[geos-commits] [SCM] GEOS branch main updated. ddd197d17589d1ce8106eee37bd4460026a854c4
    git at osgeo.org
    git at osgeo.org
    Fri May  2 13:24:38 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  ddd197d17589d1ce8106eee37bd4460026a854c4 (commit)
      from  c66c9e8adbdfea6b7a36e14ff93fe97474fedfac (commit)
revisions in full, below.
commit ddd197d17589d1ce8106eee37bd4460026a854c4
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri May 2 16:24:19 2025 -0400
    C API: Add functions to work on CoordinateSequences with M values (#1246)
    * C API: Add GEOSCoordSeq_getM, GEOSCoordSeq_setM
    * C API: Add GEOSCoordSeq_createWithDimensions
    References https://github.com/libgeos/geos/issues/1244
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 633c6b07c..6aa9952a0 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -1105,6 +1105,12 @@ extern "C" {
         return GEOSCoordSeq_create_r(handle, size, dims);
+    CoordinateSequence*
+    GEOSCoordSeq_createWithDimensions(unsigned int size, int hasZ, int hasM)
+        return GEOSCoordSeq_createWithDimensions_r(handle, size, hasZ, hasM);
     CoordinateSequence*
     GEOSCoordSeq_copyFromBuffer(const double* buf, unsigned int size, int hasZ, int hasM)
@@ -1138,19 +1144,25 @@ extern "C" {
     int
     GEOSCoordSeq_setX(CoordinateSequence* s, unsigned int idx, double val)
-        return GEOSCoordSeq_setOrdinate(s, idx, 0, val);
+        return GEOSCoordSeq_setOrdinate(s, idx, CoordinateSequence::X, val);
     int
     GEOSCoordSeq_setY(CoordinateSequence* s, unsigned int idx, double val)
-        return GEOSCoordSeq_setOrdinate(s, idx, 1, val);
+        return GEOSCoordSeq_setOrdinate(s, idx, CoordinateSequence::Y, val);
     int
     GEOSCoordSeq_setZ(CoordinateSequence* s, unsigned int idx, double val)
-        return GEOSCoordSeq_setOrdinate(s, idx, 2, val);
+        return GEOSCoordSeq_setOrdinate(s, idx, CoordinateSequence::Z, val);
+    int
+    GEOSCoordSeq_setM(CoordinateSequence* s, unsigned int idx, double val)
+        return GEOSCoordSeq_setOrdinate(s, idx, CoordinateSequence::M, val);
     int
@@ -1180,19 +1192,25 @@ extern "C" {
     int
     GEOSCoordSeq_getX(const CoordinateSequence* s, unsigned int idx, double* val)
-        return GEOSCoordSeq_getOrdinate(s, idx, 0, val);
+        return GEOSCoordSeq_getOrdinate(s, idx, CoordinateSequence::X, val);
     int
     GEOSCoordSeq_getY(const CoordinateSequence* s, unsigned int idx, double* val)
-        return GEOSCoordSeq_getOrdinate(s, idx, 1, val);
+        return GEOSCoordSeq_getOrdinate(s, idx, CoordinateSequence::Y, val);
     int
     GEOSCoordSeq_getZ(const CoordinateSequence* s, unsigned int idx, double* val)
-        return GEOSCoordSeq_getOrdinate(s, idx, 2, val);
+        return GEOSCoordSeq_getOrdinate(s, idx, CoordinateSequence::Z, val);
+    int
+    GEOSCoordSeq_getM(const CoordinateSequence* s, unsigned int idx, double* val)
+        return GEOSCoordSeq_getOrdinate(s, idx, CoordinateSequence::M, val);
