 #include <tut/tut.hpp>
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
diff --git a/tests/unit/capi/GEOSCoverageSimplifyTest.cpp b/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
index 812db7cc1..4ca7e9c39 100644
--- a/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
+++ b/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
@@ -4,11 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
diff --git a/tests/unit/capi/GEOSCoverageUnionTest.cpp b/tests/unit/capi/GEOSCoverageUnionTest.cpp
index 2d7fccc32..13e922524 100644
--- a/tests/unit/capi/GEOSCoverageUnionTest.cpp
+++ b/tests/unit/capi/GEOSCoverageUnionTest.cpp
@@ -4,11 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
diff --git a/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp b/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
index 0064d8073..d685ae25b 100644
--- a/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
+++ b/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
@@ -4,11 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSDistanceTest.cpp b/tests/unit/capi/GEOSDistanceTest.cpp
index 0416532ef..f5f5e1471 100644
--- a/tests/unit/capi/GEOSDistanceTest.cpp
+++ b/tests/unit/capi/GEOSDistanceTest.cpp
@@ -6,11 +6,10 @@
 #include <geos_c.h>
 // std
-#include <cstdarg>
 #include <cstdio>
 #include <cstdlib>
 #include <fenv.h>
-#include <memory>
 #include <cmath>
diff --git a/tests/unit/capi/GEOSDistanceWithinTest.cpp b/tests/unit/capi/GEOSDistanceWithinTest.cpp
index 567e43192..e64c14b63 100644
--- a/tests/unit/capi/GEOSDistanceWithinTest.cpp
+++ b/tests/unit/capi/GEOSDistanceWithinTest.cpp
@@ -5,13 +5,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <limits>
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <math.h>
-#include <memory>
diff --git a/tests/unit/capi/GEOSEqualsTest.cpp b/tests/unit/capi/GEOSEqualsTest.cpp
index 0164a3ced..392e2cd32 100644
--- a/tests/unit/capi/GEOSEqualsTest.cpp
+++ b/tests/unit/capi/GEOSEqualsTest.cpp
@@ -6,9 +6,6 @@
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
 #include <cstring>
diff --git a/tests/unit/capi/GEOSFrechetDistanceTest.cpp b/tests/unit/capi/GEOSFrechetDistanceTest.cpp
index ad6215a28..dc7d69929 100644
--- a/tests/unit/capi/GEOSFrechetDistanceTest.cpp
+++ b/tests/unit/capi/GEOSFrechetDistanceTest.cpp
@@ -4,12 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
-#include <cmath>
diff --git a/tests/unit/capi/GEOSGeomGeoJSONWriteTest.cpp b/tests/unit/capi/GEOSGeomGeoJSONWriteTest.cpp
index 23b2d68d1..b5861b4d1 100644
--- a/tests/unit/capi/GEOSGeomGeoJSONWriteTest.cpp
+++ b/tests/unit/capi/GEOSGeomGeoJSONWriteTest.cpp
@@ -77,27 +77,27 @@ void object::test<3>
     std::string wkt("LINESTRING(102.0 0.0, 103.0 1.0, 104.0 0.0, 105.0 1.0)");
-    std::string expected(std::string{"{\n"} +
-        "    \"type\": \"LineString\",\n" +
-        "    \"coordinates\": [\n" +
-        "        [\n" +
-        "            102.0,\n" +
-        "            0.0\n" +
-        "        ],\n" +
-        "        [\n" +
-        "            103.0,\n" +
-        "            1.0\n" +
-        "        ],\n" +
-        "        [\n" +
-        "            104.0,\n" +
-        "            0.0\n" +
-        "        ],\n" +
-        "        [\n" +
-        "            105.0,\n" +
-        "            1.0\n" +
-        "        ]\n" +
-        "    ]\n" +
+    std::string expected(std::string{"{\n"
+        "    \"type\": \"LineString\",\n"
+        "    \"coordinates\": [\n"
+        "        [\n"
+        "            102.0,\n"
+        "            0.0\n"
+        "        ],\n"
+        "        [\n"
+        "            103.0,\n"
+        "            1.0\n"
+        "        ],\n"
+        "        [\n"
+        "            104.0,\n"
+        "            0.0\n"
+        "        ],\n"
+        "        [\n"
+        "            105.0,\n"
+        "            1.0\n"
+        "        ]\n"
+        "    ]\n"
     test_geojson(wkt, expected, 4);
diff --git a/tests/unit/capi/GEOSGeomToWKBTest.cpp b/tests/unit/capi/GEOSGeomToWKBTest.cpp
index e445e47a5..dffeeedb7 100644
--- a/tests/unit/capi/GEOSGeomToWKBTest.cpp
+++ b/tests/unit/capi/GEOSGeomToWKBTest.cpp
@@ -6,10 +6,8 @@
 #include <geos_c.h>
 // std
 #include <string>
-#include <cstdarg>
 #include <cstdio>
 #include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSGeomToWKTTest.cpp b/tests/unit/capi/GEOSGeomToWKTTest.cpp
index 548da91ea..cbd4c34e2 100644
--- a/tests/unit/capi/GEOSGeomToWKTTest.cpp
+++ b/tests/unit/capi/GEOSGeomToWKTTest.cpp
@@ -6,10 +6,7 @@
 #include <geos_c.h>
 // std
 #include <string>
-#include <cstdarg>
-#include <cstdio>
 #include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSGeom_cloneTest.cpp b/tests/unit/capi/GEOSGeom_cloneTest.cpp
index 3466a1b95..8ab1e9e6b 100644
--- a/tests/unit/capi/GEOSGeom_cloneTest.cpp
+++ b/tests/unit/capi/GEOSGeom_cloneTest.cpp
@@ -1,10 +1,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
index 93474d8cb..626465851 100644
--- a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
@@ -6,11 +6,8 @@
 #include <geos_c.h>
 // std
 #include <array>
-#include <cstdarg>
 #include <cstdio>
 #include <cstdlib>
-#include <memory>
-#include <string>
 #include <vector>
diff --git a/tests/unit/capi/GEOSGeom_createRectangleTest.cpp b/tests/unit/capi/GEOSGeom_createRectangleTest.cpp
index 95be7a936..a80be052a 100644
--- a/tests/unit/capi/GEOSGeom_createRectangleTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createRectangleTest.cpp
@@ -3,10 +3,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSGeom_createTest.cpp b/tests/unit/capi/GEOSGeom_createTest.cpp
index 6bfb82c69..aec9ae316 100644
--- a/tests/unit/capi/GEOSGeom_createTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createTest.cpp
@@ -5,11 +5,8 @@
 // geos
 #include <geos_c.h>
 // std
-#include <string>
-#include <cstdarg>
 #include <cstdio>
 #include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSGeom_extentTest.cpp b/tests/unit/capi/GEOSGeom_extentTest.cpp
index bf31bd9c8..49a703c5e 100644
--- a/tests/unit/capi/GEOSGeom_extentTest.cpp
+++ b/tests/unit/capi/GEOSGeom_extentTest.cpp
@@ -4,10 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp b/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp
index 3d5c98614..95ca4e05e 100644
--- a/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp
+++ b/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp
@@ -4,10 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSGeom_transformXYTest.cpp b/tests/unit/capi/GEOSGeom_transformXYTest.cpp
index b2112ea36..b1295806f 100644
--- a/tests/unit/capi/GEOSGeom_transformXYTest.cpp
+++ b/tests/unit/capi/GEOSGeom_transformXYTest.cpp
@@ -4,10 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSGetCentroidTest.cpp b/tests/unit/capi/GEOSGetCentroidTest.cpp
index f99c78f12..e0fc823fe 100644
--- a/tests/unit/capi/GEOSGetCentroidTest.cpp
+++ b/tests/unit/capi/GEOSGetCentroidTest.cpp
@@ -5,11 +5,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
diff --git a/tests/unit/capi/GEOSHausdorffDistanceTest.cpp b/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
