[geos-commits] [SCM] GEOS branch main updated. 4b9a5ad063a7ea31662d6cd054a123b8b32099a6
    git at osgeo.org
    git at osgeo.org
    Tue May  6 09:48:28 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  4b9a5ad063a7ea31662d6cd054a123b8b32099a6 (commit)
      from  6f4a7396481ab28dd240cc7b1511949f1892ac2a (commit)
revisions in full, below.
commit 4b9a5ad063a7ea31662d6cd054a123b8b32099a6
Author: Roman Karavia <3082173+rkaravia at users.noreply.github.com>
Date:   Tue May 6 18:47:59 2025 +0200
    Allow GeoJSONWriter to force polygons to be counterclockwise (#1262)
    Add a `setForceCCW` function to GeoJSONWriter, which enables conversion
    of polygons to follow the RFC 7946 winding order.
    When `isForceCCW` is true, linear rings in Polygons and MultiPolygons
    follow the right-hand rule, meaning exterior rings are counterclockwise,
    and holes are clockwise.
    See https://datatracker.ietf.org/doc/html/rfc7946#section-3.1.6
    This addition to GEOS is inspired by a corresponding change in JTS,
    see https://github.com/locationtech/jts/pull/694
diff --git a/include/geos/io/GeoJSONWriter.h b/include/geos/io/GeoJSONWriter.h
index 002a6f501..d8011b872 100644
--- a/include/geos/io/GeoJSONWriter.h
+++ b/include/geos/io/GeoJSONWriter.h
@@ -95,13 +95,27 @@ public:
     void setOutputDimension(uint8_t newOutputDimension);
+     * Sets whether the GeoJSON should be output following counter-clockwise orientation aka Right Hand Rule defined in
+     * RFC7946. See <a href="https://tools.ietf.org/html/rfc7946#section-3.1.6">RFC 7946 Specification</a>
+     * for more context.
+     * @param newIsForceCCW true if the GeoJSON should be output following the RFC7946
+     *                      counter-clockwise orientation aka Right Hand Rule
+    void setForceCCW(bool newIsForceCCW);
 private:
     uint8_t defaultOutputDimension = 3;
+    bool isForceCCW = false;
     std::vector<double> convertCoordinate(const geom::Coordinate* c);
     std::vector<std::vector<double>> convertCoordinateSequence(const geom::CoordinateSequence* c);
+    std::vector<std::vector<std::vector<double>>> convertLinearRings(const geom::Polygon *poly);
     void encode(const geom::Geometry* g, GeoJSONType type, geos_nlohmann::ordered_json& j);
     void encodeGeometry(const geom::Geometry* g, geos_nlohmann::ordered_json& j);
diff --git a/src/io/GeoJSONWriter.cpp b/src/io/GeoJSONWriter.cpp
index 8c9db9d7b..b6981600c 100644
--- a/src/io/GeoJSONWriter.cpp
+++ b/src/io/GeoJSONWriter.cpp
@@ -52,6 +52,10 @@ GeoJSONWriter::setOutputDimension(uint8_t dims)
     defaultOutputDimension = dims;
+void GeoJSONWriter::setForceCCW(bool newIsForceCCW) {
+    isForceCCW = newIsForceCCW;
 std::string GeoJSONWriter::write(const geom::Geometry* geometry, GeoJSONType type)
     json j;
@@ -223,7 +227,13 @@ void GeoJSONWriter::encodeGeometry(const geom::Geometry* geometry, geos_nlohmann
     else if (type == GEOS_POLYGON) {
         auto poly = static_cast<const geom::Polygon*>(geometry);
-        encodePolygon(poly, j);
+        if (isForceCCW) {
+            auto ccwPoly = poly->clone();
+            ccwPoly->orientRings(false);
+            encodePolygon(ccwPoly.get(), j);
+        } else {
+            encodePolygon(poly, j);
     else if (type == GEOS_MULTIPOINT) {
         auto multiPoint = static_cast<const geom::MultiPoint*>(geometry);
@@ -264,14 +274,7 @@ void GeoJSONWriter::encodeLineString(const geom::LineString* line, geos_nlohmann
 void GeoJSONWriter::encodePolygon(const geom::Polygon* poly, geos_nlohmann::ordered_json& j)
     j["type"] = "Polygon";
-    std::vector<std::vector<std::vector<double>>> rings;
-    auto ring = poly->getExteriorRing();
-    rings.reserve(poly->getNumInteriorRing()+1);
-    rings.push_back(convertCoordinateSequence(ring->getCoordinates().get()));
-    for (size_t i = 0; i < poly->getNumInteriorRing(); i++) {