     int
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 06a5dec49..3ca7a9aac 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -444,6 +444,13 @@ extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_create_r(
     unsigned int size,
     unsigned int dims);
+/** \see GEOSCoordSeq_createWithDimensions */
+extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_createWithDimensions_r(
+    GEOSContextHandle_t handle,
+    unsigned int size,
+    int hasZ,
+    int hasM);
 /** \see GEOSCoordSeq_copyFromBuffer */
 extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_copyFromBuffer_r(
@@ -506,6 +513,12 @@ extern int GEOS_DLL GEOSCoordSeq_setZ_r(
     GEOSCoordSequence* s, unsigned int idx,
     double val);
+/** \see GEOSCoordSeq_setM */
+extern int GEOS_DLL GEOSCoordSeq_setM_r(
+    GEOSCoordSequence* s, unsigned int idx,
+    double val);
 /** \see GEOSCoordSeq_setXY */
 extern int GEOS_DLL GEOSCoordSeq_setXY_r(
@@ -543,6 +556,12 @@ extern int GEOS_DLL GEOSCoordSeq_getZ_r(
     const GEOSCoordSequence* s,
     unsigned int idx, double *val);
+/** \see GEOSCoordSeq_getM */
+extern int GEOS_DLL GEOSCoordSeq_getM_r(
+    const GEOSCoordSequence* s,
+    unsigned int idx, double *val);
 /** \see GEOSCoordSeq_getXY */
 extern int GEOS_DLL GEOSCoordSeq_getXY_r(
@@ -2252,6 +2271,16 @@ extern void GEOS_DLL GEOSFree(void *buffer);
 extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_create(unsigned int size, unsigned int dims);
+* Create a coordinate sequence.
+* \param size number of coordinates in the sequence
+* \param hasZ whether the sequence should store Z values
+* \param hasM whether the sequence should store M values
+* \return the sequence or NULL on exception
+* \since 3.14
+extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_createWithDimensions(unsigned int size, int hasZ, int hasM);
 * Create a coordinate sequence by copying from an interleaved buffer of doubles (e.g., XYXY or XYZXYZ)
 * \param buf pointer to buffer
@@ -2347,6 +2376,18 @@ extern int GEOS_DLL GEOSCoordSeq_setY(GEOSCoordSequence* s,
 extern int GEOS_DLL GEOSCoordSeq_setZ(GEOSCoordSequence* s,
     unsigned int idx, double val);
+* Set M ordinate values in a coordinate sequence.
+* \param s the coordinate sequence
+* \param idx the index of the coordinate to alter, zero based
+* \param val the value to set the ordinate to
+* \return 0 on exception
+* \since 3.14
+extern int GEOS_DLL GEOSCoordSeq_setM(GEOSCoordSequence* s,
+    unsigned int idx, double val);
 * Set X and Y ordinate values in a coordinate sequence simultaneously.
@@ -2405,6 +2446,7 @@ extern int GEOS_DLL GEOSCoordSeq_getX(const GEOSCoordSequence* s,
 extern int GEOS_DLL GEOSCoordSeq_getY(const GEOSCoordSequence* s,
 * Read Z ordinate values from a coordinate sequence.
@@ -2415,6 +2457,18 @@ extern int GEOS_DLL GEOSCoordSeq_getY(const GEOSCoordSequence* s,
 extern int GEOS_DLL GEOSCoordSeq_getZ(const GEOSCoordSequence* s,
+* Read M ordinate values from a coordinate sequence.