index ead81cd93..eb569c60a 100644
--- a/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
+++ b/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
@@ -4,12 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
-#include <cmath>
diff --git a/tests/unit/capi/GEOSHilbertCodeTest.cpp b/tests/unit/capi/GEOSHilbertCodeTest.cpp
index b70cd1fd8..0220a847f 100644
--- a/tests/unit/capi/GEOSHilbertCodeTest.cpp
+++ b/tests/unit/capi/GEOSHilbertCodeTest.cpp
@@ -4,10 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSInterruptTest.cpp b/tests/unit/capi/GEOSInterruptTest.cpp
index b54ef8d7f..0843d1bea 100644
--- a/tests/unit/capi/GEOSInterruptTest.cpp
+++ b/tests/unit/capi/GEOSInterruptTest.cpp
@@ -4,11 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSIntersectionPrecTest.cpp b/tests/unit/capi/GEOSIntersectionPrecTest.cpp
index 0d38e06ac..d6ed8c620 100644
--- a/tests/unit/capi/GEOSIntersectionPrecTest.cpp
+++ b/tests/unit/capi/GEOSIntersectionPrecTest.cpp
@@ -5,10 +5,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSIntersectsTest.cpp b/tests/unit/capi/GEOSIntersectsTest.cpp
index b86d8c282..fe11fd70e 100644
--- a/tests/unit/capi/GEOSIntersectsTest.cpp
+++ b/tests/unit/capi/GEOSIntersectsTest.cpp
@@ -6,9 +6,6 @@
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
 #include <cstring>
diff --git a/tests/unit/capi/GEOSLargestEmptyCircleTest.cpp b/tests/unit/capi/GEOSLargestEmptyCircleTest.cpp
index 6b0e69a86..c47dbbb7d 100644
--- a/tests/unit/capi/GEOSLargestEmptyCircleTest.cpp
+++ b/tests/unit/capi/GEOSLargestEmptyCircleTest.cpp
@@ -5,11 +5,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
diff --git a/tests/unit/capi/GEOSLineMergeDirectedTest.cpp b/tests/unit/capi/GEOSLineMergeDirectedTest.cpp
index bd5537d08..1e145abc6 100644
--- a/tests/unit/capi/GEOSLineMergeDirectedTest.cpp
+++ b/tests/unit/capi/GEOSLineMergeDirectedTest.cpp
@@ -4,9 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
diff --git a/tests/unit/capi/GEOSLineMergeTest.cpp b/tests/unit/capi/GEOSLineMergeTest.cpp
index d8c40c4e0..48817c074 100644
--- a/tests/unit/capi/GEOSLineMergeTest.cpp
+++ b/tests/unit/capi/GEOSLineMergeTest.cpp
@@ -4,9 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
diff --git a/tests/unit/capi/GEOSLineStringTest.cpp b/tests/unit/capi/GEOSLineStringTest.cpp
index d05a47a72..ca795de60 100644
--- a/tests/unit/capi/GEOSLineStringTest.cpp
+++ b/tests/unit/capi/GEOSLineStringTest.cpp
@@ -4,9 +4,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
 #include <cmath>
diff --git a/tests/unit/capi/GEOSLineSubstringTest.cpp b/tests/unit/capi/GEOSLineSubstringTest.cpp
index df79b2659..8135a75d5 100644
--- a/tests/unit/capi/GEOSLineSubstringTest.cpp
+++ b/tests/unit/capi/GEOSLineSubstringTest.cpp
@@ -4,9 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
diff --git a/tests/unit/capi/GEOSMakeValidTest.cpp b/tests/unit/capi/GEOSMakeValidTest.cpp
index 1c6071e94..c6531d5b8 100644
--- a/tests/unit/capi/GEOSMakeValidTest.cpp
+++ b/tests/unit/capi/GEOSMakeValidTest.cpp
@@ -4,10 +4,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cmath>
 #include <cstring>
 #include <cstdint>
diff --git a/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp b/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
index 1ca8a7936..c309d0a76 100644
--- a/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
+++ b/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
@@ -5,11 +5,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
diff --git a/tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp b/tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp
index 5b7c1dff4..f535fce86 100644
--- a/tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp
+++ b/tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp
@@ -6,7 +6,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
 #include <cstdio>
 #include <cstdlib>
 #include <cstring>
diff --git a/tests/unit/capi/GEOSMinimumClearanceTest.cpp b/tests/unit/capi/GEOSMinimumClearanceTest.cpp
index 0e58f470a..064763986 100644
--- a/tests/unit/capi/GEOSMinimumClearanceTest.cpp
+++ b/tests/unit/capi/GEOSMinimumClearanceTest.cpp
@@ -4,10 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp b/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp
index 6782d20c2..b2eff83fd 100644
--- a/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp
+++ b/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp
@@ -4,10 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSMinimumWidthTest.cpp b/tests/unit/capi/GEOSMinimumWidthTest.cpp
index 57f935da8..4b5658126 100644
--- a/tests/unit/capi/GEOSMinimumWidthTest.cpp
+++ b/tests/unit/capi/GEOSMinimumWidthTest.cpp
@@ -3,10 +3,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSNearestPointsTest.cpp b/tests/unit/capi/GEOSNearestPointsTest.cpp
index d5e7ced4a..c1caa1887 100644
--- a/tests/unit/capi/GEOSNearestPointsTest.cpp
+++ b/tests/unit/capi/GEOSNearestPointsTest.cpp
@@ -5,10 +5,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSNodeTest.cpp b/tests/unit/capi/GEOSNodeTest.cpp
index 9b11e1a15..41324bda5 100644
--- a/tests/unit/capi/GEOSNodeTest.cpp
+++ b/tests/unit/capi/GEOSNodeTest.cpp
@@ -4,11 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSOffsetCurveTest.cpp b/tests/unit/capi/GEOSOffsetCurveTest.cpp
index b3414dc15..a979155b8 100644
--- a/tests/unit/capi/GEOSOffsetCurveTest.cpp
+++ b/tests/unit/capi/GEOSOffsetCurveTest.cpp
@@ -5,7 +5,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
 #include <cstdio>
 #include <cstdlib>
 #include <cstring>
diff --git a/tests/unit/capi/GEOSOrientPolygonsTest.cpp b/tests/unit/capi/GEOSOrientPolygonsTest.cpp
index 1b9a7a3d1..a82955911 100644
--- a/tests/unit/capi/GEOSOrientPolygonsTest.cpp
+++ b/tests/unit/capi/GEOSOrientPolygonsTest.cpp
@@ -4,12 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <string>
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSOrientationIndexTest.cpp b/tests/unit/capi/GEOSOrientationIndexTest.cpp
index 71e50d6f8..8c827e008 100644
--- a/tests/unit/capi/GEOSOrientationIndexTest.cpp
+++ b/tests/unit/capi/GEOSOrientationIndexTest.cpp
@@ -4,12 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <string>
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSPointOnSurfaceTest.cpp b/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
index 2675a3a7c..0118234fa 100644
--- a/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
+++ b/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
@@ -5,11 +5,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
diff --git a/tests/unit/capi/GEOSPolygonHullSimplifyTest.cpp b/tests/unit/capi/GEOSPolygonHullSimplifyTest.cpp
index 43f426e04..f769b001f 100644
--- a/tests/unit/capi/GEOSPolygonHullSimplifyTest.cpp
+++ b/tests/unit/capi/GEOSPolygonHullSimplifyTest.cpp
@@ -4,10 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSPolygonizeTest.cpp b/tests/unit/capi/GEOSPolygonizeTest.cpp
index c0c2eb576..8ed9325bd 100644
--- a/tests/unit/capi/GEOSPolygonizeTest.cpp
+++ b/tests/unit/capi/GEOSPolygonizeTest.cpp