-        rings.push_back(convertCoordinateSequence(poly->getInteriorRingN(i)->getCoordinates().get()));
-    j["coordinates"] = rings;
+    j["coordinates"] = convertLinearRings(poly);
 void GeoJSONWriter::encodeMultiPoint(const geom::MultiPoint* multiPoint, geos_nlohmann::ordered_json& j)
@@ -298,14 +301,13 @@ void GeoJSONWriter::encodeMultiPolygon(const geom::MultiPolygon* multiPolygon, g
     polygons.reserve(multiPolygon->getNumGeometries());
     for (size_t i = 0; i < multiPolygon->getNumGeometries(); i++) {
         const Polygon* polygon = multiPolygon->getGeometryN(i);
-        auto ring = polygon->getExteriorRing();
-        rings.reserve(polygon->getNumInteriorRing() + 1);
-        for (size_t j = 0; j < polygon->getNumInteriorRing(); j++) {
-            rings.push_back(convertCoordinateSequence(polygon->getInteriorRingN(j)->getCoordinates().get()));
+        if (isForceCCW) {
+            auto ccwPolygon = polygon->clone();
+            ccwPolygon->orientRings(false);
+            polygons.push_back(convertLinearRings(ccwPolygon.get()));
+        } else {
+            polygons.push_back(convertLinearRings(polygon));
-        polygons.push_back(rings);
     json["coordinates"] = polygons;
@@ -342,5 +344,17 @@ std::vector<std::vector<double>> GeoJSONWriter::convertCoordinateSequence(const
     return coordinates;
+std::vector<std::vector<std::vector<double>>> GeoJSONWriter::convertLinearRings(const geom::Polygon* poly)
+    std::vector<std::vector<std::vector<double>>> rings;
+    auto ring = poly->getExteriorRing();
+    rings.reserve(poly->getNumInteriorRing() + 1);
+    rings.push_back(convertCoordinateSequence(ring->getCoordinates().get()));
+    for (size_t i = 0; i < poly->getNumInteriorRing(); i++) {
+        rings.push_back(convertCoordinateSequence(poly->getInteriorRingN(i)->getCoordinates().get()));
+    return rings;
 } // namespace geos.io
 } // namespace geos
diff --git a/tests/unit/io/GeoJSONWriterTest.cpp b/tests/unit/io/GeoJSONWriterTest.cpp
index e075e577f..4256e6bab 100644
--- a/tests/unit/io/GeoJSONWriterTest.cpp
+++ b/tests/unit/io/GeoJSONWriterTest.cpp
@@ -453,4 +453,40 @@ void object::test<30>
     ensure_equals(result, "{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]},\"properties\":{\"array\":[{\"key\":\"value_1\"},{\"key\":\"value_2\"}]}}");
+// Test Polygon right-hand rule
+template<>
+template<>
+void object::test<31>
+    geojsonwriter.setForceCCW(true);
+    GeomPtr geom(wktreader.read("POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0))"));
+    std::string result = geojsonwriter.write(geom.get());
+    ensure_equals(result, "{\"type\":\"Polygon\",\"coordinates\":[[[0.0,0.0],[1.0,0.0],[1.0,1.0],[0.0,1.0],[0.0,0.0]]]}");
+// Test Polygon with hole right-hand rule
+template<>
+template<>
+void object::test<32>
+    GeomPtr geom(wktreader.read("POLYGON ((0 0, 0 20, 20 20, 20 0, 0 0), (1 1, 10 1, 10 10, 1 10, 1 1) )"));
+    ensure_equals(result, "{\"type\":\"Polygon\",\"coordinates\":[[[0.0,0.0],[20.0,0.0],[20.0,20.0],[0.0,20.0],[0.0,0.0]],[[1.0,1.0],[1.0,10.0],[10.0,10.0],[10.0,1.0],[1.0,1.0]]]}");
+// Test MultiPolygon right-hand rule
+template<>
+template<>
+void object::test<33>
+    GeomPtr geom(wktreader.read("MULTIPOLYGON (((0 0, 0 1, 1 1, 1 0, 0 0)), ((2 2, 2 3, 3 3, 3 2, 2 2)))"));
+    ensure_equals(result, "{\"type\":\"MultiPolygon\",\"coordinates\":[[[[0.0,0.0],[1.0,0.0],[1.0,1.0],[0.0,1.0],[0.0,0.0]]],[[[2.0,2.0],[3.0,2.0],[3.0,3.0],[2.0,3.0],[2.0,2.0]]]]}");
Summary of changes:
 include/geos/io/GeoJSONWriter.h     | 14 +++++++++++
 src/io/GeoJSONWriter.cpp            | 46 ++++++++++++++++++++++++-------------
 tests/unit/io/GeoJSONWriterTest.cpp | 36 +++++++++++++++++++++++++++++
 3 files changed, 80 insertions(+), 16 deletions(-)
hooks/post-receive
More information about the geos-commits