+* \param val pointer where ordinate value will be placed
+* \since 3.14
+extern int GEOS_DLL GEOSCoordSeq_getM(const GEOSCoordSequence* s,
 * Read X and Y ordinate values from a coordinate sequence.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 981d0cf8e..c6a824cbb 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2689,6 +2689,14 @@ extern "C" {
+    GEOSCoordSeq_createWithDimensions_r(GEOSContextHandle_t extHandle, unsigned int size, int hasZ, int hasM)
+        return execute(extHandle, [&]() {
+            return new CoordinateSequence(size, hasZ, hasM);
     CoordinateSequence*
     GEOSCoordSeq_copyFromBuffer_r(GEOSContextHandle_t extHandle, const double* buf, unsigned int size, int hasZ, int hasM)
@@ -2854,19 +2862,25 @@ extern "C" {
     int
     GEOSCoordSeq_setX_r(GEOSContextHandle_t extHandle, CoordinateSequence* s, unsigned int idx, double val)
-        return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 0, val);
+        return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, CoordinateSequence::X, val);
     int
     GEOSCoordSeq_setY_r(GEOSContextHandle_t extHandle, CoordinateSequence* s, unsigned int idx, double val)
-        return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 1, val);
+        return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, CoordinateSequence::Y, val);
     int
     GEOSCoordSeq_setZ_r(GEOSContextHandle_t extHandle, CoordinateSequence* s, unsigned int idx, double val)
-        return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 2, val);
+        return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, CoordinateSequence::Z, val);
+    int
+    GEOSCoordSeq_setM_r(GEOSContextHandle_t extHandle, CoordinateSequence* s, unsigned int idx, double val)
+        return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, CoordinateSequence::M, val);
     int
@@ -2908,19 +2922,25 @@ extern "C" {
     int
     GEOSCoordSeq_getX_r(GEOSContextHandle_t extHandle, const CoordinateSequence* s, unsigned int idx, double* val)
-        return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 0, val);
+        return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, CoordinateSequence::X, val);
     int
     GEOSCoordSeq_getY_r(GEOSContextHandle_t extHandle, const CoordinateSequence* s, unsigned int idx, double* val)
-        return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 1, val);
+        return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, CoordinateSequence::Y, val);
     int
     GEOSCoordSeq_getZ_r(GEOSContextHandle_t extHandle, const CoordinateSequence* s, unsigned int idx, double* val)
-        return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 2, val);
+        return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, CoordinateSequence::Z, val);
+    int
+    GEOSCoordSeq_getM_r(GEOSContextHandle_t extHandle, const CoordinateSequence* s, unsigned int idx, double* val)
+        return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, CoordinateSequence::M, val);
     int
diff --git a/tests/unit/capi/GEOSCoordSeqTest.cpp b/tests/unit/capi/GEOSCoordSeqTest.cpp
index ffa7912b0..8adf02658 100644
--- a/tests/unit/capi/GEOSCoordSeqTest.cpp
+++ b/tests/unit/capi/GEOSCoordSeqTest.cpp
@@ -834,9 +834,7 @@ void object::test<25>()
     set_test_name("setOrdinate on XYM coordinate");
-    /* TODO: use GEOSCoordSeq_createWithDimensions() instead */
-    double buffer[3];
-    cs_ = GEOSCoordSeq_copyFromBuffer(buffer, 1, 0, 1);
+    cs_ = GEOSCoordSeq_createWithDimensions(1, 0, 1);
     ensure("setX", GEOSCoordSeq_setOrdinate(cs_, 0, 0, 1));
     ensure("setY", GEOSCoordSeq_setOrdinate(cs_, 0, 1, 2));
@@ -851,4 +849,36 @@ void object::test<25>()
     ensure_equals("M", m, 4);
+template<>
+template<>
+void object::test<26>()
+    set_test_name("getM and setM on XYZ sequence");
+    cs_ = GEOSCoordSeq_create(1, 3);
+    // setM fails
+    ensure("setM", !GEOSCoordSeq_setM(cs_, 0, 4));
+    // getM succeeds but sets value to NaN
+    double m = 0;
+    ensure("getM", GEOSCoordSeq_getM(cs_, 0, &m));
+    ensure(std::isnan(m));
+template<>
+template<>
+void object::test<27>()
+    set_test_name("getM and setM on XYZM sequence");
+    cs_ = GEOSCoordSeq_create(1, 4);
+    ensure("setM", GEOSCoordSeq_setM(cs_, 0, 4));
+    double m;
+    ensure(GEOSCoordSeq_getM(cs_, 0, &m));
+    ensure_equals(m, 4);
 } // namespace tut
Summary of changes:
 capi/geos_c.cpp                      | 30 ++++++++++++++++----
 capi/geos_c.h.in                     | 54 ++++++++++++++++++++++++++++++++++++
 capi/geos_ts_c.cpp                   | 32 +++++++++++++++++----
 tests/unit/capi/GEOSCoordSeqTest.cpp | 36 ++++++++++++++++++++++--
 4 files changed, 137 insertions(+), 15 deletions(-)
hooks/post-receive
More information about the geos-commits