@@ -4,11 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSPreparedDistanceTest.cpp b/tests/unit/capi/GEOSPreparedDistanceTest.cpp
index 45147eec2..5ea53f1e0 100644
--- a/tests/unit/capi/GEOSPreparedDistanceTest.cpp
+++ b/tests/unit/capi/GEOSPreparedDistanceTest.cpp
@@ -5,10 +5,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp b/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp
index 81e74491b..7be2a2d2b 100644
--- a/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp
+++ b/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp
@@ -5,10 +5,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSPreparedGeometryTest.cpp b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
index b720214b2..28e24b187 100644
--- a/tests/unit/capi/GEOSPreparedGeometryTest.cpp
+++ b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
@@ -8,9 +8,6 @@
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
 #include <memory>
diff --git a/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp b/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp
index 6ac00004e..effa0628b 100644
--- a/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp
+++ b/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp
@@ -5,10 +5,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSProjectTest.cpp b/tests/unit/capi/GEOSProjectTest.cpp
index 91c861823..af8640f8b 100644
--- a/tests/unit/capi/GEOSProjectTest.cpp
+++ b/tests/unit/capi/GEOSProjectTest.cpp
@@ -3,11 +3,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cmath>
diff --git a/tests/unit/capi/GEOSRelateBoundaryNodeRuleTest.cpp b/tests/unit/capi/GEOSRelateBoundaryNodeRuleTest.cpp
index e8b08adf4..d27d4d23b 100644
--- a/tests/unit/capi/GEOSRelateBoundaryNodeRuleTest.cpp
+++ b/tests/unit/capi/GEOSRelateBoundaryNodeRuleTest.cpp
@@ -4,10 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSRelatePatternMatchTest.cpp b/tests/unit/capi/GEOSRelatePatternMatchTest.cpp
index b60ab1e18..a942917ef 100644
--- a/tests/unit/capi/GEOSRelatePatternMatchTest.cpp
+++ b/tests/unit/capi/GEOSRelatePatternMatchTest.cpp
@@ -5,9 +5,7 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
+#include <cstring>
diff --git a/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp b/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
index 1a0780b57..0b78590b2 100644
--- a/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
+++ b/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
@@ -3,12 +3,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cmath>
-#include <cstring>
diff --git a/tests/unit/capi/GEOSReverseTest.cpp b/tests/unit/capi/GEOSReverseTest.cpp
index fae65d95f..cb8895d26 100644
--- a/tests/unit/capi/GEOSReverseTest.cpp
+++ b/tests/unit/capi/GEOSReverseTest.cpp
@@ -3,10 +3,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSSTRtreeTest.cpp b/tests/unit/capi/GEOSSTRtreeTest.cpp
index 80c52499d..ab3697fab 100644
--- a/tests/unit/capi/GEOSSTRtreeTest.cpp
+++ b/tests/unit/capi/GEOSSTRtreeTest.cpp
@@ -6,7 +6,6 @@
 #include <geos_c.h>
 // std
-#include <cstdarg>
 #include <cstdio>
 #include <cstring>
 #include <cmath>
diff --git a/tests/unit/capi/GEOSSegmentIntersectionTest.cpp b/tests/unit/capi/GEOSSegmentIntersectionTest.cpp
index aec95a847..f3e2c75da 100644
--- a/tests/unit/capi/GEOSSegmentIntersectionTest.cpp
+++ b/tests/unit/capi/GEOSSegmentIntersectionTest.cpp
@@ -3,10 +3,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSSharedPathsTest.cpp b/tests/unit/capi/GEOSSharedPathsTest.cpp
index db3b24fb9..e1708d938 100644
--- a/tests/unit/capi/GEOSSharedPathsTest.cpp
+++ b/tests/unit/capi/GEOSSharedPathsTest.cpp
@@ -5,10 +5,7 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
 #include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSSimplifyTest.cpp b/tests/unit/capi/GEOSSimplifyTest.cpp
index 407589b8b..1de11740b 100644
--- a/tests/unit/capi/GEOSSimplifyTest.cpp
+++ b/tests/unit/capi/GEOSSimplifyTest.cpp
@@ -4,11 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSSnapTest.cpp b/tests/unit/capi/GEOSSnapTest.cpp
index fba18f8e8..7fedee2e6 100644
--- a/tests/unit/capi/GEOSSnapTest.cpp
+++ b/tests/unit/capi/GEOSSnapTest.cpp
@@ -5,10 +5,7 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
 #include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp b/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp
index ca84ed899..1f6bdcb33 100644
--- a/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp
+++ b/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp
@@ -1,11 +1,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSUnaryUnionPrecTest.cpp b/tests/unit/capi/GEOSUnaryUnionPrecTest.cpp
index 0f873b9e3..2c421f513 100644
--- a/tests/unit/capi/GEOSUnaryUnionPrecTest.cpp
+++ b/tests/unit/capi/GEOSUnaryUnionPrecTest.cpp
@@ -4,11 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
diff --git a/tests/unit/capi/GEOSUnaryUnionTest.cpp b/tests/unit/capi/GEOSUnaryUnionTest.cpp
index b33b07a2f..ad431e12b 100644
--- a/tests/unit/capi/GEOSUnaryUnionTest.cpp
+++ b/tests/unit/capi/GEOSUnaryUnionTest.cpp
@@ -5,9 +5,6 @@
 // geos
 #include <geos_c.h>
 // std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
 #include <cstring>
diff --git a/tests/unit/capi/GEOSUserDataTest.cpp b/tests/unit/capi/GEOSUserDataTest.cpp
index 18345f769..9049f7564 100644
--- a/tests/unit/capi/GEOSUserDataTest.cpp
+++ b/tests/unit/capi/GEOSUserDataTest.cpp
@@ -1,14 +1,9 @@
-// Test Suite for C-API GEOSSimplify
+// Test Suite for C-API GEOSGeom_setUserData
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSVoronoiDiagramTest.cpp b/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
index b379a49d0..7c5b05bcd 100644
--- a/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
+++ b/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
@@ -6,10 +6,6 @@
 #include <geos_c.h>
 // std
 #include <cfenv>
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
diff --git a/tests/unit/capi/GEOSWithinTest.cpp b/tests/unit/capi/GEOSWithinTest.cpp
index 703a9b86e..387f40909 100644
--- a/tests/unit/capi/GEOSWithinTest.cpp
+++ b/tests/unit/capi/GEOSWithinTest.cpp
@@ -4,10 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
diff --git a/tests/unit/capi/GEOSisClosedTest.cpp b/tests/unit/capi/GEOSisClosedTest.cpp
index 656ec1ab1..2b322542e 100644
--- a/tests/unit/capi/GEOSisClosedTest.cpp
+++ b/tests/unit/capi/GEOSisClosedTest.cpp
@@ -4,12 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cctype>
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
diff --git a/tests/unit/capi/GEOSisRingTest.cpp b/tests/unit/capi/GEOSisRingTest.cpp
index 1d0b6da47..0f263be6c 100644
--- a/tests/unit/capi/GEOSisRingTest.cpp
+++ b/tests/unit/capi/GEOSisRingTest.cpp
@@ -4,12 +4,6 @@
 // geos
 #include <geos_c.h>
-// std
-#include <cctype>
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
diff --git a/tests/unit/capi/GEOSisValidDetailTest.cpp b/tests/unit/capi/GEOSisValidDetailTest.cpp
index 56d005268..4c0c12e9e 100644
--- a/tests/unit/capi/GEOSisValidDetailTest.cpp
+++ b/tests/unit/capi/GEOSisValidDetailTest.cpp
@@ -6,10 +6,6 @@
 #include <geos_c.h>
 // std
 #include <cctype>
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index aef573565..67818d6a1 100644
--- a/tests/unit/capi/capi_test_utils.h
+++ b/tests/unit/capi/capi_test_utils.h
@@ -7,8 +7,6 @@
 #include <cstdarg>
 #include <cstdio>
-#include <cstdlib>
-#include <cstring>
 #include <cfenv>
diff --git a/tests/unit/geom/CoordinateSequenceIteratorTest.cpp b/tests/unit/geom/CoordinateSequenceIteratorTest.cpp
index 7fa846335..ca98b8172 100644
--- a/tests/unit/geom/CoordinateSequenceIteratorTest.cpp
+++ b/tests/unit/geom/CoordinateSequenceIteratorTest.cpp
@@ -1,7 +1,7 @@
 #include <geos/geom/CoordinateSequence.h>
-#include <numeric>
 namespace tut {
diff --git a/tests/unit/geomgraph/TopologyLocationTest.cpp b/tests/unit/geomgraph/TopologyLocationTest.cpp
index 86bc6d602..731dcfd72 100644
--- a/tests/unit/geomgraph/TopologyLocationTest.cpp
+++ b/tests/unit/geomgraph/TopologyLocationTest.cpp
@@ -6,10 +6,6 @@
 // geos
 #include <geos/geomgraph/TopologyLocation.h>
 #include <geos/geom/Location.h>
-// std
-#include <memory>
-#include <string>
-#include <vector>
 using TopologyLocation = geos::geomgraph::TopologyLocation;
 using Location = geos::geom::Location;
diff --git a/tests/unit/index/VertexSequencePackedRtreeTest.cpp b/tests/unit/index/VertexSequencePackedRtreeTest.cpp
index 877666e8d..88edfbf6b 100644
--- a/tests/unit/index/VertexSequencePackedRtreeTest.cpp
+++ b/tests/unit/index/VertexSequencePackedRtreeTest.cpp
@@ -12,11 +12,9 @@
 #include <geos/index/VertexSequencePackedRtree.h>
-// std
-#include <stdio.h>
+using geos::index::VertexSequencePackedRtree;
-using geos::index::VertexSequencePackedRtree;
 namespace tut {
diff --git a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
index 7e15311f0..f13edf7a0 100644
--- a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
+++ b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
@@ -8,8 +8,6 @@
 #include <geos/index/ItemVisitor.h>
-#include <iostream>
 using namespace geos;
 namespace tut {
diff --git a/tests/unit/index/strtree/TemplateSTRtreeTest.cpp b/tests/unit/index/strtree/TemplateSTRtreeTest.cpp
index 75de4f704..701b356e7 100644
--- a/tests/unit/index/strtree/TemplateSTRtreeTest.cpp
+++ b/tests/unit/index/strtree/TemplateSTRtreeTest.cpp
@@ -8,8 +8,6 @@
 using geos::index::strtree::TemplateSTRtree;
 using geos::geom::Geometry;
diff --git a/tests/unit/io/ByteOrderValuesTest.cpp b/tests/unit/io/ByteOrderValuesTest.cpp
index 22fc3a024..f483fd2fd 100644
--- a/tests/unit/io/ByteOrderValuesTest.cpp
+++ b/tests/unit/io/ByteOrderValuesTest.cpp
@@ -6,9 +6,6 @@
 // geos
 #include <geos/io/ByteOrderValues.h>
 #include <geos/constants.h> // for int64
-// std
-#include <sstream>
-#include <memory>
 namespace tut {
diff --git a/tests/unit/io/GeoJSONFeatureTest.cpp b/tests/unit/io/GeoJSONFeatureTest.cpp
index 0f9b4a8d9..701302289 100644
--- a/tests/unit/io/GeoJSONFeatureTest.cpp
+++ b/tests/unit/io/GeoJSONFeatureTest.cpp
@@ -14,7 +14,6 @@
 #include <geos/geom/GeometryCollection.h>
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/io/GeoJSONReaderTest.cpp b/tests/unit/io/GeoJSONReaderTest.cpp
index c5ff39db8..25ec0aa4f 100644
--- a/tests/unit/io/GeoJSONReaderTest.cpp
+++ b/tests/unit/io/GeoJSONReaderTest.cpp
@@ -13,7 +13,6 @@
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/io/GeoJSONValueTest.cpp b/tests/unit/io/GeoJSONValueTest.cpp
index 7b539ff08..2bf1f3d01 100644
--- a/tests/unit/io/GeoJSONValueTest.cpp
+++ b/tests/unit/io/GeoJSONValueTest.cpp
@@ -6,9 +6,7 @@
 // geos
 #include <geos/io/GeoJSON.h>
 // std
-#include <sstream>
 #include <string>
-#include <memory>
 namespace tut {
@@ -99,4 +97,4 @@ void object::test<6>
     ensure_equals(3, value.getArray()[2].getNumber());
\ No newline at end of file
diff --git a/tests/unit/io/GeoJSONWriterTest.cpp b/tests/unit/io/GeoJSONWriterTest.cpp
index 7db14f5cf..e075e577f 100644
--- a/tests/unit/io/GeoJSONWriterTest.cpp
+++ b/tests/unit/io/GeoJSONWriterTest.cpp
@@ -163,27 +163,27 @@ void object::test<11>
     GeomPtr geom(wktreader.read("LINESTRING(102.0 0.0, 103.0 1.0, 104.0 0.0, 105.0 1.0)"));
     std::string result = geojsonwriter.writeFormatted(geom.get());
-    ensure_equals(result, std::string{"{\n"} +
-        "        [\n" +
-        "            102.0,\n" +
-        "            0.0\n" +
-        "        ],\n" +
-        "        [\n" +
-        "            103.0,\n" +
-        "            1.0\n" +
-        "        ],\n" +
-        "        [\n" +
-        "            104.0,\n" +
-        "            0.0\n" +
-        "        ],\n" +
-        "        [\n" +
-        "            105.0,\n" +
-        "            1.0\n" +
-        "        ]\n" +
-        "    ]\n" +
+    ensure_equals(result, std::string{"{\n"
+        "        [\n"
+        "            102.0,\n"
+        "            0.0\n"
+        "        ],\n"
+        "        [\n"
+        "            103.0,\n"
+        "            1.0\n"
+        "        ],\n"
+        "        [\n"
+        "            104.0,\n"
+        "            0.0\n"
+        "        ],\n"
+        "        [\n"
+        "            105.0,\n"
+        "            1.0\n"
+        "        ]\n"
+        "    ]\n"
 // Write a LineString to formatted GeoJSON with custom indentation
@@ -194,27 +194,27 @@ void object::test<12>
     std::string result = geojsonwriter.writeFormatted(geom.get(), geos::io::GeoJSONType::GEOMETRY, 2);
-        "    [\n" +
-        "      102.0,\n" +
-        "      0.0\n" +
-        "    ],\n" +
-        "    [\n" +
-        "      103.0,\n" +
-        "      1.0\n" +
-        "    ],\n" +
-        "    [\n" +
-        "      104.0,\n" +
-        "      0.0\n" +
-        "    ],\n" +
-        "    [\n" +
-        "      105.0,\n" +
-        "      1.0\n" +
-        "    ]\n" +
-        "  ]\n" +
+        "    [\n"
+        "      102.0,\n"
+        "      0.0\n"
+        "    ],\n"
+        "    [\n"
+        "      103.0,\n"
+        "      1.0\n"
+        "    ],\n"
+        "    [\n"
+        "      104.0,\n"
+        "      0.0\n"
+        "    ],\n"
+        "    [\n"
+        "      105.0,\n"
+        "      1.0\n"
+        "    ]\n"
+        "  ]\n"
 // Write a Feature
diff --git a/tests/unit/io/WKTWriterTest.cpp b/tests/unit/io/WKTWriterTest.cpp
index 4622e9b98..27897f3d3 100644
--- a/tests/unit/io/WKTWriterTest.cpp
+++ b/tests/unit/io/WKTWriterTest.cpp
@@ -20,7 +20,6 @@
 // std
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/io/WriterTest.cpp b/tests/unit/io/WriterTest.cpp
index d616e4136..69ab6296a 100644
--- a/tests/unit/io/WriterTest.cpp
+++ b/tests/unit/io/WriterTest.cpp
@@ -6,9 +6,7 @@
 // geos
 #include <geos/io/Writer.h>
 // std
-#include <sstream>
 #include <string>
-#include <memory>
 namespace tut {
diff --git a/tests/unit/linearref/LengthIndexedLineTest.cpp b/tests/unit/linearref/LengthIndexedLineTest.cpp
index 09909f6bf..8ab1bd38d 100644
--- a/tests/unit/linearref/LengthIndexedLineTest.cpp
+++ b/tests/unit/linearref/LengthIndexedLineTest.cpp
@@ -16,7 +16,6 @@
 // std
 #include <cmath>
-#include <sstream>
 #include <string>
 #include <memory>
diff --git a/tests/unit/math/DDTest.cpp b/tests/unit/math/DDTest.cpp
index 93d3f1ea1..b98cbae33 100644
--- a/tests/unit/math/DDTest.cpp
+++ b/tests/unit/math/DDTest.cpp
@@ -10,10 +10,6 @@
-// std
-#include <memory>
-#include <string>
 using namespace geos::math;
 namespace tut {
diff --git a/tests/unit/noding/NodedSegmentStringTest.cpp b/tests/unit/noding/NodedSegmentStringTest.cpp
index dbda3eb6b..35100878f 100644
--- a/tests/unit/noding/NodedSegmentStringTest.cpp
+++ b/tests/unit/noding/NodedSegmentStringTest.cpp
@@ -18,7 +18,6 @@
 using geos::io::WKTReader;
 using geos::geom::CoordinateSequence;
-//using geos::geom::LineString;
 using geos::geom::GeometryFactory;
 using geos::noding::SegmentString;
diff --git a/tests/unit/noding/snapround/HotPixelTest.cpp b/tests/unit/noding/snapround/HotPixelTest.cpp
index a7cb0c129..5ed39ba2e 100644
--- a/tests/unit/noding/snapround/HotPixelTest.cpp
+++ b/tests/unit/noding/snapround/HotPixelTest.cpp
@@ -8,8 +8,6 @@
 #include <geos/geom/Envelope.h>
-// std
-#include <memory>
 using namespace geos::noding::snapround;
diff --git a/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp b/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
index 4221bad3b..11d760c55 100644
--- a/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
+++ b/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
@@ -20,11 +20,7 @@
 #include <geos/geom/MultiLineString.h>
 // std
 #include <memory>
-#include <fstream>
 #include <string>
-#include <iomanip>
 namespace tut {
diff --git a/tests/unit/operation/BoundaryOpTest.cpp b/tests/unit/operation/BoundaryOpTest.cpp
index fc8aa1e68..de392dbff 100644
--- a/tests/unit/operation/BoundaryOpTest.cpp
+++ b/tests/unit/operation/BoundaryOpTest.cpp
@@ -5,8 +5,6 @@
 #include <geos/algorithm/BoundaryNodeRule.h>
 #include <geos/operation/BoundaryOp.h>
 // std
-#include <cmath>
 #include <string>
 #include <memory>
diff --git a/tests/unit/operation/buffer/BufferBuilderTest.cpp b/tests/unit/operation/buffer/BufferBuilderTest.cpp
index e3f4613c9..09f8a7119 100644
--- a/tests/unit/operation/buffer/BufferBuilderTest.cpp
+++ b/tests/unit/operation/buffer/BufferBuilderTest.cpp
@@ -18,7 +18,6 @@
 // std
 #include <memory>
 #include <string>
-#include <vector>
 namespace tut {
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index 342f95db2..520256585 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -19,7 +19,6 @@
 // std
 #include <memory>
 #include <string>
-#include <vector>
 using namespace geos::operation::buffer;
diff --git a/tests/unit/operation/buffer/OffsetCurveTest.cpp b/tests/unit/operation/buffer/OffsetCurveTest.cpp
index e845a51f4..0e817439f 100644
--- a/tests/unit/operation/buffer/OffsetCurveTest.cpp
+++ b/tests/unit/operation/buffer/OffsetCurveTest.cpp
@@ -10,7 +10,6 @@
 #include <geos/operation/buffer/BufferParameters.h>
-// #include <geos/io/WKTWriter.h>
 // std
 #include <memory>
diff --git a/tests/unit/operation/distance/DistanceOpTest.cpp b/tests/unit/operation/distance/DistanceOpTest.cpp
index 9df481a39..32eee5bbf 100644
--- a/tests/unit/operation/distance/DistanceOpTest.cpp
+++ b/tests/unit/operation/distance/DistanceOpTest.cpp
@@ -20,7 +20,6 @@
 // std
 #include <memory>
 #include <string>
-#include <vector>
 namespace tut {
diff --git a/tests/unit/operation/geounion/CoverageUnionTest.cpp b/tests/unit/operation/geounion/CoverageUnionTest.cpp
index 50135e195..4da7a6ed9 100644
--- a/tests/unit/operation/geounion/CoverageUnionTest.cpp
+++ b/tests/unit/operation/geounion/CoverageUnionTest.cpp
@@ -17,7 +17,6 @@
 #include <memory>
 #include <string>
 #include <vector>
 namespace tut {
diff --git a/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp b/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
index a898a60f4..7866fb732 100644
--- a/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
+++ b/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
@@ -11,7 +11,6 @@
 // std
 #include <memory>
 #include <string>
-#include <vector>
 namespace tut {
diff --git a/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp b/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp
index a03163f93..6342b4243 100644
--- a/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp
+++ b/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp
@@ -9,7 +9,6 @@
 #include <geos/geom/CoordinateList.h>
 // std
-#include <string>
 #include <vector>
diff --git a/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp b/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp
index a49b5aec7..e2fccc582 100644
--- a/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp
+++ b/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp
@@ -13,7 +13,6 @@
 // std
 #include <memory>
-#include <vector>
 namespace tut {
 using namespace geos::operation::overlay;
diff --git a/tests/unit/operation/relate/RelateBoundaryNodeRuleTest.cpp b/tests/unit/operation/relate/RelateBoundaryNodeRuleTest.cpp
index ab9d09da3..5c481cac3 100644
--- a/tests/unit/operation/relate/RelateBoundaryNodeRuleTest.cpp
+++ b/tests/unit/operation/relate/RelateBoundaryNodeRuleTest.cpp
@@ -5,7 +5,6 @@
 #include <geos/operation/relate/RelateOp.h>
 // std
-#include <cmath>
 #include <string>
 #include <memory>
diff --git a/tests/unit/operation/relate/RelateOpTest.cpp b/tests/unit/operation/relate/RelateOpTest.cpp
index 9c75fd33b..92759da80 100644
--- a/tests/unit/operation/relate/RelateOpTest.cpp
+++ b/tests/unit/operation/relate/RelateOpTest.cpp
@@ -20,7 +20,6 @@
 // std
-#include <cmath>
 #include <string>
 #include <memory>
 #include <thread>
diff --git a/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp b/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
index 58d9ef046..ded1c83fc 100644
--- a/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
+++ b/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
@@ -15,7 +15,6 @@
 // std
 #include <memory>
 #include <string>
-#include <vector>
 namespace tut {
diff --git a/tests/unit/operation/valid/MakeValidTest.cpp b/tests/unit/operation/valid/MakeValidTest.cpp
index 188f41a52..0a6cdddf4 100644
--- a/tests/unit/operation/valid/MakeValidTest.cpp
+++ b/tests/unit/operation/valid/MakeValidTest.cpp
@@ -12,11 +12,6 @@
-// std
-#include <cmath>
-#include <string>
-#include <vector>
-#include <fstream>
 using namespace geos::operation::valid;
diff --git a/tests/unit/operation/valid/ValidClosedRingTest.cpp b/tests/unit/operation/valid/ValidClosedRingTest.cpp
index 9ef97c870..54074f678 100644
--- a/tests/unit/operation/valid/ValidClosedRingTest.cpp
+++ b/tests/unit/operation/valid/ValidClosedRingTest.cpp
@@ -17,13 +17,11 @@
 #include <geos/operation/valid/TopologyValidationError.h>
 // std
-#include <cmath>
 #include <string>
 #include <memory>
 #include <iostream>
-//using namespace geos::operation;
 using namespace geos::util;
 using namespace std;
diff --git a/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp b/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
index 944a2ff0d..98d986f2b 100644
--- a/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
+++ b/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
@@ -17,7 +17,6 @@
 // std
-#include <cmath>
 #include <string>
 #include <memory>
 #include <iostream>
diff --git a/tests/unit/precision/GeometryPrecisionReducerTest.cpp b/tests/unit/precision/GeometryPrecisionReducerTest.cpp
index bd51e355c..7c2161ddf 100644
--- a/tests/unit/precision/GeometryPrecisionReducerTest.cpp
+++ b/tests/unit/precision/GeometryPrecisionReducerTest.cpp
@@ -13,8 +13,6 @@
 // std
 #include <string>
-#include <vector>
 using namespace geos::precision;
diff --git a/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp b/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
index aec43a41a..1371f7d15 100644
--- a/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
+++ b/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
@@ -11,7 +11,6 @@
 // std
 #include <string>
-#include <vector>
 namespace tut {
diff --git a/tests/unit/triangulate/DelaunayTest.cpp b/tests/unit/triangulate/DelaunayTest.cpp
index 0b324c7df..eb8d859ea 100644
--- a/tests/unit/triangulate/DelaunayTest.cpp
+++ b/tests/unit/triangulate/DelaunayTest.cpp
@@ -11,12 +11,10 @@
 #include <geos/triangulate/quadedge/QuadEdgeSubdivision.h>
 #include <geos/triangulate/IncrementalDelaunayTriangulator.h>
 #include <geos/triangulate/DelaunayTriangulationBuilder.h>
-//#include <geos/io/WKTWriter.h>
-//#include <stdio.h>
 using namespace geos::triangulate;
 using namespace geos::triangulate::quadedge;
diff --git a/tests/unit/triangulate/VoronoiTest.cpp b/tests/unit/triangulate/VoronoiTest.cpp
index 5333de0dc..dd9066a95 100644
--- a/tests/unit/triangulate/VoronoiTest.cpp
+++ b/tests/unit/triangulate/VoronoiTest.cpp
@@ -19,8 +19,8 @@
 #include <iostream>
diff --git a/tests/unit/triangulate/polygon/ConstrainedDelaunayTriangulatorTest.cpp b/tests/unit/triangulate/polygon/ConstrainedDelaunayTriangulatorTest.cpp
index 0380a416c..d236962ea 100644
--- a/tests/unit/triangulate/polygon/ConstrainedDelaunayTriangulatorTest.cpp
+++ b/tests/unit/triangulate/polygon/ConstrainedDelaunayTriangulatorTest.cpp
@@ -11,9 +11,6 @@
 #include <geos/triangulate/polygon/ConstrainedDelaunayTriangulator.h>
-// std
-#include <stdio.h>
 using geos::triangulate::polygon::ConstrainedDelaunayTriangulator;
diff --git a/tests/unit/triangulate/polygon/PolygonHoleJoinerTest.cpp b/tests/unit/triangulate/polygon/PolygonHoleJoinerTest.cpp
index afe0f6fa3..d96d6ec2b 100644
--- a/tests/unit/triangulate/polygon/PolygonHoleJoinerTest.cpp
+++ b/tests/unit/triangulate/polygon/PolygonHoleJoinerTest.cpp
@@ -13,9 +13,6 @@
 #include <geos/triangulate/polygon/PolygonHoleJoiner.h>
-// std
-#include <stdio.h>
 using geos::triangulate::polygon::PolygonHoleJoiner;
diff --git a/tests/unit/triangulate/polygon/PolygonTriangulatorTest.cpp b/tests/unit/triangulate/polygon/PolygonTriangulatorTest.cpp
index a1e2032b9..5755807b0 100644
--- a/tests/unit/triangulate/polygon/PolygonTriangulatorTest.cpp
+++ b/tests/unit/triangulate/polygon/PolygonTriangulatorTest.cpp
@@ -13,9 +13,6 @@
 #include <geos/triangulate/polygon/PolygonTriangulator.h>
-// std
-#include <stdio.h>
 using geos::triangulate::polygon::PolygonTriangulator;
diff --git a/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp b/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
index 9521a8a7e..05e0221a1 100644
--- a/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
+++ b/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
@@ -21,9 +21,8 @@
 #include <geos/operation/valid/RepeatedPointRemover.h>
 // std
-#include <stdio.h>
diff --git a/tests/unit/triangulate/quadedge/QuadEdgeTest.cpp b/tests/unit/triangulate/quadedge/QuadEdgeTest.cpp
index c6f877731..a6c4519a3 100644
--- a/tests/unit/triangulate/quadedge/QuadEdgeTest.cpp
+++ b/tests/unit/triangulate/quadedge/QuadEdgeTest.cpp
@@ -7,8 +7,6 @@
 #include <geos/triangulate/quadedge/Vertex.h>
 #include <geos/triangulate/quadedge/QuadEdge.h>
 #include <geos/triangulate/quadedge/QuadEdgeQuartet.h>
-// std
-#include <stdio.h>
diff --git a/tests/unit/triangulate/quadedge/VertexTest.cpp b/tests/unit/triangulate/quadedge/VertexTest.cpp
index 62c10a054..ee7a8b829 100644
--- a/tests/unit/triangulate/quadedge/VertexTest.cpp
+++ b/tests/unit/triangulate/quadedge/VertexTest.cpp
@@ -8,8 +8,6 @@
-// std
-#include <stdio.h>
diff --git a/tests/unit/tut/tut.hpp b/tests/unit/tut/tut.hpp
index f8d464819..ea7104c24 100644
--- a/tests/unit/tut/tut.hpp
+++ b/tests/unit/tut/tut.hpp
@@ -4,14 +4,10 @@
 #undef public
 #undef private
+#include <cassert>
 #include <map>
-#include <vector>
-#include <set>
 #include <string>
-#include <sstream>
-#include <iterator>
-#include <algorithm>
 #include "tut_exception.hpp"
 #include "tut_result.hpp"
diff --git a/tests/unit/tut/tut_assert.hpp b/tests/unit/tut/tut_assert.hpp
index faf10b874..506192c4c 100644
--- a/tests/unit/tut/tut_assert.hpp
+++ b/tests/unit/tut/tut_assert.hpp
@@ -7,6 +7,7 @@
 #include <iterator>
 #include <cassert>
 #include <cmath>
+#include <sstream>
 #if defined(TUT_USE_POSIX)
 #include <errno.h>
diff --git a/tests/unit/tut/tut_console_reporter.hpp b/tests/unit/tut/tut_console_reporter.hpp
index c30459e06..bc06fd12b 100644
--- a/tests/unit/tut/tut_console_reporter.hpp
+++ b/tests/unit/tut/tut_console_reporter.hpp
@@ -1,6 +1,7 @@
 #ifndef TUT_CONSOLE_REPORTER
 #define TUT_CONSOLE_REPORTER
+#include <iostream>
 #include <cassert>
commit 737904ec0274e64d2cd5079d0ee2988855b83a41
Date:   Fri May 2 11:11:23 2025 -0700
    Add MaximumInscribedCircle isRadiusWithin fast envelope check, port of https://github.com/locationtech/jts/commit/7835f24417b2e748bf251814779ef652f28895c4
diff --git a/src/algorithm/construct/MaximumInscribedCircle.cpp b/src/algorithm/construct/MaximumInscribedCircle.cpp
index a39640227..12fbefeda 100644
--- a/src/algorithm/construct/MaximumInscribedCircle.cpp
+++ b/src/algorithm/construct/MaximumInscribedCircle.cpp
@@ -55,11 +55,11 @@ MaximumInscribedCircle::MaximumInscribedCircle(const Geometry* polygonal, double
     if (!(typeid(*polygonal) == typeid(Polygon) ||
           typeid(*polygonal) == typeid(MultiPolygon))) {
-        throw util::IllegalArgumentException("Input geometry must be a Polygon or MultiPolygon");
+        throw util::IllegalArgumentException("Input must be a Polygon or MultiPolygon");
     if (polygonal->isEmpty()) {
-        throw util::IllegalArgumentException("Empty input geometry is not supported");
+        throw util::IllegalArgumentException("Empty input is not supported");
@@ -192,6 +192,16 @@ MaximumInscribedCircle::isRadiusWithin(double maxRadius)
         return false;
     maximumRadius = maxRadius;
+     * Check if envelope dimension is smaller than diameter
+    const Envelope* env = inputGeom->getEnvelopeInternal();
+    double maxDiam = 2 * maximumRadius;
+    if (env->getWidth() < maxDiam || env->getHeight() < maxDiam) {
+        return true;
     tolerance = maxRadius * MAX_RADIUS_FRACTION;
     compute();
     double radius = centerPt.distance(radiusPt);
@@ -207,7 +217,7 @@ MaximumInscribedCircle::compute()
     if (done) return;
-     * Handle empty or flat geometries.
+     * Handle flat geometries.
     if (inputGeom->getArea() == 0.0) {
         const CoordinateXY* c = inputGeom->getCoordinate();
commit 2d9b0f5e5e75dab3a11a94b85b0cf6d4a051faea
Date:   Fri May 2 11:08:34 2025 -0700
    Fix ExactMaxInscribedCircle to handle collinear input, port of https://github.com/locationtech/jts/commit/e788619f9436abaf8e71645e16c368c651f1d3e1
diff --git a/include/geos/algorithm/Angle.h b/include/geos/algorithm/Angle.h
index 164c89844..6f86f3d33 100644
--- a/include/geos/algorithm/Angle.h
+++ b/include/geos/algorithm/Angle.h
@@ -150,6 +150,7 @@ public:
     /// Computes the angle of the unoriented bisector
     /// of the smallest angle between two vectors.
     /// The computed angle will be in the range (-Pi, Pi].
+    /// Collinear inputs are handled.
     /// @param tip1 the tip of v1
     /// @param tail the tail of each vector
diff --git a/include/geos/algorithm/construct/ExactMaxInscribedCircle.h b/include/geos/algorithm/construct/ExactMaxInscribedCircle.h
index d41866ef6..c68ddc7dd 100644
--- a/include/geos/algorithm/construct/ExactMaxInscribedCircle.h
+++ b/include/geos/algorithm/construct/ExactMaxInscribedCircle.h
@@ -107,9 +107,9 @@ private:
     static bool isConvex(const CoordinateSequence* ring);
-    static bool isConvex(const CoordinateXY& p0,
-                         const CoordinateXY& p1,
-                         const CoordinateXY& p2);
+    static bool isConcave(const CoordinateXY& p0,
+                          const CoordinateXY& p1,
+                          const CoordinateXY& p2);
     static bool isPointInConvexRing(const CoordinateSequence* ringCW,
                                 const CoordinateXY& p);
diff --git a/src/algorithm/construct/ExactMaxInscribedCircle.cpp b/src/algorithm/construct/ExactMaxInscribedCircle.cpp
index 3491d8703..46ce08794 100644
--- a/src/algorithm/construct/ExactMaxInscribedCircle.cpp
+++ b/src/algorithm/construct/ExactMaxInscribedCircle.cpp
@@ -29,6 +29,7 @@
 #include <geos/geom/Polygon.h>
 #include <geos/geom/Triangle.h>
 #include <geos/util/IllegalArgumentException.h>
+#include <geos/util/IllegalStateException.h>
 #include <typeinfo> // for dynamic_cast
@@ -197,8 +198,8 @@ ExactMaxInscribedCircle::computeConvexBisector(
     std::size_t iNext = index >= pts->size() ? 0 : index + 1;
     const CoordinateXY& pPrev = pts->getAt(iPrev);
     const CoordinateXY& pNext = pts->getAt(iNext);
-    if (! isConvex(pPrev, basePt, pNext))
-        throw util::IllegalArgumentException("Input is not convex");
+    if (isConcave(pPrev, basePt, pNext))
+        throw util::IllegalStateException("Input is not convex");
     double bisectAng = Angle::bisector(pPrev, basePt, pNext);
     CoordinateXY endPt = Angle::project(basePt, bisectAng, len);
     return LineSegment(basePt.x, basePt.y, endPt.x, endPt.y);
@@ -245,11 +246,11 @@ ExactMaxInscribedCircle::isConvex(const CoordinateSequence* ring)
 /* private static */
 bool
-ExactMaxInscribedCircle::isConvex(const CoordinateXY& p0,
+ExactMaxInscribedCircle::isConcave(const CoordinateXY& p0,
-    return Orientation::CLOCKWISE == Orientation::index(p0, p1, p2);
+     return Orientation::COUNTERCLOCKWISE == Orientation::index(p0, p1, p2);
index 4f10b0c29..985a1a7ae 100644
@@ -296,5 +296,15 @@ void object::test<16> ()
         0.001, 4.7545, 3.0809, 2.081 );
+/* testQuadWithCollinearVertex */
+template<>
+template<>
+void object::test<17> ()
+    checkCircle("POLYGON ((1 5, 5 5, 9 5, 5 1, 1 5))",
+        0.001, 5.0, 3.3431,  1.65685 );
 } // namespace tut
Summary of changes:
 include/geos/algorithm/Angle.h                     |  1 +
 .../algorithm/construct/ExactMaxInscribedCircle.h  |  6 +-
 .../construct/ExactMaxInscribedCircle.cpp          | 13 ++--
 src/algorithm/construct/MaximumInscribedCircle.cpp | 16 ++++-
 tests/unit/CMakeLists.txt                          |  1 +
 tests/unit/algorithm/AngleTest.cpp                 |  2 -
 .../CGAlgorithms/OrientationIsCCWTest.cpp          |  1 -
 .../unit/algorithm/CGAlgorithms/signedAreaTest.cpp |  1 -
 tests/unit/algorithm/CentroidTest.cpp              |  1 -
 tests/unit/algorithm/ConvexHullTest.cpp            |  1 -
 tests/unit/algorithm/InteriorPointAreaTest.cpp     |  1 -
 tests/unit/algorithm/IntersectionTest.cpp          |  2 -
 tests/unit/algorithm/LengthTest.cpp                |  1 -
 tests/unit/algorithm/MinimumAreaRectangleTest.cpp  |  1 -
 tests/unit/algorithm/MinimumBoundingCircleTest.cpp |  1 -
 tests/unit/algorithm/MinimumDiameterTest.cpp       |  1 -
 .../unit/algorithm/OrientationIndexFailureTest.cpp |  3 -
 tests/unit/algorithm/PointLocationTest.cpp         |  1 -
 tests/unit/algorithm/PointLocatorTest.cpp          |  1 -
 tests/unit/algorithm/PolygonNodeTopologyTest.cpp   |  1 -
 .../unit/algorithm/RobustLineIntersectionTest.cpp  |  1 -
 .../unit/algorithm/RobustLineIntersectorZTest.cpp  |  3 -
 .../algorithm/construct/LargestEmptyCircleTest.cpp |  1 -
 .../construct/MaximumInscribedCircleTest.cpp       | 11 ++-
 .../distance/DiscreteFrechetDistanceTest.cpp       |  1 -
 .../distance/DiscreteHausdorffDistanceTest.cpp     |  1 -
 .../algorithm/hull/ConcaveHullOfPolygonsTest.cpp   |  1 -
 tests/unit/algorithm/hull/ConcaveHullTest.cpp      |  1 -
 .../locate/IndexedPointInAreaLocatorTest.cpp       |  2 -
 tests/unit/capi/GEOSBufferTest.cpp                 |  4 --
 tests/unit/capi/GEOSBuildAreaTest.cpp              |  4 --
 tests/unit/capi/GEOSCAPIDefinesTest.cpp            |  4 --
 tests/unit/capi/GEOSClipByRectTest.cpp             |  2 -
 tests/unit/capi/GEOSConcaveHullOfPolygonsTest.cpp  |  3 -
 tests/unit/capi/GEOSConcaveHullTest.cpp            |  3 -
 .../GEOSConstrainedDelaunayTriangulationTest.cpp   |  4 --
 tests/unit/capi/GEOSContainsTest.cpp               |  3 -
 tests/unit/capi/GEOSConvexHullTest.cpp             |  3 -
 tests/unit/capi/GEOSCoordSeqTest.cpp               |  3 +-
 tests/unit/capi/GEOSCoverageIsValidTest.cpp        |  5 --
 tests/unit/capi/GEOSCoverageSimplifyTest.cpp       |  5 --
 tests/unit/capi/GEOSCoverageUnionTest.cpp          |  5 --
 tests/unit/capi/GEOSDelaunayTriangulationTest.cpp  |  5 --
 tests/unit/capi/GEOSDistanceTest.cpp               |  3 +-
 tests/unit/capi/GEOSDistanceWithinTest.cpp         |  7 --
 tests/unit/capi/GEOSEqualsTest.cpp                 |  3 -
 tests/unit/capi/GEOSFrechetDistanceTest.cpp        |  6 --
 tests/unit/capi/GEOSGeomGeoJSONWriteTest.cpp       | 42 +++++------
 tests/unit/capi/GEOSGeomToWKBTest.cpp              |  2 -
 tests/unit/capi/GEOSGeomToWKTTest.cpp              |  3 -
 tests/unit/capi/GEOSGeom_cloneTest.cpp             |  4 --
 tests/unit/capi/GEOSGeom_createCollectionTest.cpp  |  3 -
 tests/unit/capi/GEOSGeom_createRectangleTest.cpp   |  4 --
 tests/unit/capi/GEOSGeom_createTest.cpp            |  3 -
 tests/unit/capi/GEOSGeom_extentTest.cpp            |  4 --
 .../unit/capi/GEOSGeom_extractUniquePointsTest.cpp |  4 --
 tests/unit/capi/GEOSGeom_transformXYTest.cpp       |  4 --
 tests/unit/capi/GEOSGetCentroidTest.cpp            |  5 --
 tests/unit/capi/GEOSHausdorffDistanceTest.cpp      |  6 --
 tests/unit/capi/GEOSHilbertCodeTest.cpp            |  4 --
 tests/unit/capi/GEOSInterruptTest.cpp              |  5 --
 tests/unit/capi/GEOSIntersectionPrecTest.cpp       |  4 --
 tests/unit/capi/GEOSIntersectsTest.cpp             |  3 -
 tests/unit/capi/GEOSLargestEmptyCircleTest.cpp     |  5 --
 tests/unit/capi/GEOSLineMergeDirectedTest.cpp      |  3 -
 tests/unit/capi/GEOSLineMergeTest.cpp              |  3 -
 tests/unit/capi/GEOSLineStringTest.cpp             |  3 -
 tests/unit/capi/GEOSLineSubstringTest.cpp          |  3 -
 tests/unit/capi/GEOSMakeValidTest.cpp              |  4 --
 tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp |  5 --
 tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp  |  1 -
 tests/unit/capi/GEOSMinimumClearanceTest.cpp       |  4 --
 .../unit/capi/GEOSMinimumRotatedRectangleTest.cpp  |  4 --
 tests/unit/capi/GEOSMinimumWidthTest.cpp           |  4 --
 tests/unit/capi/GEOSNearestPointsTest.cpp          |  4 --
 tests/unit/capi/GEOSNodeTest.cpp                   |  5 --
 tests/unit/capi/GEOSOffsetCurveTest.cpp            |  1 -
 tests/unit/capi/GEOSOrientPolygonsTest.cpp         |  6 --
 tests/unit/capi/GEOSOrientationIndexTest.cpp       |  6 --
 tests/unit/capi/GEOSPointOnSurfaceTest.cpp         |  5 --
 tests/unit/capi/GEOSPolygonHullSimplifyTest.cpp    |  4 --
 tests/unit/capi/GEOSPolygonizeTest.cpp             |  5 --
 tests/unit/capi/GEOSPreparedDistanceTest.cpp       |  4 --
 tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp |  4 --
 tests/unit/capi/GEOSPreparedGeometryTest.cpp       |  3 -
 tests/unit/capi/GEOSPreparedNearestPointsTest.cpp  |  4 --
 tests/unit/capi/GEOSProjectTest.cpp                |  5 --
 tests/unit/capi/GEOSRelateBoundaryNodeRuleTest.cpp |  4 --
 tests/unit/capi/GEOSRelatePatternMatchTest.cpp     |  4 +-
 tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp   |  6 --
 tests/unit/capi/GEOSReverseTest.cpp                |  4 --
 tests/unit/capi/GEOSSTRtreeTest.cpp                |  1 -
 tests/unit/capi/GEOSSegmentIntersectionTest.cpp    |  4 --
 tests/unit/capi/GEOSSharedPathsTest.cpp            |  3 -
 tests/unit/capi/GEOSSimplifyTest.cpp               |  5 --
 tests/unit/capi/GEOSSnapTest.cpp                   |  3 -
 .../unit/capi/GEOSTopologyPreserveSimplifyTest.cpp |  5 --
 tests/unit/capi/GEOSUnaryUnionPrecTest.cpp         |  5 --
 tests/unit/capi/GEOSUnaryUnionTest.cpp             |  3 -
 tests/unit/capi/GEOSUserDataTest.cpp               |  7 +-
 tests/unit/capi/GEOSVoronoiDiagramTest.cpp         |  4 --
 tests/unit/capi/GEOSWithinTest.cpp                 |  4 --
 tests/unit/capi/GEOSisClosedTest.cpp               |  6 --
 tests/unit/capi/GEOSisRingTest.cpp                 |  6 --
 tests/unit/capi/GEOSisValidDetailTest.cpp          |  4 --
 tests/unit/capi/capi_test_utils.h                  |  2 -
 tests/unit/geom/CoordinateSequenceIteratorTest.cpp |  2 +-
 tests/unit/geomgraph/TopologyLocationTest.cpp      |  4 --
 tests/unit/index/VertexSequencePackedRtreeTest.cpp |  4 +-
 tests/unit/index/strtree/SimpleSTRtreeTest.cpp     |  2 -
 tests/unit/index/strtree/TemplateSTRtreeTest.cpp   |  2 -
 tests/unit/io/ByteOrderValuesTest.cpp              |  3 -
 tests/unit/io/GeoJSONFeatureTest.cpp               |  1 -
 tests/unit/io/GeoJSONReaderTest.cpp                |  1 -
 tests/unit/io/GeoJSONValueTest.cpp                 |  4 +-
 tests/unit/io/GeoJSONWriterTest.cpp                | 84 +++++++++++-----------
 tests/unit/io/WKTWriterTest.cpp                    |  1 -
 tests/unit/io/WriterTest.cpp                       |  2 -
 tests/unit/linearref/LengthIndexedLineTest.cpp     |  1 -
 tests/unit/math/DDTest.cpp                         |  4 --
 tests/unit/noding/NodedSegmentStringTest.cpp       |  1 -
 tests/unit/noding/snapround/HotPixelTest.cpp       |  2 -
 .../noding/snapround/MCIndexSnapRounderTest.cpp    |  4 --
 tests/unit/operation/BoundaryOpTest.cpp            |  2 -
 tests/unit/operation/buffer/BufferBuilderTest.cpp  |  1 -
 tests/unit/operation/buffer/BufferOpTest.cpp       |  1 -
 tests/unit/operation/buffer/OffsetCurveTest.cpp    |  1 -
 tests/unit/operation/distance/DistanceOpTest.cpp   |  1 -
 .../unit/operation/geounion/CoverageUnionTest.cpp  |  1 -
 .../operation/overlay/snap/GeometrySnapperTest.cpp |  1 -
 .../overlay/snap/LineStringSnapperTest.cpp         |  1 -
 .../validate/OverlayResultValidatorTest.cpp        |  1 -
 .../relate/RelateBoundaryNodeRuleTest.cpp          |  1 -
 tests/unit/operation/relate/RelateOpTest.cpp       |  1 -
 .../operation/sharedpaths/SharedPathsOpTest.cpp    |  1 -
 tests/unit/operation/valid/MakeValidTest.cpp       |  5 --
 tests/unit/operation/valid/ValidClosedRingTest.cpp |  2 -
 .../valid/ValidSelfTouchingRingFormingHoleTest.cpp |  1 -
 .../precision/GeometryPrecisionReducerTest.cpp     |  2 -
 .../SimpleGeometryPrecisionReducerTest.cpp         |  1 -
 tests/unit/triangulate/DelaunayTest.cpp            |  2 -
 tests/unit/triangulate/VoronoiTest.cpp             |  2 +-
 .../ConstrainedDelaunayTriangulatorTest.cpp        |  3 -
 .../triangulate/polygon/PolygonHoleJoinerTest.cpp  |  3 -
 .../polygon/PolygonTriangulatorTest.cpp            |  3 -
 .../quadedge/QuadEdgeSubdivisionTest.cpp           |  3 +-
 tests/unit/triangulate/quadedge/QuadEdgeTest.cpp   |  2 -
 tests/unit/triangulate/quadedge/VertexTest.cpp     |  2 -
 tests/unit/tut/tut.hpp                             |  8 +--
 tests/unit/tut/tut_assert.hpp                      |  1 +
 tests/unit/tut/tut_console_reporter.hpp            |  1 +
 151 files changed, 111 insertions(+), 490 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
